- Maximus Prime
- So my Chain tensioner piston fell down the chain cover... BIG MISTAKE
- Check engine codes 0201 and 0603...coils...how to fix?
- those who LED'd their guages
- Between idle and 1500rpms, I get a hard grinding sound from left side engine bay
- Heat wrapping WS y pipe to fix noise?
- Fixing the Clunking sound when making a right turn
- anyone else like cloth over leather?
- Anyone taken apart the gauge cluster before?
- Tail light fuse...
- CEL blinking steadily while engine is running
- Lmao! Sand Thru Intake
- starting problems
- loud sound from engine bay
- Thoughts on swapping an NX1600 Gauge
- Question about 95 Fed ECU
- Whos Maxima is this?
- Does a Deep evergreen look right with a CF Hood?
- JWT ECU RESULT
- Hesitation upon acceleration/revving...
- Wierd TPS and transmission problems please help
- Mevi Question..
- Can I get pictures of Engine bay grounding?
- Gate type Shifter
- shock and spring combos
- Shortened Shifter
- 4th generation engine monitoring thread
- stuff for sale.
- need help car wont start
- Short ram pipe
- post pix of your CAI
- Bose Display
- Changing E-Brake Boot
- can i have link on how to resize pix
- Red Bumber lights on Red Max instead of Clears?
- changing rubber trim on rear window... is it possible?
- torn between headlight options
- 97 Max 3.5 Swap...tranny upgrade...
- Suspension/rims
- clank-clunk from under armrest area over bumps?!
- Question on rims
- Custom Enterprise is back but do they still have..
- How about this Maxima taxi?
- JWT VS TS ECU Which one is Better for a 00 VI conversion
- Just ordered some Nex SS coilovers...
- Loose Axle Nut
- wtf.. pinstripe rant.
- 4th gen 5 speed sucks
- Help me set up a money savvy exhaust
- 1995 Maxima Diagnostic/tuning
- found a tsx projector conversion kit
- check engine light help
- 8 gauge Oxygen free wire. Where?
- OEM Stage 2 Clutch?
- stock ride height again?
- WTB: Trunk Spoiler ASAP
- Opinions on this chop...
- Hydraulic clutch 2nd bleeder/tubing question
- budget y pipe issues???
- Alternate intake that bypasses the MAF
- Rear Strut Tower Brace: what's the deal, here?
- Got 0302 EGR System Hi/Low Flow Code, Need Help
- Sabotage?: CV boot busted (2nd time in probably 50K miles)
- 4th gen. Tint
- Trunk Lid swap
- Show off your ***!
- what should i do with the headlights? HID? NEW bulbs?
- ok, wtf??????
- question about traction control?
- Warpspeed Y-pipe (I know, I Know)
- H4?? I don't get this....
- Anyone have a spoiler plug?
- Solutions for trunk/spoiler rattles?
- Gas goin up to much in NY
- Dual projector retro completed (pics)
- new headlights
- taking apart mirrors
- is tha pad ok!!!????
- check out my new sub-forum!
- Leaking exhaust gasket...
- Installing I30 gas release button
- y-pipe
- Ebay headers
- Am i just stupid or can i not find this?
- Weird cold idle
- Custom Steerling Whees Column Gauge Pod
- any Good Maxima Mechanics??
- REMOVING SMALL CORNER WINDOW
- High Pitched Front Wheel Noise
- MPG dramatically dropped...
- My hood doesn't line up (pictures)...and its pissing me off
- eBay clutch kit?
- Looking for the wire
- Need Help ASAP Please!!
- Installing New Exedy Stage1 Clutch
- rear end conversion
- After AE headlights........
- having problems with hid and suggestions?
- Car is dead! 1997- Maxima -auto
- Is my 4th Gen an SE or GLE?
- Is my clutch shot?
- Passenger axle
- ECU Flashes 0215 Why?
- Engine Clearance
- is this a fair deal on my tranny
- Yellow Top Battery
- red out ambers?
- Fan-assisted air box: another home-made mod.
- Should I get a VLSD or a low mileage open?
- heated seat switch + more
- y-pipe 95-2001 fits right???
- Pacesetter or Megan?
- front end problems....
- crazy brake light
- Which struts to get??? Need some advice
- Question about lip kits
- Urgent: A/c delete info
- att: Daniel B. Martin, I'm stumped
- how much is it gona cost to get a diagnosis on my maxima?
- Let's play "name that noise"!
- Worn Suspension Questions
- Tranny leaking!
- What is that part called???
- PROCLUTCH
- This is what an ebay clutch does to your tranny v. pics!!!
- 300ZX TT ENGINE CONVERSION
- What the hell is this crap?
- axle again???
- Going to buys some coilovers today....need some advice
- Got a code need some help
- ObdII To usb
- Replacing exterior door handle...Help
- Where to buy triple gauge pod??
- tapping noise in colder weather starts...??
- finally fixed my hard start problem
- need brighter fog lights!!
- rattling noise??
- Re did my niteshades.
- sudden loud idle
- Catalytic converter install
- cel from air intake?
- P0420 Code for CEL. Catalyst??
- I need a paint (KH3).
- All peeps on Tokico full suspensions... pics of your drops please!!!
- Confused on which model this is
- Need a new rear window defroster
- PLIZ HELP
- How good of a mechanic are you?
- Stay away from XTR clutch kits!!!
- Rear brakes hissing after rotor replacement
- 4th gen wont start
- Intermittent Starting Problem-Resolved
- has anyone done s2000 antenna on maxima?
- does your console look like this?
- Coolant Temp Sensor
- intermitten no-start on my 96 - starter tested ok
- Can someone get this ****ing code off my car
- New radiator leaking: manuf. defect or something else?
- Tokico warranty question
- Seats direct fit for 97-99
- How to add AUX in to stock 96 Bose? - FAQ link is wrong
- Transmission Dead, Alternative solutions?
- Hai guys! long time no see
- Reinforcement bar removal
- (NO start)need help ASAP. still searching.
- digital climate hookup
- Difference in drivers axle? Auto vs manual
- Is this a front nose conversion?
- whining noise after start up
- KYB AGX damaged
- changing y-pipe
- Mising Third Brake light
- AXLE CHANGING!!!!!!!!!!!!!!!!!!!
- G35 Coupe Seats In a 4th Gen
- cleaned the MAFS and TB, Now my mpg is down, and running rough
- Steering problem
- Damn, what a dissapointment
- Blowin' in the Wind
- Need Help...Tranny Problems
- EGR Delete
- Replacement Windows
- Spoiler Light Thread
- cone air fillter on stock intake?
- Opening Fog Lights
- Write-up for heated mirrors?
- what are these wires/connetor for?
- New Suspension KYB?
- Hard starting on 96 maxima
- MT lock or shifter linkage problem??
- Prototype LED Boards!
- Possible Clutch or Transmission problem
- Front End Bushings
- water leak
- A few problems and possible solutions
- Update on my car..
- 4th gen Brake light strip
- Bellhousing ?
- bad smell in cabin
- injector question
- Motor mounts
- power antenna issues
- BOSE cracks and pops, now completely dead
- FINALLY! 1997 maxima and got some Qs
- WHere is that red maxima with the gold 5 or 6 spoke rims?
- Need Some Quick help!! DE-K swap
- Seized Calipers?
- Spoiler Question
- hks twin fire ignition system
- What's new?
- which max to buy....
- cel 0803,1302
- ok so i replaced my alternator ..
- Engine "Gunk." Can it be used on a driveway?
- Suspension Suggestions
- CEL 0114 Fuel INJ Sys Right bank:rich
- HID blinked!
- Front Stabilzer Link -broke- replacing tips
- CEL 0705 (EVAP) and 0309 (Undefined)!?
- For Interested In LED Tails:
- Rewire ground by O2 free wire?
- part number for unorthodox underdrive belt?
- is the K&N drop-in air filter bad for your car?
- New struts/springs, now loud rubbing? :(
- LED mirrors (pic request)
- missfire at WOT
- engine trouble
- IAT SENSOR????
- Who has 15" wheels on their cars right now?
- Car Contest
- Crankshaft sensor on ebay?
- when i turn my wheel i get this really LOUD screeching noise
- Seafoam Question
- Here's to the nitrogen in the tires advocates: Video
- Flywheel Installation Quandry
- engine/trans question
- moving battery to the trunk
- Cant go into 4th?
- removing the AC evaporator
- need a new battery
- Downshifting into 2nd without giving it gas...
- Sounds when turning steering wheel..
- intake problem, need som help!
- DYI Red Taillights
- HELPP CAR WONT START BUT TURNS OVER
- GI: 98 SE Auto loaded minus leather...school bills FTL!
- Rewiring Headlights with relays
- battery dying?
- Need help: car just shut off
- So...who wants a gear indicator in the cluster?
- A.C. Compressor..... Falling off???? pic------------------->
