- Grille Tech Inserts...Quality?!?!?
- New pics with B&G drop
- want to change the gauge lighting but not sure if I can...
- Is it worth it
- Throttle body looks horrible!!
- problems with PIAA foglights
- sounds coming from exhaust
- Air filter adapter? and Factory keyless entry
- got my car back
- 5spd shifting feeling/noise...help please
- REALLY cheap interior mod
- Starting Problem and CAT
- LED to illuminate console/shifter area
- Just got a call from aamco... my auto is sick
- 5 speed conversion brake pedal
- need your feed back (pics)
- '99 Center Arm Rest
- Hyper Black RIMS?
- A/C Compressor question
- Muffler hole(?) Q (and hopefully A)
- Got a Stupid Ticket !!!
- Tires for 98 GLE
- Powerslot rotors for the maxima
- wheels or full exhaust and coilovers
- Help me convince my father
- Which part number for the H&R Spacer Kit
- 10 feet of spiral cable wrap enough?
- IDLE out of wack some times
- No One Will Install My Gauges!!
- Help a new guy out with some advice
- C&D Long Term Test
- Check out new website!
- I30 Front end Maxima converstion
- need help
- NEWEST MOD, 75 HP...well worth it.....
- winter sucks
- Brake selection...
- where to buy all clear tailights
- Has anyone had the pleasure of
- I30 engine in Max? Are they EXACTLY the same?
- Quick bodykit Q
- Blue Fluid in clutch res...
- 02 engine in a 95
- what is this called?
- carfax please
- funny noise from engine compartment
- Blue LEDs in switches
- anyone know were I can get HID's for a good price
- keyless entry still won't work
- Those of you with the RVM UDP
- brake pad help choosing / install questions
- Do 350 Z rims fit the 4th gen Max? 18's.
- Need a pic of a front Lip for 97-99
- NGK Copper Spark Plugs
- Find / Suggest me matching bulbs....
- Do they make a molded aluminum dash kit?
- POLL: Calling Everyone with KYB AGX STRUTS: What Settings?
- how much louder will it be w/ a b pipe?
- should i buy this + carfax plz
- People with sprints and cold weather...
- tranny problem, always at start up
- car heats up quicker...
- Template to install spoiler - need one.
- 97-99 Grill
- insurance claims
- Installed Energy Suspension FSB & Endlink Bushings...Thoughts and Pics
- transmission resistor switch
- Still chasing a rough idle problem
- Performance and rear heated o2 sensor
- exhaust is 2 loud
- Keyless Entry Help!
- '00-up Sentra Headlight swap?
- Transmission Fluid
- 1999 SE stock horsepower
- Starter
- Problem... Need help!!!
- Keep Euro tails on or go back to stocks?
- How much more power with this setup?
- 97 GXE squeaks up front
- Undecided...
- Problem with Spoiler, comming loose.
- What is a knock sensor?
- Grille tech opinions
- Brake Service..
- Hard Starts: Tranny to Engine Grounding??
- Carfax Needed, Please
- Keep blowing headlights
- 5Speed Problem
- Where Can U Buy Stock Fog+headlight -bulbs-
- Hey everone check my ride out!!!
- o2 sensor help
- Question about fog lights
- for those with 97-99 maximas who really want true cornering lamps...
- 5th gen wheels
- 5th gen wheels
- A few pics of my custom/painted grille.
- Do i need to bleed my brakes if i install new rotors and pads?
- good deal?
- Help...Auto-tranny question!!!
- PHOTOSHOP....Side sills onto my i30....
- ~Talkin Quality Tires...
- 4th en body kits
- bumpy ride...
- Maxspeed spring on stock or aftermarket shocks?
- Good thing i didn't drive or else max = caput
- Stupid B&G springs!
- trunk floor
- God damn Whislting Noise!!! (Getting Closer)
- Cruise Control...?
- AHH!!! My Exhaust Rattle Is UNSOLVABLE!
- Where to buy All Clear APC Tails for 95-96?
- Need help with my Tire Presure
- alarm doesn't go off
- main frame of 95-99 maxima
- warm air coming from gas pedal area
- Search not bringing up info...
- Spark Plugs
- maxima got damaged or vandilized
- Which tools for bumper
- 5spd Transmission problems --- Please Help
- Rattle in my rear end.....
- Apex'i S-AFC With JWT ECU??
- Baseline dyno - 190 tq - 180 hp
- Weird noise after starting???
- 27.3 Mpg
- Stickers anyone?
- Alignment problems
- Question about downstream O2 sensor vs. upstream
- Rough Idle
- gunmetals GEN II altezza ?????
- Stripped tranny oil drain plug -- PICS
- Key ring LED
- Interiror bulb
- No mods :(
- Nice Vids
- jdm CEFIRO emblem for your rear!
- Custom Maxima
- Red Clear installation question
- Bomz Cold Air Intake, Any Feedback Yet???
- Compression Test completed
- REPOST: Bumper lens mod : completed (Pics)
- HELP! i shaved my a s s
- Altezza Housing for red/clears
- Bose
- 4th Gen's with 5th Gen's Spoiler
- Diff Bearing price...
- HELP IN North Carolina!
- Cooalnt leak
- Tranny question...down shifting at higher speeds. (Long)
- Brake squel
- 97 Maxima Front and Rear Caliper Pins Same
- rear sway bar question
- odometer/tripometer not working - just dunno
- Buying an I30 infinity 97 ,need all info abt the car
- 97 Auto - 96 5spd conversion questions
- whats the part of hood shocks
- Pics of 17x8 Evo 5's ??
- I Need Help Fast
- I Never Get My MAXIMA.ORG Stickers ??
- looking for 97 fog lamp anti-theft screws
- Top Line ??????
- can't shift my 5 speed
- did i blow my bose speaker?
- Help! Should i buy a rebuilt Max?
- ECU specialists: Need help deciphering serial number on ECU. Confused, Mishmosh?
- Sunroof Sunshield Off its track - Help?
- nissan "majorly" backordered on wind deflectors?
- Y-Pipe, Cat, and B-Pipe What brands?
- If I get an exhaust, which one???
- locating the speed sensor
- Squealing noise when I press on the gas pedal at 40-50mph
- Who's max is this?
- My Tip Fell!!!!!
- New Window Tint!! *pics*
- Check Engine Light-Sensor
- ****ing Knock Sensor!
- air/fuel ratio
- Basic question about 95 GLE
- rewire 97+ clearnace to be like 95/96...?
- Carputer install?
- New pics of the Ionic Dynamics wing mounted on a 4th gen!!
- Major problems with a 96 or 97?
- Weird thing with our Bose units...
- getting new suspension soon, some ?'s
- Transmission oil leak stopped ??
- advancing timing
- Might do Red Clears tomorrow.
- Install Question?
- Everyone please read, Need help
- Shifter Problem
- OBX Cat-back exhaust system- PICS!!
- Installed front rotors...How the hell do you do the rear?
- Anyone with H&R's using Camber bolts?
- Y-pipe vs MEVI.....what's better?
- More Power?
- Remote
- Fog light modification
- Quick CEL Help.. Please
- Just bought a 5-speed!!!
- {I Cant Believe It!!!
- 80k today, maintance for my car?
- 95 Headlamp fit on a 96
- 2000 engine in my '95
- I need help, How do you................
- bad smell
- Clutch Install Price!?!?
- Choke any way to make it work?
- tick tick tick sound in car
- power steering hard at high rpms
- Im Back Again
- Speedometer and O/D Light
- Hybrid
- putting 17's on my max...
- spining gears after ACT Clutch :)
- R/C Maximas????
- Hanabi 8000k installed.
- is my tranny going?
- Eibach OR Sprint?
- Are all 4th Gens PRE WIRED for heated seats?
- Has anyone painted eyelids directly on their headlights?
- Transmission Oil Question
- Worn out steering wheel? Ideas?
- any opinions on the k&n oil filter? its got antidrainback...
- steering box leaks
- Oops, broke a stud on my spoiler
- clutch leak? Please help
- rpm spike during start
- 220 to a tank???
- LED's in climate control
- Mesh the 2 bottem pieces
- How long do OEM O2 sensors last on average?
- Bearing PLates and Struts need to be changed for 97 MAX??
- 99.5 Front Strut Bar
- Help! Herbie Love Bug Syndrome !!
- whats the best OIL?
- downshiftin for autos? heal-toe for auto?
- eibach, kyb setup question
- red/clear tails with red side reflector... could someone please post a pic?
- 4th gen 'maxima' sketch
- After all this, is the VI worth it or nah....
- Rubbing with Intrax and 17x8, how bad is this?
- Weird Starting Problem !!!
- Some guy ran into my Maxima :(
- Question about headlight adjustment here
- how to install a knock sensor and drive belt
- Help my car is eating starters
