- Ignition switch installation
- Heads up display
- new pads and rotors.. ftw!
- Brake Pad Questions
- fuel pump question
- intake hoses
- 300zx seats in a max?
- 99 max GLE wheels going to 04 350Z enthu wheels
- Weird sound when turning the wheel
- Replacing Seat Belts
- 95/96 owners: who babies their car the most??
- Changing the Oil Pan Drain Plug Washer?
- Knocking Noise coming from Front Passanger side when in 1st and 2nd
- Memoirs of a new Maxima owner
- OK, so how much will I be spendin...
- Ok guys I need help this is driving me crazy.
- The Tranny Trick Drop Resistor
- How much can I get for my Max...?
- intake question
- rear wheel bearings
- Can't get calipers back on with Hawk HPS pads
- Small Mods, Few Pictures.
- Problem Changing Fuel Filter
- Custom Enterprise Closed?
- does SES light come on for 60k service?
- High rev's that important?
- Not Your Typical Intake Question Thread...
- P0420 (0702)
- Waterpump replacement Sucess
- I need seats...but what?
- David L Taillight R.I.P. - Next best light?
- Removing the black plastic cover that is covering the side view mirror bolts
- watch out for this scam
- Advancing odometer
- part numbers for seals
- Search doesnt work, Auto to Manual question
- need a better ride
- cant figure out these 02 sensors
- Can't find access to upper rear strut bolt
- Repairing a MAF
- Guys looking for chrome inner door handles...
- Exhaust in my hood?!
- Transmission Bolts
- Just found out: My 97 Maxima is really 97 Nissan Lego ?
- Need some help. 2 flat tires
- ideas for shrouds for is300 projectors in 4th gen fogs
- @#&*@#$& Tranny leak
- A/C Help - Temp Selection Switch Not Working
- Bad gas mileage. Please help. =)
- strange knocking
- what would be the best oem Bose deck
- Taking apart rusty exhaust bolts
- SFC's are available!!!
- Windshield replacement
- air intakes
- Stock Bose Speakers
- Dimming lights
- how many miles possible?
- clutch problems
- I've had it with my max
- Max Vandalized!
- Why did Nissan not use the VQ30 in the Pathfinder?
- NOPI Nationals
- 1995 Maxima GXE Hard to Start
- Stillen Sound Clip
- website request
- Shifter Bushing Part#???
- anybody ever seen these rims on a max
- So I'm thinking about buying a Y-Pipe
- 95-96 Grill with a 97 Front Bumper.... Please chime in
- so my car turns of after i race?? what the hell?
- Wheel diameter + Speedometer question
- Time to say good bye…. How much should I ask for my Max?
- D2 coilovers... Anyone interested?
- Looking for a black or carbon fiber hood for my 96 max
- rattle on hard accelaration
- High unstable idle after cleaning IAC
- ok this really is getting obnoxious...(strut 'top hat' bolt)
- Failed CV joint?
- Weird noise, sounded like air seeping out
- 97-99 taillight harness
- Cat. Converter or O2 sensor causing hard starts?
- Losing MPG and quick.. read!
- Slight dilemma, need advice
- Is there anyway to fix Urethane?
- Ripped seats. uhhhhhh!!
- S F C Review Thread
- ProLong any good?
- Annoying little thing
- cabin air filter?
- Tranny problems??
- Deft Racing CF hood
- Knocking noise coming from driver side....
- Car Wont Stop Running - Help Please
- PPL who have replaced/rebuild their auto-tranny step right in
- stock throttle body size?
- License Plate Lights
- How to pull engine wink
- Knock Sensor....to replace or not
- Rubber parts around courtesy light switch (door switch)?
- Lugs coming loose. Don't know why.
- turbo kits on ebay?
- What parts die regardless of miles?
- rear main seal
- cv axels??
- Knock Sensor Code not clearing?
- Thanks for all the help
- 4th gen /5th gen
- misfire, fuel injector replacement, no start
- Turn Signals Don't Flash when Locked with Remote FOB
- MAF sensor needed ? ? ?
- water pump removal help....ASAP!!!
- 00VI, 4th gen TB w/ stock intake- anyone?
- How f*ucked am I
- Cruisin 4 Taylor Car Show - Jacksonville Maximas
- 96 ECU in 95?
- Rear 02 sensor
- Motor oil in Air intake midpipe
- MPG Increase (Proof)
- hubcentric rings
- Momo Shift Knobs
- Need Help Removing Seats
- Next Best Mod?
- Lug Nuts Question
- lets see your exhaust 4th gens
- i hate ECU codes how do i fix this one tho?
- 5speed swap question
- 1pc headlihgts review!
- Best way to install an OEM spoiler?
- No muffler at all LOL
- Soft brake pedal feel
- What to look for when buying a 4th gen
- Timing Chain replacement?
- how easy is to change the power steering fluid?
- Illumination on Auto Climate Control Buttons Stop Working Again
- HOW TO: ADD HEATED SEATS & Interior Overhaul
- White Smoke From Exhaust
- Problems with 5-Spd
- Wheel Lock Fitment
- Is it Repost day? WTF?
- O2 sensor 2 BANK - 1
- Creaking noise only at high speeds?
- New Clutch: Am I hosed? Grinding noise while accellerating
- I tried to but it in maxima disscusions but i couldnt so...
- what does this code mean?
- Burning smell on highway?
- Mysterious Battery Drain ??
- Low idle,stall on startup-fixed!
- Which 02 sensors typically fail on the 99 Fed-spec cars?
- 00VI vs. MEVI
- 99 coils got the best of him
- 2200 Km road test.
- want to hear exhaust vid... sp2 and cattman headers
- Rear Sway Bars
- Taillight Removal
- key value clutch?
- Greddy SP2 Clip
- the clutch and flywheel of choice
- MEVI installed with Technosquare ECU
- Finally did my knock sensor
- Question on cleaning my Head Lamps
- Wheel Locks
- brakes sticking
- Should I opt for Alignment with Slightly bent front sturt
- RPMS hang up then drop...5spd
- Squeaking noise in the rain
- Pics of Sterling Mist with CF Hood
- Oh just wow... v. Midas techs are morons.
- HELP with weird tire leak
- Seafoaming...what Are The Benefits And How's It Done???
- rear strut tower bar?
- Fog lights burned out by HID kit?
- Aftermarket antenna?
- Air bag light blinking
- Oxygen sensors
- I need quick help (oil pan problem)
- power steering belt
- eBay rotors
- custom enterprises?
- how to break in new clutch/FW?
- I Sold the Maximas
- Gas tank pressure
- Spark Plug question
- cold start sensor for 1997 Nissan Maxima
- exhaust question
- ecu question
- code 1003 help!
- AC Problem
- Oddest shenanigans today... read inside!
- Can't find TAM screw
- How hard is it to change A32 accelerator cable
- Advise me on prospective purchase
- ☼☼ AC PROBLEM, Help please!!
- studdering problem - MAF sensor - Please help
- Where to get flex sections?
- Whenever I go over 50mph
- Tranny/Drive Shaft Issue
- stillen body kit out of shape
- Check out this video (poor max)
- Apexi WS2 (97-99) owners... help!
- Am I missing something or...?
- Changing Break Pads and Rotors - Which ones to chose?
- Feedback regarding ebay tails needed...
- NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
- Demand!
- So i got another one under my belt.....
- 9004/9007 conversion
- Screw missing on ecu, cant pull codes
- Got a 2nd car while my max gets its tranny rebuilt.
- 96 EVAP system question
- Need advice with changing strut / jacking up the car
- steering wheel "ding" noise
- Violent shaking below 2500 rpms.
- code 400 egr..........
- Which Clutch would you recomend?
- 5-Spd Gearbox Trouble
- need quick help (workin on car now)
- cattman headers
- *video* of my 4th gen with Budget B & Y Pipes & Greddy SP1 Muffler
- Can someone do a quick photochop to my wheels?
- need help wiring heated seats...
- High pitch squealing in reverse
- got some serious issues
- vortech v1 SC
- Drl..
- Bigger throttle body
- New suspension - clarification questions
- Mice... i've got mice help
- Differential Question
- Taking another leave of absence from the org... Iraq tour #2
- Yooooo Two Codes And Im Mad!!!!!!!!!!!!!!!!!!
- changing rear rotors
- Front axles
- I did something pretty stupid today... need help!!
- Warpspeed vs Budget Y-Pipe
- alright, i feel like a complete meatball. (wipers)
- Painting interior
- Tranny w/ Auto Cooler Only
- question about so-called "Performance chips"
- Recharging A/C
- Car stalling / Rough Idle
- My R34 retro - not done yet
- Change black transmission fluid or not?
- Which OEM rims for a 97 Black Max?
- left headlight socket keeps freaken burning out
- good rubber maintenance
- No A/C again
- Gas Tank reading issues...
