- Fast and Furious Maxima?
- 96 240SX - Shocks/ SPrings Interchangeable with a 96 GXE?
- What is the best intake for $200-300 ???
- 96 A/C Problem Help
- Trenze Valence Grille for 95/96?
- Spark plugs
- turn signal issues.......
- I have the basic mods....what else guys?
- how do u clean canister to get rid of EVAP codes?
- Running on bad spark plugs kill engine?
- MaxSpeeds vs. Sprints
- new site with pics and vids of my custom $15 intake for those who have not seen it!!!
- Aluminum Dash Kit, Need Help!
- Rim question
- most aggressive springs, excluding GC
- mid MEVI install - Lower intake plenum Q~!
- some mods i wanted to try
- fog light high beams?
- Help! Helicopter Misfire sound!!!!!!
- Throttle body...
- Ground control w/ KYB AGX combo...
- Gas Tank Pressure Issue
- Best springs for stock struts
- Who has a Remus?
- Best Strut Brand
- o2 Sensors.
- AGX question.
- Photos of chrome CAI installed and impressions
- How safe is an ECU upgrade
- Anyone have the 5zigen
- where can i buy a MEVI?
- wheel question
- difference of indiglo gauges 95-97 to 98+
- any NISMO parts available?
- In-dash 6 CD changer question
- How should I paint my tails?
- Buy Intake or Y-Pipe first?
- On 4th starter in eight years...What's the problem?
- stalling w/ 5spd
- 98 Max owners LOOK (Question Re: Alternator)
- new max in paper.. looks real good
- Tires
- My Project (Engine Swap)
- Alternator?
- No MAF No problem?
- Howto on 3 gauges under radio
- p0325 and p0324
- 96 Maxima SE Computer/Timing Chain
- This could be why my MPG was going bad.....
- Knock Sensor Replacement
- How many miles on your 4th gen Maxima?
- RPM switch stil isnt here! Probs w/ Harlan service
- Extra hose after stock extraction
- Aftermarket thermostat?
- Annversary Edition Headlights and Corners
- How much do springs and struts weigh?
- H&Rs or Maxspeeds?
- License plate light
- TPS question 96'SE
- finaly got my new max
- whats louder a CAI or POP+MID
- Got first maxima, got first troubles, please suggest
- why jwt?
- where are you?
- Lip spoilers
- anyone ever bought this
- About suvlights.com
- Carbon fiber dash kit?
- grille question
- Please Post Pics of Monsterflow Filter Installed...
- Finally, my exhaust is HERE!
- <--Pony Killer-->
- Engine light on!!! Don't wanna get ripped off!
- heating springs to lower car.....good or bad
- where to tap for gauge lighting and power?
- Can the cops pull me over for the altezas?
- Should Oxygen sensors be replaced in pairs??
- sprint spring questions
- pics of my max on 18x8 chrome wheels
- got a new car
- 1995 Maxima Blower Not Working at low speed.
- Finally got clear corners
- how to make duals....
- More sunroof problems
- Can I put a jack here?
- Basic Mods needed for an auto wheelspin?
- Finally! M3 Style Mirrors for our cars! Look Inside!
- Good Deal ??
- I30 springs and shocks interchangable?
- BF Goodrich G-Force T/A Drag Radial impressions?
- Red and Clear Tail lights for the 95 Maxima
- Engine Pinging question
- Congrats redmax007 for MOTM! Got a quick question..
- selecting tranny oil- does really it matter?
- Problems with the 5 speed... car buckling while in gear.. clutch slipping?
- transmission coolers
- Help with power steering belts
- How is the Autozone no name cone filter?
- for all u guys looking on a tire decision
- Buying a Maxima 4th Gen SE: San Diego and Escondido area
- Battery Acid is STRONG!!!
- Warpspeed Y Pipe and Stock Catback
- to all the engine guru's
- Is the regular pop charger cone filter compatible with PR CAI??
- New Pics of 30S Touring A32 S4 - Australian Maxima
- eclpise
- how do you get rid of road noise?
- Stock Air Box with aftermarket upper pipe? Thoughts?
- third brake light question
- Changing knock sensor?
- Anyone Have the Templates For 95-96 Fog Light Kit?
- Clear Spoiler LED Idea For OEM Spoilers
- Which grade of oil is best?
- Has anyone thought of powdercoating a Trenz Grille?
- so i decided to change my wheel bearing labor day weekend
- She's in the shop-New Skyline Tails Too!
- New Pics w/ 18x8 Evo5s!!
- Front O2 Sensor...ECU code 0503
- help with stock maxima
- Which clear light is better?
- HKS optional set up
- I just installed my y-pipe....big problems!!!!!
- 2nd gear lag
- Changing the Knock Sensor with DuckTape!
- New Knock Sensor = 1.2 Meg Ohms ???
- Question about speaker size...
- Karguy explains why our cars NEED NGK plugs!
- fuel pressure too low?
- tranny becoming less responsive
- 200+ keyless entry remote work with a 4th gen?
- Bad not to change suspension?
- 96 Maxima stereo issues
- Is a 3rd GEN MAF intake adapter the same as a 4th Gen?
- Help! Battery fuse blown!
- shift nob
- injen?
- Tire wear/alignment
- Need opinion (struts situation)
- Please help me post a picture.
- aluminum pulleys for Supercharger Kit???
- gear selector problem
- Is 2.0 drop too much
- Where to buy maxspeed?
- amount of boost on 3.125 pulley(V2 kit)??
- anyone riding on cut springs?
- shaving door handles? about door pop kits
- this max is complete (for now) pics
- Red/Clear Tail Light Problem
- How much did your 4th gen cost new?
- New sig pic H&R and KYB
- What site to buy springs at
- For any maxima owners who had a blue paint job--help me
- Bad things happen when parts fall off
- How does the lower CAI pipe attatch to MAF on PR CAI setups?
- Just bought a 95 GLE, questions.
- My car is missing the self diagnostics screw
- FYI on SilverStar bulbs on sale
- check this out..........
- What Do I Need With SC?
- max with 112k, is PENNZOIL oil for cars over 100k good or bad oil for my max??
- cleaning an after market INTAKE with WATER- good or bad ??
- jic's vs. cattman?
- hey
- Question regarding G2 Altezzas....
- New kit on CustomMaxima.com...
- trying to post a pic. please help.
- TB cleaning - i searched!!
- How to "red-out" your tails (especially for 95/96 owners!)
- Raced '00 prelude with CAI/Ypipe and without CAI/Ypipe.
- wiring diagram
- red clear- do it myself?
- Bad gas mileage....but ECU says nothing is wrong???!!
- New pics of my car! check it out!!
- Power anttena?
- my Malfunction indicator light is on
- Southwestautoworks.com NOW OPEN
- What's the latest on the Cattman Mid-Pipe?
- skyline headlight conversion
- new budget y pipes
- How do you pull engine codes?
- Loving the new Custom Mid Pipe....
- How will unlowered 17's look
- need help with set up on sprint/agx help!!
- I wanna hook my car what do you guys suggest?
- What kind of Headlights do you have?
- Finally snagged myself a Maxima -->
- how loud will a y pipe and cat make your car?
- MaxSpeeds with GR2's
- exaust
- PIAA Headlights
- Is that a Black Woodgrain Kit for our cars?
- any latest news on the frankencar?
- do you get water in your CAI?
- Car hesitates to start
- need some help on deciding which headlight bulb to get
- Lightened Flywheel Concern ?
- question about the MEVI
- I Hate You Guys!
- Dent removal
- when will the octane body kit be available?
- need some help on removing the defrost and hazard button
- 4th gen max sighting....GTRBlkMax97 is this you?
- turbos
- anyone ever paint your keyholes??
- What wing is this?
- Finally finished my Ionic Dynamics kit!
- Upgrading Headlight Hareness... Work?
- Taking of Decal stickers
- Anything I need to do before installing 18's
- what is ECU , I'm totally lost???
- CHEAP aluminum dash kit on EBAY, need opinion
- upgrading fog lights, higher wattage bulb?
- Suspension Q
- Camber Adjustments
- 99.5 fog rewire
- Feels like wheel wants to come off
- Are iridium spark plugs better than the stock platinum plugs?
- stillen
- Just Started Driving My 97 SE Today!!!!!
- climate control dash lights
- Driving while intoxicated =(
- New owner of a MAX...!
- sluggish under 3k rpms with SC?
- Tips on a Smoother Ride
- can anyone offer some insight where to find yellow fog bulbs?
- Where to buy NOS Flip Switch???
- Stock Plastic Kickpanels or Custom?
- should i just get another wireharness upgrade or piaa bulb?
- Please help -- Question about '96 Maximas
- clear lights
- will this y fit?
- Red/Clear Inserts inner and outter peices Now available
- Rolling on 19's god i love um
- Where you guys bring you car to change springs and struts if didnt do it yourself ?
- Pulled 4 CODES, NEED HELP!
- People with SC's
- 95 modded 5 speed max vs 91 modded 2 door legend coupe auto vs 95 m3 5 speed modded..
- Help! front Brake hardware kit has 6 shims. wtf are the2 shiny cutout ones for?
- engine code confusion, 0304 0302
- plugs were never changed....
- Rsb Stillen Or Adco?
- has anyone been able to go into the 13's N/A?
- Question about bushings?
- I think i need new brake calipers
- Need Both Airbags and Unit
- PICS of AIR RIDE r finally here......enjjoy
- Opinions wanted on exhaust tips......
- dead alternator
- Where to drill for headlight strobes!??!?
- What mods? need advice
