- looking for these 3 parts.
- ENGINE COLANT SENCOR PROBLEM!!!
- NEED SHIFT LINKAGE BOLT HELP ASAP
- Ball Joint Nut
- Lower Control Arm Replacement
- Questions, HELP
- Will the motor start..
- Questions for S Tech Owners
- I effed something up during tranny removal help is appreciated
- HELP! Removing Silencer
- How much to expect from a wrecking yard?
- Stiff Ride
- Would one faulty fuel injector cause crazy idle sporadically?
- 97 5 spd transmission issues?
- Looks like another one bites the dust :(
- Quality tie rod ends?
- Pinstripe Idea
- Starting issue
- fuel leak WTF?
- Steering wheel swap?
- Black subframe bent (Front)
- Advice on exhaust
- ECU 05 05
- Rotor doesn't fit caliper odd problem
- Exhaust is Next
- What Bearings to use?
- NEED HELP BAD
- Clutch Issue
- Clutch Issue
- can a bad wheel bearing cause locking brakes?
- My fog lights won't work!
- Got Stillen lip installed!
- Short term fuel trim?
- camshaft sensor questions
- Planned rear valve cover gasket replacement - question
- Brake Light Problem!!! PLEASE HELP!!!
- tranny or linkage?
- Rear Seatbelt Stuck... Help?
- new here....my intro 95 gle cali spec auto
- FSM Download
- Getting my car tinted!
- ambient air smells like coolant sometimes?
- ebay smoked bumper lights - anyone?
- Grrrrr, Now with the black one ?
- Timing chain/tensioner rattle? With video
- Engine tune-up suggestions
- WTB: Non-Bose factory radio
- Wideband install
- help identify [transmission?] noise
- No gas after start up. Max starts, then dies immediately.
- Engine to Manual Trans
- Polyurethane Busings or OEM Bushings?
- Possible to hit 200 whp w/o 00VI?
- before/after skyline rear body kit
- Knock Sensor Annoyance
- Anyone have the writeup for changing the alternator?
- Sunroof glass perimeter gasket not sealing and letting water in.
- PLEASE HELP!!! MY FRONT TIRES ARE GOING IN OPPISTE DIRECTION
- steps to changing rear brakes
- Blown Head Gasket??
- 5 speed problem
- 95 max fog light question
- Just need a little advice
- front radiator area need help/advice
- Ksport .. Question
- Gas mileage.....issue??
- NAPA has GL-4 Dino
- Car Won't Start
- WEIRD CAR STALLING PROBLEM
- Strange Misfiring
- past few days have been pretty great for maxxine!
- need new axles...
- EGR Mystery!!
- possible to have codes thrown but no CEL?
- Pictures of the body work I did on my maxima
- No coolant pressure?
- 95 Maxima CYL 1 will NOT fire. Please help, need car!
- diffrence between auto and manual. my version
- Cooling Fan issue - Thermostat? Fan Relays?
- **HELP**cheapest intake??? weapon r intake???
- Fun worthless facts: Weight Stock Cali spec to Warpspeed y + fed front manifold
- Help! Bald Fuel Injector Screw :-(
- Best pace to purchase control arm kits??
- audi s4 style spoiler
- how to tell rotor is bad or under spec?
- 3.5 swap using the 3.0 ecu?
- greddy emanage help
- my 95 is going glug glug glug
- neutral saftey switch
- Moving on
- Input Shaft Bearing?
- Is it necessary to remove the radiator to get to the front exhaust manifold?
- Rear Spindle
- Random power loss
- Identify a Locking tranny by sight?
- Eibachs/Konis installed - before/after PICS
- Ultimate Light Setups thread
- where to order warpspeed y pipe....
- Detailed Instructions On How To Remove And Install Injectors With Detailed Pictures
- Headlight Problem
- Best Shock/Strut Set up on tein springs?
- pretty easy, really cheap, possibly effective lower rad support "fix"
- timing belt or chain???
- Concerning a 1996 JWT ECU in a 1997
- PCV valves- ever clog?
- will a 97 tail light fit on a 96?
- clutch opinions
- Tire size and A/T shifting points
- Headlight Trade!
- autodimming mirror wiring
- Tail Light Removal
- vibration in the steering under load
- need help with staggered rims
- Taillight Bulbs Question!
- How do I measure mainshaft bearing preload?
- replaced my radiator today
- 97 Max Steering wheel RPM question
- Replaced front wheel bearing and....
- 1 piece headlights
- aftermarket muffler VS no muffler?
- couple of probs, hard start but only sometimes
- 4th gen stock on factory 18" 350z
- rear body kit with dual exhaust?
- Looking to Drop my Max! need advice! plz
- Snow Fail v.2010
- SS or OEM brake lines????
- car wont start
- Rpm's sound high, Auto not shifting gears
- Port and polished heads? 3.5 cams?
- Best non-poly motor mounts?
- Spring rate the only differene in trim lines?
- has anyone bought anything from this site?
- about those tires
- Remanufactured fuel injectors good or not?
- what clutch/flywheel are you using?
- Mass Air Question
- how the hell do i remove sensors on throttle body??
- Help! Could Bad Injectors Cause Stalling Only When Cold or Dealership full of BS ?
- Changing Spark Plugs
- Anyone know if this will work?
- trunk pop question (not valet mode problem)
- Argh! DIY Headache...
- Y Pipe install
- Help Is My Torque Converter Going Bad?
- 97SE part out or sell?
- Helpo! 95 Maxima Threw P100 & P325 Code
- Suspension Shot.. Need Advice (noob alert)
- quick HID fog question
- Car dies at cold starts only, no CEL...:(
- Paint types
- *Part 2* Pioneer unveils NEW products at 2010 CES [Video Coverage]
- 97 SE windshield leaking
- 12v Power Outlet Cover
- Ypipe Gurgling
- maxima in modified mag!!
- MEVI back for sale
- Quick LED Window Switch question...
- r34 headlights..... no bulbs
- Loss of Power
- removing bose faceplate
- Drivers Window Problem - not typical
- Weird Tranny problem??
- Cranking but won't start. Cam vs. Crank
- Can 5th gen coilovers work on 4th gen
- A couple of minor issues.......
- Didn't pass smog and wanted to get some advice: I have previous smog and failed one..
- difference in front strut tower brace
- From then..... To now!!!
- R34, melted corner section after corner light mod.
- need cam shaft sites/links.
- has anyone heard of adding a resistor to intake system to improve performance?
- headers without y pipe for 4th gen
- Cracked windshield because of rust??
- what to do???
- mods for a 99 gle at.. suggestions..
- Quick camber bolt question
- How long do I have left?
- GOT PICS ?
- How do I remove double side 3M tape
- Need help identifying this...
- Any tips on how to install the EGR Valve and the tube that connects to it? on a 99
- 99 car OBX header/ Y pipe install have 02 questions
- tranny swap in NY?
- wanting to delete a vacuum hose...what size filter?
- 1999 maxima se grille?
- P1105 code after installing V-AVCII and custom made O2 sim
- I been searching for the past hour now.. for the 3.5 swap
- Power Steering Belt won't Tighten???
- Revised TPS Adjustment(TSB-NTB99-053b)
- Wheel Trade
- 30 min debadge
- Tein S-Techs and Stillen Front Lip
- pulling cable through the firewall
- UPDATE #2: NEED HELP! Car Dies When Coming To A Stop
- 13yr old grown man hurting
- how restrictive are the oem exhaust
- i got a question about the intake manifold
- Maxima - mini cooper edition
- Performance Chip mod from Ebay
- wanting to buy new wheels.
- power antenna - wanting to go stubby for cheap.
- Thanks to the org
- Please Help? Will a 4th gen i30 suspension fit a 4th gen max?
- 00-01 exhaust on 98????
- Fuel filter needs to be changed monthly!!!
- Why does rain makes my car lose power? MAF?
- Weird starting issue
- cost of body work n paint??
- Pieco-o-crap clutch
- Rear window not staying up. and its cold.
- Afermarket TPS Recommendations Please
- MAP sensor interchangeable from Nissan Quest??
- rusted magnaflow junk....
- Which ebay headers are good?
- I have a Great Idea.. But who thinks it is worth it?
- Flywheel Removal Help
- Engine Problem with 96
- Can't go above 2000RPM......
- what is this part (steering rack)
- Ohms for IAT...and where is the FSM link
- Car turns over but won't start
- mailman brought a gift
- MAF Question
- Transmission Filter Nut won't come out!
- Close-up picture of my spark plugs after 110K Miles
- mod question
- Locked-Up Rear Wheels
- 95 SE Motor Mounts
- Write-Up: Upper Oil Pan Removal
- need advice on problamatic maxima, fix it, sell it part out?
- Please Help QUICKLY: Had a New Engine Installed But Having Starting Issues
- 235's on OEM offset?
- does anybody know how to remove the key cylinder???
- Help about choosing a tint percentage
- Best place to get new coilpacks?
- help cant disengage e-brake!!
- Begining of a shave/tuck
- what rim size?
- 245/45/18 with coilovers
- loud rattle
- My Custom PJ
- P0141 Error Code: Rear HO2S sensor
- part # or other ordering info
- Help with Flywheel Selection....
- camshaft sensor bad?
- help, max will not start
- Rejoining the 4th Gen Community
- Anyone tried just brushes instead of entire alternator?
- Odd rear main leak
- Another Alternator Diagnostic Question - wiring and ground harness
