- spark plugs and air filters
- maxspeed springs vs. you
- Removing Bulb Shield
- Gabriel Struts?
- motor/tranny mounts
- CEL question
- swirl valves
- clutch install?
- MIL on but no codes!
- S techs.....good????
- are automatic & manual starter's interchangable?
- What are the best shocks and struts?
- for those who took off their spoiler.
- 5spd related question.Help needed!!
- Dry type air filter?
- license plate location - 95/96
- poorman torque wrench
- Greddy SP2 VS Apexi WS2
- confirm ecu
- question about brake light and battery light...
- Is "BOMZ Racing 3" inlet Cone Air Filter" any good?
- opinions on progress springs,RSB/AGX combo?
- Replacing front wheel bearing
- temp sensor/s location anyone
- PRO's&CON's of lowering(Sorry if it s repost!)
- es motor/tranny mounts..
- Does any one have these on?
- stock size pulley upgrade
- Inaccurate spedo reading
- Opinions needed: Tokico Blues+Eibach Pro kit...
- Another A/C question
- Turn Signals, please read.
- electrical problem - why cant the fuse just have blown!
- Picture of rear strut assembly?
- brake problem?
- Grinding Noise
- 3.5 or dek?
- Why are both my cooling fans on all the time???
- Goodbye.
- Wood Trim From I30 Fit 4th Gens?
- How deep has your Maxima gone?
- Trunk problem
- what fluid to use in clutch cylinder?
- Carfax VIN request
- high idle + lower idle when lights are turned on?
- Need To Get Motor Changed !!!
- Its a whole new car *pics*
- knock sensor?...Is this normal????
- Can you ride on just lowering springs w/ stock shocks?
- Belts and Filters....
- Maxima headers
- HELP- Hard to start!!
- poorman HAI
- drive belt how to = me confused.
- The big 250..
- brake and battery lights on?
- HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
- Trunk wont open With Key..WTF
- replace stock shifter on automatic
- difficult installing HID kits ??
- Ever hear of a 'slick shifted' trans?
- Air conditioner recharge: EZ Chill?
- Maxima wont start
- Inhibitor Switch, Code 11 01.
- Driveaxle Leaking Oil
- Knock sensor on ebay
- Oxygen sensor are they all the same?
- Loose suspension
- dumb thread......qwik question....
- ac only works on high
- stuck on 2nd gear
- Help! Cv Joint Came Out While Changing Front Strut!
- What is wrong with people :(
- MECP picture..
- Car loses Voltage
- Facing $2,000 repair and dont know what to do...
- What did you pay for Tune Up
- PRICES for painting body kit/bumpers and minor repair
- 9007 Harness and bulbs
- Squeaky Struts/schocks
- Driver side axle replacement
- WTF is this
- Started My Motor Swap...Teaser Pic
- Stealthy installs for radar detector in 4th gen
- abnormal engine noise when throttling
- Installing Stainless Steel Clutch line on 4th Gen.
- Rear o2 Sensor yuck...
- more lca removal question
- Cheap Muffler thats kinda quiet
- screws stuck in stereo
- car is stalling
- best ceramic brake pads
- Where to get exhaust gaskets
- should my car do this
- Inner/Outer Tie, LCA. . . (rant)
- advice please on a system idea ...
- Max went out of ? gear ? twice
- How do I remove this?
- Driver window sticks to inner weather stripping?
- 4th gen dash kits
- truck stuck shut
- Painting trunk keyhole and antenna
- engine stalling while at red lights
- car trouble
- Endeavor To Fix The Sunroof Minus The $$$
- Once And For All, B-pipe Hp Gain
- Custom Y Pipe with installed pic goodness
- Front Emblem
- Misfire on #6?
- Shifter acting up. (automatic)
- not important, but real annoying
- Brakes
- quick ksport adjusting ?
- Which HID Kit to get ??
- Car Poping-Backfiring
- ATTN: '99 autos w/ more then 125k miles and LSD, final drive noise
- help help guys!!
- Ignition switch update
- synthetic oil
- What's missing?!
- Y-Pipe Q - I know there's an increase in noise, but where should it be coming from?
- droppin my *****
- trunk wont open
- which sensors do i unplug ?
- Max broken into - San Antonio
- Any Good Head Gasket Shops ????
- An Ounce of precaution
- Cat-back
- Please Help with 3 ecu codes
- 1997 SE ---- STEERING and SEATS ???
- weird Relay clicking sound when pressing brake pedal?
- So How much Horsepower does your Gen 4 Maxima have?
- LUCKY DAY..... picked up sum free hids
- anyone have complete 2 1/2 inch warpspeed exhaust????
- Auto Climate Control Change from Celcius to Fahrenheit
- Pinging Pinging and more pinging
- (Almost) complete front end overhaul
- The Boy really screwed up...
- Summer is here A/C stinks, any solutions?
- question about stock airbox hack...
- UR pulley belt #
- NGK o2 sensors
- How long can a Maxima sit without being used?
- Something strange....
- rear sway bar necessary?
- The new ULTIMATE LED instrument cluster...sneak peek!
- Speedometer/Odometer frustration
- Blinglights HID Kit On Ebay?
- Car Stolen 6/19/2006
- 190k on original clutch?
- Poll:.org What is the best Gen-4 Maxima year, in your opinion?
- Exhaust setup advice? (Warpspeed?)
- What are the best ways to make your Interior, become black Leather Interior?
- droped max to night having problems!! help
- on air
- jus changed BACK brakes.......funny noise now...
- Cel 1008
- Cost to have clutch replaced
- Door panel removal Part 2
- Door panel removal Part 1
- 96 Rear wheel alignment.
- The cupholder from hell; HELP!
- 4th gen stalling
- SAFC II Tuning
- Will this Exhaust fit on my Maxima? Please help
- Offset Question
- quick question ???
- Urgent Help Needed - Crush Ring gaskets on used WSP Y, pics included
- squeeky suspension
- Ripped Leather
- Door Pillars
- Creaking from driver's side front wheel well
- CEL disappeared
- New Short Ram Air Intake
- Busted Exhaust System - Pleasant Surprise!!
- How low to go?
- Should I...sell my car?? Need advice, dumb thread, but need to know a bit about 2002s
- Shift Lock Problem
- Tint DIY?
- Maxima seems like its Slacking
- anyone have a service manual....
- Need shorter belt to run without A/C
- Going back to stock exhaust
- jiggling/shaking noise under car??
- Please Help!!! OXYGEN SENSOR Question
- Is this what a POLISHED ENGINE supposed to look like?
- does any one kno what this code means? 0707
- Need some info ASAP about brake fluid
- Alternator Trouble? - 1999 GLE
- Front End Diagram ??
- NEW SUSPENSIOn a few ??
- Im Replacing my CV Driveshaft- few questions
- Powering-up power windows
- Stillien body upgrades.
- Are Mille Miglia 18 x 8 rims nice?
- squeaky squeaky....belt??
- Wheel Hub Removal 1998 SE Max
- engine cranks, but wont start
- axle nut removal
- Baterry.
- Few quick questions
- rear power window problem.
- Mirror electronics
- Need a new car window
- Question about alignment
- Muffler Exhaust tip, whats compare to stock?
- Does anyone have a Brockway R920?
- 5.5 Gen Seats Installed in a 4th gen Maxima
- Might need coil packs...so sellers help me out, see if you agree with me
- Here's a weird one...
- Random engine shutdown.
- Premium 93 octane huh?
- D2 Coilovers and Strut bars
- exhaust help
- 97 Maxima need help
- 99 SE-L Misfiring
- So, about these clear corners...
- Y-pipes
- should i buy these tires?
- Installing air horns
- lip kit on
- drivers side fog light on ebay
- o2 sENSOR Question
- Sweet someone broke into my car
- Steering / Wheel vibration... low speed and bumps
- Spark Plug tube seal
- 95-96 pacesetter exhaust
- Which foglight bulb is the best ???
- What Nissan's did you own previously?
- low gasoline light
- Tired of saggy spare tire covers? Step inside...
- does anybody downshift gears on automatic?
- good springs to lower
- Cali or fed spec
- what are the best lowering springs
- Help!!! Please!! What Could Have Cause This??
- Paint the Gutter Guard Black or leave it Silver?
- whats your racial profile?
- help w/ cf hood
- Engine Shudder..?
- Windshield Wipers Don't Work
- check engine reset
- oil on spark plug??
- Car shaking to the beat of the engine
- engine choking..
- stillen or greddy exhaust
- Maxima in the new Fast and the Furious movie ?
- Antena mast
- Damn Immobolizer!
