- lower caliper mount
- Car on Ebay
- front axle nut size? 98 i30
- Bleeding Clutch issue. Help please
- misfiring
- help replacing my gold-pkg center caps?
- Accident: Lady ran stop sign *PICS*
- Good CatBack Exhaust for Around 350?
- Front crossmember question
- What are these things
- need some diagnosis opinions...
- Megan Racing any good?
- Does this sound right??
- Crossfire wheels
- 300 Rotors for sale
- Brake Light On
- H3 vs. H1
- High pitched sound after brake replacement (HELP)
- Cheap Buy???
- Knocking sound when AC is turned on??
- This guy said Maxima guys are jealous of Infiniti guys.
- Climate Control Only Works On 4
- Paint or polish transmission?
- Need some help with the clear corner lens..
- Ac compressor
- Weird question on remote
- Tune up?!
- Does this look like a fog light wire?
- This isn't NORMAL.HELP!!! (Serious Inquiries only)
- Anyone photoshop these on my car please?I think they will look HOT,8$ for a good pic?
- How notchy are 5spd shifts supposed to be?
- UDP with a 2 Amp system
- How tell if cali. or not?
- lowering question
- Transmission problem options
- 97 taillights. How long keep them in oven and what temp??
- led mod question for the pro's
- SO....i figured out the clanking noise i was hearing....
- drop in air filter
- Finally broke my engine in
- 1999 Brakes Maxima
- Price for cv joints replacing?
- got new stereo, need help with dash kit
- NEW Item made for 97-99's. Yellow Fog Housing
- Bsa Or Voxx Wheels?? Quality??
- Bye Bye Wilwood - Hello AP Brakes
- 00VI Question on $$$
- Timing Help??
- Would Someone Mind Doing a Carfax for Me?
- Suicide Doors
- 02 sensor
- O2 sensor - Front and Rear
- Need Help w/ 1895 Bayonet Map Light
- are ypipe flex sections repairable?
- My Clutch Hates the Summer! TO Bearing? HELP.
- hi-flow cat
- Need help on rear brakes...asap please!!!
- $30 Retrofit project for a friend
- Idle increases in any gear....
- 5spd swap HELP!!!!
- ebay control arm
- Front Vicious Limited Slip Differential?
- Help! Front Doors
- suspension gurus please enter
- Horrible Steering Wheel Vibration on Highway. Anyone else?
- lightening effects on a dyno???
- Cut or pull transmission bearings?
- How do your guys think about the following quote
- Key Stuck in ignition on 5spd Swap
- 1995 maxima fuse list
- 5Speed Swap Completed, Big Brake Kit also Completed...
- Knock Sensor replacement
- window visor
- Big Problem!! Need HELP! Tranny Experts!
- NE1 know MaxedOut99SE's cell number?
- what r the best spark plug for the 4 gen?
- Air suspension vs Stock
- Knock sensor totally new idea!
- raybestos ceramic?
- Tracked the Max at MSR against formidible odds
- Wiper Blades Streaking
- need help!!!
- Weird Sound After New Muffler -- Help!
- Camber question
- Odometer stopped counting?
- Will the 97-99 red/clear tail light fit on 96 rear ??
- Quick clear bumper light question..
- bomz cai
- ebay generic coilovers?
- If anyone can photoshop these on my car Id really appreciate it!check out these rims!
- Cruise control doesn't work after the 5spd swap
- Intermittent wiper doesn't work. Fix??
- ECU not letting me pass SMOG
- My pass. side axle is seized. Please help.
- will acura wheels fit??
- HELP!!! 00VI install
- Why do foglamps cost so much?
- Greddy Sp2 Fittment ?
- Small Leak A-Pillar Driver Side
- good website to buy BRIGHT hyper white bulbs
- Need Help ASAP w/ Transmission Problem
- P0705/ code 10 03 and 11 01
- This will throw off your timing (56k take a walk)
- Mysterious Smoke from under my hood
- factory alarm going off on its own
- Fuel Pump? maybe...
- tail light problems..
- 300zx with vq30de
- where to get lower ball joint
- How to disable day time running lights?
- HELP !!!! Transmission problem....
- pros and cons of bigger rims?
- 1995 SE w/ 5 Speed Curb Weight?
- i30 died while breaking
- Unorthodox Underdrive Pulleys...who's got em?
- Anyone use exhaust wrap?
- VQ35 swap
- step lamp out
- Socket size for changing knock sensor
- what do you guys think about my new wheels
- 350z 18" wheels
- Phase II or III fenders - bring cooler air into the intake?
- AC blowing hot air
- Spark Plug Tube FILLLED with oil!
- ac and front window defroster not working
- Suspension install question....
- Half my electrical system is not working
- 1999 SE-L (Production number)
- PIC request: black max with oem headlights+superclear clearance lights
- Need help with my aunts car-failed inspection
- What's my max worth?
- Ball joint and/or lower control arm?
- 99 max misfire
- What size center caps will fit our cars?
- Crashed my car this weekend...
- fuel pumps
- Door moldings/protectors
- How much does a rebuild cost?(On Avg)
- New wheels+tires *pics*
- stock shocks vs aftermarket??? help??
- Need Quick Help to anyone with a couple of minutes and a clue
- finally buying a 4th gen!
- Car runs like crap but no codes HELP
- A little help guys.
- Looking for 95/96 rear bumper
- thumping from RR, and smooshed parking brake cable..
- Firestone Brake Service Quote, Need Suggestions
- Converting Clearance lights into blinkers
- cant get ECU out?
- Test pipe?
- Replacing Struts.....Need advice
- Would these fit my 98 Max exactly?
- black smoke on start up
- Beeping Alarm
- Exhaust HP amount?
- How much $$$ to replace bushings up front?
- Where can i get OEM Floor mats or close to..
- Seats swap
- springs to pair with illuminas
- rear window wind deflector
- Shake Shake Shake...Brake Brake Brake...
- help, my car sounds ricey as F***
- Failed Emissions Inspection - "Not Ready" Status
- 97-99 Rear Conversion (95%) Complete. Pics inside.
- 95-96 owners with CAI, step inside.
- AC Fan slows down on long trips
- Need some advice with my cooling fan.
- ECU fuses blows!!!
- how do i tell if my shocks are shot?
- i just slid off the road 10 minutes ago. what do yall think
- Spark Plug pics?
- intake + y-pipe + high flow cat = better gas mileage?
- front struts
- hood pins - are hayame brand okay to use?
- brake calipers
- keyless entry question
- My car smells like gas
- Testing Ignition Coils
- alignment after ball joint replacement
- Fuse panel diagram
- Fuel Pump Fuse Blowing!!!
- Sloppy Steering
- Air Bag Light?
- Radiator support rust out
- Best clutch kit??
- ALTERNATOR FTL ZOMG My Brake and Battery Lights are on
- Bad Struts or Bad Bushings?
- Steering issues
- Ive joined the 5 speed club
- question about evap canister please
- Parts disaster! Need help!
- De-Lining Glass
- Should I Keep My Chrome Wheel Fender Trims?? 5 PICS
- gasket for y pipe
- programming home link again!!
- ignition question
- rear wheel rolling resistance
- Nissan Quest wheels-- any reason they wont fit?
- Crazy Shaking & "pup pup" Noise from exhaust
- BBK Installed Pics (56K Make Dinner)
- Motor Guys...step in. Misfire
- Recharging A/C
- headlight problem ?
- Sway bar price & installation
- Check engine soon light....
- full size CF roof spoiler made by IONIC DYNAMICS!!pics! pics!
- Gauge Cluster
- ECU error code 0412 or P0134
- Homelink visor signal very weak
- cost for shop to install exhaust
- Can you lower the brake pedal?
- Need New Brakes for under $800
- Tranny Problem???
- SS Clutch Line install help.
- CEL code = 14 05 WTF!?
- what's the best brake upgrade?
- Programming visor garage opener
- Cold Air Intake Owners
- check it out 95/96 owners
- EGR valve replacement
- **Interior Swap Questions** Help!
- Need Suggestions, Get a car or not!
- help..how can i tell if i have abs?
- Oversized brakes with stock components.
- BBK/Suspension Install **56k no way**
- what type of ngk plugs to buy
- My brakes suck... step in if you can help
- ran out of gas, car won't start after refueling
- Are These BreakPads OK?
- Stereo does not work - Fuses?
- allignment after axle replacement ?
- Wut exhaust setup to go with??
- Mitsubishi Evo 8 Enkei's on 4th Gen
- NISMO wheels
- PICS: Bad wheel bearing + Hub + ~2k miles = ....
- Another 99 calispec question
- 5th gen. muffler ?
- Spitting in muffler right before it reachs idle
- replacing Steering wheel
- fog light aiming?
- wheel alignment
- AT howls when cold
- Ran my brake fluid dry, cant bleed!!!!
- morning start up question?
- New cat??
- Engine/Exhaust is getting buzzy
- Looking for ECU will all work
