- why you shouldn't let charcoal95gxe get drunk
- Brake Pad Question...
- Help Asap
- body kits: what brand, how much, where'd you get it?
- what to look for a in 96
- Front end rock chip protection..
- Blue Led Window Switches, Just Some ?'s About The Rears
- HAI installed - holy awesome
- Mevi results are in please read...
- Sts
- where do I buy a sports suspension?
- 97 SE Auto....Deal or what
- PowerSlot Power Slot Rotor (Style:Slotted, Finish:Silver) I got questions ?
- Smoked Cefiro's installed
- need help on checking my crank pos
- STEP IN :: 99'ers who did the led mod on their Bose.
- 60,000 mile tuneup??
- Adding Fuller Instrumentation to non-SE
- Couple exhaust questions.....
- what is this leak from my front left axle?
- Code 0510?
- Starter / Ignition Trouble
- Obd Ii
- Come help me make some custom catback decisions!
- Cheapest place for a knock sensor?
- Max has sat for 5 months: any precautions i should take before cranking ?
- MEVI question
- dome light
- Who has a factory service manual that can
- E-Brake Light Still On
- HELP: Everytime i step on the brake, I hear a clicking noise??
- RPM's go up, Coolant temp goes down...
- Older w/low miles or newer w/high miles?
- replacement of heated seat lights
- Rear camber adjustment kits?
- when i brake my clock dims and my gauges light up!
- Cuts out when put in Drive
- DIY Power Steering Flush
- Doing a tune up: Seafoam before or after new plugs?
- picked up 4 NEW MURANO 18's wheels for $225
- Looks or Go??
- Car will not start, no dash lights turn on w/ ignition..Need help ASAP Please!!
- Vibration from engine at low rpm
- uncontrollable speakers!
- Fuel pump maybe?
- car wont warm up, HELP!!
- O/D Button Not Working!
- Lights dimmed after crossed wires
- BCM power drain
- Just how much does the KS retard timing?
- DOESN'T TAKE MUCH TO MAKE ME HAPPY :>)
- Best riding lowering springs
- Y PIPE: 2 piece vs. 1 piece
- Hella projectors
- pics of 2 inch drop with bodykit??
- 300z calipers on ebay
- adjusting lights left/right
- Motostorm UPD folks check-in
- ring around key hole color change
- Resonator? For Stillen y, B pipes and muffler
- Has anyone replaced the stock radiator?
- Polishing Info Needed
- Short Shifter
- brightest reverse lights???
- Damn Car wash!!!!
- 99 maxima bumer on a 95
- Painted front grille PICS [figured out how to post pics x) ]
- would a faulty cat or evap leak cause the car to run bad?
- good way to prevent knocking?
- Bumper Lights
- Mass Air Flow Sensor
- Creaking and clunking from Upper strut...
- Magnaflow Muffler Part Numbers for 4th Gen
- Good muffler
- lug thread size?
- Should I do it?
- 1157 led bulbs in tails?
- Spark Plugs
- 4gen Video
- Programing remote
- Cigarette lighter help.
- New starter, engine light on?
- Broke my tensioner
- brake calipers roters
- Tensioner Nut Missing on Alternator belt
- TPS (code 0403) no MIL
- help with code 0407 (crankshaft position sensor)
- Can you put led in your AUTOMETER Gauges??
- How'd Your O2 Sensor Replacement Go?
- Shift kits for auto???
- Tein Basic Coilovers
- Choices!!!!!!!!!!!
- Engine hesistates during acceleration
- gauging interest
- Car needs jumpstart every day
- how do you hold the filter in place if you remove the lower half of the airbox?
- Engine Swap Questions
- rear sway bar installation
- AGX vs. Illuminas
- CF hood
- ur udp
- Tomorrow's the day...
- question about hawk brake pads
- How to remove antenna?
- Gen 4 Red Maxima?
- UGLY Auto Shifter (need idea pics)
- should i order these floor mats?
- Weird sounding on start up
- my air temp. sensor isnt even plugged in
- Dusting?
- Clock, power antenna, remote
- Weight reduction
- exhaust tone?
- InstALLED BOMZ CAI but ENGINE LIGHT CAME on!!!, have ***PICS***
- I have a question...
- good sale?? 95 max
- RSTB? Any difference
- plugs
- Exhaust setup opinions and price question
- Suspension parts
- hood hydraulic holders not working??
- those that know about manual transmissions
- those of you with aftermarket ECU's
- *pics* of my exhaust going on saturday
- Oil overfill question, please help
- Any tips for pressing wheel bearings?
- inspection question
- installing MOMO steering wheel???
- purpose in grounding kit
- Not much cash, best bang for buck????
- installing SS clutch line, need help QUICK
- keyless entry remote
- caliper question
- 95 Maxima GLE Start Engine in Cold Weather
- Transmission problem
- What should I do Next?
- What exhaust setup to get?
- Engine Bay Photos (chariot is down but not dead)
- Stillen y & B pipes plus Resonator
- HELP! headlight needs fluid change ASAP!
- next mod???
- how to replace heated seat switch blub?
- Help backing up...
- adding heated seats and side airbag, but wasnt an option before. possible?
- How much does it cost to paint stillin lip kit?
- About to hit the big 200,000
- 5spd
- HP Brake Pads/Rotors, or OEM?
- Strut problems help!!!!!
- Please Help!!!!!!!!!!!!!!!!!!
- Another Engine Swap "Pics Inside"
- Help finding a thread
- Maxima $250 Free Gas Gift Card Giveaway !
- Unorthodox Underdrive Pulley
- lost of speed, RPM jumping up and down
- engine,brake,oil...lights on...
- Coil Pack
- 5 speed or car switch?
- Stealth Maxima
- What do you think of this? What does everyone think?
- Outer Shell of Muffler is rotten?
- Granny
- Cefiro Projectors. need your opinions!!!
- tranny question
- ECU differences??
- Added leather on max
- Is it worth installing a cold air intake?
- cv joint quick boots?
- Where do you buy your OEM Nissan parts?
- MAFS problem, help!
- quick clear corner installation question
- Transmission problem?
- Knock sensor is in, what a pita...
- iac valve
- i've said good-bye to the noises and rattles from my front doors....
- Considering Selling My Max on Ebay
- Custom catback questions
- Hacked Adult Membership Site
- Battery Help???
- my 6.5 kappas wont fit....
- Cefiro Head light question
- Got Grounding Kit But No Optima Battery, Wht Should I Do!!???
- Blown head gasket or timing-chain?
- Should I get a "Fuel and Air Induction System Cleaning"?
- Oil Leak!!!!!
- Noise from turning....
- what other shiftknobs will fit on maxima ?
- HELP...How's the a-pillar come off?
- bad strut mount symptoms
- thinking about exhaust
- Sound System HELP!!
- Need Help adjusting belts
- 5spd conversion question RE: 3/4" spacer ??
- Anyone who purchased clear corners from ebay, need assistance...
- Airbag in seat!? check this out fellas...
- what kinda oil do you use???
- Please help! Whining noise!
- Replacing rear valve cover gasket.
- Quick Question
- flywheel question...... simple
- Rear exhaust ?
- So many questions!
- tokiko problem
- Just got 2004 Maxi 18's on my 4th gen
- Alternator replacement suggestions
- Updated cardomain page
- odometer only works when cold
- remote start
- what is the most super rice 9004 bulb out there?
- anyone still making the rear window shade/ spoiler ???
- PICS of TYC
- TYC's came in
- Psi
- Change Head Light
- fog switch(stalk)
- "StoneRacing" SS Y-pipe....
- Gauging Interest... in Clear/smoked replacement covers for clock/ac/boseradio
- Lost power
- Hub Centric Rings
- Exhaust question
- SP2 prices...
- No anti-rattle/returning springs (brakes)?
- Y-Pipe and Steering Questions
- What other cars can I get a 5 speed transmission from to replace in my 97 maxima
- resonator Q: getting my exhuast put on over the weekend.
- installed hi-flow cat, got smell
- OD light blinks, no codes
- My new 98 GLE *PICS*
- o2 Sensor question
- Need to know the part name
- Led Mod Problem
- Groaning on a HARD right turn
- LED Tails are on the car{pics}
- 99 Maxima Owners plz help
- Taillight idea's.....
- Homelink sunvisors
- low fuel solution???!!!
- startup problem solution!!!???
- Custom Exhaust people, listen up!
- superbrightled.com
- Anyone with Stone Racing Headers & Ypipe?
- Bad Idle and loss of power...sometimes
- Will i30 fenders fit our maximas?
- pretty cool
- convert seat to power
- need non-constant 12v source
- Will an Altima key fob work for a 4th gen Maxima?
- HELP...doing front end body work...
- Looking for a good job in the Bronx, NY area!!
- Strut/suspension problem? Not sure what it is...
