- Hid Q
- Brakes question price/quality/performance
- Clutch Fluid Reservoir Dry!
- simple belt question......
- anyone seen these "Pulstar" plugs?
- Car sputtering at idel in Drive..not in neutral though???
- Steering Wheel Lock/Key Broken in Ignition
- Fire! in a crowded... alternator?
- 2nd Time Getting Stuck
- Trouble Starting - Cranks Slowly
- Another Idle Problem!!
- Y-Pipe + OEM Exhaust or Catback w/o Y-Pipe
- Anyone Have One? Megan Racing NA Type Catback
- Power Steering Out
- what's the difference between projectors?
- Need some help here
- General LED Mods
- clutch not engaging after trans rebuild
- Wheel Bearings? Input?
- Electrical Issues
- List some members that Retrofit Projectors.
- I think I wanna go 300ZX front brakes...
- Corner lights
- brake fluid issues
- Integrate Aftermarket Alarm into IVMS???
- Hard Left Curves = Running out of Gas?
- need help installing y pipe CT
- ABOUT: HID kits in 4th Generation Maxima housings
- Im thinking of buying my co workers max..
- Ahh help with hazard light plug
- 3.5 Swap....DONE
- Serious Problem - Shifter
- Water Pump??
- 2009 4th Gen Calendar Extention
- An interesting Problem...
- car doesn't turn over HELP
- Anyone know if this y-pipe will fit my maxima?
- california spec cars differences
- Bleeding brakes which caliper first discrepencies
- Brake upgrade ?
- window tints or Y-pipe?
- fuel pressure regulator?
- Which belt squeaking?
- 1 PC R34 Headlights - Chrome vs. Black
- Problem removing water pump!
- Is there any needed mods in order to put in h3 hid kid on fog lights?
- EVAP Codes > Me. Yes another CEL thread.
- can't get rear hub off
- 95 Maxima tails tinted ?
- maxima code problems
- Warpspeed Y-Pipe HELP!!!!
- looking for front passenger side top strut seat and mount.
- does this part exsist in aftermarket?
- Will these Axis Hiro Rims fit on a 4th gen?
- dull lights how can i shine them up?
- Car stalls randomly, bogs down, hesitates
- 95 Max need help with Vafc
- control arm all the way to compressor oil leak
- carbon fiber vented hood
- Would like to thank that gust of wind today
- Replacement Upper Intake Manifold
- High mileage owners -- parts replaced to keep it running..
- EGR BLOCK OFF CEL Now What?
- took off the throtle body to clean it and omgg...
- New Electric Mod
- 5th gen steering column
- need rack and pinion which and where to get one
- Which RPM SWITCH do you use with your 00vi/Mevi?
- Auto Climate Control, cool air set to 84, warm air at 85
- cel light on but no codes
- Technical Serice Bulletins
- So I Bought a Y Pipe
- I have no throttle response at start up in D or R
- So i tinted my red/clear tail lights.. *PICS*
- maf question!!
- Can i use a '94 alternator for my '95?
- How to fix brake light
- Regrease New Starter??
- PIAA 959 install
- Cheapest place for a transmission?
- MEVI Parts list
- full warpspeed exhaust
- leaving my antenna on causes my battery dead
- Bushings trying to escape from control arms
- Thinking about going CAI
- What's My Max worth
- Exhaust rattle caused by Cat?
- Warpspeed Y-Pipe Install (pics)
- Bose is dead. Fix it or replace it?
- idle drops to 500 when shifting
- Yet another fuel filter change ?
- NEED Chrome Exterior door handles!! 98 Maxi
- 98 se auto vs 96 se 5spd
- My new Max...and an introduction
- Is it time to replace spark plugs? or engine issues...?
- Replacement Lower A Arms
- broken spoiler question
- trunk latch problem/question
- 125 amp or 110 amp..the difference
- should i buy this 97 5spd as a project car?
- headlight beam pattern
- Fog light screws broke...
- Transmission Leak help needed
- got a HID kit of e bay and what did i get?....
- Posessed door locks
- H tech in the front/S tech in the rear????
- Spark plug color(pics inside)
- How To: Get Rid of ANY Brake Dust
- Radio turn off by itself!
- fender flares with a purpose?
- snap clicking sound when slowing down with brakes or engine.
- Audi style 4th gen headlights
- Automatic HeadLight Control
- Road Rage Project
- key fob problem yes i did search
- 1st problem with the max
- can't get in reverse!!
- how do i change a ball joint? ( yes serched)
- Alternator might be going...
- Is $400 reasonable to paint stillen kit?
- Car lags off the line
- Replaced injectors, now car won't run...
- New clutch advice
- question about energy suspension motor mounts.
- where to get the fog lighjt bulb holding pin
- car starting to strangly vibrate at 60 or more MPH why?
- Door Wont Open
- 2 questions??
- what really frigin bothers me...
- No crank after heat soak
- FSB link bushings: How tight is tight ?
- HELP!!! confusion with 0807 and 0402????
- Less Expensive Paint Job Suggestions/Experiences
- Those of you with yellow fogs
- Smoked Foglights
- Knock and O2 Sensors HELP!
- Cruise control going weird
- Horrendous sounds turned out to be just belts
- New Gas car getting really good mileage
- Steering wheel "shedding"?
- help required.. Door is stuck closed and I need to get the interior door panel off
- Reverse lights keep going out...
- intake question
- whats the point of the intake snorkel?
- Sealing Headlights ??
- Jerk?
- 95 Maxima 190k miles...
- Lights Love Em but want more ....
- ebay headers and y-pipe
- trans prolem
- 98 Maxima high RPMs
- Finally got Oem G35 exhaust
- Clutch release ?
- New wheels: will they stick out?
- Front Strut bar link question...
- Any good OE type muffler suggestions
- Car stalling issues
- OE exhaust rusting out after 10 years.. what to replace it with?
- ECU Bad, Tranny going bad
- Rear License Plate Light
- Camera mount ideas?
- Maxima is US, Teana is Japanese?
- IACV behavior seems odd on my 4.5 gen
- brake hardware kit - extra
- Headlights lining up with the hood
- battery and brake light
- Your opinion on Injen CAI VS $15 CAI
- Rear wheel bearing or hub assembly?
- I think my hubs have gone bad...
- VQPower.com: IonicDynamics FRP Front Lip Review
- New Look Let me kow what you think .....
- where to get 5 speed syncros
- tps; feeler gauge
- Bad fuel injector
- yellow tinted fog light lenses?
- heated seat issues....need help
- Trunk Pop fix
- Exhaust Question
- New 4th Gen Owner
- Strange Vibration
- your clutch choice?
- Where is this leak coming from...
- vibration under accelration
- kinda weird..
- Trunk Light
- Effectiveness of a REAR SWAY BAR??
- Basic Front Strut Brace FSB Question
- a/c compressor replacement question
- 22's on the 4th gen
- 95 SE: New coil packs, plugs and injectors. Still getting 0701
- Clicking sound from brakes when stopping?
- constant beeeeeeep at idle
- Inside of front left wheel is grease stained.
- HOLY SEATS
- CEL question
- HELP ME:Rear axle is shifted to the left about 4"
- Help with grounding issue
- Quick window switch LED question
- Some kind of leakage??
- Need 62349 wheel center caps
- Are the Rad. fans multiple speeds?
- dek swap how to question
- car squeeking everytime i start
- Mini shoot after many repairs and replacements since May
- White (Crust Like) Residue Around The Front Blinks (Picture Inside)
- Blown headgasket, how far can u drive?
- ECU Code 0707
- looking to buy a 4th gen max..but have some questions
- ss clutch install
- Attempting to change the rear motor mounts....
- I want to do 3.5 swap.
- Maxima Door Start
- getting ready to do belts, what should i check while i have them off??
- quick/easy wiring question for a/f gauge
- IAVC Screw...
- Willing to Pay: Repair my DE-K swap please!
- anybody got this HU?
- Crankshaft Position Sensor code?
- car is shutting down
- Starter, Battery, Alternator or Alarm?
- got bored today
- Vafc TPS trouple shoot
- depth of axle seal
- fuel pump wiring
- Replace Water Pump
- cat back with obx headers and y pipe stock cat
- Teaser pics
- control arms question
- Damn Exhaust Leak
- Tranny slipping? odd problem
- Need help in installing HID's in 4th gen
- Alternator change?
- Foglight ground locations?
- Exhaust Question
- Defeat...
- Hood
- 98 boost sensor on 96???
- resetting car alram
- ECU reset?
- Bumper Signal Lights
- Good deal?
- Swaybar bushing some BS
- I am about to do my driverside axle ...
- "clunk" noise when shifting into first. cause?
- need pic of stock spoiler not mounted
- High Flow or Cold Air
- exhaust set up
- Max not starting....
- HELP! WEIRD STARTING SOUND/PROBLEM
- HELP! my belts are burning
