- I am putting black leather seats in my Max with tan interior.
- Exhaust from hell...
- Better low end??
- Des Moines Maxes?
- Better low end??
- Trouble with starting the MAX
- Well, I went to the car wash today...
- Frankencar Intake- K&N or Apexi Filter
- engine swap
- Another garbage clutch WTFwtfWTF
- 95 tail light assembly replacement
- weird idle...help
- has anyone made a led taillight mod writeup yet?
- CAI to Hybrid conversion
- My max is making a cracking noise not like a popping noise when i take off help!
- help! electrrical problem
- Swapping Open Diff to LSD tranny...do i have everything?
- Ballast Location...2000 Max
- pass smog?
- Ignition Switch Bulb Replacement
- Reasons to replace 02 sensors?
- VG vs VQ
- Clutch Problems
- re upgrading ground wiring
- Rewire Alarm Beep Louder?
- Front door panel removal...
- Idle RPM on 5-speed? Also, speed to RPM in different gears?
- tune-up question - spark plugs
- Trying to locate previous owner
- Z32 fuel filter in Max
- Air Bag Light on Solid, NOT Flashing
- Where are all of the jack accessories?
- Camber kits for Sprints..
- Harsh ride on new I30t- Change tires or springs?
- Adjustable Air/Fuel
- Power steering rack replacement
- need pics of a white max (or any max) with grill mesh.
- How Late is Too Late??
- Quaife ATB
- How to change power steering belt?
- best catback systems out there!
- Throttle cable adjustment.
- I'm one of the lucky MEVI owners
- How to change the Fog light Bulb
- MY smoke cefiros with jdm bumpers
- Cheapest place to buy JWT pop
- Oil Leak!
- Battery Group size?????
- VQ30DE Exhaust manifold idea
- Please Help Me on 02 sensor.
- Need help with grounding.
- Dropzone struts/shocks (anyone using them)
- brake grinding...help
- 4th gen owners rejoice-Tein to release the Basic Damper kit!!!!
- Idle question
- Cali spec Y pipe
- Great news and bad news...help
- what should i do w/ my lighting?(clearance light,side marker,and blinker relocation)
- TPS Switch
- Has anyone test n tuned with a lightened flywheel ?
- EVAP fault
- Maxima stalling out helppppppppppp!
- ECU Code 0505 1996 Canadian Maxima... ?
- my rotor replacement story
- Need Your Opinion; I Have To Make A Decision Early Today
- Mevi
- $3200 allowance to repair
- any mods to increase air flow to brakes?
- help bad coil?
- computer/ks question
- Lambo Doors
- Exhaust question.
- exhaust hangers
- Intake Banging
- **New Pics of my Red Beauty! Check them out...
- Installed GREddy SP2 Cat-Back.
- Transmission Shopping List - All you need to know about swaping or upgrading !
- running problems
- What Can Be Polished??
- warpspeed y o2 sensor problems
- Are these brake instruction we use WRONG?
- Knock sensor replacement without intake removal?
- need some help
- Wiring Diagram Question
- Check out my drop! Did it myself!!!
- $120 to install a Y PIPE!
- newbie ?'s in Y-pipe install
- Whatever happened to HLH0501
- correct way to add resistor to knock sensor harness
- Where to get MEVI parts
- Is there a bottom-up diagram of the Maxima Exhaust system with the names on there?
- Tall drivers with B&M
- Cannot get muffler off!!!!
- new rotors warper in the box
- idle problem?
- Maxee's back ... back again ....
- Front Left Htd 02 sensor heater
- Getting gas and CEL
- lowering my max..dont kno what to buy
- 800 miles left to hit 30k. Maintaince Questions
- **PICS** Black Chrome Clear Corners for those who are interested to buy these **PIC**
- Car doesn't Idle right after replacing both front O2's
- a/t computer
- sticks are bad
- HO alternator??????????????????????
- Brake pads?
- What do u guys think of this shift knob on my current interior?
- Need Help, Clutch Won't Go Into Gear
- B&G Springs
- What could make my BRAKE light come on this morning?
- A such thing as a "QUIET" Y-Pipe? Is it GAS FRIENDLY??
- Corner light rewire/ Melted the corners
- Drop Res Mod = CEL ???
- CAI Template
- Noise when I travel over bumps; Help
- Plugs
- auto 99 gle to manual
- Tokico or Tokico ?
- How To Remove 4th Gen Door Panels - Quick Guide
- Stupid question... but how to align headlights?
- Repair, Tune, and Cleaning Advice on a 130k 95
- *wow* Ks *wow*
- Re: Helpppp!
- 97 Fixed Antenna, suggestions
- I want more power
- CAI-prove my friend wrong
- serpentine belt?
- SE vs. GLE suspension
- Problem with odometer???
- Dual exhaust
- Hope for ECU afterall
- ebay RSTB
- New pics of the max
- Who knows what this engine part is?
- CRX claiming to beat anycar
- Haters and Thieves got me today
- Shopping for Fog Lights...Advice?
- new tranny and intake need help qwik
- motor swaps
- looking for info on:Line Pressure Solenoid Valve (Automatic Transmission)
- Sorry what size socket do i need for the MAF to get it off the stock air box?
- For Y-Pipe DIY
- y-pipe; bees in a can problem fixed without exhaust wrap
- Max makes funny noise when in reverse?
- 99 SE How much?
- Air Bag Light Blinking
- install help stillen side skirts?
- Clock And Climate Control Color Change
- eatrice zone bodykits question?
- where to buy resistor for KS
- Armrest
- Which one is faster, Auto or manual?
- high output alternator
- Exhaust/Power/Noise Solution???
- shaving door handles
- friendly-manner discussion: which intake has better throttle response?
- smoother shifts on tranny?
- removed intake manifold...something isnt right
- Dash Trim clips
- o2 sensor cleaning
- What do you think of this series of Error Codes
- What does replacing the PCV valve help?
- grill removal question
- moonroof help please
- how to reset ecu? Looked in the how to...
- mpg's
- O/D light blinking diagnosed
- Is this the IAC Valve???
- HELP Check Engine Light
- Cardomain page not there...?
- 3rd brake light broken...ideas?
- Rattle From Broken Gasket?
- Knock sensor replacement (search not working)
- MAxspeeds and gr2s installed ;0)
- Which muffler to buy?
- Stupid Y Pipe
- Why do people get big brake kits.
- how do i take off the center pillar?
- Reverse Threads
- O2 Sensor
- just bought BOMZ hybrid intake off EBAY...what filter should i buy?
- are these chrome handles legit?
- Total $ for interior blue leds.
- carbon fiber hood
- is it just me
- I need help to locate a fuse. Please help!!!
- * Is it Safe to clean the engine compartment? *
- Who here has a torque coverter?
- getting MEVI parts and... What is this thing?
- HomeLink garage opener...
- redline second gear??????????
- Wheel bearings blown?
- I need to get new carpet in my max, is this possible?
- What will intake add??
- Wheels are peeling (literally!)
- Pics of the new I30t
- Pics of 97 SE w/ paint and rims
- 1998 bose stereo wire color code-HELP
- Auto or 5-speed
- Suspension Issues.
- Radio Installation
- blue...clock and climate control
- cat gasket
- frankencar full intake help
- Where am I supposed to lift hte car/place jackstands?
- Ground Control Coilovers
- Need Rear Suspension help..Safety issue
- Problems changing rear brakes.. help!`
- Need suggestions on tensioner nut removal.
- spoiler mounted third brake light
- spoilers?
- Stainless Steel Clutch Hose?
- cylinder 3 misfire
- just got dual exhaust
- NEone hav pics of Stock Dustboots???
- What is a/the IACV?
- removing power antennae mast --- HELP!
- need sound clip of y-pipe
- Where can I get a dash kit where the piece below the vents and clock piece are one?
- any MiNNESOTA MAXIMA owners?
- Blacking out Tail-lights
- ECU code- P1446
- quick body question....
- Best type of intake for an automatic
- MT leaking
- need measurements of spare wheel cover
- Whos got sub-frame connectors?
- Problems with KS and EGRC Solenoid
- Un-responsive brakes
- Cooling Fans will not turn on
- Mitsu or Hanshin Coils
- Guys w/an A/F gauge
- Extend Keyfob range?
- Power Steering
- Upgrading suspension; ?'s
- 98 Maxima Vs. 2000 Civic SI
- * Any Help, Tips, and Opinions of Budget Y-pipes and b-pipes *
- Went to the track in the 99SEl tonight
- has anyone ever blown kyb gr2's, agx's, or tokico illuminas on eibach's before?
- Y Pipe install question
- Strut Bars
- Omg!! Car Totalled!
- Oversized chrome window trim ?
- HELP!! CLUTCH is leaking fluid
- MAF ground
- Selling my 96 GXE center armrest
- Good and bad stuff
- Check this out!!! (KS)
- Clutch!
