- Quick HID wiring question
- kyb gr-2 or tokico illumina struts
- po420 fix with o2 simulator
- Does anyone have a black roof? or a black vynil on thier roof??
- Who makes this flywheel?
- Removed manifold; anythng I shld cnsider while I got this opened??
- exhaust question..AGAIN!!!
- 'zone starters - any good?
- Battery died
- SNOMAX L.C.A's for 4th Gens (Large PICS inside)
- Which sensor is P0430?
- How do I determine if it is California emissions?
- Replacing antenna
- CEL
- PRCAI for 00VI. *PICS
- Newb Question!
- $315 to install ES LCA bushings?
- New AC compressor issue
- Loose suspension
- front driver side power window messed up
- Changing Brakes
- custom exhaust advise
- Power Surging During Acceleration (~3000-4500rpm)
- What size is the stock airbox hardware?
- HELP...Starter motor dead
- Can i redo my own brakes?
- R34 HID Conversion
- RPM Gauge Not Working
- Rear Brake Issues
- anyone know the name of this part
- Advice: Replace Rack & Pinion
- Wiring a Volt Meter
- Cautious about trying to replace A/C Evap
- Fixing rust spot on Fender
- Moog parts?
- Brake Squeak That will Not Go Away
- need help quick 00 maxima springs
- Want to hear a crappy exhaust
- ignition coils
- Having problem gettin my car out of park....
- OEM diameter
- ASAP: where to locate camshaft position sensor
- throwed a 0401 code
- Not much lower after H&R install.
- Need help removing grill 97-99
- In need of serious help and advice
- Addco and Progress Rear Sway Bars are the same, right?
- heated side mirror
- Alignment problems...could it be my LCA bushings?
- Car jolts when stopped in drive
- My clock is possessed
- Need a quick fix till Thursday..
- I got a reason to mod it, help/suggestions appreciated!
- Cupholder...
- Ignition sometimes hard to start...any ideas?
- tokico hp shocks and springs
- I'm lost...
- Tailight Mod Preporations For Tonigh!
- can someone get me a carfax??
- Passenger axle is stuck -- advice?
- Those of us with gold door handles
- Rack & Pinion!!!
- Toggle Switch Below Hood Release on 97 Maxima
- Seasonal codes??
- Blower motor noise, any ideas?
- what should be my first mod?
- Just blew motor.. DE-K swap help needed
- No start, No crank, Starter changed. HELP
- New Auto Climate Control LED Upgrade
- Replaced rear calipers + Pads & Rotors now stuck
- Car is harder and harder to start, PLEASE HELP
- knock sensor code from hell!!
- nismo 350z rims
- Help ASAP strut install. axle won't tilt back
- Problem with Brakes. Pedal goes all the way to the floor, Did almost everything...
- auto vs manual
- help on ac electrical issue
- Does your Cruise Control work after 5 speed swap??
- Water pump or Cat?
- Knock Sensor on 99 GLE
- Maxima died on the highway on my way home,wtf?!
- HELP CODE 1320 MISFIRE
- A/C -Heater Interior Blower 1995 Max Se
- 5 speed axle leaking... what do you think
- Another radiator core support rust problem
- A little problem after installing Intake...
- radio
- Shaving trunk keyhole help
- I think Im missing the belt adjustment nut..
- 3 codes, but parts are new? bad wiring? help!!! about to give up & junk it
- HOW TO: Fix broken cupholder
- Would you be interested in an EGR removal kit?
- SeaFoam (not again)
- Greddy issue: need help!
- just bought yet another max
- Rear Wheel Bearing Issue.
- Suspension/Handling Overhaul
- 2009 4th Gen Calendar REMINDER!
- Front end wreck.
- Drivers side axle
- suspension help
- question about an intake install on 95 maixma
- radiator overflow bubbling
- Cold air intake question
- Bad ignition switch???
- suspension and brakes recomendations on a budget
- Lower control arms 2 or 1?
- kinda dangerous wiper problem
- Nankang NS-II Tire Defect Question
- Auto tranny on the way out?
- Will it make my signals brighter if I swap 1156 harness with 1157?
- TPS code when on highway with cruise
- How to replace light bulbs?
- My first SES Light
- Retrofit Projectors
- Whining Noise - Maybe Water Pump??
- HELP!! - airbag replacement
- 00VI swap help
- Crumbling Head Rest
- TRANS issue :(
- Exhaust problem, catalytic converter?
- Extra sensor pipe?
- Best muffler
- Odd noise on start-up
- exhaust problem, need opinions and help...
- Misaligned Core Support?
- 3.5 Cam's
- Problem taking rear rotor off
- Help with overheating problem
- MAF Adapter
- 03-04 infiniti 17" five star on 95 max
- Bank 1, Sensor 2
- my hood went BOOM!!! (radiator blew up)
- Where to buy solenoid for starter, or starter?
- hid fog lights
- Tiniting Fogs
- ECM/wiring problem - Master Class!
- FIXED! Condensation leak from A/C evaporator
- Calipers really starting to go... Whats the best price? You have found?
- Need Help with AC
- EGR Codes
- Starting Problems "Checklist"
- wat the freak!!
- rpms sticking at 1400 and 2300
- Cracked the plastic to the clock
- Engine Stuttering
- Been a long time
- 95-96 Outer all clears on Ebay
- Service engine light
- 00vi swap help needed.
- fuel guage not working
- Should my steering fluid reservoir gurgle?
- how do i get rid of the air bag blinking light....i have a 99 maxima!
- Fog lights not working
- abs light on 97 nissan maxima
- Any benefit to replacing lateral link bushings?
- Need weird help!
- Windows, locks and 1/2 of the interior lights arent working
- Cali spec knock sensor replacement
- The Dr. says my car is sick and old.
- 2001 springs on a 1999 maxima gle?
- Replacing engine
- keyless Remote
- What to do for general maintenance on my A/C?
- How do I know if I have LSD?
- brake lines
- rear brake light woes
- Ebay bulbs vs HIDS?
- digital clock keeps resetting?
- Repainting my 96 Maxipad
- O2 Sensor Help
- 95-99 auto trans stock shift points?
- Ton of things wrong with car..
- RPM SIGNAL for msd switch. HELP NEEDED!
- Dropping tranny-maintenance suggestions
- High Output Apt Wire...
- Wheel Size/Fitment Help Needed Please
- aftermkt exhaust question
- Anyone have some type of Performance meter/ MPG meter on their car?
- installed new motor, now problem with trans.....
- Question about Auto-RX.
- BIG Issue after clutch install
- Unknown suspension noise...
- 2001 maxima coilpacks work on 1999 maxima?
- License Plate Lights, Sunroof Motor
- Photo Request: ’98 Factory Installed Spoiler
- Wheel bearing replacement require alignment?
- Window Modulator broken, How to replace..
- Radiator? Which one is best (several listed)
- Bad Gas Pedal position?
- Sunroof repair
- brake trouble
- Tokico HP Blues
- strating issues
- Lack of power?
- URGENT - Hard steering after CV axle & Lower Control Arms Replacement
- shifting from 'D'to 'N'
- gray tilting headrests??
- Got an alternator issue...maybe
- Comparison of Eibach and Tokico springs please
- starter? ignition? searched with no answer, help!
- maxima grill
- Charging System Help - I'm Pulling My Hair Out!!!
- To all those with Aftermarket Exhausts...
- motor mount bolts
- service engine soon light
- Live Search cash back that could benefit you
- 3 misfires. Need help please.
- Bolts Breaking
- Mods
- OEM Spoiler Mounting - Same On '98 and '99?
- Did The Fog Lamp Mod...
- Managment system?>
- PA Safety Inspection- Power steering pump
- Rear Spoiler Plastic Type?
- Cali or fed?????
- Which gas/ oil / spark plugs do you use ?
- Has it happened to you before?
- Bumper Paint Job
- exhaust clip
- LED light bulbs
- how do i fix this codes ???
- Soo i got hit and the....
- Cat Back
- 3000 Watt amp too much for the max to handle?
- auto to 5spd
- CaT. Converter
- wreck w/PICS*
- Inconsistently occuring CEL codes
- GXE to SE door handle swap
- 350z Seats in 4th Gen- With pictures
- Throttlebody Vacuum Ports
- manifold absolute pressure sensor
- Bumper light rewire
- grey interior swap
- Buying Magnaflow muffler: Street series or Race series?
- Car back online - Only took like 8 weeks
- tokico hp blues bs illuminas
- Brake lights wont go off? wtf?
- suspesion overhaul
- Symptoms: Bucking on the highway, no coolant
- The ever hunting search to find a 36" 6 rib belt. lol
- Any Paint and Body Guys Out There? Spoiler Repair?
- Whistling noise on the engine room.
- WTF!? Why would my rear speakers be like this?
- front motor mound problem
- Check out a review of the Nitto Invo [video]
- Keyless entry not working
- For you that have a FSTB installed.
- Engine light on
