- Bose speaker specs...
- Bearing makes noise. Need some help.
- Moderators PLEASE do not delete!! HELP!!! need answer, i know someome knows!! HELP!
- tranny
- Worth it to part out?
- Clearing Codes
- Ive finally joined the family... pics included
- Which looks better...pics
- K&N Air Filter effecting MPG, negatively?
- Drop After Illumina install Settled + random pics
- Washer fluid light is ON
- OD light blinks intermittently
- 35% Tint
- condensor?
- Caster/camber alignment nightmare HELP
- now what
- Cheapest place to buy replacement motor mounts?
- Should i replace my existing engine with a newer one?
- Knock sensor harness
- Pics of new TYC tail lights
- Are these good spark plugs??
- What color would you change your Max to?
- rear sway bar????
- Maxima98 takes to much Fuel
- aluminum dash trim .. where to buy?
- timing chain seal leaking oil ? how much should it cost to be repaired ?
- 96 maxima won't start
- What difference did you notice with SS brake lines?
- Hit pach of ice, kissed a curb, bent control arm, need advice!
- SpeedyCarParts - Import Parts + Free Shipping + Upto 60% off Deal Prices !
- Discount Radiators from $89 !
- Sticky Odometer
- CF Hoods...Yes or No?
- Shakey drivers side door mirror
- NEW 4th Gen?????
- Whats your idle in the morning?
- Curious -> Cost for a dealer to replace your water-pump?
- coilovers for $52?!?!
- Timing Chain Replacement
- Headrest install Questions
- car got hit today! would this be HIT and RUN? what can i do?
- 97 Max. alternator under recall?
- CD Player is horrible...stopped working
- anyone know of an injen knock off cold air intake?
- How do you adjust the trunk torsion bars? Make trunk swing open..
- Ebay Tokico vs Custom Enterprises Tokico Springs
- Will 5th gen springs fit a 96gle
- Eibach Pro & KYB GR2?
- Crank position sensor.
- why: Dies on start AND times of hesitation on highway?!?!?
- totalled 97 I30 base
- Remus exhaust
- My new Nissan Maxima QX
- cf dash
- need help starting problem
- What sensors are these?
- oil leak thats ruinin' the driveway
- Woodgrain Dash Kit Pieces
- Magnaflow exhaust
- tachometer
- changed front valve cover gasket...
- Position of HID bulb shields
- my right headlight is WAY off, looks sooo akward
- Boreddd...Just some random *pics*
- Wouldn't this be tight?
- Door sills
- would you guys recommend the superflo model warpspeed y-pipe?
- Other Trannies?
- Here are *pictures* of my accident on Friday, think its totalled?
- Name ONE thing you dislike about your max.
- i need a waterpump
- Installed 01 Tranny In 95 Now No Speedo
- O2 sensor HELP
- car drops rpm's
- Car overheating.....well kinda
- New jack or ramps or what?
- CEL codes: 0702, 0703, and 0705
- hesitation and stalling
- wrecked my max, anyone have a clue on part prices?
- do i have too many miles to mod?
- Pacesetter exhaust...
- 95 Maxima Electrical Problems
- Check Engine 0707 question
- 95 maxima electrical problems
- Tokico HP
- oil filter absolutley will not come off
- sportcompactonly/southwestautoworks promo code?
- sick of doing my climate control. bulb #'s?
- Non-corrupt or broken link for a chilton or Service manual plz!
- Can a bad camshaft position sensor cause my car not to start?!?!
- Dies On Start
- reset switch for door lights?
- Probably selling my (FULL) mevi...
- What suspension????
- What are the exact differences between each 4th Gen. year?
- Can anyone give me info?
- What do i need to fit 04 max rotors?
- I hate car washes...
- Will '97 headlights fit a '96?
- Rear Calipers
- Illumina suspension settings & Drop ?
- ECU Reset Time
- cannot find how-to's on replacing power steering and alternator belts
- heated seat light went off, cant find post from last week
- Brake light
- 02 Sensor Help
- what clutch kits everyone using
- Need help with my KS harness
- Puddle Of Oil
- arggg wiring problems and fuse problems.
- replacement antenna
- Camber/alignment problem
- 3rd gear lag
- warpspeed exhaust
- aiming fog lights
- New pics of everything
- HELP: I have no heat in my car
- MEVI help Pleeease!
- how can i tell which y-pipe my car needs
- Battery Draw when car is off...
- Bah, wrecked my car... is it totalled?
- Ball joint change, please help
- No heat!!!!
- working link for a chilton or nissan service manual?
- bose problem
- Will not pass smog!!!!!!
- lights won't shut off
- how often do u need an ALIGNMENT?
- carbon fiber cover for front valve cover
- New setup
- putting 99 gauges in a 96
- Code 205 - Idle Speed Control
- Max Pics Under Ice!!!
- Parts for nose mask?
- Cat-Back Set Ups
- cefiro how to
- help please
- Coilovers from ebay
- custom maxima y pipe & service
- Stainless Steel Brake lines
- Will a shifter from a 94 auto work in a 99?
- hazard flasher removal
- alternators and starters
- Dek 00V.I.
- buying 7000k HIDs, please help me before I screw up :(
- wiring diagram needed for guages
- what does the IAC valve look like
- beam patterns the same?
- Bad CV Joint noise but it isn't the CV Joints??? Help!
- remote start
- taking off the dash
- Hazard lights aren't working...
- Carfax report needed
- slight knock under clutch/gas
- got new brembo rotors, should I resurface them?
- anyones trunk noise beeper mod stop working intermittently?
- 95 Maxima Engine Ticking Noise
- Accord vs. Maxima.....56k heck no...cable maybe
- *mad* Mitsubishi coil packs discontinued????!!!
- Need Help Installing Skyline Body Kit
- Russell Brake Lines????
- ? about 97-99 bumber conversion
- Samsung SQ5 - brother to the Maxima?
- Crankshaft pulley factory oil seal
- Se-L: how limited?
- Power Windows, Doorlock Problems
- Anyone with slotted and or crossdrilled rotors?
- Seat Belt Question?
- Total '95 / '96 Maxim Sales Numbers???
- Deciding on which bumper to use...
- Fog Light Rewire -- what wire to use?
- KYB GR2 struts
- Knock Knock Knock on wood? kinda long
- motor numbers
- my tranny has been acting up latley... is this a problem??
- CRUSHED a ACURA TSX last night
- can this be done?
- Problem starting in cold weather; rough idle!
- Transmission Mounds
- Have 2sell Ms. Maxie
- Choices for sway bars/strut tower bars/short throw shifter?
- will I need to enter her...from behind?
- Time for new motor mounts??
- Interior door handles removal
- tint laws i think someone asked about this
- Steering vibration finally gone. Yeah!
- My new 4th generation isn't as tight as my old third, is it me?
- Strong gas smell from vents....
- Maxima exhaust system
- 97-99 Grills work with 95-96 Maximas?
- 97-99 conversion almost complete inside and out
- ...regarding the check engine light
- Plate frame
- anyone buy this y-pipe??? Header wrap on Y-pipe???
- Headlights slightly dull/cloudy
- Thinking about getting a 98 GLE
- Strongest 4th Gen.?
- advice on how i should buy my exhaust
- Advice on hard start, even when car is warm
- Heads being Ported?
- Cams?
- Go Back And Add Mod?i
- Lost Control.... =(
- fender crushed
- someone broke my F...ing window!! need help
- P0505 Aicv?
- Knock Sensor
- 4th Gen. Bose TO Video Replacement
- bump stop on front spings
- Woot! got my es bushings in..
- Valve body mod
- Chrome Trim Around Wheels on a 99 GLE
- in car laptop?
- new pics of max
- Help with Tranny
- Who bought a stillen lip?
- Some kind of electrical problem...I think...
- Help....... what muffler should i get??
- HELP! Codes P0325 and PO745
- EGR, Fuel System, & KS problem
- 1997 Maxima Airbags and sensor install, any tech links?
- Post Trunk Setup Pictures
- My battery dead? If so, what type of replacement?
- Sarona Body Kit Ver 2 - Anyone tried it?
- G35 exaust
- Where can i get performance parts for 3.0l nissan engine?
- Obx or Greddy need advice plzzz....
- dynomax turbo
- Time for new spark plugs
- HKS cat back exhaust
- max not sarting up on comand??
- Looking for any pictures of OEM muffler with aftermarket tip. Thanks
- Oil Cap
- Intake question, need opinions
- E-brake light stays on
- Rust Proof Warranty??
- my security light and alarm doesnt work
- Trunk opening problem..both "trunk popper button" on drivers door and keyhole, help
- rear strut top bolt help
- Will 99 bumper cover fit 96?
- Did ur BUTT DYNO work after KS replacement?
- Writeup for 95/96 red/clears
- Do you think the max is reliable in general?
- What is your Clutch and Flywheel Set up?
- shocks / struts
- Whining from transmission when moving in first
- black dash with tan interior
- Power windows are the bane of my existence.
- 01-04
- Any Benefits From The Oscai?
