- Me and my dad did some maintenance..
- Headlight
- cv/axle shaft assembly ?
- gaskets?
- need help on manual transmission remote start
- idle speed?? which one? 700, 800, 900
- Quafie Diff Alternatives???
- Help
- Clearance lights
- Dual Intake for the max???
- 5speed swap questions
- 99maxSE 5-spd or 98 240SX SE 5spd?
- Ignition Coil Check
- Will stock '95 or '98 cat back fit on my '96?
- who is the heaviest 4th gen owner?
- knock sensor
- low-mid-high end power
- HELP starting up problems
- Suspension for 1997 GXE
- one piece rear valance or two piece rear valance?
- Maxspeed springs and lowering amount
- back seat center seatbelt....
- I along with many other wonder the same thing, how many of us have Evo 5's on 4th gen
- Clearance lights not working properly
- any noticable differences in the y-pipes
- axle
- 4 lug conversion
- tach is pooooo
- Best Tire Pressure Gauge?
- This tranny is always breaking - Mechs don't know why
- Is this a GLE or a GXE?
- Car won't start
- Help me convince my parents a Maxima is a good choice!
- How reliable is the 5-speed tranny?
- Are Buying Mods for your 4th Gen, Killing YOUR pockets?
- Sprint springs to G\C set up
- Need 2 Vent After Dealer Screwed Me In The Arse
- Evo 5 questions and tire reccomendations?
- Y does my check engine light come on when it rains??
- Maxspeed/GR2 installed
- Keys for my 99 SE-L
- Yup, you guessed it! More oddities with my week old 99SE-L
- Parking brake is frozen
- programming remote not working
- Question on Budget Y-Pipes
- ECU error help/advice
- Would 5th Gen rims fit 4th?
- Got Into an Accident on Friday!!!
- Beinstien Flush, Getting the Sludge out!
- did some maintance to the max today...
- Newbe question for 5-speed drivers
- New TACHOMETER!! HELP
- 50K Maintains
- how much for an O2 sensor?
- Installed intake!!
- pulsating lights on my '96 se
- cheapest headlight?
- Heat does not work..What could be the problem?
- For those with 5th gen mufflers on 4th gen Maximas...
- Just went to the dealer.....*sigh*
- Clicking noise when brake pressed, right tail not on
- HELP PLEASE... Fan assembly
- Interior Lighting
- Bent Brake Backing Plate*********************
- gas Light on my 99SE-L
- which CAI is better?
- Budget B
- Struts move in rear strut mounts, how do I fix it? (Motiational rear strut mounts)
- cleaning the O2 sensors and KS
- New alignment specs => bent suspension components?
- Pics Of My Wrecked Max
- OBX bumper alignment fixed!
- Painting my maxima
- finally made up my mind..
- Head light Eye Lids - Where to get them?
- Modded 2.5rs (99) or stock 97 MaximaSE
- Bouncing Hood - Help
- Carfax???
- Bent Frame
- Dallas - Ottawa road trip - singing my car's praise.
- Those With New OBX
- Gauges dont work
- Found a cheap axle replacement
- jumpy idle PLEASE HELP !!!
- Need a 4th Gen Maxima in Los Angeles Area!!
- Which plugs to use?
- suggestions for a bose sub
- timing chain
- Normal RPM's for 4th Gen
- Junkyard Run
- What Is The BEST Looking 4th Gen Body Kit On The Market?
- Where are GR-2s available for $207?
- 97 Rosewood Factory Paint Code
- 14's possible in Cali-Spec Auto NA ???
- Exhaust system opinions?
- What is that notch in console for? 1997
- What exhaust system do you have on your Maxima ?
- Remote Starter Install
- no O2 codes, KS, but bad gas mileage, help
- 4th SE Rims
- Lower control arm bushings
- SERIOUS problem w/ MAX..."The Knowledgeable" PLEASE help
- HIDS. which ones would you choose?
- Solution to my front suspension creaking
- Side mirror switch wire map
- Skyline VS Supercharger
- spark plug wire debate... AGAIN lol
- any help
- Big Week For Me! System And Rims!
- Installed my budget too!
- quick ECU question
- Intsalled my y-pipe!!!!!!!!!
- EEREY noise coming from steering...
- Clearance Lights on 99 SE-L
- Installing Indiglo Gauges
- Headlights out, Help Please
- projector headlights and clear corners?
- installation (deck/speakers)
- THROTTLE and TORQUE CONVERTER problems?
- valve intake filter looking thing?
- what is a vi?
- Problem with car...
- Help me with car. Trembles at idle/low rpm.
- Nissan Xterra head unit
- Question on rim compatibility across years
- good deal are not on cf hood ?
- what parts should i take off my freinds maxima
- Can I put 98 door panels of a 96 maxima
- New Eibachs v. Old Ebiacs v. H&Rs v. Maxspeeds
- somtimes hard start?
- Interim Results of Ground Wire Project
- Paint job price?
- Yay my budget y-pipe came!
- Does the fuel filter need to be an ABSOLUTE copy of the OEM one?
- In search of ODB2 connector on '95 maxima...
- 3-gauge pillar?
- ionic front lip
- Aftermarket Muffler Length = Longer is Quieter?
- Brake Pads?
- Looking for spoiler brake light (LED light).
- Can't put front lip on???
- Maxima Shocks
- engine cradle frame
- Alignment ? AFTER I have searched....
- Please Post Pics of 1999 SE-L Tan Leather Perferated Seats
- hahaha - mechanics suck
- KYB GR2 and sprint springs....
- Weapon R, Franken, or......
- Hot/Cold indicator
- Junkyard Run
- tranny question
- GAUGING INTEREST for OBX Catback
- MEVI install - Where to get tach signal from ECU.
- wanna help me with this?
- installation: diamond plated floormats.. need advice please
- Cracking on door panel... will liquid leather work??
- How much should I expect to pay for replacement CV axles?
- Online repair manual & info: Chiltons searchable manual online
- gr2 = agx. settings
- Harlan switch/underhood heat
- EVO 5s
- Heated Seats
- Question about dash kit
- What is the drone sound from exhaust ?
- Rewiring the fog lamps to be used by themselves
- Cleaning the throttle body on my 99SE
- Okay, i did something really stupid.
- Junkyards Rock!
- Just got my Custom Cat-Back installed
- Update: Oil change with tranny fluid...... (kinda long but good)
- Hardwire install for Valentine One radar detector
- Cheapest place to get ACT Clutch + ???'s
- 02 atlima VS 02 max same muffler???
- i FINALLY got my new toy!!!!
- removing tail lights...
- have you clean EGR valve?
- Streetglow l.e.d exhaust tip worth 3/10 in 1/4 mile!
- Air Bag Seat Belt Prob.HELP!!!!!!!
- Rims and tire problems
- Rewired Fogs and now
- Dam! Dam! Dam!
- rsb questions
- Completed Intake!!
- CV Joint and brake ??
- has any one ever painted there engine
- brake service price question
- Question for those who painted altezzas
- Bought '98 SE, Engine Noise
- Changing front break pads
- just bought a 97
- Gauge Bulbs and Heat Sheild? Melting?
- Which side skirts would you choose
- Dual Guage Pod, wheres the Tweeter GO
- Knock Sensor
- anyone ever swtich from manual to digital climate control?
- HID's from 2k3 to 4th gen
- CV axle
- exhaust + dash is here!!!!
- AE Headlight and Clearence on Sterling Mist..
- LF O2 sensor and Y pipe install
- just got an email from custom maxima...
- 03 03 code after installing GForce
- ANYONE have 98-99 with RED/BLUE LED'S?
- Can I put a 2001 automatic transmission in my 95 Max?
- Shifter
- center console compartment
- What do you recommend?
- glo-gauges
- tinted windows
- Strange noise from the manual transmission... synchros? :(
- I want more RPM
- No cranking due to anti-theft relay
- gettin new wheels...lug size question
- Are The 2k2-2k3's Really That Fast As They Say????
- everyone with fstb
- Caliper Paint = Engine Paint?
- in dash clock broke
- 2 everyone that has Cattman Motor mounts read!!
- recent problems with electrical system
- Service Engine Soon Light Problem
- *pic* Did I Cut My Rear Bump Stops Correctly?
- MEVI installation questions...
- Tried the instructions for programming remote...didn't work
- 350Z Deadpedal replicas
- Help with CarFax report please!
- 02-03 Indiglow Door Sils
- 350 Z Dead Pedal-Replica
- pretty unique suspension question
- kyb agx ground control bumpstop setup problem
- rear sway bar
- HELP !! my exaust is to loud
- My Car Wont Start!!!
- knock sensor code, one by week??? help
- Center Caps
- Help with Budget's Website
- Noise at 70 from intake?
- AE Headlights and clearance lights...
- Old school ignition?
- 95-96 ECU put into a 98???
- A Short Story for you all.
- Anyone notice a diff when washing car with hard water compared to not....
- Can you tell me a little about the gas?
- KYB AGX and bump stops
- Alignment w/ 19'z
