- skyline body kit
- 20 INCH RIMS!!! some one please help!!
- If you want KYB AGX's for $346 shipped...
- Gauging Interest
- ***HELP!!****Pulled/Replaced Spark Plug, Filter -> engine light on, car shakes.
- D#@m!!, stripped drain bolt on 5-Speed M/T '96 SE, how to fix?
- Injector missing tabs
- engine codes
- wiring harness problem
- car wash & RSB?
- CF Bezel
- Coil Packs
- Quick brake question
- Weighed my 96 SE today = 3240lbs
- Frankencar intake order
- skyline body kit
- Drag Suspension
- Air Fuel Gauge
- Something rattling under my car?
- Do they still sell....
- Just a lil question about rewiring clearance light
- One wheel peel
- Rubbing Noise coming from wheel well
- Bad Moter Mounts ?? rouf throttle
- Odometer not moving
- What is the drive belt?
- Speed Governer?
- fog lights
- Altezza Lights!!!!
- Replacing Airbags
- best pedals
- Anyone Have Problems with SKYLINE Body kit?
- timing belt pan leak
- well i finally took my '96 5spd to the tranny shop...
- Help!!!! rear of car has its own mind
- Phillips Blue Vision Bulbs (Where to Purchase)
- NEED a pic of skyline bodykit on 95 max
- Projector Headlights
- P400 on scanner (EGR? How much of a priority?)
- Camber kits for a 95 max?
- Fixing fiberglass...
- just a quick dimmer question...
- Locking my wheels
- Fixed shimmy finally!
- 97-99 headlamp bumper swap to 95-96
- what to get? progress springs or fstb or intake
- Possible to break welds inside muffler (baffles)??
- PIAA Xtreme White 9004 Bulbs
- custommaxima.com maxima
- Fog light harness??
- I need to talk to someone who is somewhat familiar with the cornering lights
- New 99 SE 5speed...what to do what to do?
- ABS and fog lamps
- Good price on BG 44K Fuel System Cleaner
- Small RPM drop when headlights turned on, Normal?
- Those using Gen 5 mufflers...
- highest mph with OD off, and still downshift?
- Cold Start Info
- NEED HELP with my exhaust setup
- ebay strut bars
- Need help deciding on rims????????
- what do you use to lube the antenna mast?
- Knock sensor from hell...can't get it out!
- Sunroof Problem.....
- Interested in 4th Gen Black Leather Interior Swap?
- Why would rear brakes wear out before front?
- Code From PL Cold Air
- Has Anyone Seen NightRider(Rich) Or Know Him???
- y pipe or catback next?
- Woah, old I-30 smokes my max
- Here's a nice look but I need suggestions!
- a4 2.8 vs. maxima
- Flywheel any good?
- Car not accelerating well from a stop
- y-pipe exhaust leak, need help
- Supercharger with UDP?
- Factory fog lights - how good are they?
- Possible issues with ADR wheels?
- Factory remote control
- Engine Mounts ?? Poly Home Made ??
- Supra wheels
- got a code after replacing knock sensor. and a cel
- squeaking clutch pedal
- Passenger Side Door Light Works Again
- Idle Control Sensor Code???
- front struts
- rebuilding engine
- y-pipe difference
- is this mod true.. or is it fake
- 95 -99 Cattman Catback Exhaust
- overdreive
- setting new factory alarm remotes (searched)
- New dirty engine mod (pics)
- Stillen Supercharger - Price Info
- Who has an air bypass valve for there cold air intake?
- dual exhaust.....
- Keyless entry quit working
- KYB Dustboots for 95 GXE
- NGK Spark plugs...
- Broke Antenna
- question about ignition coil packs
- Cold air box with stock parts?
- interior lights question
- Apexi WS + y-pipe = weird noise?
- Steering is getting loose at 50K, what to do?
- Engine knocks unless I use 93 + octane booster !?!
- headlights
- Y-Pipe volume from inside?
- after more than 20 tanks of gas, some results...
- ECU code 03-02 EGR System Hi/Low Flow
- Frankencare Intake system and MEVI
- How can I know if my car have abs?
- Turbo Manifold
- is it possible to install HID in fogs using aftermarket foglight harmness?
- Strange noise when starting Maxima
- UR UDP removal
- antenna mast won't pull out....
- Code 0115
- Replaced the thermometer tonight
- Squirrels in my engine?!
- y-pipe
- My 1st tune up..done
- I love the Max but new cars are just getting to quick...
- 4th gen siting in TN
- Wasting money on suspension, help!!
- Winterizing my Max and squeeling belts...
- No Clutch!
- Dual Exhaust question
- Is the VBX ECU decoder accurate?
- Anybody running AMSOIL in their MT?
- Back up lights after tranny conversion
- HELP! ECU error code! Stuck at work!
- Car won't start
- EGT's - need help comparing my numbers
- Help!!! My is Clutch Sticking
- Failed NYC Emmisions Test
- Found the top speed on my Max
- CHECK ENGINE 10-5 code
- How to remove stuck spark plugs?
- quick question for Injectors
- Peeps w/ Red Clear Tails 95-96 bulbs?
- Piaa Blubs anyone melt harness
- Very "Weird" Noises......
- cattman cattback
- has anyone tried BOTH potenzaRE950s and Toyo TPTs?
- exhaust system finally in check!
- Two quick Sprint questions...
- different tires
- Do i have to roll my fenders?
- Supercharger install almost finished ... except!
- any experience?
- Powdercoating Stock Rims
- one piece headlight???
- Will this fit a 4th Gen?
- Yellow Max Skyline rear (pic)
- Goodbye maxima.org!
- Opinion on local 4th gen max for sale.
- how do i stiffen shifter??
- header wrap on sc piping, ypipe, and test pipe
- OMG!! 33 mpg this weekend!
- Starting problems with my Maxima...anyone experience this before?
- 97 SE. Hear a rattle when I hit bumps sometimes. Shocks?
- Tire Cupping: Inner and outer shoulder blocks
- What else should I replace when I do a starter???
- i changed my temp.sensor and my knock sensor code went away also.........
- O2 sensors...
- Automatic Transmission Problem 95 GV30 Maxima
- 4th Gen Altezza light pics?
- Difference between automatic and 5-speed engine mounts?
- Infiniti I30T
- Ignition Signal Circuit Problem
- Engine noise on highway...
- 4th gen parts list
- high flow fuel pump??????
- HVAC Blower Fan positions 1,2,3
- resetting the ecu
- lots of questions about subframe connectors and x-braces
- CAI...is your filter smashed against the fender wall = less air???
- new hyperwhite headlight blown out
- cattman or frankencar
- fog light switch - same for 95-99? (merged threads)
- clutch makin noise when i push it down... need advice!
- spinning out in 2nd...
- EGT gauge readings?
- altezza gen2 95-96
- want to fix: cruise control, trunk, chipped spoiler, etc.
- Best Low Cost/free Mod(s)
- rigged forced air?
- Where and how much
- pics of my 97-99 front and rear end conversion
- Bulb sizes on 4th GEN? (merged threads)
- 02 sensor troulble codes
- Just got an autostarter
- What First?
- I GOT BEAT by a HONDA?!
- New Body Kit
- 19" rims, stillen body kit and sprint springs = trouble?
- Low compression?
- pic of old PCV versus new PCV
- changed my hood supports...pics inside
- we need another 1/4 stickie
- Help...Auto trans shifts hard into reverse
- Tire Stud Replacement (the thread the lug nut goes on)
- anyone with auto, lowered with progress
- How to fix interior rattling noises?
- Egged Car :( Please Help...
- Dropzone or Aerospeed
- Going to dealer for motor mount
- Thinking about selling 8k HID kit
- Q about OEM Sparks
- Redline MT90 Discount????
- Wider tire on stock rim 205/65-15
- Something wrong with my Fog Lights???
- 95 intake versus 99 intake?
- 97se steering wheel different form a gxe or gle
- Engine died, now I need help.
- Automatic shifting
- Hubcaps - anyone with pic's?
- Hanbi Kits
- How do you take off the front bumper?
- HELP!!! Wiring Heated Seats??????????
- Stillen Or Cattman
- Carbon Fiber Do-it yourself?
- Thermostat and coolant change/flush
- High beam light comes while driving
- Should I go to Vortech or local shop to fix the V2?
- projector lights
- Wondering how much a dyno run should cost?
- Vcn-2000
- Help Check Engine Light won't go off
- What Brand of spark plugs
- would you still buy it ?
- Cattman or Stillen?
- Flames?
- y pipe help please
- Decided to take the muffler off....What will I lose?
- spoiler troubles
- Help Me Please!!!!!
- Keyless Entry Question
- Trunk Mod.
- Considering purchasing car cover for winter, need advise, opinions, have questions...
- Aluminum Kit over OEM Woodgrain?
- Removing clearance lights
- Silver Star headlight owners, any problems with Silver Star Head Lights....?
- Other manufacturer Bose systems
- Starting problems.
- ORANGE (not amber) 1156/194 bulbs?
- Body roll with Motivational struts and H&R?
- Budget Y-pipe purchase
- Interior LEDs - How Many?!
