- What are the symptoms of a faulty gas cap?
- Water leak on driver's side in '99
- Which NGK spark plugs are better?
- bad vibration after BBK install??
- Lowered on GR2 step in...
- Busted right clear corner
- Return of the Max! I'm back, another 4th gen!
- Auto trans replace - how difficult?
- How do you test a MAF sensor
- Electronic Rust Protection
- Car vibrating bad!
- Need/looking for a Muffler
- I'm just wondering
- Don't flame me I just need your opinion.
- Im In the market for some new rims,BUT
- Need photos of 4th with altima se rims asap
- Eurothane bumper repair?
- maxima headers
- Sudden jerks at low speed
- 99 sel oem foglight aiming help?
- Help -- 99 cali-spec max
- suspension worries
- Seafoam + Maxima = FTW?
- Windows wont clean!
- Where can I download Nissan Fast Parts system?
- can I fix this bumper
- NJ Piscataway area Meet?
- Rear Bumper Cover
- 95-96 IonicDynamic Lips *Pics anyone???*
- Battery & Brake Light
- Engine dies, now codes for MAF/Knock sensor
- is this bad?
- have other max have this same noise close to the throttle body?
- Oil coming out of the UIM....Help!
- Got a package in the mail today.......
- Fuel filter location and substitution query.
- What Model Flex-a-Lite Fan
- Typical Life of a Front Rotor?
- Engine bucking
- Car accident...read..need some advice
- WHOS goin to H.I.N in San Francisco???
- 215-series tires on 300zx rims?
- Need help assessing a problem
- EGR problems....worth fixing?
- Parasitic Draw: How many amps w/ key off???
- those who did their endlinks and swaybar bushings.
- Spotted Ugliest Max on NJ I-95 *PICS*
- restoring the "pep" in your maxima
- auto tranny slip! need new tranny now??? help!
- crankshaft position sensor
- Struts sitting a long time....problem?
- Starter gone bad
- bronze wheels..come on in
- Electrical Problems. . .
- composition of PB Blaster
- need help w/ left front O2 sensor
- Tokiko Illumina Creaking
- What is absolutely necessary for the installation of an aftermarket suspension?
- Coil Pack testing
- Help Westchester Ny Orgers
- Alternator dead??? Need help baaad!
- LCA Ebay Vendor Recommendation
- what strut/spring setup should i get?
- Nite Shades
- NEED HELP!!!! - - line pressure solenoid valve(automatic trans)????
- Hard start, need to give gas.
- Ran out of gas... share your story!
- reset ecu after knock sensor replaced
- It seems that the 0304 (KS) code has been going around lately
- major problem
- Are 96 & 97 exhaust systems the same?
- CF hood?
- Intake installation help
- Where to get B&M Short Throw Shifter?
- ? to BIXENON HID KIT owners
- Can Y-pipe cause this problem?
- BCM under the radio....
- Fuel gauge no longer reaches full?
- cheapest oe parts
- My engine is pinging.....
- Budget B pipe contacts the gas tank.
- Troublecode
- HELP! Need to know where to tap for RPM - for MSI switch (MEVI install)
- cleaning iacv/intake
- new brake pads sugestions?
- need bolt help. hub adj. nut
- Who has HID fogs?
- Trunk floor board thing...
- Question on lighting/bulbs
- engine cutting out past 3k
- Looking to get back in the 4th gen game...mad questions
- Wheel bearings...?
- traction bars? where can i get some?
- Looking for rotors...
- p0138 code
- Questions about blower motor resistor..
- idler pulley spacer... what size???
- Anyone has a one front coil for sale?
- Installing rear springs.... Help
- Alternator?
- Ghost in the Machine?
- uhhohhh no gas guage
- Something DIFF for once.. Request pictures of 95-96fogs with yellow bulbs.
- Coolant leak from thermostat.. how?
- spiral cable?
- I might get banned for this....
- AGX's and stock springs: what settings?
- Another oovi question.....
- Battery light and brake light intermittantly flashing, yes i read the FAQ first
- Rear Window switches Reversed in Main Window Controler?
- Air Bag Air Head
- Knock sensor fun
- 89 octane gas fried my KS and O2 sensor
- Leaking coolant
- resonator
- Suspension Improvements
- Thermostat housing bolts
- tranny drain
- Theoretical speed
- the knock sensor won, forgive me
- 5-Spd. Swop
- Coil packs at autozone
- RSB with aftermarket struts/springs?
- Redline still no good :(
- Driver side tire noise
- damn it!!
- Hissing Noise When Cold....
- aiming foglights?
- Weights of 350Z and G35 rims?
- driver's window controls not working
- anyone around Baltimore who can help with aftermarket suspension??
- Replaced Spark Plugs and got 0603 -Cyl 6 Misfire, Help!!!
- Service Engine light pissing me off
- Noob Question: GR2s + Maxspeeds= ?
- Max has no get up
- water pump access cover..
- Heat Affects My Car.....wtf??
- Suspension - Strut mount stuck HELP!
- Who has the best deal on knock sensors.
- Jammed sunroof. How do I fix it?
- Is changing the auto tranny oil that delicate?
- Does leaving the ignition on with the engine off hurt the engine or ECU?
- Stock Intake Swap
- Code Po733
- Rear Suspension Bushings
- CEL randomly came on last night.
- need source for online OEM parts
- Tranny shifts harder with a/c on?
- Headers???
- Under-drive pulley
- axle seal question
- Manual Transaxel fluid change??
- Can excessive heat blow a head gasket?
- Tire inflation and tire diameter
- springs still good after 93k?
- my climate control setting only works at full blast
- burning oil
- Hole in my exhaust *HELP*
- Pulled 2 codes from service engine light
- rear window spoiler
- Best way to determine the Tranny type?
- 96 and 97 rear deck interchangeable??
- Leaking Green Fluid, Immediate info needed!
- I have friggin' searched everywhere...
- BANG!! Side mirror GONE!!
- just got my 350z 18's how to drop
- Worrying Noise *Vid*
- Ran over a Parking block, Wow...
- NOT TO POST LIKE A NEWB BUT.. Obx headers??
- whining noise and BATT and HandBrake light constantly on
- bored with the max
- Question on throttle response
- Can I short out my Climate Controls? Did I? Changed LEDs.
- Alternator ground location.....and ****
- Power Steering hose inside diameter...?
- Amsoil VS Redline MT-90
- I look for threads with the 1005 code pics, but nothing, so here are some..
- Talk about issue's, Radio only works at 1000rpms...ideas?
- Power seats not working
- Need differential bearing part numbers
- Performance issues need help
- suspention questions?
- rear suspension questions
- s-techs 3mnths later busted cv boots help?
- Weird!
- Random Technology catalytic converter 95-96
- Best place for bodykit?
- help with intakes!!!!!!!!!!!!!!!!
- 4th Gen Radio/CD/Cassette into 90TT?
- RedlineMAx
- Weird rustling/ruffling noise when I make turns...
- replacing lower control arm bushings
- passenger side air bag removal.
- H&R springs, but with what shocks?!
- looking for opinions
- Stupid 9004 bulb ?
- Cruise Control Won't Come On.
- Rattling from Budget Y-pipe
- vibration in the pedals..
- Clutch
- Clutch Burning??? HELP please
- Custom Fabricating Exhausts/Intakes?
- progress/illumina *pics* ? on settle time
- Its over for my max
- Starting problem??
- Part #'s needed
- LXP mufflers?
- Yellow Fog Light Film?
- Maxima Belts 1999
- Steering wheels and shifter vibrations!
- tie rod replacement..
- fuel pump/no fire
- smoked out vinyl tape
- As seen on tv
- SeaFoam Trans Tune, question regarding its use.
- Ebay KYB GR2's...Any good?
- 90K question
- Anyone have a stock vs. intake dyno?
- Speed governor/limiter?
- How to get rid of P0446
- why is my CEL blinking like this?
- Leaking gear oil AGAIN!
- intake hose wear.
- Help with Spark Plug
- Is there a 4th gen pic thread?
- Suspension travel
- My roommate played a trick on my Maxima....
- Too much rust?
- Still Misfiring!!!
- Dropping the max
- Some strange noises from the front
- Quick question about 7000k bulbs.
- Automatic LSD question
- Suspension install question
- Anybody replaced steering rack bushings????
- all but drivers window quit working:all at same time
- whats the difference between a 198 bulb and 164?
- ? for those with HIDs in their fogs.
- How much gear oil does the 5spd need?
- Is replacing KS worth it??
- Replacing ECU
- Synthetic or dino?
- Rear suspension squeaks
- Auto Trouble! Help please?
- Hayden transmission cooler
- Do You Have To Gap The NGK V-Power Copper Plugs ?
- need help, fuel pump control module
- Quiet axel-back?
- Do u think it they might fit? 18x10
- Synthetic or Motor Oil?
