- Fail Safe Mode with 2001 AE cluster swap ?
- Check Engine Won't go Out when reset
- The dreaded ignition slop
- Stalls at low temperature
- Clicking noise coming from dash
- What's the name of this part? Pt.II
- 1997 Maxima, Both high beams don't work, regular lights work. What to do?
- Car won't start - Ignition Switch issue?
- 99 maxima no start
- 95 Maxima, what wires are inputs for door speakers?
- Rear Seat Removal or Get trunk open
- Y pipe questions.
- '99 Maxima dimmer switch no longer works after stereo install
- crack in timing cover
- IACV Idel Air COntrol Valve 0205 issue, the iacv test good but doesn't work
- carbon fiber trunk lid - all 4th gens
- 5 speed conversion
- 4th Gen Fenders On i30... Do they fit?
- Should I put new suspension on my car?
- Can 00 ignition coils be used on a 99?
- removing driver side exterior door handle
- tdmimports anti roll kit
- [DIY] The Home Depot/Garage Seal Lip
- fog lights question
- My belt
- 98 SE Lower Radiator Support Replacement Photos
- power on a stock tranny
- Not sure if my starter is bad or not.
- Exhaust suddenly blown?
- Price check on water pump?
- Speed Sensor?
- Whirling / Whirring noise turning left or right
- loose cam pulley
- How's this setup for my 96 se
- Urgent help with inner tie rod boot
- Sensen Struts
- Drivers LSD axel difference
- routing 5speed tranny lines
- Anyone have experience with performance chips?
- Map bulb
- need some answers for a few questions i have!
- Best baby car seats for 1995 Maxima
- any modifications needed for a 00-01 5MT to work
- Fuel Pressue Reglator o-ring - what size is it so I can get it locally?
- Need help!!!!!! Ideas on taillight setup
- couple tips for timing chain cover
- Should i rebuild my 5 speed Transmission
- replace steering rack
- 96 Runs rough only after being restarted warm
- Verifying: BOSE only has speaker amps, right?
- My new (to me) Max
- front & rear hub assembly
- Engine noise + the dreaded watery pimp
- Dash lights dimmed to off on their own
- Ready to call it quits.. Tried everything... Save my Max...
- AC issue
- Brake Master Cylinder replacement
- When Is It Time To Hang It Up For This 4th Gen?
- Vq30 w/vq35 head
- suspension
- Q: Coilovers
- 4th gens stanced??
- Very High Idle After Timing Job
- where is a good place to get a maxima axle?
- Help changing Cylinder #1 Fuel Injector
- 12v car power adapter
- Timing Chain tension-er questions, please help
- 99 Maxima Rear brake upgrade suggestions
- Any Exhaust Recommendations
- Stuttering Problem
- was gonna buy a couple of coils
- How to remove and replace handbrake boot!
- I need your guys opinion.
- What Else I need with this CD Player?
- would a car lift cause this?
- ECU code - 0303
- Hesitation
- don't block me or hate, I have a gear box question.
- Car shuts off but turns back on.. PART 2
- Car shuts off but turns back on.. HELP
- cam and crank position censor problems starting
- Symptoms of a bad MAP sensor?
- cylinder 2 misfire - check engine light flash/stop
- Weird starting issues.
- 95 Maxima cross for other years and models
- MY new headers and mods
- Power loss at WOT loud rattle
- what's your favorite/best gas to use in your high mileade max?
- Best air intake setup
- pulsating throttle
- new tires
- The end has come...
- 99 Maxima will not stay started
- Car Accelerating on its own
- Fed-Spec Cat Replacement Options
- Do you need evap solenoid while doing de-k swap?
- Maxima Killing me
- Best quality clutch kit upgrade?
- Consult Cable Software
- How Do I Remove Faux Air Vents?
- Transmission Fluid Flush/Replacement on a Manual
- Blown Headgasket, Leaky Waterpump, Misfiring at idle, what need some advice.
- 96 maxima stuck in park
- Radiator Support
- auto to manual ecm swap
- Car randomly cuts off.. what is the issue?
- been gettin evap small leak code
- Need to replace rotted out steel brake lines
- how do I loosen the drive belts so I can get the watery pimp out?
- Max Won't Turn Over
- Very puzzling vibration issue...need some insight!
- manual vs. auto ecu
- 98 Hiccup.....Tranny?
- Maf brands
- P1320 code
- Couple of questions on motor swap
- went to napa!
- stock air duct question
- 4-Speed Maxima transmission on SR20DE?
- Bad MPG on 1997 I30
- How to remove and replace rear strut mount?
- Diff bearings
- Did I destroy my clutch/tranny at a car wash?
- Air intake system
- Ideas on what to do next?
- power steering cooler
- i know this has been asked before, but i did search!!
- Ground Wire help
- Key barely turns the ignition
- Valve Cover Gaskets
- Map/boro and absolute pressure sensor question
- Monroe Quick-Struts on Infiniti I30/Introduction
- 3in exhaust
- Frustrated trying to figure out why my car dont start
- CAI or catback exhaust?
- transmission line to radiator
- '99 Maxima Fluid Leaks w/Photos, please help
- Transmission Problem?
- need help with buzzing noise...
- Major progress in DE-K swap!
- are there any good tuning books?
- Any Canadian VQ35 swapped members want to meet?
- idle is perfect when fuse removed
- Click under dash
- it won't start
- Remove the spark plug seals from VC? Front and rear installed differently? (PICS)
- Replace wheel bearing or entire nuckle and hub assembly?
- My car keeps over heating please help.
- How to open trunk on 4th gen from remote?
- Cigarette Lighter & Power
- may have figured it out
- A18-K66 E90 What year is this ECU?
- loss of power/running crap
- What oil to use?
- regular unleaded to premium
- any one running a q45 t/b
- P1490,P1491,P1492,P446 Bah!!!
- Size of the engine oil dipstick (v6 3.0 24v) 1995
- what's. a. good. price. for a cat back
- Running Lights
- Evap?
- anyone hear of running rsx springs in the front for a nice drop
- Auto to 5speed question
- ignition
- Mass Air Flow Sensor fail again
- Factory amp power cable cut. Cannot locate source!
- sluggish 95 max :(
- gauge swap info
- Shocks or struts or both?
- 1995 Maxima SE + Stillen Adjustable Rear Sway Bar
- Automatic transmission shifting rough
- 1998 ecm fault code p0201
- Aftermarket hood struts don't fit my 96
- Speakers pop/static when using brakes/turn sig/window switch
- Engine bay cleaning?
- Found a place to mount switches
- '95 Revving up in neutral
- 1996 or 1999?
- Unable to relieve fuel pressure
- 1995 Maxima help!
- need help with steering maybe?
- 1999 California Spec ECU question
- Ceifro side marker lights
- interior help new here!!!
- 98 Maxima Questions
- Startin out
- will gutted y-pipe be worth it?
- Rear Main Seal Test ???? would it work?
- Evergreen TK3020 VQ30DE Timing Chain Kit, thoughts?
- Cylinder #1 misfire-still occurring after spark and coil change! Help please!
- Recently replaced pads/rotors, getting rubbing noise when I drive down the street
- Changed to a different oil filter, now mpg going down
- sporadic problem with driver window.
- 97' Max 02 sensor/performance issue
- cali spec and 00vi swap
- rear lights
- Please advise on this estimate for radiator support
- Clutch Job Question
- car won't start
- '97 Maxima - Oil Leak, Smoking Engine, Misfire
- Clutch fluid leak and fork squeak
- Just installed new y-pipe
- e manage ultimate harness question...
- '95 water in oil
- heater not working, any thoughts?
- Coolant leak in my 97 maxima
- Remove rear strut nut
- AT keeps engine at low RPMs?
- Thank God for EBay!!
- 1997 Maxima rough gear change (automatic) + what software to use?
- Trouble removing rear timing cover because of this bolt
- Thank yall so much!! ( New guy)
- Thermostat changed, small amount of fluid on starter. Now it won't fire up. HELP!!!
- New springs popping
- What will you do with code 0201 and 0605?(no "P" in front!! )
- vibration!!!
- timing ring for swap
- 1998 4th Gen Intermittently Engine Not Turning Over
- Can a tensioner piston fall into the timing cover from OUTSIDE?
- A/C Recirculate Function 4th gen
- Side exit exhaust!
- Hard starting problem ...
- WBo2 Question
- need help with knowing what this thing is? pics inside
- over heating, tons of rust... what to do...
- PIC attached. What is this hose called?
- VQ35 Swap ECU Question
- ABS Axle questions 99max
- Replacing WP - Timing off?
- trying to identify brake pads
- Please say hello to the NEWEST-newest member of the Maxima.Org family...
- Video of my car running badly. Need help diagnosing plz..
- Disconnect battery for 5 weeks non-use?
- Found good deal on kyb New lowering kit on c/l
- charging system problem?
- Help AC issue
- Very weird steering problem help please!!!!!!!!!!
- Will P01447 Evap code make my car run like sh!t?
- No More Raxles Axles?
- Water leaking into my 97 maxima
- Advance auto ignition switchs - any difference?
- nonstop squeek/brake & battery light on
- Where to find parts for 4th gen
- 95 Maxima dragging when foot off gas
- bcm i think i fried
- The Maxima that accelerates like a Dodge Caravan...
- Horrible Loud Ping Of Death
- 5-speed when to downshift. How to tell my son
- which oil filter?
