- Pacesetter exhaust (experience only plx)
- cleaned tb and iacv....what's the residue?
- Horrible thumping/droning noise 50-70mph
- how to fit millenia rims?
- Factory & Viper alaram?
- question about 5th gen
- NGK Iridium's...Anyone using these?
- Tranny Maintenance Question ... at high mileage
- Need Help!!
- Hi-flow cat?
- Anyone with Tenzo RS-5s?
- Need Help. ECU Code 0413 (p0154)
- quick question about wiper blades
- How are Progress springs?
- starting question
- 95 Max won't start sometimes
- Shocks and Struts
- where is the alarm system located
- Coilover sleeves and springs.
- Yes Ill take 2pc fried chicken, 1 ecu
- NGK Copper Spark Plugs
- Driver door got smashed by a hit and runner, recommendations?
- What do I need to use an after market stereo w/Bose speakers?
- Is it the knock sensor?
- tranny service??
- Throwout bearing?
- ebay MAF filter adapter
- Profile on stock alloys?
- Vitek/Stillen LSD....
- Air Intake System from Ebay
- Recharging my a/c!!
- Any ideas?
- 4 letter EXPLOITIVE! how did my battery die overnight?!
- Vandalised Max to total loss, need help
- HELP! (fog rewire didnt work!!)
- Suspension problems? Not sure
- 96 Maxima- Hard Start in the Morning
- Brakes too young to squeal constantly?
- Alarm Confirmation
- bye bye max :(
- The Best Exhaust?
- o2 sensor question
- Harsh vibration
- How to adjust idle?
- Shaking at HIGH SPEED
- question about k sport coilovers
- Hard starting problem!!
- For those who service their own brakes
- New Pics in member's rides
- Bypassing the KS. A Bit Confused.
- Wierd Acceleration
- codes P0325 & P1760 PLEASE HELP
- Manifold Absolute Pressure Sensor Re-loacation
- Projector retrofit guys...what are you using for a bezel?
- Automatic Transmission Rebuild
- Advice Needed!
- Power Slots Worth It?????
- Problems w/ 4th Gen Factory Alarm System
- JWT pop charger filter question
- Front Big Brake Kit
- 1st grounding cable to install?
- 100k maintenance done
- Problem with digital climate control bulbs :(
- Those d@mn codes!
- Bearings??
- Wiper Arm Linkage Installation
- Sunroof Repair
- Mounting Air Temp Sensor after CAI Install
- Almost the owner of a chameleon maxima
- Lip Kit: Quick Question
- squeaky struts
- Stillen Kit question
- It's all coming together now!!!!!!:ben:
- Found Oil Leak
- 1999 maxima for sale on ebay
- I hope someone can help (Parasitic Draw)
- Fog light rewire mod
- Greddy SP2
- Need Help!!!
- P0443 problem with pictures
- Stop/Brake light Switch
- Cat-back death
- Where can i buy front lower control arm bushings?
- MEVI, ECU, Y-pipe, Race pipe, Rotors, Pads, Stillen Kit
- Oil Filter dangerous location
- Foot blower for passenger side?? where is it?
- Clean IACV Ticking
- Washed/waxed the car (PICS)
- Sorry if this is someone's, but what was he thinking??
- y pipe
- Light me up, but i need to know... What do our cars run stock
- Air Compressor
- rear defroster switch bulb
- A few questions for a 96'
- tranny questions??
- Lag up high...
- Growing Automatic Transmission ... wallet is not happy
- fender panel or whatever
- Guess what? Illuminas are the shiz
- Spark Plugs
- What type of grease can i use...
- Idle Will Skip????
- question on stillen bk
- Cigarrtte lighter plug not working!?!?!....
- Im gonna make some Led Tail lights (pics)
- Future Project
- What can I use to stick the letters back on my trunk?
- Will these fit my car?
- Spider Bulbs??
- 0115 code question
- Want to hide my lcd, fake faceplate help....
- Problem with the digital climate bulbs :(((
- marvel mystery oil caused engine to smoke
- Brake Light stuck on.......
- where is the bump stop ASAP
- What the heck is this?
- coolant leak issue
- help... the whining
- digital gauge cluster on a 95
- Are my tires done for?
- Another Fidanza thread...crank senors, etc
- Ects
- steering clunk
- write up
- JUST got alternator replaced, tested, battery tested, STILL SAME VOLTAGE!!! $*#(@)$*)
- OEM Foglight replacement
- Bose Stereo System
- Tire Help!!! (nobody is answering in tire forum)
- removed heat shield, will car burn??
- 5th Gen clutch conversion?
- CAI = Hydrolock???
- Cold Air Intake
- $1500 Black 4th Gen
- Any electrical geniuses?
- How do you adjust your clutch?
- Coil Packs
- those with blehmco stage 2 ltb.. lil help here..
- Black leather seats
- can't start the car, help.
- Flywheel upgrade or MEVI
- Might have to junk my max
- Led Interior
- trouble with my MAXIMA
- Please Help! my gears are not going in
- Cross drilled slotted rotors/
- Need new clear bumper lights: best price????
- What's the difference
- Finally resolved my ignition coil problem thanks to all of you!!! :)
- Looking for Hella Horn sound clips on your 4th Gen.
- Finally its all in
- ptatohed's "interior decorating" (pics)
- 00-03 ksports will they fit on 4th gen?
- maxima UDP OBX any good, anyone has it?
- Those who replaced the turn signal bulbs with LED ones...
- What do you guys think about this maxima for sale?
- Drives weird while engine is cold... anyone else have this problem?
- Changing Spindle, what else should be changed?
- Auto Hesitates under quick acceleration
- using 194 bulbs in the 98 max gauges
- Stock Ride Height
- remote
- damn car problems
- O2 sensor question
- Heat and A/C fan speed not strong?
- Y-Pipe Question...
- Titanium 2k3 or Silver 2k3 rims on Sage Mist Green max?
- Where are these located?
- BCM knowledge needed
- can anyone identidy the name of this part on the dash?
- Tach not working
- UR Pulley - anyone know the size of the belts I need?
- Any Pix of....
- you know ur tints are dark when.....
- Blue gauge lights in 98 max
- Brand new OEM Alternator BAD!
- So...it was a rough night
- Cleaned TB now high idle
- Nonlocking To Locking?
- 00 and 01 VI
- Need a picture of the parking brake switch
- RW rims????????
- HELP!! did an install and now have problems
- those of you buying matty sc plate, piping on ebay
- 95-96 clear headlight.
- guess i should have changed my mounts.
- Warpspeed SUUUUKKKKSSSS!!!!!
- Tein Basic Coilover Any Good?
- Mirror Signals
- stillen Y pipe ??
- Those with idle issues step in please
- Something on ebay I found for A32...
- Stock suspension / Higher miles...
- Loud Rubbing Noise
- Possible Anti-Theft System problem...
- M/T Flywheel Bolts VS A/T Flywheel Bolts
- Odd dealer statement on PCV valve replacement
- Parts for new strut/springs
- Whistle in heavy traffic when at a stop
- fuse for cigarette lighter
- Subframe pad?
- Z32 caliper part #'s?
- Lightened flywheel worth it?
- Speed Sensor
- installing stock fogs
- Intake manifold.
- found this out on my i30 today, kinda cool
- lost interior lighting: door, LED dome, cathode trunk
- someone tried to steal my max last nite
- Am i knocking??
- Stillen supercharger charger pipes on ebay!!!
- Need help with heat. ALL OPINIONS WELCOMED!
- Maxima & 300zx???
- Give Me Head Gasket
- Question ... about cutting stock springs to lower.
- roof antenna
- Wrecked my black GXE
- ebay if the day
- please post pics.. max w/ hr's, 17's and a 50 series tire..
- Haynes Repair Manual (CD/DVD)
- loud belt need help
- need tranny help
- fog lites wont work
- HELP!! Car Won't Start
- Front Pipe replacement $$ any other solutions?
- Snake Skin MAx
- Effect of an RSB on GXE,SE,GLE
- 350Z 18's or G35 18's?
- UDP belt tightening
- Has anyone put a new rear view mirrow w/temp & compass on??
- 2005 350Z wheels on 4th gen
- How many miles do you have?
- Did the hub check, what next?
- need to match struts, springs, rims and tires
- Fidanza Flywheel opinions
- CV boots - securing bands
- Inake Question For 95-96 Max's
- Gear ratio Auto
- Spring Diameter
- Spoiler Rattling???
- Anyone know how to adjust rear Konis?
- Control arms and Ksports
- Price to install Stillen kit?
- M3 Bodykit?
- engine swap
- Y- Pipe Install Question
- disconnecting power steering
- 00VI Idle?
- projector retrofit guys: what are you using for bezels, shrouds & sealer?
- Car starts with OUT the clutch!?!?
- 00 rotors on a 4th gen
