- Newbie to Maximas
- Is there a way to adjust the idle control (tunning)
- mpg drop in winter?
- Which Y-Pipe will last longer?
- I just bought these NGK spark plugs, please help!
- Vb mod question
- Wiring Fog Lights To Run With Parking Lights
- auto tranny noise??
- stuck alloy?
- MY MAX GOT HIT!!! need help
- Replace bumper cover?
- BS Forum???
- anti theft idea
- can I get just regular white SE gauges?
- NYC Maxima Meet ...
- WHICH grille do YOU like BEST?
- Magnetic ATF Drain Plug
- fstb and springs?
- 98 se fog lights
- Max sighting...Paterson NJ
- Trailblazer, quick ??
- air ride
- where do i get a clutch aligning tool for my 96 maxima?
- Anyone have a fold down backseat mod?
- Had a Question about my 97 SE 5 speed
- Question about struts
- max rear wing
- What Colors My Car?
- tire question
- pics of 18" rims
- Look What I hit!! :)
- where can I find the pcv valve?
- ATTN '95 Max's: Weird/Ackward steering wheel position/seating !
- Throttle Body Cleanup...engine Light???
- ECU codes throwing me a loop
- visor remote
- What is the plug on the bag side of oil pan for???
- Post pics of your aftermarket headunit installed
- Racers edge wars
- Labor charges for Big Brake Install?
- Question about getting new wheels
- high idle after starting car second time
- Steering got a lot worse after new tires were put on..
- Odd O2 Sensor Question
- Strut bars
- Finally replaced my BOSE
- Preludes are fast?
- indiglo gauges
- Rubber trunk mat- where & how much?
- I am curious....
- If anyone cares, the Suspension Part Number and pricing info is updated
- Couple problems.. Help needed
- Y-pipe ?
- questions...
- Paint the hood?
- For those whining about buying platinum spark plugs the sticky post is updated.....
- What do you think about.....
- Problem with rear brakes....please help...
- Intelliglo needles on a 98 GXE
- cargo / convenience net??
- problem with front left knocking during right turns
- Should I get an Aluminum Dash kit or more performance mods? Please give Imput
- What are my chances of beating a 2000 GXE 5 speed with my 97 Auto GXE with mods
- AutoLite vs NGK
- Konis better? You must be kidding.
- Trannie funny when cold
- AGXs -- $345/set
- strange ECU code
- Who Wins 96 GXE Auto vs. 94 Prelude Si (Non VTECH) Manual?
- oi just figured this out wow
- Hey Greg----->Clear bumper lights?
- To those with cut shifter....>>>
- I got HIT!
- Overdrive off or on?
- Stupid Addco...can't install RSB!!#!
- Advice on these codes
- Help Removing Starter... if you've removed it please read this...
- Hit 175 mph today...
- climate control ques?
- clean inside headlight?
- Koni or KYB??? Eibach or H&R?
- Door molding question?.... please help!!!!
- What rpm should an auto idle at?
- To all those with Diamond clears that fogged up...try this
- # of quarts of oil for 4th Gen???
- QUESTION: Pulsating Feel When Braking...
- INidglo Gauges
- gimme some dirt on a toyota avalon
- how2 install a spoiler!! help!
- Friendly warning about these HID look-alikes
- Door handle molding
- Suspension Moron
- How often to change synthetic?
- Consult
- 1 Hid Lamp Out!!!
- How much is a good price for used fog light?
- putting in new seats
- Timing chain tensioners
- stillen b pipe
- driving school
- How can I tell if the previous owner replaced the spark plugs?
- Can you use amps in bose system with another headunit?
- Needed: Painted rear spoiler
- Y-Pipe Fine ??
- For those with a dragon intake...
- AEM bypas valve
- Clear and Red tails?
- How to change odometer milage on 97 SE speedo?
- Staggering tire size between front and back
- trouble at start up
- know about HKS muffler?
- 1996 SE AUTO Limiter?
- Dunlop SP Sport A2
- 96 SE Maxima Vs. 96 Vw Corrado
- Covenant nissan charges...
- Stolen Max!! (papasmurf)
- Upgrading Brakes, what steps to take
- Disconnect Y-Pipe at Cat Flange
- Brighest headlight bulbs with standard 55w rating?
- Water pump time on a 96
- white 4th Gen spotted....is it you?
- Reading ABS Light Pattern
- Selling My Max
- Transmission oil change
- HP on a BMW 528?
- removing third brake light on rear deck
- Pictures
- PLZ EXPLAIN: Be sure to erase the malf info such as DTC not only in TCM but also ECM
- What do you think, beige 96 SE with Altezzas?
- BOSE problem
- 4th Generation -> SE -> 5 Speed -> BLACK <-hard to find?
- Headers
- 98 Prelude VS 95 Max
- Update: Max vs. A4
- just installed hid`s
- question about trunk lid sizes
- Need immediate response........Check engine oil light
- Hearing noises on 97 5spd se. Help me out!
- Look for pics of a4th gen with 2002 SE or GLE rims
- Brakes Noises
- who has a spoiler like this, or a pic of it ?
- new tires?
- have $2000 to spend! what should I get?
- Budget Y pipe???
- Fun with a Cougar :)
- Chrome Rims
- what up with my idle
- Q onvacant headlight harnness and lack of air box oil seperator.
- My low end sucks, is it because of my intake?
- broken truck opener
- I Wanna Slam My Car
- Does anyone have these wheels or something like them?
- 60k Service
- Non-Nissan belts
- looking for YELLOW accessory lights (1157, 1158)
- If you're looking for 4th gen Factory Service Manuals....
- KYB struts
- Stillen Muffler from 99 on a 95
- wood trim in gle
- Transmission Help!!!
- Rewire Corner Lights??
- Tire recommondation 96 se
- Using PIAA 194's for gauge cluster
- Serious Starting Problem....------>
- indiglo gauges problem please help
- twin canisters
- Whats This
- Parts List
- Fogs --> PIAA H3 Super Plasmas, StoneGuards
- Stillen Or Warpspeed Y - Pipe !?
- Exhausted!!!!
- Car feels slower under light throttle
- Drove M3 on Sat
- Battery check light-pls help
- Worst day ever: ypipe wont install, and then clutch completely died
- 98 SE Wheels and a Supercharger
- just so you know, I HATE MAXIMAS!
- aftermarket bucket seats
- Aftermarket Mirrors?
- Anyone have any experience w/ the Autoloc window module?
- Should I buy or keep looking?
- What do u think?
- Anybody know about leather seat covers.
- Good gas mileage
- Climate control on 97
- Is the Hazard light suppose to light up?
- Anyone from Central Illinois?
- How can you Increase Torque for everyday driving.
- gauge pillar
- How Much Does the 4th Gen Max Weigh???
- Aftermarket alarm question
- i hate the 4th gen side mirrors
- Exhaust Headers
- Possible GD on custom made side skirts and rear valance
- turbo's on a maxima
- wheel balance: tape vs. clip-on weights
- Intake Mod using stock Airbox
- OK back to the basics
- Lite Glow Neon Rods
- Brake Calipers
- **audio's FM/AM not working** - help!
- synthetic OIL?? any cooler??
- 97 ecu
- Anybody got pics of the really dark green color for the 97-99 Maxima???
- Climate Control... easy question...
- Intake Trouble :(
- Max with the Six Speed Wheels
- installation of grille?
- Starting trouble
- help me!!!
- Black chrome altezza's
- heres a ghettofy my car question
- Exhaust ???????????
- My brake does not feel normal
- Intake question
- 4th gen carbon fiber door pillars and door handles
- Anyone have pics of Aluminum dash kit on Tan leather?
- New 1-peice Mesh Grille For Your 95/6 Max.. I Decided To Start Making Them. Read
- ECU (33) 0303, (53) 0503 code diagnosis
- ? engine swap 2000 engine to 96 max
- Diamond Clear Fitment
- When are we gonna get a turbo made for our cars
- intake
- check engine decode...HELP!!
- 95 SE for $3800 - is this a good deal?
- My attempt to paint my altezza tails
- Trunk Dimensions, can someone help me out??
- Great group deal on hoses.....
- anyone have the z3 fenders cusommaxima.com sells?
- diamond cut bumper lense are great for strobes!
- want color led light in your headlight to blink with the alarm?(no drilling!)
- piaa Xtreme whites 1156 are on (what i think of them)
- PR CAI problem/question
- Cheap #194 Blue Bulbs
- Side Window Deflectors
- Just installed my ACT II
- Question about reading the ATF dipstick
- My max is a sled
- I need help, Quick - FTSB
- One thing that bugs me about the max...
- Cutting Stock Shifter?
- military maxima
- not happy with wiper LED install
- warpspeed y-pipe solved
- Where to buy these?
- Exhaust
- 235/45/17 on stock 17"se rims?
- got a replacement gauge cluster, but...
- Tach Problems
