- max in fast and fearless 4
- Another b-pipe question...lil more specific please help
- Custom Catback
- Questions about budget ypipe ordering
- Which model K&N or Apexi filter should i buy to fit the bomz cai
- Lower Grill for a 95
- Question about manual transmission change
- tranny cooler question
- question about y pipe install
- 95-97 grille conversion
- Can U slide your car around turns.
- A little Quirk
- Knock on engine start, oil pressure light
- Ebay Air Intake?
- nissan humpin da honduh
- Plastic Piece in Front of Gauges
- O2 Sesor
- CA or not CA???
- 0-60 for 5speed with bolt ons
- Is it Worth Getting A MEVI Being That I Have A 99 Cali-Spec??
- Ok guys. My max is all bolted out now.
- Engine Bay Cleaning
- Fuel Mileage
- to those who made the A.E. style headlights...some questions
- thinkin about sellin the max
- Installing new rotors...need help
- Airbag warning light
- Front License plate what should i do
- disassembly on Altezza's
- thinking about sellin the max
- you lowered your car, right? so, can you help a brother out?
- Stupid squeeling sound at startup!! Please help
- Increasing low end torque
- Fog Light Stalk question (not the same old questions)
- I've built another mesh grill for the bumper
- Link needed for FAQ
- Bridgestone S03, Michelin Pilot, Nitto 555
- flowmaster muffler
- O2 sensor still not working?
- slight vibration
- Replaced alternator
- Old Maxima Blues
- 14.69 1/4 with just an intake
- Anyone know of good lowend mods?
- Boiled fluid
- y-pipe w/o mods
- What happened to my brakes?
- Ever got caked?
- Are the bulbs the problem
- problems after painting calipers..
- Dynoing after getting new exhaust
- promlem with "e"-brake light
- Maxima and Altima 5-Speed Trannies the Same?
- Apexi S-AFC installed - what do you think?
- Temp Sensor code, go away!
- Some idiots WROTE ON MY HOOD!!!
- Shuddering.
- NEED HELP....REAR O2 SENSOR NOT COMING OUT FOR NOTHING...need opinions how to get off
- Almost had an accident
- Quick Question - y-pipe and ECU
- Car is falling apart.....
- steering wheel problem?
- For Those Interested, 300ZX Brake Install.....
- WTF my car burped?
- Fstb
- Americarparts Intake on ebay?
- rerouted airbox
- car wont stay on
- just checked my engine light, need some answers
- Repeated MIL Problems
- Clutch problems on my 96 Max
- engine is making loud gurgle
- stock vs. modded
- help!! something's wrong with my engine
- Should I Buy This Maxima?
- I checked why my engine light was on, now need some answers =)
- order parts from nissan?
- Removing the grille off of a '96 max
- engine is almost stalling out
- 18s or 19s? Which would you pick?
- Tranny help needed
- Airbag sensing unit: Impending Doom?
- Intake Research
- differnet models?
- Millie Miglia EVO 5 came off front rotor
- Y-pipe ?
- Keepin the car luxurious, opinions neded!
- Just installed the Hanabi 8000k
- Possible to put 95/96 frontend on a 97???
- Air Bag Light flashing
- HELP~! EVAP System error
- need help: lights/fuses blowin out after installed altezza
- need help: additional ECU question
- What clutch to get ACT, OEM, other?
- Tune up time.
- Brakes!! Need advice
- palm pilot hook up ro ECU
- cv boot
- Sub box mounting?
- Looking for: Engine Wire dress up kit
- Who makes a CAI.
- Timing problem(?)
- side marker light - is it required by law ?
- Torque Converter Lock up Question, please help
- Custom Wheel Center Caps
- B-Pipe numbers added to a 99 SE-L with Y pipe and Intake
- NEED HELP!! 4th Gen Gauge LED Lights
- hmmm, my friend pulled a 0401 code from his ecu.. can you help me out on this one?
- E-bay again. Any Chance these springs don't suck?
- 4th gen clear wing led
- help painting interior
- Maxima Driver's position
- Front Bumper
- Need help to identify ignition coil.
- Small dents in door
- help.. about radios..
- Friggin Drivers Seat is squeaking
- weird, very weird
- Red Out Tails (96 Max)
- Front door panel removal>
- Quick Battery Question
- Brake Squeal
- Sorry.. Kinda New
- Aftermarket stuff
- cattman headers??
- Modded Auto 4th Gen vs Stock/Modded Auto 2k-2k1??
- ground wires
- How long does it take to replace a water pump
- plugs
- wheel noise from rear tire.
- twighlight zone KS harness
- Making the shifter tighter, shift bushings?
- gear oil
- A/T vs M/T difference in Coil Springs used on 95/96 Maxima SE's?
- 2k2 Style Headlights (not projectors) for 4th gens.
- What should I do about my brakes?
- how-to remove dash?
- 97-99 grillle on 95
- frankencar or injen
- O/D Light / Transmission problem
- How much have you paid to get the brake pads replaced?
- Stock Tire Size
- Whos works at a Dealer here???
- Removed Trans Whats this leak??
- Door mirror defogger for 1995 maxima
- Where can I get...
- Bosch Knock Sensor
- Odd noise happing around 80mph
- How much would you pay?
- poping noise
- Vq30dett?
- Need help with fuel injector CODE
- Had a good amount of work done for an Excellent price....
- NEED HELP!! Engine Service Light
- BMW Mirrors
- Subtle rear swaybar
- oil changing...
- Directional Tire Mixup
- all opinions on Frankencar
- wheel hop
- Knock Sensor for $180 at dealer?
- new mod came in mail today!
- replaced cv joint, still have vibration...suggestions welcome. (kinda long)
- Engine & Tranny rebuild or replacement
- What size tires do you run on your 18's
- Just wondering about our Bose Speakers
- Best Strut To get With Eibach Pro Kit?
- coolant leak 97 SE
- alot of rear end vibrations
- Rack & pinion, and tirod problem
- Air conditioner/heater noise..help!
- REAL POLL: how many miles on your maxima?
- Photoshop wizards apply here...
- HELP Installing CAI in a '95
- Which HID Kit is the best
- 60k maintenance service link page ??
- Diff. bearing leaking, need advice
- problem with remote programming
- toyo oroxy fz-4---- any good
- octane boost?
- Where is the best place to get eibach springs?
- Maxima just DIED!?!
- Walbro Fuel Pumps. Why multiple Part Numbers?
- Q45 maf senser on a maxima ? read me!!!
- Please Help!!! Tb Cleaning Gone Wrong
- Reccomendations For Fog Light Bulbs
- Rear bumper color
- Gutted cat, wow!
- fog lights on a '99 GLE...
- Cloth seat covers
- JWT or GForce ECU w/ MEVI
- Better Pics
- Question about cheapo short throw
- 99 SE Maxima alarms
- Draining power...
- Tax Returns = Spring Upgrades!!
- painting stock 95 grille???
- Pics of EGT probe location, anyone?
- I have a few headlight pics to share
- Help: Paint chips
- ABS-cancel switch--is this possible
- FrankenCar install and scary test drive (long)
- Tranny problem?
- My Max won't start... why?
- EGR valve help
- Pics Of trans Removal YAY!!! But........ :(
- 160k on OEM clutch. Beat that?
- 97 SE 5 speed w/ CONE intake ONLY
- Checking oil
- need someone to run a carfax
- what clutch to get and how to install
- Battery died, need replacement...Suggestions :)
- fuel light
- Buying used Maxima
- door question
- updated the website...
- Treated the leather
- Springs
- Sorry about the 3 posts - here's the story
- anyone know the size of the screws that attach the y-pipe to the headers?
- how difficult is it to change a starter?
- Bad synchros or something else?
- People with maxspeed springs did u have to get a camber kit??
- SWA needs your help (95-96 Maxima owners)-re: Trenz
- need help diagnosing ABS problem light.
- where is the IACV?
- Ignition Coil Question...
- Service Engine Lght 07 02?
- Modifying already modified Valve Body?
- OBD ll
- RPM jumps... clutch slipping? i hate my tranny system
- Power Window Noise
- where to grease / lube
- R34 Skyline Headlights...
- Installed Frankencar yesterday and I'm VERY happy
- Air Filters for a CAI
- Tokico ADJUSTABLE Illumina Shocks
- Konig Wheels...Any good?
- Infiniti i30 Accessories finally!!!!
- Interesting, the 99's have Variable Valve Timing
- ran regular oil for 3k miles... can i go back to synthetic?
- Is there a way to rewire your side marker bumper lights?
- Brake groan?
- Rattle when starting - help!
- Does CAR Have To Be Level for an Oil CHange??
- Need Opinions on MAXSPEED SPRINGS
- New mod for automatics??
- Painting or dyeing interior cloth.. anyone know anything?
- Caliper Paint....or Powdercoat?
