- POST pics of AE style headlights on black 4th g..
- anyone with Jet Performance ECU Maxima here?
- bearing in before spring or after [trans]
- Bose Replacement
- Bad 02 Sensor.
- it could happen to you...
- window regulator motor
- Check it out......
- Will a stillen intake from a pathfinder fit a 4th gen?
- How Much Did You Pay for Replacing a VQ30DE?
- Need Help Fast!!!!
- 10 01 ECU Code - No Good Def. In FAQ's
- They Luv it in MD..what about U??? 56k beware
- 300ZX Seats in a Maxima?
- coilover question!
- Max on Fast and Furious
- collecting info for what exactly I need when installing rotors/pads..
- Allow me to introduce myself...
- Cel!!!!!!!!!!!!!!
- Problem with interior lights
- Upgraded brakes
- Clear Corners
- Its That Time Again
- Engine Balance
- 3 Codes... please read
- Does anyone have the how to on led window switches?
- will these fit
- Bad Coil Pack?
- se gauges
- match reving can it hurt?
- Code 0901
- Headlight Stalk Compatability Question..
- need help asap regaurding knock sensor... please..
- Starting Problem – Very Bizarre
- fire wall location
- Does Anyone have this???
- Knocking when you let off throttle = rod knock?
- NGK Iridium IX?
- Recurring Electrical Problem?
- HAZARD lights and passenger DOOR
- here is something every max owner should have
- Codes Galore.............
- just fixed the knock sensor...but
- Help: shops want $150 for y-pipe install, wtf?
- engine cleaning method??
- Have U Ever Bought A Lemon
- 97 Maxima with I30 Hood
- EVAP Valve
- Need some help/advice now
- anyone have experience with/or fix their 1005 code ?
- New fuel filter, clean TB, recharged K&N
- Max interior lights FUse fine
- SSautochrome Y pipe
- Just changed inhibitor switch (11 01) code still comes up
- My review of sylvania silverstars
- Radio shuts off everytime i press the brakes, what can it be?
- Short Throw Shifter deal?
- Does anybody also have this noise? (video inside)
- Blinker blinking very fast
- whoever can guess how long this air filter has been used is the man
- Clutch Noise
- ANYONE that has doen the clear tail mod need help.!!!! i30
- Interesting article
- cryogenic charger
- auto shift nobs
- newb question about knock sensor
- Gas Mileage
- Air mass sensor questions???????
- Anyone ever tint thier own windows??
- rebuilt title?
- Question
- Struts
- lol thought this was funny. ebay is great
- fog light installation
- Custom Trunk almost finished **PICS***
- Breather filter?
- paint code for Sterlingmist
- Unknown grill type
- I shredded a belt....
- easy hoursepower questions
- Look at my CV Boots
- Car makes weird scissors noise. Come in to read more.
- fuel filter
- 95-96 digital climate control ???
- gargle sound comming from the engine...HeLp plz...
- Updated my cardomain, check out new pics!!!!
- Which is the best short shifter
- Car on the lift today weirdest noise ever
- Odd turn signal behaviour!!
- how to check tranny oil
- What the hell is with these codes??
- ebay intake
- rough idle
- Brake Question
- Help Needed
- Help Needed
- which air filter do u guys suggest?
- car is leaking oil
- Performance Auto Trans Rebuild
- C/F trunk lid, and lid springs
- speedometer accuracy
- looking at a new suspension setup. Advice please :) :)
- spring comparison
- Infinity i30 seats.............
- y-pipe?
- World's fastest Max!
- 00 VI to 97'
- B & G springs
- Replacing Front Door Speakers
- CAI Maf Adapter?!?! WTF?
- Is it the clutch?
- brakepads with 8k on them. no squeaks. no groan. NOW a new sound
- simple question
- triple gauge anyone?
- C2 Style??
- My MAX need new brakes!?!?!?!?!
- British green maxes represent
- Matching clearance lights
- Courtesy ShortShifter
- Slight squeek from tein basics.. help
- Maxima Problems... Running Rough
- Anyone cut coils on Tein S Techs? Sprint owners step in also.
- Lighter Wheel Idea Help
- cattman headers
- Where can I find a K&N cone filter adapter?
- Anyone have these coilovers?
- Starter noise
- TYC Paintable Black & Carbon Taillights
- Y-pipe question
- Ignition problems..
- Funeral for a 99 SE sterling mist.
- Any of the Ebay mufflers for a 99 (decent)
- Help - Rear shock/spring install help -Alot of Noise
- Help 99 Se Will Not Start
- How much is my car worth?
- 97 steering wheel and bag in a 96? posible?
- CEL light once again
- Limited Slip Differential?
- ????300zx caliper question?????
- Help: CV Boot?
- my max is worrying me big time...
- anything i should look for when looking at a used maxima?
- Air/Fuel ratio gauge???
- Cylinder 1
- quick question...95 max fit 97 headlights/corners
- Front-end conversion?
- How much is your pride and joy worth?
- ACT street clutch
- I found my problem **WARNING TO ALL EXEDY OWNERS!** (56kno)
- Minor upgrades to this max
- What wheels fit on the max?
- y-pipe
- Hood Pins
- VB or 5sp
- Three Way Catalyst/Codes 0702 & 0703 Help!
- how do i...keep clock illuminated
- problem witht he max...
- Engine Oxidation
- Question: I just removed resonator and hacked air box...
- Rims
- ROFL ... you have to read this
- Intermittent stall on cold start
- Need motor mounts, cattman doesnt sell them anymore
- Windshield wipers not wiping
- pics of gen 4 with 300zx wheels please..
- Purpose of cutting bump stops?
- Something isn't right, banging noise/stalling symptoms insight needed
- Can you help me see the light?
- how hard to remove valve cover and intake manifold?
- Exhaust diagram
- Help - Cold Air Intake took water in and car quit on me....
- Manual to Auto swap?
- what is that POP sound coming from the rear?
- problem starting car
- stillen rsb
- ALL YOU MEMBERS THAT WANTED HIGHER GAS MILEAGE.. who wants to be the lab rat??
- Who has installed the Energy Suspension bushings?
- Need Help! I have some sounds coming from my car!
- And the story continues
- everythins blown, what springs/struts are the best - HELP!?!???
- mafs
- Brake pad replacement
- b pipe you say?
- HP Lowering Springs - Advice Please
- Leather Seat Replacements
- Y-pipe
- Volk Racing LE37
- Pearl White Matching Question
- lighting question.....
- do u have apex lowerig springs?
- Advice needed on 4th Gen. vs. 5th Gen Muffler...
- Will a 2000/2001 flywheel fit on a 4th gen clutch setup?
- Reverse Indiglo gauges are a nightmare
- CV Joint boot kind of suck in..
- New KS, now real high idle?
- best springs for even drop?
- Stupid Question
- 1157 corner light bulb covers/condoms?
- I CANNOT believe this!!
- Ignition swap??
- Transmission Question
- ecu troubles
- Blue/Red Gauges w/in-dash shift light[pics]
- Where to buy eibach for 4 th gen
- Is there a way to reposition the fog lights?
- Help with Spongy Brakes
- Fine scratches on windshield, fixable?
- Knock Sensor Code Question
- Aftermarket Headlights
- Caliper Paint ?
- Front Caliper Piston Boot
- Car heating question
- need help fixing my maxima's problem
- Replacing Bose headunit
- Wich is better??
- Need pics of gas cap
- Possible to get this grill without the bodykit?
- Does the ECU Need Reprogramming after changing tire size?
- problem with acceleration
- INNER TIE ROD Removal Tool - Where 2 BUY?
- Hurricane Max Pics
- Couldn't make it...even with propane flame
- bleeding the clutch
- Static electricity
- Corner and Bumber lights..
- Some recent pics with new paint and RX7 wheels
- POLL: IYO what grille is best 4 me?
- Good place to purchase new stater...
- <need help with fogs>
- Tein S-Tech with Illuminas on 17's? any pics?
- dust boots
- magnaflow muffler??
- Can someone make me a new sig pic?
- engine rocking ..."motor mounts?"
- HOWTO: new twist on dome light LED
- Most newb question: trunk lock
- Our 4th gen Paint- single or two stage?
- ANOTHER 350z Seat swap...
- post pics of your drop on 17's
- No Clock-Dimmer Mod Question
- P1336 P1447 how to fix?
- Show your suspension thread
- Some pictures(New) of my ride
- The perfect intake?
- Alternator, more headaches
- Noises from passenger side wheel.
- Power steering sucks!
- seafoam how to & type of fuel injector cleaners.
- door pannel question: Where are the screws at? need help asap
- some people just HATE on our rides!
