- marbles?
- Changing Mileage on Cluster
- Clutchnet flywheels?
- Boston MA, need Steel Braided brake lines installed
- Somethings wrong, Help!
- Car shakes violently over 70mph
- Looking to lower my ride
- Sunroof Rebuild kit? Does it come with the complete rail assembly? ATTN: Deezo
- 3rd gear hates me......
- what trim is my car??
- Cortesy STS back on market yet?
- Getting muffler put on. How much should it cost?
- finally..
- Subframe connectors AND lower tie bar? Pics of either?
- Suspension suggestions.... step in!!!
- Door/Light Chime Mod?
- Ecu Cel?
- H&R + GR2 = harsh ride?
- Replacing Clutch Master/Slave Cylinders & Hydraulic Hose
- blinking air bag light
- steel flywheel
- corner and bumber light replacement bulbs
- 99 ECU plastic screw will not stop turning...
- Is there anyway to get a new wheel well cover in the trunk?
- adding a y-pipe.
- Why does my rear ride lower?
- CV's this week + speedo
- Chariot wins May 2005 Cardomain " Showoff of the Week ! "
- Custom grill
- 100,000 Miles
- Where is our distrubutor?
- whats the best way to clean my headlights?
- Engine Kicking Help!!
- car wont start
- 95/96 tail lights discussion...
- So my buddies Camry got me thinkin
- Wiring problem...
- steering wheel
- power seats
- Sitting on 16's?? Show me some pics
- install myself?
- nopi
- heated seats?
- anyone know how to open up the taillights?
- Remote stopped working(keys been dropped)...
- Leaking oil! Not sure where it's coming from.
- STRUT MOUNTS... need advice...
- my ecu knows i'm afraid
- 0111 Code.. "Jackpot code" ???
- sylvania XtraVisions
- Got my Cefiros on *pics inside*
- Need help Quick... Trans stuck in R.
- found myself a real good deal
- Who would win?
- Oygen sensor
- Yes or No? Rim opinions.
- narva bulbs...
- New Grill and 18x8 Mille Miglia VRs!
- S/T struts?....info please
- Bypassing the heater core
- anyone 2k 2k1 tranny in 95 max
- what kinda HID kit is this!!!!!!!!!1
- questions about my new 99 GLE
- Max got some new shoes tonight.... (56K no)
- Does anyone have any sound clips of Exhaust with their resonator off*************
- Damn I have good taste. (pics)
- for those who swapped in lsd trannies help please
- Failed Inspection in NJ, Modified Exhaust too loud
- Homemade Mesh Grills upper and lower
- New WarpSpeed subframe connectors
- Now I am almost certain my car was never in an accident but... need some body experts
- If you've overheated join in.
- EGR System Hi/Lo Flow & O2 Sensor
- max with cobra r wing......?
- could this be the dumbest suspention idea...
- tach is wrong and slow!!!
- Many new pictures.. 56K haha real funny
- help. iacv
- Best Headers for the 4thgen?
- Bra
- Rattling noise from wheel while moving
- leak diagnosis....help!
- Is it my starter or simply my ignition switch ?
- 6.5"
- Guys Help Please!!! - Starter question
- installed motorstorm udp + initial d trailer
- Cold Start Stall?
- I keep blowing the exhaust gaskets
- Great, Max just stopped working....
- Clutch wear pics and UR flywheel machinability
- Totalled 97 SE
- Two Questions:
- Ksport Coilovers *PICS*
- Ground Controls? cheapest place to buy? what kind of struts?
- JIC-Magic FLT-A2 Coilovers
- those with rsb, how to jack up max's rear?
- has anyone rebuild there rear calipers on 95 maxima
- weird sound starting up
- fixing carbon fiber hood
- any1 got a wiring diagram for instalation of Fogs
- F@ck Friday The 13th!!!!
- New Cardomain pics
- Hows your handling?
- Are VQ30's Interference Motors?
- anybody
- My max just burned to the ground
- skyline spoiler
- Finally....Pics
- pr mounts 4sale
- NGK Platinums?
- manual climate control bulbs
- look, 97 lip ( c.f.) on 95 bumper
- Anyone have a hydraulic schematic for our auto transmissions?
- Carfax anybody?
- Locked out!!
- Need help installing clear corners (bumper)
- Technosquare ECU Upgrade
- RPM dropping issue after 1s gear
- Need clutch advice!
- Front Right Htd 02 sensor heater
- cefiro headlight price?
- spark plug change interval, 95-99 vs. 00-01 models
- Possible to remove tint on back window?
- Front brake Caliper question...
- Check out my Cardomain page.
- Are all these kits the same....
- Forgot to put gas!
- microvision or a y-pipe?
- Need quick help! Tips on removing stuck oil filter.
- Adjustment of TPS and Idle Speed
- Gas Mileage just 1/2 tank measure way.
- TS / g-force CEL fix?
- 95-96 Clear Tails
- Weapon R Coilovers?
- Check out some New Zealand Maximas/Cefiros
- Switching 95 se ecu and a 95 gxe
- y pipe?
- CEL doesn't come on when key turn...
- Another Greddy Sp2 thread breakdown
- alternator/battery...power loss???
- meguiars scratch remover
- rack and pinion problem?
- Oem Fob Key for 97 max se?
- Cheapest place to buy Progress Springs?
- steering column help needed
- How exactly should I go about posting a Group Buy?
- new tires
- 0707 code
- gas mileage has went from wonderful to gas hog..
- Cattman Cat-back Exhaust
- Anyone Saw this before!!!
- EGR help....
- Here's a hint - 99 ECU!
- 4th gen steering wheel
- Starting problem -- cranking not continuous
- Am I the only one...???
- Walbro fuel pump- where you get yours?
- interior pics request
- Quick: Adjustable or not.
- pinstripes are on the way out
- are cheap ebay parts crap?
- Tie Rod end going
- looking to get rims, need some help
- WTF IS GOING ON!>>>>PLZ HELP!!!!!
- Turn signal mirror covers instructions
- New trans symptoms :(
- Question about O2 sensor replacement?
- Maxima top speed?
- Tien S-Tech guys...which way is up for the springs?
- :( i shouldnt own a car
- CEL..now i see it, now i dont
- If u could do it all over again, what would be the order of modifications to ur Max?
- Power loss when driving
- question with BCM and wires
- Fuel Pressure regulator
- Drop Zone Coilovers?
- 00 vi
- Anyone with wheel spacers?
- Does anyone kno how much longer the y-pipe gd is for??
- AirConditioner & Transmission - common link?
- hard clutch pedal?????? master/slave cyl????
- Real quick question
- how bout brake rotors?
- 99.5 Spark Plug Replacement Interval
- Got my exhaust done at meinekee but...
- Hard to Start; Must turn key 5+ times before engine turns
- repainting back bumper
- Where to buy???
- Quick MAF question
- Ground Wires
- weird max behavior
- Advice On Mods.....
- What is this
- what is the correct name for the seal to change when you change driveaxle?
- Brooklyn fellow orger sighting
- what kits is this
- Code p0400 - EGR malfunction, ok - but how do I fix it?
- custommaxima.com discount code?
- Pictures (Finally)
- Ipod Itrip
- HID Headlights
- polished manifold
- The little round thing under the FTSB...
- mannix car alarm
- platinum or iridium spark plugs?
- MORE PICS - MotoStorm S5 Polished Aluminum grill and Max.org Stickers :) :P
- Its been a while, but she's finally home
- 300zx caliper question
- Replaced o2, still get code
- Female friend with on-going EGR woes '99 Maxima.
- Anyone have instructions/template for mounting oem spoiler?
- spyderllight replcament bulbs
- i m BACK
- Maxima Black SE Pigeon commercial !!!
- VLSD tranny in the mail
- 97 Timing Chain/Connecting Rod Issues
- Reconnecting CEL light
- O2 sensor problem.
- cutting bumper?
- Y-Pipe Flex Section Question
- Just Got the Windows re-Tinted
- car pull right done alighment twice
- So my dog woke me up this morning.....
- Brake tools
- Exhaust tip touching back bumper...
- Reaction time at track..daydreaming
- EGR System woes revisited
- Hesistant 0-2.5k rpm's + no pep in 3rd gear
- quick question
- 95 96 maxima to 97-99 headlights and grille
- different spring combos?
- Finallly .... Jinx My Self :(
- two bottom bolts on struts dont line up...
- I need pics of half sized rear window spoiler.......PLEASE!!!!
- S-Techs w/ GR2s = bad combo?
- aluminum bezel with white gauges
- WTB 99 Max SE what to look out for?
- Strut bar install without torque wrench
- how hard is it to swap out my auto tranny ?
- Just Washed and Installed Mille Miglia EV-S Wheels on my max - PICS !
- I can't believe this.
- starter
- supercharger noise found..
- 5spd conversion ABS ?
- Knock Sensor Swap: method + pics
- 4th gen lsd swap>>>>>
- Replacing GXE Dash Gauge Cluster with SE DGC
- HID Conversion?
- Finally Pics of My New Car *56K Go Home*
- key cylinder and starter help please.
