- dumping exhaust
- Car doesn't start on first try
- Rear-ended, what should I do?
- Help need fast reply 96 vlsd tranny will fit in to 99 nonlockin?
- turn signal removal
- Woooo! Pics! 56k beware!
- Is anyone making and selling Projector Headlights?
- tint %
- Questions regarding brake pads selection
- Starter negative cable connector is a MF
- valve body job
- Rear Window Defroster Slow/Weak
- F/S: Parting out Engine
- How to remove steering wheel and pass. air bag
- 99 Limited starter spins, engine doesn't
- $600 for my exhaust - reasonable?
- 300zx rear caliper conversion
- Battery and spark plug recommendation...
- All these lights.....I'm confused
- symptoms of a stretched timing chain?
- Rear Speaker Removal (specific Question)
- Windshield questions
- Radiator Leaking
- Alignment specs?????
- knock sensor harness help
- o2 again at 55mph
- Idler pulley problems
- 2004 maxima seats
- would something like this fir our cars
- Need help finding ignition coil thread
- Automatic Transmission problem, takes long to shift ??
- proper way to break in new clutch
- 5th gen interior into a 4th gen?
- Code 302 Again
- Pic of my car after meting with a deer :(
- Quick Cali-Spec Question
- clutch fell to the floor this morning.
- Trust voltage from SAFC-II or Beltronics Radar Detector?
- Megan Exhaust
- Warpspeed or Budget?
- pics of the motor tranny removal
- HID went out.
- Car's voltage.
- Where is 96 maxima block heater plug?
- intenna
- CE 95-96 tail light owners come in!
- need help, hyper blinking problems
- Painting Head Lamps
- how does this give you more horsepower?
- best/cheapest place to get 02 sensors...
- keyless entry
- Quick help please!
- Hit and Run
- Do you think this is Legit?
- Could these three problems be related?
- DAMMIT! Found a fluid leak in line right next to Oil pan...
- Drop Resistor final word
- 12 Volt Soure?
- Got my high stall TC
- Help - Thinking about buying a project Maxima: Doesn't start, elec. problems, cheap
- Speedometer illumination mod support:
- 3 gear on auto
- Low speed auto shifting.
- headlights?
- Havent heard much about this...
- 6th gen tranny in 4th gen
- 5th Gen Clutch...WOW
- i keep blowing fuses, HELP
- need a link
- Aftermath of Axle change.....
- Yippee!! Just picked up my 97 SE today...
- Transmission Filter nut removal issues .. heed help
- Brake light problem. HELP!
- Is This A Problem? *Pics*
- Keyless entry unit off ebay
- HID retrofit
- My tranny ?
- Might buy a 1995 Maxima:
- Toms Trannys?
- About ready to give up
- Upgrade Brake opinions
- Ya Gotta Give Some To Get Some
- changing the head lamps
- Annoying creaking sound from the rear...
- DIY tint difficulty
- 96 GLE Headlights
- does anyone have fender flares on their car to make a wide body?
- Power Steering
- What I learned...
- Where i can find nissan part#
- Resonator effect
- Foglight bulb question...
- 97 BOSE HU Question
- grinding sound upon coming to a stop, dont think its my brakes.
- Heated seats
- 5spd swap info
- Steering wheel sits slightly tilted to the right when car is driving straight
- Strut bars
- What were the opinions on the WSP Super-Flo Y-Pipe?
- possible starter problem?
- springs vs coilovers
- BRIGHT *** REVERSE LIGHTS (any1 know bulb #)
- Crappy auto
- Beating Up on MAX
- Fuel Injection Cleaner Through......
- Engine hesitation on pickup
- Dash bulbs have green caps?
- Do you have a 1/4 mile timeslip or time for your 4th Gen?
- Max with its new tint
- Got an alignment but rear wheels tilt inward
- 97-99 Bose AUX installation Help
- Headlight Removal Issues
- Repetative CEL
- Where can I find a write up on changing the rear valve cover gasket?
- grease in wire harness clip?
- Help! Loud scraping sound!
- Fuel Pump fuse Voltage
- This a good buy
- Broken Buttons on Bose dash (98 gle)
- urgent: o2, bank 1 sensor 2, which o2 from oxygensensors.com? link.
- Need some info quick: Starter issues
- As i'm making the door pillars the same color as my car....
- Heated seat busted. fuse ok. what now?
- hesitation/slipping? 5sp, clutch?
- Dash Painting.. Ideas?
- Cheapest Place to get illuminas?
- quick help needed: Separating control arm . . .
- Quick question for Budget Y-pipe owners...
- CV Joint replacement Question
- Installing STS and Can't get the stupid shift knob off
- Got a body kit...Step in please
- quick question about brake lines
- EBAY coil over springs for 4th gens... YAY or NAY?
- Staggered wheels?
- Short Throw Shifters?
- white max's w/ tints- post pics
- 18 X 7.5 rims whats the widest tire i can put on there
- 1998 Nissan Maxima...Toronto/GTA area
- C.F. Hood and Trunk question
- need some help...
- Funny noise at startup
- Wire Fog Lights on 96 GLE
- what to buy first..??
- Hub/Spindle Damage . . . Advice.
- ANyone have expeirence with this???
- Check Engine Light code p1447. Help!!
- Are these Ebay TIE rods any good????
- ? about continental contitouring tires
- Purchasing 34K engine from salvage yard.??
- Flashing AirBag light
- Storing the car for 6 months, comments / advice pls
- I Need Knock Sensor Info
- Quick help, PB blaster response time?
- Smog Help
- Pictrues of my '98.. Finally washed it...(56k..go to lunch)
- Quick question...
- Does replacing clutch or replacing flywheel impact tranny fluid level?
- Pissed...Verry Pissed...Any Help?
- Having hard time shifting my 5spd sometimes.....
- Is this a good buy?
- P0140 after catback instalation
- Offset questions Please Help
- 0902 code HELP plz
- Best dash kit for tan interior
- spring installation
- 97 Maxima Service manual? Also need help with problems..
- where to find MINT 4th gen w/low miles?
- Ultrasonic Injector Cleaning
- is this ground?
- Trouble starting in Cold Weather
- need new mid-pipe...advice?
- what size tire for my sawblades?
- Starter change on 99 (with ABS valve box)
- When u race
- Someone school me...
- simple question...
- Signal Lights and Hazards Cutting Out!
- Who Has Ground Control Springs? Please Post Pics Here...
- need help deciding on possible springs
- Knock Sensor code 20k after replacement
- High Pitched Whistle?? help!
- 5speed tranny swap
- door pillar question
- Now lets see the UPgraded brakes!
- post pics of 4th gens with s-techs
- knock sensor results
- Hood Struts....??
- PBR/Axxis Ultimate brake pads...
- clutch engagement point?
- Adding a 2 stage shock sensor, question.
- What the b-pipe height on stock suspension?
- Battery Question
- Quick question about fuel injectors..
- Best Place To Buy Flywheel & Clutch! ***Please Reply Soon***
- Any good paint shops near NYC????
- Quick question: How much should I pay for a service manual??
- Car died, @ Stealership! Pls help techs!
- Best Clutch?
- Any Pics of Brushed Aluminum on Black??
- How do you tune ignition timing?
- Melted Dash Kit
- Trunk torsion bars separator
- TYC Tail Lights
- Axle Change + Trans flush
- leaking coolant
- Hayden 403 or 70255 B&M SuperCooler, auto tranny cooler?
- Axles - LSD vs. non-LSD
- Starters for 4th Gens
- 95 max+18 inch murano rims need help!!!!
- how long until bearing fails?
- 4th Gen 97-99 - Anyone with a cargo net?
- Power Steering Leaks
- live in florida sucks!!!!
- R33 body kit owner plz step in
- knock sensor
- All red tail lights?!?
- Square Trade Warrany. Should I get one??
- way to test knock sensor?
- Know anything about this CF Hood?
- 300ZX MAF on the 4 Gen. Possible?
- not starting
- 4g's with grey interior, help me out
- AC problem
- Getting 12V from Fuse Box..HELP !!
- Suggestions on 2.5"+ inlet OEM mufflers
- Front sway bar
- Will a tow truck be able to tow my car???
- HOwcome no one on here . ..
- Light Question
- Post a pic of your favorite 4g -
- stock hood wobble
- Light Weight Flywheel
- Anyone Seen Pearl96Max
- Engine Movement
- ebay find question : carpet mats
- how to take out tranny
- Starting problem
- Best Clear front light color combo
- think these coil overs are worth it ? quick only 15 min left
- Name of headlights
- Lets See Them Retro Headlights!
- Advance timing for 5th Gens and the 99 Model
- 97 Maxima with 00vi
- What should I check first? Battery is being drained
- coolant leak
- Realistic expectations?
- Best test pipe
- Y pipe install...ECU reset?
- Water Pump?
- Underdrive pulley
