- Carbon Fiber Hood
- Popping sound (backfire) with Injen Intake?
- lack Chrome Altezzas come with chrome ring around them?! :(
- Valve maintenance?
- Carbon Fiber hood...thoughts, ideas
- bad struts
- Please HELP - Know any good body shops in Central NJ?
- car pics
- Wierd Noise
- O2 sensor gone bad....easy to change yourself?
- 1995 Max - LSD??
- Looking to buy my first
- blinker mod link?
- Just ordered my tranny!
- sunroof doesnt sit flush in the rear
- best intake for 99 auto
- Easiest oil change ever....
- Plug this?
- anyone with Wheelskins??
- Yokohama or Michelin??
- PR CAI (Questions)
- Cattman, or Budget Y-pipe? (not those "which is better")
- Magnetic car Bra
- ATT. people with superchargers
- Exhaust Audio
- I need to get a picture of this Maxima I see around town...
- Lowering my car soon, what else should I change while I'm in there?
- Headlight Prob?
- HELP**** My car is Jerking Like anything.......
- fire estinguesher
- Remove pinstriping?
- For those with Budget Y-Pipe's
- Squeaks from KYB's?
- Plz Help
- Ignition Coils
- Some worries with the max...
- clear bumper lenses - what should i get and where?
- Someone please provide me some audio clips from INJEN CAI??
- Passport 8500 Saved you or screwed you?
- Man i got some problems
- Wisconsin members?
- Motor up and running AGAIN
- i wanted to say hi
- DRAG MEET!!!! Reynolds, GA/Silver Dollar Raceway
- Information on a Supercharger.
- screwed up ecu and 0201? 0102?
- after knock sensor problem, idle dropped!!
- when does NISMO arrive??
- maxima photo galleries?
- maxima meet
- I'm selling my auto for a 5speed
- I Got Ripped!!!
- Stillen Kit: 3M Tape and Rivets and Screws
- 4th gen vs 5th gen ?
- Arkansas
- ECU fault code diagnosis on a 99 maxima different?
- 97-99 clear tail lights
- Signs of bad master cylinder
- squeal from left front wheel???
- potholes
- Hood flies open at track (I'm retarded!)
- I'm gettin CEL 0505 "No Failure Recorded/Detected"??
- power steering fluid leaking??
- Help! ECU codes!
- Need help to change Fuel Filter
- What if you......
- Resetting the ECU. Not the CEL.
- YOu need a new Tranny??
- Shaved MAXIMA off trunk, but screwed up
- ECU code 0901
- Replacing Antenna Mast - Help
- ECU daignose: 0707 + 0304... need help!
- can someone show me how to replace rear speaker
- 99 SE-L FSTB-How did you remove that bracket that was in the way???
- a lil help before i attempt to install 9004 harnesses...
- Projector lights for $150
- front left motor mount
- You guys know much about MaxSpeed springs?
- Nissan 95-99 Maxima Strut Bar Bomz
- Anyone have pics of Aluminum Trim w/ Black interior?
- Putting my deposit down for the car...
- Is it bad to use eibach springs with stock struts/shocks?
- what shocks with stock springs?
- Search disabled? Clutch/Flywheel Suspension/Motor mounts question
- ECU Code 84 Automatic Transmission
- airbag light
- How to fix A/C leaking inside my max
- Lubrication of Chasis
- Wondering on price of......
- TCS System problems, I think...
- Tranny fluid change or flush?
- stock headlight bulbs upgrade
- painting interior
- very low miles in a 95 rec maint?..
- Frontal crash, frame moved 5 inches up (long, beware)
- my first mod....
- 2n1 question. Brakes adn Tranny
- 95-96 Clear Tail Lamps
- Anybody heard of/using these?
- how u take the passenger side airbag cover off?
- Radio/Car will not start.
- dashboard help...
- gettin ready to get mad
- Keyless entry
- Right side fender
- Got My RSB installed have a question
- Squeaking dirve belts
- Front end noise
- Audio help!
- projection lense...
- High Ouput Alt. Mod???
- When do u feel the power of y-pipe?
- Place Racing K&N where to buy?
- Interesting auction
- Muffler stick out after install of rtcat/bpipe..any1 experince this
- Spark Plugs
- What is a LSD tranny?
- For those who installed ADDCO RSB!
- Good Deals on Maximas
- Throttle Body--PLEASE HELP
- Before I start...
- Fuel filter problem?
- axle changeout
- Help! My breaks are not responding good.
- 5 speed guys who changed their MTF.. check in...
- Car starts, then dies...
- stero install HELP
- over/drive off
- Maxima not starting.
- Gas Prices!!!
- silver disk behind the rims - rust ring?
- 20 inch wheels
- will these rims fit?
- Night Of Steve-O and a damn bucket (sorta long)
- buying a 97/98 max.. tranny questions
- Taillight Goo
- Tranny is dying
- Touch-up Paint Pen
- Where do you put jack stands?
- Emma is dead!!!!!
- trouble starting the car this morning
- Need help with code 02 15
- heater hose location?
- cattman b-pipe bung
- 99 se limited
- has anyone shopped online here??
- Just got my Budget Y-pipe in mail
- Advice!!
- suspension insight
- 99 max KYB's and sprints PIC
- Need help fixing CEL after VI install
- Ecu Code 0413
- Sam's Club gas
- HELP: melted spark plugs stretched coil !!
- 300zx brake upgrade
- Question about misfire code
- anyone want to help me out with a smoke problem?
- TCS + Slip Stay ON! Help!
- VLSD Swap+ACT clutch=Dayyyum!
- i need help/CEL no failure recorded
- CEL: EVAP Control System?? What is this??
- just got back from the dealer (starting problem)
- replacing whole system
- Auto Polish
- Did anybody replace their belts at 50k or so?
- anyone know this sound?
- how much is this
- how do i use my multimeter? ~so confused
- Knock Sensor Test Link?
- Knock Seneor Test Link?
- Maxima Insurance High?
- belt noise
- Broken Headlight bulb
- My wife backed her Maxima into my Maxima!
- Hook ups for stock maxima parts? where and who??
- Search Disabled? Wheels Flaking
- 1996 Bose Stereo
- creaking/clicking type noise when turning
- b&m tranny cooler
- MANUALS for Maximas
- Fog lights
- "Search" function disabled! Knock sensor warranty?
- Shims for 5speed
- I put my CEL thru the CEL decoder and don't understand what it means...
- angel eye conversion
- violent shake at 80mph+ ?
- Wing
- Wheel alignment Problem- what should i do?
- Not an oil analyst...need some clarification.
- CEL Light started blinking on my way to work
- Battery?SEE 3/4 AIR BAG post
- More pics of Silverstars
- anyone with Enkei RPM2's Please post your pic
- Finally Car Doesn't start
- Transmission problem, blinking S-light
- SES light..Ignition Signal Circuit.. uh oh
- cig lighter fuse?
- 225/50 or 215/55 for my 16"
- Rstb
- install FSTB
- Budget b-pipe?
- trans dragging gear
- exhaust
- Bad Suspension?
- Uninsured motorist hit my vehicle, what should I do?
- Adjusting Idle RPMs
- VG30 pathvinder too VQ30DE
- $125 for the rear heated O2 sensor?
- Those who installed OBX catback...
- think this mechanic is ripping me off....
- Straight Pipe or Randall Hi-flow Catalytic...?
- Possible Engine Swaps for a 4th gen????
- spring install
- big brakes
- Custom Air Piston Setup for sale
- 5th Gen Muffler on 4th Gen Model Theory
- Double Exhaust
- Engine vibration help.
- What u guys think about this this rim??
- Engine Codes
- Which O2 sensor usually goes out first?
- Disable airbags before instaliing reverse gauges?
- I need PICS of 18X7.5 rims on your max!
- RAM AIR OFF, will it give more power?
- your opinion on my suspension
- Ceramic or Metal Master pads w/ Brembo CD rotors?
- Paint Chipping
- having a hell of a time getting my corner lamps out.help!
- Throttle Cable Gone Bad? Help!!
- wat type of gas
- Quick Question: What gaskets to use with VI install
- Oil consomation?
- Brake noise from high speed...HELP!
- Those with RVM Pulley
- 0512 and 0510 codes
- Knock Sensor Mod?
- Starter sticking sound? Read this.
- Tire Time... Toyo Proxes TPT?
- HKS intake
- impressed a friend with the maxima
- Sure looked like a Maxima
- Place Racing CAI
- Rims, looking for pics, suggestions, opinions
- Raxles Needs Your Cores!!!
- Need some opinions AGAIN! :D
- I searched, but couldn't find enough pics of 4th gens with 300zx wheels
- interior buttons
- How can I get yellow bumper lights to stay on with headlights
- Ok,...This is Weird
- which model
