- Power driver seat replacing manual seat..
- Couple of Questions
- EGR code...best remedy???
- Cleaning IAC
- Injector plugs
- I need Some Info On Random Technology!!
- 20" rim info/roll call
- Different bulbs burned my wiring
- questions on front lights
- starter fix problem
- Why do my spark plugs look like this....
- I might have a bad ECU!!??
- car starting getting worse, any ideas?
- All Video Sticky
- Will an engine misfire throw a knock sensor code?
- CEL Question
- WHERE IS TCM connector
- D2s or Tein Basics
- How to replace side view mirror glass
- New O2 Sensors->Idle drops 200 rpm
- Heated seat question from 3rd gen owner
- New axles installed!!! Now another probleM??
- Parts to get when doing a motor swap?
- installing a sunroof
- what do u think?
- Ceasars Chariot: Drag Racing Compilation "Big 10 Race" Video
- looking for 5spd swap parts list
- Replacing f/r struts...need an opinion!
- ks problem
- Head Lights
- Eibach VS S-Tech Springs
- Brand new Max VIDEO
- New keyless entry remote.
- Finally Crappy night Pics of Retrofitted Cefiros
- maf sensor, just plug & play?
- Stillen lip problem/install
- cylinder 1 misfire - please help
- HELP-Belt noise: A/C clutch? Bearings?
- Writeup: Clutch installation
- reupholstered back seats black leather and black suede
- Problem and cant figure out what it is
- Warpspeed Exhaust Package...shorten?
- Wsp Y+5th gen muffler+straight pipe?????
- HELP: quick interior question
- Transmission leak at axle
- Intermittent Wiper Upgrade
- Interior Issues
- Failing Axle
- A/T Tcm Reset Help (Not how to read Tcm Codes)
- What are the differences with a Cali emissioned Max
- HID problem
- A Sad Chrome Rim Story
- O2 sensor testing, need some guidance…
- easiest/best place 2 splice into for voltmeter
- Horn Problems
- Air Bag Light Flashes!
- Cefiro Retrofit MIni Write-up
- EGR cleaning
- My Idle is all fux up. Need help
- why didnt it work guys?.........
- Drag Race Video: Chariot vs Honda Civic in a close one !
- question about the vent/clock bezel
- For Those With CAI... also WINTER PREP
- Suspension???
- Sux buying a salvaged Maxima
- GRound wire on Ypipe bolt by cat, is that for the 02 sensor? or what?
- cup holder on my 95 sucks!!
- Red clear tail light bulbs
- Mille Miglia EV-S Wheels
- rattling in front when making a u turn
- Sunroof not sitting flush
- Check engine light flashing!
- fan noise
- Question on Headers - '99 Cali-Spec
- Who knows stereos?
- plan on replacing rear 97-99 bumper...HOW MUCH $?
- Cefiro Retrofit Complete!!
- ebay hid
- Fuse box cover
- Alternator's last days?
- bad alternator or battery
- Side mirror glass removel w/o housing removal
- What to do
- i think that i am gonna change
- removing stock muffler tip
- Need help....CD wont eject from 95 Bose HU
- Web Poll
- let me try this again
- 95-96 Clearance Lights in 97-99?
- how to remove/reinstall lock assembly
- Cylinder Compression test
- Lowering my car
- Y-Pipes
- Who Does Led Retro Tails????
- Quess What Was Under My Hood Today
- Post 0-60 and 1/4 Mile Times for Your Max
- engine sound after adding techron
- Stealership strikes again!!!
- 5 speed transmission rebuild kit??
- yet another CV question.....
- brake rotor grinding bracket- normal?
- So...signal wire #3 in coil pack #2
- Looking for pics of 4th gens with 00-01' 17" SE rims w/out center caps, NOT 02-03'
- Keyless entry remote ?
- ECU Code help 03 04; 09 05
- slight oil leak! where is it coming from ???(Pics)
- Replaced KS.... not good...
- EGR guide tube plugged, how to clean?
- How smooth should our 5 spd shifts be?
- I keep getting the O2 code even after I've replaced it twice!
- Auto vs. 5-speed motor mounts
- Keyless entry module location
- Kmart makes a clutch for the VQ!?
- Sunroof Sticking
- Other car ideas.......
- Coolant Flush?
- 00VI...got one?
- anyone ever open their DC bumper lights?
- Which is the fuse for corner lights?
- engine lifting points?
- Need quick help identifying a picture, EVAP!
- Those with drop resistor mod
- Thoes w/ UDP
- Cheap coil packs 95-99
- egr question. yes i searched
- Door locks
- Expanding the horse?
- POLL: What are your RPM's at a certain set speed...
- Infinity I30t to Maxima engine swap?
- Alternator dead?
- Has anyone had a Keyless entry remote problem?
- Ksport CO in NYC or equivalent rough roads? Anyone?
- Anyone have a sound clip of a Apex'i WS universal muffler/catback?
- Massive Air Leak?
- squeeky brakes!!! driving me nuts! ahhh!!!!
- 02 Mt Trans?
- will this work?
- Suspension Upgrade
- Strut Dust boots
- lsd or not??!
- so, loaded auto or empty 5spd
- Calling all sunroof guru's
- what are all the tweaks I can do to speed up my automatic tranny?
- DId the previous owner change the cluster
- knock sensor wire harness
- pulled 2 codes WTF?
- dealer "deals"
- DVD Player Question
- ionic dynamics cf wing
- does changing the clutch require draining the trans fluid?
- H&R and Tokico Blues?
- exhaust making weird sounds...more trembling from engine
- Problem with blinkers
- Need Quick help with diagnosis please
- Has anyone had their KYB-AGX struts warrantied?
- Autoshifter Position Switch
- WEAK spark?????????
- Manual tranny rebuild, now shifter is moving back and forth in gear
- passenger door does not unlock
- Airbag light flash
- ignition problem ???
- Good intake/exhaust combo.
- Part # for H&R Springs
- All stock now, yea baby!
- high idle help!
- How much....
- Best hot pipe?
- 99 max, all 4 o2 sensors go bad at once???
- CV joint pass side
- Mods you regret doing!
- has anyone discovered a way to make signals blink on unlock like on lock?
- vqpower front bumper signal rewire: 1157 harness from tail or rear signal?
- Cleaned my IACV
- Do we have directional sawblades?
- exhaust question
- Eibach springs.
- Keyless Entry Module in Trunk Question
- help! rough/no starting but no codes
- Is this a good Price to sell for
- e-Bay Radiators...your opinions?
- 97-99 Front Crash Support Bar
- new ignition blowing fuse
- Eibach Spring Install Questions
- Those with 5th gen clutch in 4th gen, I have a question
- Org. Members with Sprint Springs and KYB AGX's walk in Or Anybody
- stillen lip warrenty form redlinemax?
- How do you change your power steering and terpentine belt???
- red-clear taillights
- Is it the Guage Cluster or the ECU which holds odometer reading?
- has anyone here managed to fit D2R/D2S bulbs to stock 9004 housing?
- good strut boot?
- DEK Swap ?'s
- tranny issues
- Switching Gears
- need somone with a chilton/haynes manual FAST!
- Driver's CV Boot Positioning and Length
- Head unit is dead
- 00 Tranny Non LSD--New Axles or Not?!?
- Should I replace my battery? Actual multimeter testing info inside...
- GD: $90 Shipped Motostorm UDP Pulley Paypal Preferred
- cel codes, need help please.
- 4th Gen Retrofit security question!!!!
- original window sticker
- post pics of your drop!!!
- tranny leak. analysts please :) [4 pics]
- Bad remanufactured alternator?
- Dead passenger door
- Symptoms of a bad torque convertor?
- best alarm system
- Best/Loudest Horn
- starter question
- Are heated seat switch bulbs replaceable?
- Clearance Lights
- all with body kits step in
- Headlight Harness Upgrade
- Cone filter question
- whats woud you guys think
- Engine burns oil?
- New Mufflers?
- g35 steering wheel
- Boggled by what to replace my existing suspension with
- will these 19" rims fit?
- HP Lost over the years?
- Will a bad KS make your engine oil dirtier?
- Throttle Noise
- auto-x 10/30 4th gen kicking the 3 wheel motion
- New Foglights
- Left front wheel hum then crunch
- Need quick help, bleeding clutch.
- need to tune up mom's car, some advice needed
- High end power?
- hacked airbox question
- tokico springs question
- Cleaned my TB
- Halo Reverse Gauges on 98/99
- can't remove the waterpump
- Could this be the end ...
- SS brake lines?
- Creaking noise from Front suspension
- part # for front strut bearings
- 5th Gen 6spd in a 4th Gen
- To those of you with 19's please step in
- Speedo going wack?
- Intake Question
- Apexi WS
- Spark Plugs
- 3 different EGR valves????
- Custom G35 Style LED Taillights..How
- Replacing rear bench?
- Removing trunk bars...
