- Alternator
- Quieter Exhaust Setup
- Check out my LED Gauge Mod!!
- how does a max hold up against a celica, evo, those stock turbo neons?
- where is the airbag module located in a 98
- No volume Comming from Bose Unit
- Clutch Problems
- Where can I buy 1 strut??
- Help! Drove With No Air Filter Now Car Won't Start.
- Disappearing brake fluid
- Baby got back! (and pics to prove it)
- Spoiler Light
- Cracking/Buzzing sounds from the stereo
- LED parks/stops/flash
- Cattman Catback VS. Greddy SP2
- Short Ram VS. PR CAI
- port/ polish stock intake/ tb ?
- anyone have any experience with body work, dents?
- console swap?
- Injen intake question...
- 19 X 9.5 in the rear of a 4th Gen???
- spark plug #
- CEL reset interval??
- l.e.d. question please help me out b4 i bid
- True gains from exhaust
- got ECU code P1440 and P1447
- best replacement struts
- Electrical Problems, No Taillights, cruise.....
- Installing Y- PIPE, HEADERS; Need Help!
- need new auto valve body?
- Suspension help again - how to torque top strut nut w/o the piston rod turning too?
- Tips needed for installing rear strut
- 300 dollars!!!!!!!
- RPM's go down when I apply brakes!!!WTF??
- Bose Stereo blinking
- Part question?
- Need to know how much it cost to install this!
- LED's in stock '97 SE guages
- How the F did you fit the KYB dust boots over your struts?
- 4th Gen SE rims
- Gauge Swap 98 into 97 Possible?
- Angel Eyes
- Question for those who replased their alt.
- Fuel injector is dying
- Anyone rocking sawblades with a drop?
- Center Console 2002 to a 98?
- Who Has KYB GR2 Front Struts/ Feedback
- Question for all you Z32 BBK guys...
- Problem with 96 to 99 front conversion
- Strut and spring combo...
- What does it take to get a 97-99 lip on a 95-96
- show me your LED climate control guys
- Is there a screen in the gas filler tube?
- MAF code after starter change
- lifter noise
- Brakes, brakes, brakes, and more brakes
- Stupid question:tranny swap idea
- Blew front speakers!
- testing MAF
- Missing Stud!!
- Purchase another 4th Gen?!
- Need Fuel problem help!
- Battery died and now dc is stuck in player and cd player wont work
- 300zx Calipers + 15 mm spacers + Saw blades?
- Starting problems
- Stupid EVAP
- your SP2 rattles too?
- what would corners look like w/ amber bulbs & blacked out chrome?
- MEVI anyone?
- 99 Max OEM Fog HOUSING replacements?
- Help again to choose alt ASAP
- K sport set on softest still bumpy?
- screwed by an orger
- Alternator Questions
- Horrible gas mileage
- supercharger instructions
- 255/40/19?
- question about stock cam gears
- Best Bpipe?
- strut adjustments?
- selling my maxima and getting a better one ;)
- Changing Bose Lights?
- my car isnt consistant in 0 - 60?
- how long does a 5 speed trans last???
- y pipe and b pipe
- Name that squeal
- resurface flywheel?
- How do I reset my keyless entry?
- New 4th Gen Max owner needing OEM parts
- need help , I have pics, injectors...
- People with smoked bumper lights
- Tan to Black swap questions, and also LED question.
- Anyone know about eBay "Nippon" oil filters?
- d2, d1 shift
- Quick Question
- Throttle Body Question
- Need opinion on rims ....
- Whats my body color???
- possible ac compressor problem, what do you think?
- Couple questions about 5spd swap
- cool gauges question
- Idle Air Control Question
- Guys please help with alternator
- Correct oil filter P/N?
- What is cold spec windshield washer reservoir
- Break Calipers
- clutch pedal squeak
- Engine grounding(useless thread)
- Got a Q guys?
- transmission trouble
- Ride is tooo stiff
- New 4th gen carbon fiber rear diffuser!
- found something interesting
- flowmaster
- Red interior?
- Trans fluid question
- Stock Bose....
- Input shaft bearing
- Check out a 4th gen with 360k miles
- 5th gen clutch and 4th gen fidanza flywheel
- Choices for white 95 max
- K&N Filter: Too small or just right?
- headlight conversion
- Nearly run off the road by a Lobo
- AutoMeter A/F guage. back light?
- Low auto tranny fluid
- Ts Ecu
- Oddyssey Battery?
- !ALL RED CLEARS! check out pics
- Changing gauge cluster
- My new intake setup (56k beware)
- 235/50/18 on a 4th gen max
- Want to know more about your Maxima
- Will this clutch fit?
- How to remove pinstriping??I just can't find in the stickies!!!
- Those w/ Cefiros
- Caliper maintenance? Possible?
- CPS-issues, someone smack me now.......
- Which rims? pic A or pic B?
- Where can I get a new clutch
- manual climate control to digital, cant find write-up! a lil help please...
- Removing front turn signal in bumper
- Cold Auto transmission
- crank crank rev stall crank crank
- Thinking About Going Back to Stock
- turn signals
- Exhaust advice
- Has anyone opened up the Gen II Altezzas?
- extra switch blanks
- climate control swat
- Energy Suspension Questions
- Can i add a hitch? Or anything towing related?
- New look with new headlights!
- auto climate control question
- Just installed 300zx/Cobra BBK
- Corner Lights
- Cutting coils?
- New resonator with b-pipe 190$OEM what to get instead
- Drain Plug / magnetic
- *NEW* Starting Issues/Problems
- Knock Senor Test with Multimeter
- noise from coilovers
- belt squeel help
- Where can I find it?
- need some help trying to figure out what is wrong
- Muffler Tip
- Maxima meet video.
- LED side mirrors...anyone have it?
- ODB-II port on car to computer cable, what's it called?
- Supercharger
- 60k service
- Possible to buy strut mount studs?
- Best Spark Plugs for the 4th Gen Max
- Heated Seat not working
- Turn signals work, hazards don't. Why?
- help with timing tensioner replacement
- Aftermarket Air Filters???
- Lower Control Arm bushing
- Starting issue
- safe jacking point
- vent buttons - light off
- flat spot?
- Splitfire coil packs......ever heard of them?
- Leaking shock Suggestions on stock replacement?
- Speaker Recommendation
- Im TPS adjusting-stupid
- my new grill =)
- Starting Problems
- This has been discussed b4 but are 95-96 and 97-99 exhausts interchangable?
- Ecu code 10 01 sticky link dead..need more info
- rough ridin???
- Computer Chip/Module. do they really do anyting?
- Belt Tension
- aftermarket or OEM: Inner tie rod boots.
- Clutch died last night
- Price cost?
- The old mevi question
- Is this the AMB sensor? (PICS)
- Coil Packs Question
- Bye Bye 4th Gen :(
- Ionic Kit
- Another alt. problem
- Stripped axles or CV joints
- Ground clearence with Blehmco LTB stage 1
- Blinkers gone crazy
- What is the length of a stock 4th Gen Muffler?
- Polyurethane Busings Good Or No Good
- s-tech ???
- HELLA DIFFERENT MAXIMA!! check it out, custom headlights, never b4 seen kit!
- My maxima overheated today...on the way to a Job interview!
- obdII scanner code P1130
- Did you cut your bump stops?
- Possible alternator problem???
- Bumper Signals
- Hotshot headers on a 4th gen?
- ac compressor noise, anyone else get this before?
- 4th gen Idle while driving
- Rear seat cover
- clutch problem
- Trunk question
- Should i paint my grill black?
- Code 05 04, TCM (transmission controle module) Need more info
- Rear Valve Cover Is Leaking, Help!!
- DO i need this for the safety of the car?
- Ignition Coils Good or Bad? How to Test?
- when is it time to replace the auto tranny?
- cheap tires
- How do you scape dry salt from the carpet(previous owner sucks)
- Alessio 20 spoke
- need help with oil
- pix roll bar engine bay trunk
- Has anyone successfully changed their climate control reading from F to C ???
- changing to synthetic oil
- will 245/45/17 fit??
- what the ????
- Is my cat converter clogged
- clips on grille?
- Is this bad for tranny??
- Do light fixtures need to be air sealed?
- metal maxima's door and dome leds: brightness question
- Automatic Shift Boot???Been Done?
- Ksports coilovers question!!!
- please tell me that maxima wheel bolt pattern is 5x112
- WTF is in my coolant
- rear main seal
- Please Help Trying To get Bose/Auto Climate Control out
- Motor Mount Options.
- magnaflow universal muffler on stock exhaust system
- 4gen with rims and NO drop, Lemme see em!
