- alternate
- Intermittent Blower Motor Operation (and parts/car year question)
- Clutch pedal still sinking halfways
- Replacing axle
- Center Beam Rotted
- front axel boot leaking oil
- Spring and Ball bearing found in pan after draining manual transmission oil 98 5spd
- Canadian ES Maxima O2 Sensor Specs
- no speed gain in first
- replacing stock bose which is 3 volt, with a 6 vol jvc, will there be power probs?
- problems
- Complete noob, need help!!
- possible bad starter solenoid?
- Exhaust Brackets for 1998 Maxima
- huge cloud of smoke while driving
- Ignition cylinder lock woes
- Leaking gear oil, clutch toast, shifter is possessed, input shaft bearing?
- 98 Maxima AC Thermistor Intake Resistor
- Need A/C Diagram...
- Selling I30 - should I fix the a/c
- Y pipe install question?
- Considering Getting Rid Of My Auto For A Manual
- Erractic difficulty starting Maxima
- 99 Maxima - 82K - Recommended Parts to Replace
- Test Pipe/Hi Flow Cat Concern...
- ground not hked up but now starts
- 1998 Crank but no start
- Inhibitor switch or neutral safety switch?
- bad ground..possible
- CEL P0135 O2 Oxygen Sensor Bank 1 Sensor 1
- Changing dash lights
- question about pioneer.
- 1998 Maxima Idle Issue
- removed upper N lower Intake Manifold,Now Injectors Not pulsing.
- Pulling a 4th gen engine, and swapping in a DEK question
- Quick front wheel bearing question.
- bad iacv cause hard start
- Please help me !
- 95 cali spec ecu in 96 fed spec maxima
- got P0440. which valve?
- Confusion on Corner light LED conversion
- Ignition coil problems.. but why?
- need some advice
- Spent hours reading searchable threads...codes 104..then 504
- Quad 8's in the rear deck
- Exhaust System!
- Electrical and CEL problems with 1997 GLE
- Almost 200k and losing power
- needed new cats?
- Removed UIM, now rear hose is pinched
- 2 codes engine light on
- Front Struts- Simple Advice I hope
- front shake
- Need Help!
- Coil pack question
- Tip Of Fuel Injector looks broken
- I got leaking on transmission driver side
- Rear end rattle like a mother#$%^er. Please help!
- 4th Gen door window replacement
- whats worst place to ever break down at.
- clutch and lowering springs
- Need some electrical help - stat
- I need to know what this part is!!
- Which muffler to get
- Considering trading my 99 maxima
- park/Neutral switch
- Transmission Chunk Broke. Weld OR Replace
- whats the problem
- A/C charge questions...
- Did lower radiator support the other day - spare part question
- Serp Belt / Idler Pulley Replacement advice
- vq35 swapped weird starting problem
- Any good LCAs on ebay???
- Recommendations for replacement Nissan Clutch
- Another Nissan F-U
- 1999
- Ignition coil for 99 max
- Stuck trunk problem so can I remove the back seat?
- 98 Maxima Speedometer/Odometer
- my tally wacker in my muffler...
- 98 nisssan maxima gauges not responding
- looks like i may need a new radiator?
- Front right splash guard / fender liner keeps coming off (second one)
- 98 maxima engine swap
- Oil pressure light
- Screw on base for antenna
- 02-13 Code EVAP and coil issue
- looking to do some simple mods
- 99 Manual Maxima Brown Tranny Fluid
- 350z internal swap?
- bad cats to blame for not starting
- air bag light blinking
- Having trouble; after washing engine
- 1995 MAXIMA...need help changeing back speckers!!
- Hesitation and Stalling
- Backfire in intake
- Changed coils, now code 0201
- Idle Problems Persist, Any thoughts?
- 98 Maxima 5 speed engine rpm hunts after shifting
- How do you guys keep your Y pipe gaskets sealed properly?
- quick easy coil question - PICTURE
- 99 Maxima ECU RPM Pinout for shift light
- A Video Testament to the 4th Gen Maxima
- serious problem
- Replacing Valve Cover Gas Gasket
- Low idle, reduced power using clutch after new knock sensor
- Sputtering Issue!
- hid's shut off when i turn on high beams???
- Upgrades to my 95 Maxima
- TRANSMISSION PROBLEM ?
- yellow brights in the R34 headlights
- 3.5 OBX Long Tube Headers Question!
- A32's Washer Nozzles vs. Murano's Washer Nozzles [Videos Inside]
- Dash lights
- Maxima Convertible + PICTURE
- Changed rear struts - now very odd noise problem. Please read!
- new engine put in and 3 codes, need help
- another High Idle issue from far away asia
- Overheating after pump and thermostat change
- Culprit for rough idle after 6-10secs of stopping ?
- SUMMER10 Sale at FCP - 3 Day Only Ends Friday
- exhaust header
- PO170 fuel trim malfunction?
- New Car Day
- tire size
- Exhaust guidance from you experts
- steering wheel shake after changing axles & other problems
- New Dealer Installed Clutch Chatters
- ITS CUSTOM
- HISSING NOISE???
- think i may have a problem
- EGR VALVE? WHERE IS IT?
- Shock Removal
- 4th Gen PNP Standalone+Gauging Interest/Discussion
- Is this a CA Emmissions car?
- Air flow in engine bay
- Almost replaced good wheel bearing
- Hiway Sway
- Clear Coating Rims
- Cutting out
- brakes
- car wont shift at redline!
- clogged exhaust pipe
- I moved on to the 5th gen forum today
- Alternator ain't easy to chg.
- Oxy Sensor - Part Duex - What tool? 3 wire OK in place of 4 wire?
- Need Help!!! Horrendous Noise from '97 Infiniti I30 w/ New CV Axles
- Should I sell the max?!
- Having trouble diagnosing brake issues
- engine shaking/pulsating - need help with diagnosis
- New guy, 1996 Maxima GLE noise
- video-is this slippage or lack of tune up
- Need advise on best parts to rebuild a tranny
- So I need a new cat converter..
- Wondering about dot 3 or dot 4 fluid in clutch master cylinder
- Crank No Start
- Crazy Car
- Will A Z32 Steering Wheel Fit On A 4th Gen?
- what is this part ?
- How would a set of Rogue wheels look?
- Bank 1 Sensor 1
- Are all Ignition coils the same? (location)
- Where can I get these MOOG sway bar end links?
- look what appeared on my doorstep today!
- Looking for a mechanic or enthusiast in Atlanta or near to help with 1996 Maxima NOW!
- wanted to know
- Right Engine Mount Removal
- O2 Sensor
- Name Products and Supplies to get rid of oxidation on hood and top.
- NEED Advice FAST new owner of 1996 Maxima !
- NEED Advice new owner of 1996 Maxima !
- Question about test pipes...
- Maxima in trouble...
- Hose help
- No reverse or 1st gear is my tranny shot?
- evap canister plugs up lines
- How do you secure the lower end of the shock bellows?
- Name those parts...
- strange front end noise?
- jerky/shaky drive @ no throttle (D) and 1500rpm - 1800rpm @ any speed/gear in O/D
- sway bar on vq35 swap
- ok running lights
- 98 Max Questions...Help appreciated
- XYZ Coilovers Interest thread
- car wont start, blown eng con2 fuse
- hard starting...smelling gas? pls help
- weird idle at warm up.
- Fellow Maxima Owners, Please advise on this Price Estimate
- p0505 Help
- muffler-only recommendation please
- Can someone help me determine which A/C compressor I need?
- turbo maxima
- 4th Gen Gear swap out
- Replaced KS and MAF, still got P0100 and P0325??
- 03 Maxima 3.5 Tranny in 99 3.0?
- Anyone over got a 9/2 code?
- replaced MAF and knock sensor
- 95 or 96 rear struts on a 97?
- Coil packs, buying / replacing knowledge needed!
- Knock sensor wire
- new ECTS, do i have to clear the code?
- 5 out of 6 plugs replaced, one stuck.
- 97 maxi, intermitent acceleration, RPMs drop fore no reason?
- popping
- a/c issue
- New to forum, Where to start?
- Lower control arms or just balljoints?
- RTH: Driver side axle installation help
- p0450 and p0466
- Oil in rear spark plug cylinders
- NEW TO THE GAME!!
- now this is clean, and an awesome color
- Vq35 sensors
- this squeak needs to GO!!!!
- MT or AT for VQ35 Swap
- 99 Maxima - Tranny or Torque Converter?
- I need a brake guru..
- p1320 code for my 1999 maxima
- Air Bag Light flashing and fail codes.
- Upgrades and what not
- Corner light (electrical problems)
- New body kits - built it myself
- FSM pdf file? NO VIRUS, please!
- Which Strut Mounts are better?
- Rear caliper bracket bolt dimension?
- wow my harmonic balancer came off and shredded my belt!!!
- Warpspeed Y-Pipe and cat
- H&R springs with 18x8 rims
- Aackshun's Long Start Thread
- auto shifter?
- Digital climate control swap
- oil still leaking after ......
- Source for electrical connectors
- Just got my 99 Max back up and running.. TIPS NEEDED!
- Cali Spec motors
- Which year Infiniti I30 compressor works for 99 maxima?
- how tos are down. how to rewire fogs?
- Steering pull after suspension install...
- so whats currently in your player?
- Fuel guage goes to half when the car is parked
- Broken Bolts In Foglights. Help.
- Oxy Sensor Replacement - where is it, any tricks?
- Nitto Tire Contest - Vehicle must be less than 5 years old to win
- need advice regarding oil change, synthetic vs semi vs regular, need advice?
- 2001 AE with 120k miles
- Recommend me an A/C compressor
- Need help with power steering pump belt removal
- LCA ES bushing life?
- Poll: I'd like opinions on spoiler options please
