- Math: Why you SHOULD use cheap gas!
- b/s upgrade or not?
- How do I get pics in my sig?
- Going to start to mod.
- Popping/thumping in front suspension
- Exhaust
- Car Nearly Stalls when i Press on Brakes
- suspension install checklist help??
- Anybondy know where to get OEM parts cheap!!!
- Installed Intake - CEL
- How do I change the FOG lamp bulbs?
- ECU Codes 1003 and 1101?
- How much should I pay for used ignition coils??
- Lost a bunch of oil!!! WTF!!!!!
- Water Pump and Timing Chain Tensioner...
- Needs pics of tints on our cars....
- Need a frontal bumper pic - white
- The-95 vs. The-98 ...... wow!
- Of these three options for tires/wheels what would be best?
- Replacing Suspension Bushings along with Struts
- Adjusting Spark plug gap .043"?
- Custom Enterprise Front Strut Bar...
- O2 sensor cost?
- How to remove headlights
- 5-speed axle play
- Couple of Questions?
- Totally pi**ed off!
- OEM Fog Lamp Dimensions?
- NEed A Part
- Funny sound from my exhuast
- Parking lights??
- Wheel spacers to fit G35 rims?
- pics of 4th gen with rota subzero?
- Underdrive Pulley
- Pics of A32 Cefiro headlamp beam pattern. >>
- Where can I get these door sills? *pic inside*
- 35th Z rims...if someone wants to jump on them
- Part# for knock sensor?
- 4th gen photochops/pic editing---56K beware, large pics
- i need some clues
- Custom Enterprise AE Shift Knob
- 10 Year Check-Up
- traction vlsd
- injen fake cai vs. weapon r short ram????
- Getting new struts/shocks
- top speed and hesitation
- Mass air flow help needed
- Spring 2006 Crutchfield mag, whos 4th gen is in it?
- FOB's ?
- Tranny 5 spds rebuilt
- Sylvania Xtravisions?
- 5th Gen cltuch question (Real quick)
- need a new fender
- 95/96 clear tails
- Weird sound from my car? Chain/metal sound..
- RTP Rotors or Brembo's?
- 97-99 headlights vs new euro clear 95-99
- Alternating bumper lights
- ***RAXLE**Brand New DriverSide Axle For Sale
- which intake do I have?
- Exhaust leak help...
- Trunk Stuck Dont Say Read the STICKIES!!!
- Custom Maxima Tail lights not lit at night
- Need motor mount advice and prices
- factory rear brake pads on a 95 max
- Going to Japan, what to get
- Shift Knob & Boot
- Changed water pump, got some stories/tips...
- Trunk dimensions
- custom door sills
- Time Chain Tensioners Gone..help
- I hate subaru
- jack stand - not hydraulic jack
- How hard to put abs on a 99 not equiped
- Wtb Z32 Calipers
- Anyone worked with fiberglass?
- keep having immobilizer problems....
- Arrrgh.. thought that fixed everything(squeaking problem)
- MAX is no more
- Unorthodox Crank Pulley
- Need help with vehicle shimmy
- Put the rims back on
- Power Steering Leakage
- Control arm
- A/C Compressors...Which one?
- my car is starting wierd....
- Speedometer problem............
- ATF in power steering?
- Upgrade from factory car alarm
- door lock problem
- Looking to buy 4th Gen
- taking apart gauge cluster to install bezel
- ebay gold trim for maxima....LOL
- 2005 SE Wheels
- Driver side door hinge has a litlle slack sometimes clicking
- the wheel shimmy saga continues.. front end pro's step in
- Intake installed. Now car won't run.
- Spring is here...new projects: Tires/center caps
- Got in a wreck today...
- Maxima R34 Skyline Kit
- 1156/1157 LED bulbs?
- Front bumber lip...
- Clutch fluid disappears
- OEM Tail Pipe Hence More Power
- problem installing front strut bar in a GLE
- clear out 97 tails
- Two types of iridium spark plugs?
- Favorite hidding spot
- 4th gen with g35 wheels...?
- Shift Knob Removal!
- Caliper rebuild kit
- Problem with Losing power
- ECU code
- what kind of gain with the vq30
- Is this a good deal?
- Installed my ws y + hi flo cat (sound clips inside)
- no heat
- max vs. 350z
- I love the OEM fog lights on my 98, but...
- Autotragic issue, stuck on Park!!!!!
- BATTERy LIGHT & PARKING BRAKE LIGHT "on"
- Lol my car sounds like poo
- Airbags...
- What's that smell!? Someone please Help!!!
- Look what came in the mail today...
- ebay muffler
- ebay muffler
- Safc settings
- 2 alarm light's
- CV Axiles
- tail lights
- splash guard
- How to install satellite radio
- 95 maxima, factory radio screen not lighting up..
- Black Cloth?
- tail lights question
- E55 Retrofit
- Need help with CODE P1105!!
- Not starting just ticking
- Colored AE headlights
- in-cabin air filter
- quick question about fuses.......
- gas gauge help
- RPM gauge not working
- 99 maxima upgrade
- Well Finaly I think I got me a 4th gen
- Does RSB help with coilovers?
- rip off....!
- Removing Pin-Striping?
- KYB AGX and TEINS s-tech
- Car dies in traffic,RPMs jump,Engine Sputters!!
- O2 Sensors, 0303, and location
- changed knock sensor
- Will Crank But Won't Start (99 5Speed)
- Short throw
- Thinking about going with solid strut mount... Coilover guys step in!
- and you thought YOU had problems..
- How are my shifts? (Video)
- Bose Head unit stereo input
- Upshift Light
- Heres a new one... Every time I fill up, car has trouble starting.
- Compression Check Help/Info?
- Look here guys removed IACV first time after 160k*PICS* miles
- throttle cable
- Anyone tried these gauges?
- Water pump replacement: Duralast vs. Bosch?
- Power steering pump install
- Bad Luck with the Max
- Replacing resonator on 98
- question about 1996 max
- how to remove vent trim?
- flywheel-...resurface or not
- Groaning sound from rear brakes?
- tranny fluid viscosity
- 5th gen clutch part numbers needed asap
- clutch replacement
- help tranny leak
- help tranny leak
- Surging idle problem?
- Putting in new carpet, how did you do it?
- isnt my car to slow?? (VIDEO)
- I have about $200 to spend, are KYB GR-2 shocks any good?
- rattling clutch noise?
- Stuck in Park
- 205/40/17 how will they look??
- Car wont start
- anyone know where maxima meets in ny are??
- why is the 2000+ maxima intake louder then ours.
- WOW awesome price for headlights
- Anyone know Mobil 1 Oil Filter Part #?
- need help with a tough descision
- Question about shift knob
- Dealer v. Local shop
- Help with my 99SE 5spd....Newbie to Max's
- SP2 less then $554.14 US? anyone?
- I regret buying my maxima.
- Should I buy these?
- Car idle 600-650 rpm on "D" position is it fine?
- What does that seat airbag really do?
- Attack of the Cold Start...p.II
- Removed woodgrain....... and lost Auto/AC button
- Question about my 95 =]
- hi-flo cat????
- Arrgg....Squeaky Belts
- Need a pic showing the difference between 95 and 97 fog lights
- I need a new grill
- REALLY REALLY mpg
- So what do yall think about the new C.E. black housing headlights
- Problems with guage lights...need really bright ones
- What reflector lenses are good for a retro fit to go beside the E46 Projector
- Dipstick covered in oil? WTF
- Axxis brake pads
- led write up?
- Color Combo's
- How To Change The Rotors + Pads
- To guys who did their 5 speed swap!!!
- Auto shift problem
- Door Open Talking
- Can you put HIDs in the Smoked Cefiro Headlights??
- teaser pix of my new cf hood
- DIY: Window Tinting?
- Putting power seats in a 98GXE?
- Light Bulbs
- trunk won't close
- Looking into the future...
- heres an idea about Greddy SP2
- Universal mufflers, need kits?
- Rear brake parts...
- Sawblade
- Some fun for this weekend...
- Need help! URGENT!!!!
- Door lock sticking
- need a lil help here.. anyone riding on 235/50/17's??
- Photochop Please
- Headlight Frame
- Chromed intake manifold?
- So I went to the Junkyard today...decided i would get a spare.....
- auto climate control
- 0707 Rear Heated Sensor
- A different Starting Issue
- how the hell do i get this axle in the tranny - 99 i30 auto lsd
- Which grille? (pics)
- replacing antennae mast
- Question about window switches and locks
- dealer told me not to replace knock sensor
- auto transmission ground
- Annoying Auto
- Clicking/Widing/Griding at startup
- how much weight reduction must be done to increase gas mileage?
- Cylinder 4 misfire
