- Problem with trunk.
- Ok 225/60/15 or 215/60/15
- Power Steering Follow-up
- Retrofit auto climate control
- How can I keep the OEM springs and struts?
- CRAP! Someone ordered my new engine!!!!!!!
- Trouble starting-once
- belts replacment help or advice...thanks.
- help, grinding noise
- springs for maxima...
- cv shafts
- RSB Opinions (Addco, Cattman, Stillen)
- filter size for bomez cai??
- Noises from engine wheel area please take a look.
- Programming keyfob / Another Key
- rear door panels
- OEM Shocks must go...................
- Question about my car
- Hankook Ventus HRII H405 or Kumho ecsta 712 or 710
- i am going to recharge my air cond. where do i screew in the tube?
- hmmm, what do you guys think about wheel spacers?
- Help! ECU Codes 0107, 0605, and 0804
- Question about test pipe to replace cat, and get new b-pipe
- replacing all lights in the front of my car, what are the names of the bulbs i need?
- MEVI Owners: Do you use a RELAY or NO?
- Need Replacement for Clear guage cover!
- Sunroof adjustment
- fstb question
- ecu code 0508,
- Rear strut bar?
- Man Something is Seriously Wrong
- Best
- Paint taking a beating
- Cornering lights available?
- CEL on for the first time..
- Just another example of why civics suck!
- How long the CEL stays ON?
- ECU code 0215???
- Pic's of joseph and I after wax job
- Sprint vs Progress Springs
- Just completed 60K service - and tribute to maxima.org
- Bodykit???? uhg
- engine rebuild
- jdm stuff
- Re-setting computer?
- pics of dual tips on 4th gen max
- Front lip spoiler
- Need some help w/ spark plug distributor?
- Vanishing Oil
- alarm beep
- Clock Stopped Working!
- Yay! Fixed my clear corners
- MEVI vs. 2000 Intake ???
- Amsoil OIL filter help needed!! ASAFP
- I need some advice on lowering my car..
- Couple of Questions
- LED Rear Brake Light ?
- symptoms of a bad.............
- Remus Muffler
- Losing braking at higher speeds
- question about indiglo qauges
- I finally got my MAX!!!!!
- Car won't start help!!!!!!!!!!!!!
- Wig=Wag lights
- Flywheel question
- Official Picture Thread
- Alternator size
- hey i'm new
- how do i tell trim model
- Advise...ECU 0304, 0705, and 0309
- the lights are out...?
- Waxing the max
- Having prob changiong spark plugs HELP!!
- Taking it off
- Glove Box Dimensions
- cutting rotors
- Omg What Happened!!
- H-Pipe ?
- 17 inch tire size recommendation
- Front grill
- Removal of Dings, scuffs, etc
- best alignment spec
- maxima or wrx
- Wreck
- SE tire size
- Where to find color code if it's not oem ones??
- Changing most of front end, what is necessary.
- apexi WS/greddy SP catback users ATTENTION!!!!!!!!!!!
- To everybody that has already converted to 5 spd
- best cat-back for the buck?
- what's the best intake that's quiet?
- Frankencar Mid Pipe Install
- Too Much Resevoir coolant?
- Skyline R-32 Mirrors
- Finally a bath!!!! (Cleveland winters SUCK!!)
- Slotted or Crossdrilled??? Hawk Pads??? Opinions wanted...
- I wonder?
- Is there something wrong with my Fog Lights?
- Governor or not???
- Air Cleaner Diagram NEEDED
- Please Help. All My Guages Are Not Working...
- sprint or intrax
- New pics of my car
- Indiglo Gauges
- Should I challenge my friend to a rematch?
- Anybody Got Any Pics?
- Fog Lights
- Headlight question
- is it okay to fill cracked motor mounts with polyurethane?
- car hesitating / missing at about 3500 rpm
- Help..........ALL MY POWER SWITCHES DONT WORK NOW MORE!
- does a cai actually make a big difference?
- Addco Installed impressions.
- Check out my new homepage(new 96 SE 5speed)....
- 15" Tire Recommendations
- parts list for rear brakes hardware kit
- EVAP valve error code woes! HELP HELP HELP!
- Fuel Hose Size?
- 97 SE gauge cluster
- price of diamond cut clears??
- can Ypipe Flex Section get damaged?
- change to premium fuel at 110,000 miles?
- High pitched whine?
- Alternator's shot - who makes a good replacement? Need It Yesterday :o/
- Raced shaved Bimmer
- Need help changing ECTS (engine coolant temp. sensor)
- Stolen Stuff from car....
- Write-up for replacing a starter?
- ECU code 0303, 0304: Front o2 sensor and knock sensor
- Fitment issues with energysuspension ?
- PCV valve pics
- Clearcoating Rotor Hats??
- Ground Control Users
- Installation of after-market power antenna
- Cruise light
- HELP -- Air Intake part missing
- Finally drove a 5-speed 4th gen
- KYB AGX and Sprint combo question.
- Changing rotors
- 94 SE Max vs. 95-99
- Slipping something in the drivetrain
- Dropzones and free rims (pics)
- Pedals Stick/Unresponsive
- Body Body Body Kits...
- Question about FrankenCar install....
- Smog Check....
- Weird creaking when accelerating from the front left spring
- Question about a creeking when start to accelerate?
- Wings West 95 Super style spoiler on 97 Maxima SE
- Custom Mounted Gauge, Check it out:
- What taillights should I get?
- Question about UDP?
- Alternator belt screaming at start-up..
- MEVI Guts pics??
- what's up with power steering?
- possible starter problem?
- Do You Want To Dimmer Your Indigo With Stock Dimmer?
- adding oem fog lights on '99 GXE
- Odd Fan Noise
- 5th Gen Muffler vs. Greddy
- Things to replace when installing new springs/struts
- 1 & 2 ok 2&3 ok 3&4 ?? IACV prob's
- K & N drop in air filter... oiling question
- MOMO Shift Boot
- Warm Weather and O2 Sensors
- "How To" Sites
- Need help fixing CEL codes - 0705 0903
- remedy: left bank injector lean
- Installed RVM pulley today, question
- Part Numbers for Brakes!!
- ? about Seat replacement matches for 98 SE Maxima
- New Rims
- When Do You Guys Shift
- hesatation from stop lights
- Just my $.02
- I'd like a pic of a 95 max 3/4 red-out and smoked tails
- I dynoed pretty well...
- I am a donor- PM or email me if you need a search run.
- List of who makes which modifications for the 4th generation Maxima…
- Blinker mod how to?
- Insurance Company/Thieves
- Interior electrical power
- Site sucks without search function...
- windshield crack again!
- Question about tires
- Am I making mistake selling Trenz Valance?
- Quick Question About Brembo Rotors and Axxis Pads
- New Cat
- Transmission going Bad?
- Things I learned about engines
- cruise control problem
- Knock sensors universal?
- People Without Trunk Keyhole.
- Will the improved suspension travel from motivational rear mounts prolong strut life?
- Question about tire size
- Do I need a Ca spec Y-pipe?
- ABS and sunroof optional on 99 gle?
- Help Please Car stalling
- Poor Man's Hai
- ? about TRUE cornering lights for 97-99
- complete all 3 O2 sensor location pictures!!!
- 5speed guys- question
- Need Your Approval on 18x8.5 offset 40
- Y-pipe
- Intake manifold bolts- torque specs please
- Climate Control Face Plate (w/ AMB)
- Test Fitting
- Stock Y-pipe pre cats.
- headlight fuse for HID
- jejeje bmw 328, and gran am GT smoke my a...
- one question please help
- How to keep hood up...
- brakes
- Dealer's Manaul
- Tail light swap?
- A new front axle?!
- Whats the deal with Headers?
- Need help with EVAP valve/system and knock sensor
- New Headlights, Need suggestions ???
- Flowmaster 50 series.. sounds nice!
- Jumpy Brakes?
- Help with IAC valve OHM measure results.........
- Wheels - Question
- pics of my new gauges
- Narva Bulbs
- Are These Rice?
- Stillen muffler shakes back and forth, what to do
- HELP! W/ New Tach
- Want less drone? Move that Tailpipe
- Yellow H3's
- upgraded wire harnesses
- LED Turn Signal Mirrors
- check engine light ( Malfunction ignition light) codes mean?
- sticky accelerator pedal
- Yellow HID??
- more power...ideas?
- Zip tied shift boot?!
- CEL code 0111 HELP!
- Anybody have maxspeed/Agx gr2 combo?
- Spoiler brake light (and new member here)
- THIS IS INSANE! No sig pix. No search. Calling all 4th genners, send your $$$
- **Racing seats***
- Brakes?????
- 15's-17's
- Lowering without struts side effects?
- Storage above front ashtray
- complete budget systems
- my max isnt totalled!!!!
- pulsating gas pedal?
- guage lights
