- Anyone in here installed "Maxed Up" door panels
- how much hp loss from ks?
- trouble starting up car
- My horn sounds like a little scooter
- Good place to buy shocks/structs online?
- Hello everyone
- mid-pipe how to??? (Link is down)
- tranny question
- Now I'm REALLY Pissed!
- power driver from a 95/96 work in a 97?
- Starting Problem, 95
- Camshaft Sensor location on a 97
- Legal Question about tail lights.
- Changing The Steering Wheel???
- 5th gen wheels on 4th gen
- Need help ASAP! Problem starting...
- Factory Spoiler Question?
- Build Auto Tranny (Cyro, Internals, Level 10), or Swap to 5 Speed
- Can a bad cat effect performance? Also is there any legal HI-flo cats?
- Adjustable lumbar?
- black smoke and lean fuel
- Warpspeed Y-Pipe Quality
- Brake Light in Console is ON
- post pics of your CF lip.
- DIY -Window Roll-Up Module Installed 4th Gen
- Tranny Dying out i think ??
- how do u clean injectors?
- new dash kit ***pics***
- Battery
- who has a GTP carbon fibre hood?
- I want CD & Tape
- where can i find a nice and not too costly stillen lip or kit for a 97and up?
- water leak inside right front tire?
- Dealers explainations of ECU Error
- MAxima NOt Turning On
- "No such thing as a 99 SE-L"
- power source for leds in vents...
- New tint Let me know what u think
- Pairing illuminas with springs
- Ce Y-pipe Questions?
- Altezza Lights...I like them...Show me yours
- Will 95-99 MAXIMA FRONT BUMPER LIGHTS 4PCS will fit 96 infiniti I-30
- new tail lights
- What hid is right for you?
- How's your manual tranny holding up?
- 4th Gen Maxima
- Emergency...brake is sticking
- Auto to Manual
- New headlights, anyone get them yet?
- Rear Creak Noise
- just got a maxima
- Available Carbon Fiber for 4 Gens??
- Shifter Short Throw
- Why is my ac fan working off and on
- Lowering Questions
- Slipping clutch Due to wheather? or Oil?
- drastic help plz! : car is dying!
- Bra/Mask for Maxima
- Flipout Key
- Optimal shift point/cruising RPM?
- Huge dent, with pics (56k no no) ... Need advice!
- 0203 showed up after installing y pipe
- where is PCV valve
- warming up the tranny
- Where can i purchase this?
- Taillight mod
- Need Some Help With Manifold Collector
- best H/O alternator available?
- Are these 4th gen lug nuts...pics
- Where did you guys put your switches
- Is THIS RIGHT??
- faster: 5th gen(auto) or 4th gen(auto)?
- Question about a new Max
- Quick Question, Ecu Stuff
- Its The Commpression. !!! F#*k !!!!
- [URGENT] Black Signal light!
- Head Lights Lamp Problem
- brake pad decisions...
- New EREBUNI kits
- Exhaust Poll...
- caliper piston wont budge
- I Need A Pathfinder Throttle Body Spacer
- Question about SAFC
- Define oil consumption please
- 96 motor w/ 98 ecu no cel. Y?
- Random Tech High Flow Cat? Worth It?
- making ground wire
- 5 spd swap
- Gauge Light Problem
- Jerky Car
- power steering problems
- 99 i30 cd changer
- Clicking when I turn the steering wheel?
- It's time....
- How loud is loud? Idle ticking
- how low should i drop it
- Im Stuck At Work! Help! Lol
- Question for 4th Generation MANUALs
- Ball joints
- Just got into a accident!!!!!!!
- Bought a high miles 99 SE. What should I expect
- K&N Filter Part Number
- Strut Boots
- Tranny
- I finally got it! [Pics]
- Will it pass the Emision test...
- The misterious case of the CE light...
- color code for dark green 1995 maxima
- How hard is drive belt change?
- Y-Pipe FINALLY INSTALLED, SMOKE FROM UNDER HOOD NOW!
- How long does a typical
- Oem Lsd
- How can I fix an Evap System Leak - 0705?
- exhaust
- Got questions about 300ZX front brake upgrade??
- What kind of brakes should i get
- MAP/BARO SW Solenoid/Valve
- starting problems
- P1320 CEL code
- Electrical Woes
- 95 Timing Chain
- most repairs in a small amout of time
- Quick ? on Cattman Headers
- AC Compressor Problems
- Starter replacement for a 95 Maxima
- Heated Seat problem
- '99 revs high on startup
- Difference between cali/fed spec
- Fog Lights...??
- Inlet/Outlet
- speed pulse wire on 96 5spd
- EGRC Solenoid valve???
- cruise control mod doesnt work for me, help please.
- Valve Cover Torque Spec.
- finally got a cardomain page
- fender replacement
- Replacing Fuel Filter
- Just got a Maxima!
- beam pattern of cefiro headlights, pics wanted
- Wire Harness or ECU????
- Bose quistons
- Exactly how bad is Maaco???
- Bumper Fitment Quistions.....
- Next Performance Part??? ($1K to spend!)
- How reliable are Maxima's
- emblem removal
- Another projectored Max
- anybody know where i can get a red intake off ebay
- Shifter/Transmission Trouble
- bad wheel hop
- 96 Maxima Grille to 97, 98, 99 style
- need help quick!!
- fuel filter replacement
- Oil Pressure Switch
- So, how's your Max doin'?
- B&M install almost there help.
- Awkward Jerk/Hesitation upon Deceleration
- 5spd Slave Cyl. Piston Travel
- Washing car yields expenses
- tyc paintable tailights
- 99 maxima cracked lug nut stem
- Where to purchase UDP which brand?
- Reverse button on shifter
- newb..with a question
- Breaking in a new clutch
- Injen CAI knockoff...
- MY CAR SUDDENLY STARTED TO SHIFT AT 6 1/2 to 7 is this bad
- Car has rough idle and RPM's are erratic
- CEL Advice (0705) (0903)
- Does anyone have Aluminum splitter osn their stillen kit?
- Dynomax Muffler
- Driver's side window mechanism about to die
- Strange vibration from 70-80mph when a passenger is onboard
- 1995 Console Removal HELP
- Right Head light keeps going out!
- What the hell?
- A picture is worth 1000 words....
- New PB = 14.56 @ 94.10 mph
- Time to buy...
- people who bought LED's from ebay user: cwithk
- posted about 5 times, yet no solid answer..
- B&M Install problems
- Stereo removal
- Good Muffler
- fuel filter question
- Niteshades Spray Tint
- how much should I pay?
- Hit Pothole, Now Metal Scrape sound from wheel(s)
- Cool Video! Check it!
- Free desktop PC
- Need help: 99 Maxima jerks when taking off
- Leather Interior Question for 95'Max
- 9004 ---> 9007
- How much to get Pearl White Bumper Painted?
- 300ZX brakes on a 95-99 max
- Your Gains with the Apexi SAFC??
- sunroof problem
- really basic: how do you remove clearance lights?
- im doing my gauge cluster leds, and i want to know how much blue ones i need
- maxima y pipe...Smoke comin out HELP!!!
- People who have bought clutch related parts from dealer, get in!
- Not cool at all
- CM jdm black bumpers lights...
- turbo questions
- HOw do you know LSD?
- Should I remove headlight housing bulb cylinder?
- Electrical Problem
- How to replace control arm bushings?
- i need headlight,corners, and sidemarkers
- how DO you know if your tranny is dying?
- Question about my intake??? please let me know what you think
- Plugs and Wires
- Hey guys look what im getting!!!!!!!!
- buying clutch from jr nissan. which parts do I need?
- unorthodox clutches suck!!!!!
- competed my 5th gen motor swap!!!!
- Installing Rear Brakes Question
- running other oem wheels on stock
- Pacesetter and CustomMaxima short shifters
- Help?!!? (pics)
- mods
- 96 ECU in a 98 - getting rid of P0136 (long)
- Q about Redline shift boot installation
- Shock Sensor = wonders!!!
- Cutting stock shifter - HowTo
- max stalling
- quick question about headlight fitment...
- help help help
- New Euro Headlights on CM
- Ball Joint Destroyed
- Shifter color question
- did the I30's come w/factory phone under the armrest?
- stupid lowering spring ?
- my bumper is cracked!!!
- brake pads??
- 2 inch drop on stock wheels...Good idea?
- Front license plate bracket- 95-96 same as 97+?
- getting "clunk clunk" sound from front left struts
- Oil pressure gauge
- Put in indiglos. RPM needle wack??
- Need help w/ wires
- bought this trans fix
- Quick question I was wondering
- Hacked air box (did mine different)
- Quick question
- Best Brands for HIDs?
- Led Work
- can 2002 injecters fit 96?
- doing the led's in hazard/defrost buttons. HELP!
