- How much is for the both CV shafts?
- Suddently.....Is it time to die? UPDATE
- Both fog lights out?
- Megan Catback and Warpspeed Install - Pics
- Got some new rims, let me know how you like them...
- Need a mass air sensor where do I go?
- gr-2's
- WOW, BG is GREAT!!!
- Fuel Pump question?
- Whats this hole for
- For those have upgraded Stock Speaker wiring
- anyone ever adjusted their belts?
- Crazy to replace the whole dash?
- Those with carbon fiber hoods (a little help please).
- 98 i30 engine swap???????? please help
- Center Arm rest replacement
- Red Instrument Gauge needles
- Polarg or any brand lights???
- My Antenna Wont Work!
- what happened to the MEVI faq?
- anyone replaced their rear axle?
- Complete (A) piller triple gauge pod needed
- HID Problem
- What's YOUR Favorite Setup?
- I need a midpipe, what are my options?
- please, show me the link on flushing transmission fluid
- Urethanne problem 2 **with pics** (56k beware)
- best fuel treatment?
- 95 Tail Light options
- Suspension
- pics from Infineon (sears point) HPDE - my whip looks good in new shoes
- New Rims on my Max: Pics (56k warning)
- Is it normal for the coolant to drain below min in 4 months?
- Top speed of an auto?
- Is My Clutch Dying???
- Angel Eye Type Mod...Comments Plz.
- 4th Gen Pics
- oxygen sensor ?
- hey y'all
- i found one ! Read
- How often to change rotor and fuel filter?
- Front O2 Sensor
- ECU help
- Hey
- drop resistor.. bad??? help
- How Do I Change My Spark Plugs?????
- transmission blown
- need ideas with my spoiler
- cheap new mod for 5-7 dynoed horse power
- For those of you who have the infamous starting probelm
- TCS and SLIP light constantly on, and 0201 CEL (multiple misfires)
- Anybody ever get the cel code ignition signal circuit...
- Need New Engine like yesterday
- Please tell me someone's heard this noise!!!
- Which wire do I cut for the Drop Resistor??
- Purpose of Hood Lining?
- MAF adapters...
- Moved my amp cable and moved my intake, car runs better...
- how to move engine?
- Cruise control problem
- Focus that thinks he can beat maxima's!
- head light problemo
- Urgent! Fuel filter replacement... Fecking nightmare!!!
- $3000+ to spend
- engine weight?
- all motor?
- Buy Question
- Driver's Side Floor Mats
- need some quick help on a Tranny question
- how much is my max worth
- cd changer
- battery died?
- A/C problem
- Ebay Intakes - Which is what knockoff?
- Immobiliser or NEVI Reset or Bypass
- Low Fuel Light
- Anyone ever replace the carpet in your max?
- Rear heated 02 sensor
- Will this actually work?
- slow???
- Odometer not working, what could be wrong?
- Check Engine Light and Hot Weather
- manual to 5 speed...whos done it?
- Service Engine Soon (0903) EVAP
- HELP !.. Engine power surges, stalls when at low RPM's, not constant but annoying
- Just pulled code please help
- A/C problem, alternates between cool and cold air
- what kind of 1/4 should I expect.....
- where to buy stillen front lip
- Just bought a 95 GLE..
- do the ebay intakes/CAIs replace the rubber accordian(sp) section?
- I did some REAL stupid ****....
- Clicking noise-acceleration
- Oil Pressure Sending Unit Leaking
- Oil On My Spark Plugs!!! :(
- Confused by Weapon R
- :lightbulb:
- Another "stick" question/comment
- thinking about going custom with magnaflow
- red clears huge problem, help quick
- Auto Tranny Buzzing Sound?
- Maxima Acting up
- check engine light
- What kind of aftermarket rotor styles are better to get?
- Get scratches out of gauge cluster clear plastic
- Custom 2.5" exhaust :)
- Interior Lights Out - HELP
- changing the belts?
- Anyone have a Topspeed SS muffler?
- Name of bushing and where to buy
- Miss at idle when hot
- What do you think of this max? Good deal or no?
- Knock sensor resistance!!!
- Insurance offered me this for my wrecked max.....
- problem searching this forum?
- modding driver side window switch to do auto-up
- How do you make DTM tails?
- can I paint clear bumper lights?
- how to fix rattling in trunk caused by subs?
- Plastic coating peeling off tire rim??
- Which is positive on a cig. lighter adapter?
- Dad accidentally filled up tank w/87 octane. 1 wk later: CEL 0304 = KNOCK SENSOR!!
- Mod so side lights don't come on when parking lights are on?
- About 1999 Maxima GXE FSTB
- VQ35 into 4th gen
- Rebuilding Calipers
- bolt size for engine cover...
- Rough Idle
- Muffler recommendations
- LED Front Turn Signals?
- securing clear corners?
- Trunk won't open
- rats in the dash?
- what brakes pads should I get?
- tach not working properly
- Help: Buying Decision
- CV Boots/Joints/axles repair questions
- Wht do you guys think of this Maxima??
- How do I change out a fog light
- water leaking from passenger side.
- Max does not want to start without applying gas pedal...
- Please, expert help with cruise control.
- 95 Maxima trouble code 11 5 ???
- what is a 585?
- Trustworthy catback possibly?
- Odd gear change: what happened?
- yellow foglights?
- does anyone have eibachs with st struts?
- Maxima Totaled: This a good replacement?
- suspension
- I will miss you guys...replacement
- Mudd got to my CAI, how do I clean it?
- What fuse is the homelink on? and what fuse is the clock on?
- painting calipers
- what the hay
- i need advice
- Problem With urethane kit.
- Updated cardomain site
- 99 Maxima SE strut Tower bar/installation questions
- Car and Driver/5th gen/HIDS ARTICLE
- Getting the 95-96 Sp2 to work?
- Did Reset and Now Car Doesn't Start
- VIDEO: Chariot make a nice 1/4 mile pass at dragway
- How do you replace the knock sensor on a 99 SE Cali Spec
- Will this hurt my car in any way????
- aftermarket muffler
- 2k2 muffler
- What is your Fav 4th Gen Maxima?
- Sr20det?
- Cooling fans not turning on
- dash vents exploded!!! what can i do!?!?!?please help me
- Why is my car like no other????
- My new tires.. Rolling on Dubs lol.. Check it out.
- trouble starting max
- Rack and pinion? Should I replace it?
- Installed Injen and a code poped up???
- Checking codes in a 99 SE?!
- So I decided to pull out the ECU codes...
- would you guys trust Circuit City to install an alarm?
- Changed Plugs and got CEL
- GLE can't get out of park
- Perfection Clutches
- 02 Sensor Left Bank
- Knock sensor
- For all who wanted to see painted sawblades,
- hot weather shifting problems?
- pulley and mesh screen for rear window
- Help me find where to buy last pieace for my MEVI!!
- It all started when I took my car to Pep Boys for a tune-up
- Gas Cap Release Line
- Few video's of Matt's Max (burnout and gauges and nitrous OH MY)
- Post pics of your aftermarket gauges
- Is a '96 Max OBD I or OBD II?
- where can I find coil packs for cheap????
- How to adjust belt tension?
- need help: used mobiletek v.b. not working
- Need Help! 0304 and 0504
- Converting my GXE to an SE: ? about fog lights
- lug nut question
- What should be the best next mod
- what model is my max?
- Just deposited $500 for 2002 SE…
- Short video of my car
- Why is my Idle dropping ??
- rims for a 4thgen, is this a good deal?
- factory alarm beep mod
- Some body kit questions
- engine swap question?
- motivational rear shock mounts
- I made my own front lip lol *pics*
- fuse keeps blowing
- 95 ecu reprogram question
- Thanks guys
- Lighting Question
- recommended panel air filters?
- All moded SE wheels
- Got my max today.
- Replacing a CV axle
- a question to the SP2 owners.
- air bag light flashing
- Massive HP boost..too good to be true?
- Just some quick questions before I do my 5spd swap...
- No start: Replace starter or just regrease it?
- mass air flow MAF sensor 0102
- wheres the distributor
- Real Short Vid Clip after Y-Pipe Install
- How much can the Max tow?
- A lil brake help, please
- Auto Tranny Question
- A little help please....
- what's with the noise, is my belt going...??????
- AGX and Ground Control Question
- 5spd Conversion question
- manual climate control to digital
- Help: EGRC Solenoid valve
- ECU is showing two Codes.
- C/D and slotted rotors question
- Question: H&R'S or Tein H's for 95 Max 5spd ?
- CM armrest leather.
- i30 transmission swap
- Cold Start Squeal
- Where is a good place to buy brake rotors?
- Max won't start, ECU codes undefined!
- fmoc
- Test Pipe?
- ae headlight help
- Just installed Xtravision bulbs, but the beam is lower than stock?....
- Need Help....Experience Needed !!
- Help, sunroof hit the dust
