- reverse indiglo gauges
- where to buy chrome gauge rings?
- Where can you get longer studs?
- Has anyone ever used BG Sycroshift in a manual?
- Think about getting a maxima *help*
- fogs/brights
- udp pulley install
- auto vs. manual
- fold down back seat?
- Who's seen maximumpower96's car
- help! udp install (can't remove one belt)
- My First Maxima, anything to be careful about?
- Turn Signal is acting funny
- auto tran prob?
- Hanabi HID keeps shutting off while driving =(
- shocks hit too hard on bumps
- are '96 and '99 gauge clusters the same?
- Need pics of CAI
- DIY Strut/Spring Install and Brake Install
- Can't get trans-axel back into tranny...Help
- tranny... need some help
- ABS Light Problem, need help
- ? about rims and ? about top speed
- Looking at a Max... fair price?
- Yikes! Car only had 1L of oil!!
- front left heated o2?
- GC Coilovers with KYB-gr2 shocks
- 0302, 0104 ecu code
- Max vs. Si
- Hard Shifting
- Engine knocking / shuddering. Help Please
- Should I get my Transmission flushed?
- Need help with strut replacement
- Real Gains From Ecu/mevi Combo??
- P130 Fault Code (O2 Sensor) Help
- taking off front bumper
- help my car wont start!! Plz relply a.s.a.p
- throw out bearing, oem vs act
- Rear Spoiler Light
- Need help with intake ideas
- gapping a spark plug???
- how about "assisted air" for JWT/Stillen cone intake?
- *&$%*@#!!!!! Rear Main Seal leaking now!!!
- tps help!!
- Instructions on how to install AGX shocks & B&G springs?
- Changing driver belts on 99SE
- Help! Car wont start--might be starter?
- Q's about hood scoops
- finishing up my little project :) - gauge install
- HELP-brake groan when backuing up
- More mods, which exhaust?
- Warning: Fuse Panel Incorrect....?
- 14 03 ECU code on a 99.5 Max=?????
- recurring CV, front axel shaft problems.
- Are front anti-sway-bar bushings equal between 89-99 max?
- Help- Odd/Undefined ECU code+ no start
- ecu code please help me!!!
- 95 Maxima US Version Design Problem??
- Eyelids For A 97
- Poll - MEVI screws falling out
- Rollercoaster ride on GC/Tokico Blue setup
- Adjusting camber - Camber Questions..
- New plugs?
- RSB / emergency brake line
- Track tested 3" Micron Filter
- seat mod
- new pics added to my home page
- Remote Door Opener
- Installed y-pipe & sts today and having many noises
- Bad one here... no start
- Noises from passanger side axle....help please
- 5spd transmission leak
- Track result for new intake prototype are in!!! WOW!!
- tranny drain
- whats this part on the front end?
- Throttle stuck wide open!
- 5spd Tranny rebuild / repacment clutch complete.
- Next Mod To Do
- anyone know this car?
- Problem with transmission?? Help!
- Crankshaft Position sensor (reference)
- Need new clutch???
- Revamping entire suspension. Need advice.
- Front license plate holder removal
- Heavy Steering Wheel
- Oil-soaked spark plug!
- Caliper Paint
- What are the torque specs on the flywheel?
- Exhaust replacement
- HELP...what does this engine code mean??
- o/d switch problem / '97 automatic
- crazy weekend rant and help needed.......
- The old Cold Air Intake post.. help me out d00ds
- Place Racing Inake HELP
- New pics on my home page
- Rear Brake Drag- Brake Cable - TSB ?
- How to remove and clean O2 sensors?
- How to tell if your air-bags were set off PRIOR to purchasing car ? ? ?
- Help!
- Unknown ECU code (04-12)
- Loud Metal Spinning Sound
- Why only one stripe when burnout??!!??
- Oil Leak, Need Opinions
- Factory manual on CD?
- replacing fog lights
- Replacing Foglights
- 96 gle
- I made the Auto -> 5spd 'Conversion!'
- 3rd gear problem! AUTO
- intake installed, now check engine on
- any one know what this is??? pics
- Redline CF Hood, WSP Y, ApexI WS installed
- 2003 maxima hid kit
- ECU code suggestions
- Who bought bumpers from Ebay before?
- Lowering a 97 Maxima
- ecu upgrade?and knock sensor a must?
- what's the next bang for the buck power mod??
- lost acceleration
- managed to change knock sensor in 10 minutes
- Need a new Cat...RT?
- Int. Lights; Where/How to Get Diff. Colors?
- sticky clutch
- Ignition Wire
- Cosmo STS
- Knock Sensor Testing Question
- Question for 95-96 owners?
- door open beeper?
- Variable intake butterfly screw monster got me :(, may want to read if you own one
- taking your tail lamps apart
- Monster Flow Filter Question For the P.R.C.A.I
- dropping a Maxima question
- VI is not opeining all the way.....
- Squeak near back door
- they hit me...
- A?c Blower
- fixing loose tie rod and loose belt
- Just installed new rotors but may have problem, help?
- H&R spring problem
- Got time to play with Illumina settings today
- ECU Self Check - Different on 99 Maxima?
- Multiple cylinder misfires and wet passenger carpet
- Sarona Grill
- Spark Plug experience
- Air conditioner Part NAME
- Muffler tip banging on bumper
- Those with Place Racnig CAIs
- Cruise Control Not working
- New 1997 Max GXE.
- What is the best gas for my max in canada ?
- 5spd conversion progress and questions
- Paint comming off of the SRS airbag cover. WTF
- Tornado Intake Dealy
- Quick question
- shold I order dusboots from cattman or Tire rack?
- Warpspeed Y-pipe
- shocks/struts question
- How much does the stock nissan catalytic converter weigh?
- Y PIPE Installed Today! FULL STORY...Details inside...
- JWT or Gforce ECU for 96 auto.
- Larger throttle body question
- NGK Platinum Plugs for 4th Gen $37 shipped
- 99.5 Cali-spec Max question (again)
- Added stuff to car...
- Replacing All Vacume Hoses.. need help!
- painting door posts
- keyless entry isnt working, blown fuse?
- overheating
- Fire in the engine bay!!! alternator to blame!!!
- UPDATED pics of my car
- how would this look?
- Outer CV boots gone bad ! Best place to get replacements cv boots and install ?
- Greddy Exhaust Repair
- 99 se mod question
- Anyone have JIC Coilovers ??
- Squeking rear brakes
- Does anyone have 19 inch Alessio F1s?
- Got rearended, insurance questions
- where can i purchase raybesto QS pads?
- strange hesitation, and rough idle
- Stock Main Drive Belt part number?
- Custom made y-pipe
- Nissan Online subcription
- where to buy KYB shocks
- Strut & Spring Install
- Front Strut Bearing DIY or Not?
- Has anyone powdercoated black their stock wheels?
- Tokico Illumina or KYB AGX
- How to increase torque in the 1500-3000 rpm range?
- should I?
- video of my car not running very well, any more ideas?
- what does overdrive do ?
- Addco vs Progress sway bar
- KYB AGX's or Progress Coilovers
- Will a bad idler pulley make higher idle speed?
- Good brake pads and where to get?
- Got in accident, shipping time for carbon fibre hood???
- continued transmission issues
- 98 Maxima Vs. Acura Legend '91
- noise around the engine area
- What's the best way to increase HP in a 99 SE
- Legacy 7 inch tv.....
- Removing the storage compartment
- Oh Oh...Help
- Why did this dude put a hole in his intake?
- Mounting a fire extinguisher...NEED HELP
- FSTB on ebay for 95-97....will it fit 98??
- help ! my car is stalling at take off.
- 1997 Maxima SE rear speaker removal?
- NOOB here
- Need to track down an interior part
- LEDs
- Pilot bearing puller
- 99.5 maxima (The sequel)
- Anyone successfully repaired cracks in vinyl door panel?
- AW FORK! Armrest Leather Splitting...Help!
- Rusted Rotor Help
- KYB AGX installation
- The right tire size?
- My recovered 3rd gen headrests intalled...pics inside...
- K&N cold air filter sock
- hard to get into and out of 3rd and 4th gear...help needed.
- Is there a way to tighten the steering?
- Y-Pipe/High-Flow Cat ?
- Where's the 2nd VSS located
- 97 Maxima GLE mods
- Brakes....Ceramic pads vs. others ????????
- Sunroof Protector... OFF
- Hidden cost of Budget Y-pipe
- Seat Belt Removal
- AC turning off and on. While taking off briskly with
- Clutch quest.
- someone please tell me this is normal.
- Turbo Blow Off Valve BOV "pssshhhhhht" sound
- suspension noise
- Battery cable, Where to Get?
- Help...piece of rubber fell into cylinder via spark plug hole
- Mevi???
- warranty VOID??
- Fog Light
- Questions from a newbie
- 99 Auto Tranny Broken??? HELP NOW
- center console lights went out
- Wierd noise from parking break
- How Do I.........................
- Altezza Tailights also Bubmer Lights
- black smoke at start up
- Anyone with a 99.5+ Max? Help!
- How much is max HP for VQ30DE engine?
- STS question...
