- Maxima cutting off while driving
- ID This Max
- Fourth Generation Subframes
- need help auto to 5speed swap
- Rear brake caliper pistons - where to find them?
- STRUTS - lots of hills and potholes - need new struts
- Where do I test for fuel pressure?
- p0400 code...
- code 21 ??
- Just bought a 96 Maxima. HELP!
- Who has competition clutch flywheel???
- exhaust noise??
- Trouble Removing Right Fender Bolts
- p0444 evap
- 350z exhaust
- MAF replacment and ECU reset..Help
- Skyline Bodykit Fitment
- Rpm Needle moving when cranking but no start
- straight pipe from cat back
- rear valve cover leaking on 97
- stereo replacement
- Whose old 4th gen do i have????
- Clutch!
- Removing Motor Mount?
- 1998 Maxima GLE to sell or not to sell after accident
- Pricing Question???
- just did a 5speed swap need help
- new starter fixes no crank no start issue
- replacing non-bose rear speakers
- Engine Cradle-Auto-Manual
- P1320 code after replacement of head gaskets
- 00vi guys step in here
- Water pump ears broke upon removal.
- 'Foulers'? 'Simulators'?
- Tie Rod Quality
- Custom 97-99 Tail Lights
- Need trans. Advice for a 99
- I30 Mud flaps!!!???? Help...
- car shuts off when stopping
- Should i buy these?
- I need help
- Is this symptom of too much oil?
- Rough ride
- 00vi parts
- wow!!! a $50,000 95 maxima!??!?!?!!!
- 95 GLE Noise Engine Right Side
- 98 maxima shuts off at 2500 rpm
- 00vi: a33 fuel rail connectors
- egr - rusted nut removal
- has anyone seen this?
- Replacing Rad/Water Pump/Tstat/Hoses + Flush
- How hard is it to replace the engine harness?
- Which transmission!?!
- Yet another DIY wheel bearing question
- MAF and no start?
- will 03 3.5 auto tranny fit 4th gen?
- Whats the cure for intermittent harsh starts in the cold
- need help maxima 99 a32
- no spark possible CKPS POS??
- Rear main seal estimate
- (I know) another Front wheel bearing thread
- Should I buy it?
- starter broke again
- knock sensor replaced but code P325 still there
- ware can i find a 140a fuseable link?
- Cold start up smell raw gas bad!
- will it work
- intermittent buzzing sound help!
- Where can I bring my car to get my timing set up right on my 3.5 4th gen?
- 1999 Maxima SE Subframe
- Replacing knock sensor on 99, vacuum thing in the way.
- 10 Codes after Changing Starter !
- how to identify drop springs in j/y
- I have a 1995 Maxima. Im thinkning about upgradeing the head unit.
- a California Spec. vs a Federal Spec. Catalytic converter
- white smoke+extreame gas out muffler+random miss fire.
- Help me set up timing on my new vq35 I'm dropping in? I'll pay!
- Groaning from Right Rear when brake is tapped
- Help with drivers side door after minor accident
- Car Pulls to the left HELP PLEASE!
- Desperate!
- idling a tad high?
- Ionic or Stillen kit with mud flaps??
- immobilizer key issues please help!
- URGENT! 96 rear (catalytic) o2 sensor thread size???
- new to the maxima scene PLEASE HELP
- 99 Crimson Red SE-L Bumper Light suggestion
- Gas sending unit all messed up? needle goes up and down
- 00vi: a33 LIM without AFC
- ionic dynamics rear window spoiler, painted & installed
- help with grounding kit
- Shift interlock -- car shifts with key out of ignition
- No spark, No codes, No CEL working
- Replace whole resonator assembly?
- When has your starter crapped out on you
- Please help me with my 3.5 4th gen.
- Who's exhaust clip is this????
- Installing two cylinder heads and TDC
- ecu
- Look at what followed me home
- How to remove a 100% Stripped Alternator Bolt?
- Anybody got a shop in jersey and owns a 4th gen 3.5?
- Maxima with straight pipe after cat, sound clip
- Could it be more than injectors?
- 1995 California Spec ecu?
- fixing my flooded 98
- 2000 I30 parts for 4th gen Maxima
- What 4th gen trans have you broken?
- which style valve spring compress
- Maxima Stops While Driving
- Dome Light LED
- Starter makes running noise
- STAGG SHS 4 STRUTS & VOGTLAND SPRINGS NISSAN MAXIMA 95 to 99
- Does the ECU case have to be grounded?
- Which Transmission is STRONGEST for the 3.0
- Need help with codes!!
- Can I pass insepction without a muffler?
- TX: Parting out 98 maxima
- Upper oil pan cover broken
- Cefiro water pump on Ebay...
- 1997 Maxima - Yellow/Clouded Headlamp Assembly Replacements?
- Maxima 1998 GLE Won't Start
- loss of power/ bad misfire
- valve cover
- 1995 maxima automatic
- 1998 maxima
- 1998 maxima fuel problems
- knock sensor
- ionic dynamics half size roof spoiler, painted, installed pics please
- Undefined CEL code
- Fcukn....Car wont start
- Pulling The 3oh Out Its Home..(Any Surprises?)
- Suspension Noise
- P0303 Causing me to go crazy here
- my new rad is cooking the fan assembly
- Transmission Problem Help
- not start,, starter? battery? etc?
- My 4th gen (pics)
- someone please help me
- 3.5 swap...Is it worth the hassle?
- 1995 Nissan Maxima mods
- Advice for dealership service issue?
- Another AC problem
- Automatic Hit Redline before shifting to 2nd
- Bad EGR Temp Sensor symptoms?
- Drop the engine or no?
- Air Intake / Fuel Delivery help
- Cassette Player & Sunroof Problem
- loss of performance (sometimes)
- ABS kicking in under normal conditions.
- OEM Cargo Net
- Inside valve Cover slightly bent
- What is this piece and how do i replace and or clean it?
- axles
- Jacking and supporting rear of 98 gxe
- grinding noise
- If you're pulling your IACV...
- timing chain tensioner gasket part#
- 98 MAXIMA SE 5SPD vs CHARGER 3.5L on a drag strip
- Larger Oil filters
- 99 max not starting after changing knock sensor
- need help!! new battery be drained!!
- Fog light install
- P0505 question!!!!!!!!!!!!
- What yrs '95 to '99 ft end body parts fit a '99
- no stock clutch pedal pressure in 97 se
- Reworked battery cables for my AGM battery
- Replacement key fob - aftermarket
- How to Install Blue tooth Mic
- come out to support my wife at nopi on the spring!
- Next step for 95 Max engine probs
- 1500 mile round trip
- purging air from cooling system
- Passenger side CV.
- Fuel Pressure Regulator - Video or Guide?
- Please Help! P0340
- 00vi cost/pricing?
- Heater Core Removal
- Which Alternator do I need for my Nissan Maxima 1997?
- 96 Maxima ebay catback and headers question.
- compression test engine outside of car
- ECI problems....electrical problem need help.
- Oil pan gasket question
- Fuse link keeps blowing
- Who does 3.5 swaps and is a proffesional in the tristate area?
- 1999 Cassette-Player to CD Player (non-bose) upgrade Questions...
- Alignment after replacing struts (Front or Rear Or Both)
- Heat goes cold when sitting at a light.
- 99 SE - blower fan runs at the slowest speed in all settings
- Deleted my Post ? Really
- where does this hose connect ??
- Anyone in San Diego interested in installing Struts in 97-Maxmia?
- dome light LED not working
- Seat covers?
- Have you replaced your shift knob? If so, post about it.
- Transmission replacment
- Engine code 0807 aka P0433 - 96 Maxima
- How to replace the serpentine belts.
- Installed Sensens, now having issues
- FCP Cyber Week Sale Is Back - Coupon Code Here
- 95-03 Cattman Headers/Y-pipes in production, order now with little wait!
- Ionic Dynamics roof spoiler half size!!!
- vq35 swap help
- I have a question, car wont stay runnin?
- Would you buy these ebay quick struts?
- homemade torque link (pics)
- I need a list of the things I need for TC job
- Hey new to Maxima's
- oil pans
- Redundant Max problem
- Ran Tranny dry....
- Transmission Issue/Only 95,000 miles
- what mods are there?
- license plate bracket and new license plate LED
- hesitation and backfiring
- No crank, no click, after running out of gas... how do you jump the relay?
- 1997 Upgraded Maxima for Sale!
- Cold air intake
- Switching trunk lock?
- what is needed for "basic tune-up"?
- Help me Diagnose my Tranny/Electrical
- seats
- Retrofit
- gad damn water pump...
- Extremely Loose Spoiler
- 5 spd Tranny Leak?
- How many LEDs do I need if I'm changing the gauge lights?
- Lowered
- New Headlights, Should I get these?
- What would you do about this leaky engine
- Hard Shifting and Car shutting off
- I have no clue.....
- How loud am I looking at here?
- I'm about to give up on this car
- Weird light issue
- A/c bypass question
- 97 Max non bose, bought bose speakers
- Reverse lights stopped working. I am worried
- Battery replacement in 4th gen
- Cannot disable alarm 1999 maxima
- straight cut gears
- Look what I installed today
- Issues Adding Up on my 95
- New to The Maxima Club
- Bad IACV?
- Bought a sweet '96 today
- rusted rotors and threads stripped options?
- Obx headers
- my latest youtube vid
- Water Pump?
