- Do O2 sensors "fix" themselves?
- Fuel filter replacement with ABS
- #$!@# CEL Codes 03 04 - 07 05
- How much torque do i need to apply for a FSTB?
- Jack stands
- Will a 96 Auto JWT work on 95 5speed
- Stolen clear corner again!
- Engine light after oil change?
- Ebay strut bar anyone buy it?
- what do you think of this car?
- Please help - Passenger Seat Back Pocket Falling Off
- TPS Clicking??
- How can I tell if my max is a 99.5 (1/2)?????
- Get to ECU to check codes?
- Vaccum Check Results (First Post!!)
- diamond chrome floor mats
- What's the brightest and whitest bulbs for clearance lights?
- Valve cover gasket...?
- 3 wires?
- custom maxima indiglo door sills
- Help: All light specs for maxima
- Does anyone have a G-Tech?!
- fluid leak - help
- OMG...just realized I put in the full non-diluted coolant!
- customaxima L.E.D mirror turn signals
- Grille for 96?
- Need help in deciding between 2 tire choices??
- Pocket Logger
- WTB: 96 Automatic Maxima ECU
- wheel opinion! Powdercoating
- Anyone know where i can buy new exhaust bolts and screws to attach the y-pipe?
- Stillen flywheel woes
- KYB AGX or GR2 --> is it worth it?
- Headlights
- Guys & Gals with PIAA Platinum Series 9004
- Skyline Body Kit & Headlight replacement/W photoshop stuff
- Vehicle Production Date
- highpitch sound from the engine bay, HELP
- Stick popping out of gear (sort of)
- Noise at start....
- Freeze plugs
- Fuel economy with Variable Intake?
- Whats the best product to remove scuff marks off leather?
- Is there a .pdf of the service manual floating around?
- Changing brake pads...but have question
- need help finding/installing blinker harness
- Do I need any special tools to install camber bolts?
- GLE Disks
- just had a vision... actually im bored
- Has anyone Noticed any Difference from changing REAR O2 sensor when cil came on?
- question- ECU compatability 95-99
- I Need Opinions on SPRINT SPRINGS
- Anyone have a FSTB from eBAY??? What brands are best???
- lack of idle/coasting power
- side mirrors
- Smoke "adhesive" tint for tails - where to buy?????
- Toronto Winter Fun
- Seat Comfort and Carpet
- vibrating...(read)
- Stupid Mechanics!! *RANT*
- important clutch question
- JWT ECU installed
- I got cat-back... $260 installed
- What do you have????
- tie rod ends
- tie rod ends
- Struts and springs....
- stillen from lip cracked
- Another Question
- Which Wire is Positive for Bumper Rewire?
- Who has a black maxima w/ carbon fiber altezza lights??
- show car
- Those who have Jeff's vb
- Advice, my b-day and I get to choose something for my car
- What is MEVI????
- removing dealer stickers...
- Finally installed my AE pedals
- looking for nice floormats for a '99 GLE...
- Shaving trunk emblems: Help please!
- clunking/grinding sound when car is in reverse
- Question about the door...
- What are these catbacks made out of?
- Keyless engine start
- Engine problems please HELP!!!!!
- another starting problem (a little long)
- Oxygen Sensor P0138 code, Please help
- key problem
- Accident: front-end damage
- cleaning up valve covers
- A'Pexi SAFC II???
- looking for 97-99 SE
- Beginner-Tune Up
- How many of you are interested in buying a performance flywheel?
- Need help selecting tires for 99' Maxima
- Test drove '99 maxima - have question
- Hello...........
- Question about oil pressure sending unit that NOBODY has been able to answer!
- Recently aquired '95-with an alarm problem
- I want to upgrade my brakes, thinking about this setup from eatrice
- 5sp Tranny Differential Bearing Problem
- ok, my fogs are behaving oddly... (turn on and off with switch)
- Not so impressive 50-90mph video
- I'm finally giving back!!!
- anyone with pics of brown door inserts?
- what to do about leatherseats.com leather?
- 99' max SE ,,,indiglow gauges
- 1157 tailight mod
- Stupid Sensors...
- Help! GLE PocketTray
- Question about what Glue to use on the back of the "Maxima" letters
- I30 Clock in a Max?, can i do it?
- JDM Parts
- Right underdrive pulley?
- What is the best air filter for PL Cold Air Intake?
- Where to get Carbon Fiber Gen. 2 Altezzas?
- Wiring help. (Speed signal & RPM signal)
- whats up the org/ read this crap
- Gunmetal Dash Kit...
- short shifter for $60? WHERE?
- cost to replace belts?
- UPDATE: Fast Blinker not fixed by replacing BULB
- doin the worst thing ever
- Help I Need A Good Max Mechanic In La
- Fog light foul-up
- Will an infinity I30 locking auto tranny work on the max?
- K&N Panel Filter - Re-oil BOTH sides? -Or just the Bottom?
- Wind Noise from Drivers Door Area
- Sound from Right Side of Engine Bay
- 97+ Maximas- Do or Did you have the option of an IN-console cupholder?
- More Body Kit Options...
- torchinf the springs
- Antenna mast.
- Help! Diesel in tank!!
- Help! Need Suggestions for my '97 Max Mods
- New Ebay Cold Air Intake(not the Bomz), anyone try it yet?
- 4th Gen vs. 2k2-2k3 Max?
- interior stains
- hood supports
- Newbie Wheel Question
- Engine Oil Flush?
- Daytime running lights...
- Fuel cut on a 95 SE
- Help!!!What't the best bulb combo for my head & corner light?
- remote keyless ?
- Possible to get stock wood trim to fit SE-L?
- Is it worth it to upgrade my intake?
- 5 speed driving experience
- Sarona + Stillen = ugly?
- odometer problems
- Need others opinions about body kit...
- Updated my Home Page
- Different 4th generation models
- Question about spoiler
- How do you know if you have "bees in a can" noise from y-pipe?
- Miles per tank??
- Need help with clock electronics
- Manual
- Bilstein Engine / BG Tranny Flush Service
- NE1 Know the Shift Knob Thread Size?
- Washing engine bay
- Who's pushing 200+ hp to wheel with all motor??
- 2001 Ser Steering Wheel
- carsound cat problem
- HELP: Poor acceleration (Knock Sensor?)
- Knock Sensor Problem ?
- Popping sound from WeaponR Coilovers?
- Tokico / AGX Combo?
- What replaced my 95
- What type of gas do you use and a ? for ya
- Please HELP? Intermittent stalling when coming to a stop/hard starts
- 5 spd converion question
- self-diagnosis ECU help, please!
- how do i just get greddy muffler
- Inexpensive but good Shock/spring combo
- Sprints causing problems
- Fuse box
- How to make the dome light fade out....
- Q? Will these Interior Speakers fit My Max, link inside
- What is this chip that adds 10hp?
- problem taking off my rear drivers side wheel
- '99 SE on autotrader.com in metro Detroit area, good deal??
- What do you think about these rims?.....
- want to convert my auto tranny to manual tranny
- TRENZ Billet Grill Owners-Middle Bar Or Not?
- HELP! my blilnker turns really fast now, and front wont turn on!
- timing chain / oil question
- Remote Control Maxima ?!?!
- More & more impressed with my '97 Maxima SE
- just a little tick
- Will 95/96 ECU work in a 99?
- Will the Frankencar mid-pipe and Stillen pop-charger work together
- Help, I have a phantom under my hood...
- Exhaust Straight out of CAT
- Which CAI Do I Get?
- Pics of my new max uploaded, 99 SE-L
- How does one remove the clutch slave cylinder?
- Can anyone recommend a decent shift boot?
- Factory Keyless entry/alarm question
- check engine
- Do air and fuel filter brands matter
- neon under body......placement??
- what size tires??
- Trading Auto for 5-speed
- 97-99 conversion to 95-96
- Can I put a popcharger on a CAI??
- 225/45/17s or 235/45/17s for 5th Gen Rims
- oil question
- My car hasnt run this well over a year
- Twin Turbo Info
- Marker Lamp rewire?
- good price for a 98+ max?
- Back from USA!!
- top speed
- Twin Turbo?
- ? about making red/clears
- Re-post a question. MEVI?
- Feul Filter Help!!!
- White guage faces
- What kind of Paint
- brake calipers paint question?
- Aluminum dash kit over Wood trim
- bose speakers
- Please help on exhaust!!!!
- Rims Question
- How much for a y-pipe & cat installation?
- starting issues...
- This can't be true!!! Engine question...Everyone read.
- For the 5spd people
- Best place for New Coil packs??
- silver or gunmetal rims on a beige maxima?
- GXE Keyless Entry
- service engine soon light!!
- i need an opinion
- cat back experience needed
- 20th Anniversary Pedal install
- Havoline Coolant-Antifreeze
- How to install oil pressure gauge in max?
- HELP!!! Car is burning oil rapidly!
- JWT Pop Charger
- Has anyone done this mod???
- 114k and Going Strong
- Need feedback
- Creaking Noise...Please help!!
- Transmission problem?
- CD static: Any suggestions?
- Starting problem: bad starting sequence?
- Exhaust Studs & Bolts? Where to buy?
- 5speed conversion question please help
