- Okay guys- I REALLY need an answer to this seemingly worthless question.
- Hankook's Ventus HRII H405 Tire. Good or bad?
- Help, ECU ERROR CODE is 10, 5
- Question about Eibach Springs and KYB AGX Struts ?
- Best Fitting 18" rim on 4th Gen ??
- New Poll: Max Performance Tire Choices
- preload transmission
- battery problem
- weird idle speed problems ???
- What is the optimal activation point for the VI?
- Anyone interested in Red Clear inserts for 97-99 max's
- Alternative to Injen intake
- Ecu Upgrade
- Tranny fluid for 5spd......I want Redline MT-90 right??
- several tries before the starter turns, after having the problem addressed twice -->
- Help!!
- 2 questions
- Why brake pads come RH & LH pads? Are they not interchangeable?
- Recomended upgrades
- KS question
- Tapping sound...
- would ya'll say that this is a decent mid pipe??
- brake question?
- Y-pipe installed, reset ECU?
- opinions on OBX Type-R pedals?
- indigo gauges
- Marble dash kit from custommaxima?
- newb question...
- Finished conversion, now how about some reverse lights?
- You just can't have nice things anymore...
- spring/strut pricing
- HELP! trouble installing VI
- TSB for sunroof
- Getting the Best Gas Mileage...
- Mechanial Oil Pressure Gauge
- Worth it or not?
- Anyone Pass the NY Inspection with a y-pipe, RT CAT and b-pipe?
- question for all you with altezza's
- starter removal
- Tokico Blues and Sprints
- Valves
- I was called a Ricer the other day....
- peeps with warpspeedperforance b pipe&test pipe
- car vibrating plz HELP
- 6 Speed shift knob on 95?
- crank shaft position sensor?
- exhuast "finisher"
- spark plugs ?
- Max Performance tire choices
- Frankencar intake...
- cleaning stillen intake...
- diesel like noise from the engine bay...
- My Max Jumps Between Gears
- Where is PCV valve
- Will '96 foglamps fit a '95?
- Reverse creaking
- Energy suspension question
- HELP! Wheel question
- Sprint Springs on Sawblades
- VERY weird right pull pleeeze help..
- Need Opinions..
- Newbie question on coil packs
- question bout rims...
- exhaust upgrade
- problem with stillen lip kit
- Need a little help
- grinding grr
- When you sold tires did you ship in boxes?
- How much do stock 96 SE sawblades weigh with tires?
- Does my car have ABS?
- $500 + Parts: Clutch job on '96 SE 5-Speed? Too much? Clutch failure symptoms?
- emission on budget y-pipe
- Strange Noise...
- Suspension Installation Question
- Got into an accident= me very happy!
- KYB strut installing price?
- Rear Caliper ?
- strut bars?
- WTB: 18" TSW Revos
- Which clear bumpers are better?
- Ignition Coils Replacement Question
- Does anyone have the stock suspension parts (Strut bearing, Bumpstop, Mounting plate)
- Does 4th generation Maxima has an immobilizer for Alarm autostart purpose....
- who has the hottest.......
- conversion question
- Want to clean the Combustion Chamber but need info
- Lights: Important Need Help
- Hiya
- Shot alternator now? Is it my alternator?
- Budget Test Pipe fixed!!!
- ECU code....im lost
- Headlight wires? Help please!
- Maximum Problem, Oh My God Help Help Help Fast!
- which intake??
- Auto Tranny Flush Questions
- Mudflap install...duh question I know...
- prelude rims on 95 max
- Painted Altezzas
- Strange smell after rain
- Remove overspray from body?
- 60k mile tune up 98Max
- Knock Sensor HELP :(
- leds in SHIFTER light
- 17 inch 2001 SE wheel weight??
- Tripping KS question
- Ebay Headlight bulbs? results?
- Strut Boots arrived. Are these the right thing? *PICS*
- test
- Odd starts sometimes
- E-Brake Boot Install
- How do I get the antenna out?
- Tranny is stuck!!!
- How to remove molding around exterior door handles?
- Removing door trim
- Painted my grille silver
- Full Intake/Exhaust System Questions
- Installing lowering springs
- how long can I go on bad tranny main bearings
- Anybody know how to program a Nissan Remote?
- transmission flush?
- Looking for body kits
- Pondering production of a full header for 4th gens...
- Wierd Smell
- SUCCESS!!!! (kinda long, but somewhat interesting :)
- Fuel injector Cleaning
- People who have Sylvania Silverstars...
- Anyone know where's Shadow?
- IACV changed but got Qs.
- questions about 20's
- Is this right? Suspension parts cost...
- Pics added of my VI prep.
- Quick OIl question..please help
- question about clearing tails
- any one with 95 tan maxima
- pull problem
- Would the 97 Grill fit on 96
- Just as I suspected...>
- UDP Installed. Got codes
- how to instal an engine coolant temp sensor
- euro license plates
- E-BRAKE Boot
- How to make shifts in auto smoother....?
- Possible cause for CEL?
- Brand New 95 Se!@()#!@)#(
- For those of you who don't allready know this
- Free 100pt inspection at stealership?
- Tan (leather and carpet)- what pedals will look best? POLL
- Sturt Bar Help
- FSTB - Causes buzzing noise on highway?!?
- Two 4th gens Just Painted
- EyeLids?
- rear oxygen sensor removal
- Why the 4th gen Max is the only sports car for me...
- Frankencar vs. Injen CAI vs. Stillen
- PCV and fuel filter
- How do you know when your battery is about to die?
- Injen CAI Question and Problem
- Who Wants A Free Y-pipe<<<<<<<<
- Maxima stalling randomly and hesitaing
- what should i ask to have done
- Will 240SX wheels fit my Maxima?
- ECU fault code 0215 Undefined
- 95-96 red/clears
- trouble in the mornings
- APC wiring harness problems.......HELP!!
- o2 sensor help debate....
- Very faint 'knocking' noise while driving..
- Question about painting door
- KS sensor 2 harness or 1???
- How the hell do you remove the front bumper lights
- timing chain cover problems
- ECU Code 0705 & 0903 Help
- 98 Recall question
- Why get OPTIMA and which?
- Budget Test Pipe review and comments
- RSB recommendations
- Lost my My Manual--0902
- brake pad replacement
- Will They Fit?
- Injen Intake pics for '97
- I'm on the way to doing a 5spd swap.. clutch and shifter info?
- cleanin headlights
- photoshop help pls
- updates
- Is it necessary to oil a new cone intake?
- aluminum gauge bezel not fitting :(
- muffler questions
- How to get Smooth Shifts in 5spd
- Stock 15" tire size ??
- gen 3 altezza's
- Do I need an INTAKE????????????????????????
- dash kits
- Project Gin&Juice...Advice...(Long)
- MAF cleaning
- rough starts...
- Is an alignment required after a 4th gen strut change? (it isn't for a 3rd gen) n/m
- OEM Brake Pads and Rotors. 33K need replacement?
- Help - ABS Sensor stuck
- Update on Emma's Heart Transplant
- Blitz FATT installation instructions
- sound while turning
- JDM A'pexi S-AFC questions...
- variable intake??????????
- Tranny Cooler Hoses for B&M Tranny Cooler
- To catback or not to catback?
- chrome gauge rings
- Spring Isolator Question......
- start / ignition switch grounding issue?
- GC Coilovers
- BOMZ cai intall/reviews
- What would you chose: Dunlop A2's, Dunlop 9000's, or Bridgestone S-03's???
- Differences Between 95/96 and 97+ Wheel Info.
- Spark Plug Seal on '95 Max
- Offset ?? Quick Question ??
- New INJEN CAI on ebay
- max in magazines?
- Replacing tranny main bearings. A DIY project?
- Trenz Grill?
- Added some new pics
- Civic SI
- Car is acting weird again, EGR valve to blame?
- Anyone have pics of a self painted dash?
- Whistling engine mount???
- Why th KS code just appears pulling out the code
- ECU reset question
- Cut my stillen lip for a custom look
- H&R + KYB AGX = love my car all over again !
- Excedy clutchs compared to OEM
- Make MY friend a NEW MAX OWNER, CONVINCE HIM TO BUY ONE!
- just got an oil change! car drives smoother
- anyone selling HID Kits?
- refinishing?
- What muffler should i combine with a Budget B-pipe
- Mods avail for Higher MPG
- Guys need your help!! Where to find cheap parts...
- First problem in 4 years!
- Possible Computer Problem!! Please Help!
- How much do stock 95 se alloys weigh?
- Thanks
- squealing during startup
- Recurring Start Problem!! Has This Happened To Anyone Else?
- Strut Boot Question
- 4th gens are fairly cheap to mod
- Fuel Cut-Off Problem
- Need OEM wheel comparison pics
- Shifter Boot and E-brake Boot
- Check engine light??? little help please
- O2 sensor Prices
- katana wheels?
