- Need help with debadge
- help asap! keys keys
- 205/75/15 FIT ON A 4TH GEN MAX?
- what is this?? axle shifting or a mount??
- Car not starting?
- Making cigar lighter permanently on
- Black Shifter Trim/Bezel (Manual) and Shift Boot
- Alternator or something else? 2 dead batteries in 6 months
- Auto Transmission swap
- Installing Factory Keyless Entry
- Help me pass emissions!
- Knock sensor/ECU has me in a RAGE!
- Would you sell your Maxima for . . .
- what to look for when buying a 4th
- Anyone have door lever/lock issues?
- New alt is only putting out 13.3 volts with a highly accurate DMM.
- 99 Maxx Cuttin out at full throttle.
- Have to pump brakes for good braking
- how do i get rid of a fashing airbag light again on a 99?
- 97 SE just blew transmission- part out car?
- Making a killswitch for your 4th gen...
- Need help from people with mild suspension drop....
- how do i track this down?
- another hard start thread
- engine sourcing/prices
- is it my charging circuit? or battery?
- TOB or ISB
- Cali Spec front precat
- Help diagnosing noise from front after ac runs (maybe radiator fan rubbing?)
- y pipe replacement
- worn ignition switch
- still studdering after new motor/trans/axel
- Idle speed minimum
- Nissan Maxima Dash Kit Trim Parts
- Knock Sensor Trouble
- UIM Heat Shield/Wrap
- Improving the lights
- crank pulley seal
- the new maxima
- Coilovers in my Maxi? Shes old, and I only gonna have her for a year. Should I!!!???
- Anyone know what this is??
- anyone know what this is
- AC Air Conditioning at Idle not working
- Where do you get your paint?
- interior lights don't work
- Where to find replacement side trim?
- Say HI to Carlotta!!
- Amber, Clear, or Smoked corners.
- How do you know if your ignition switch "was" bad?
- Going under the knife....
- Any feedback for a velocity stack?
- Service engine light keeps reappearing
- Door open light on.
- Look what I bought over the weekend!!!
- Fuel Injector service suggestion
- Tranny Help!!!! Car only moves in Reverse.
- Swapped out my JWT and now have CEL
- Just bought a Pearl White SE 5speed!
- Need of ideas/ motor
- axle came apart when replacing control arms?
- lookin for a sig made up
- Cmaxima's Mini Summer progress thread.
- Experience/activies next to user name
- Loose exhaust!
- Cosmetic Corner Light question.
- Reunited with my first car, after one year and two other owners!!!!!
- Does Frankencar exsist? I can't find a website...
- side marker wiring harness connector???
- Is anyone here using an Ebay knock sensor?
- Ignition Key - Can I Drill It?
- Which cat? Vibrant or Magnaflow?
- 99 Maxima Starter got really weak then back to normal...
- thinking about replacing my cat..
- Alternator question
- Windshield Washer
- POSSIBLE AUTO TRANNY PROBLEM......need help ASAP
- starting issue
- Swapping 99 Maxima seats into an I30 - SRS question
- manual tranny fluid?
- Really rough idle
- Just Seafoamed & Replaced My Knock
- Throttle gasket
- Starting problems Help
- Rain shorted system, need help troubleshooting
- please help with my problem.....
- intake manifold swap from 00 max.
- Carbon fiber gauge bezel trim
- 95 ecu
- air bag light - intermittant
- '94 maxima rims fit onto my '97?
- MAF SWAP QUESTION.....
- my car has a ghost!!! what can it be???
- Black Interior swap question
- 97 Max...rough idle and hesitation
- Aackshun's Current MPG Thread
- Quick question for heater core hoses
- Coolant needle goes down under acceleration
- Dudes, anyone have a hood propped 4th gen?
- Wearever Gold Brake Pads - Front?
- Automatic Shifter indicator light/ light around cig lighter
- The real Fast & The Furious Maxima on ebay
- woke up this morning and discovered someone tried to steal my car
- 95 throwin some codes
- Can anyone diagnose this please?
- Broken Bolt off my AC Compressor for Alternator replacment? Options?
- help 98-99 cluster swap in my 97
- Pulls left and right
- Indiglo gauge install...
- Red/Clears Done! Couple Tips Learned...
- 300zx brake parts list
- woke up sunday morning 7/10/11 to this....
- IRRITATING Idler Tensioner Pulley Assembly **NEED HELP**
- Ct Emissions
- time to start retrofitting
- struts and lca bushings
- 200K Mark...
- can i just use a regular rubber clutch line instead of stainless steel...?
- Ignition Coil Resistance
- Weather Stripping
- Thoughts on these...
- Gotta re-do my oil pan gasket
- Nismo Decal On Hood
- cluster issue...
- clutch problems
- Fuel issue
- P1400 WTF
- BRAKE LINES
- oil Drain plug stuck
- Fenders 97 (removal)
- any ideas on restoring a steering wheel?
- The grimlins are back....Maybe TPS?
- Rear Wheel Bearing Replacement
- Keyless/Door Lock/Trunk Lock Issue
- OBX Short throw shifter
- fogged up exterior windshield
- FS: Another chance for Gauge ring GD
- Stock alarm won't deactivate
- vibration/shaking problem
- feeler gauge tps
- How fast will an auto 4th Gen go?
- Any of you 4th geners out here know what this is
- another problem...with idle
- HELP! engine timing
- raxles is dead?
- ViciousMo and his tranny
- How do you keep your sub box down?
- Goodbye .org :'[[
- bought my turbo today
- If anyone is interested the Aluminum Gauge ring GD ends July 4th 2011
- major OIL LEAK any ideas
- Need opinions on how is this motor running .
- Strange condition on 1995 Maxima; could use some help!!
- air bag light reset using bad door trigger switch
- help! another crank pulley failure
- 01 vlsd swap into 96 problems...
- Would you be interested?
- 4th Gen picture thread
- car wont start.. fuel issue
- O2 spacer post CAT
- help with exhaust manifold gasket leak
- Petroleum jelly and oil pump?
- please help asap. my car wont start and im about 500 miles from home
- Fast Idle CAM not functioning
- cant figure out the wheels
- New Moog springs which side goes up?
- soo many codes
- muffler/exhaust
- how much compression
- What lights am I missing???
- Rotors milled??
- New OEM clutch installed by shop -- feels too soft -- Need Advice -- Shop Nightmare!
- Need replacement seat for '99 leather - what years?
- Heating control lights out - repair?
- help with minor running issues
- xskydivingdudex's Build Thread
- Clunky Noise + Putrid Smell + Smoke = Bad Pulley?
- Sensor Compatibility Between Years
- When changing spark plugs....
- lookin for HD 4th gen wallpapers - any ideas?
- Power Antenna removal
- still no power
- Timing chain replacement...is it worth it?
- tail lights will they fit ?
- Grinding noise front axel
- Its Been a while, having some issues. =/
- sunroof wind deflector delete
- Restored Q45 Steering Wheel Swap just installed...
- Bees! Yes I know.. but ive tried everything
- Sway Bar Link Impossible
- What is the correct parts for the oil pump seals?
- What's the color code on your front springs?
- Rack and Pinion Boot
- wont turn over and start. help, tonight! does run though. alternator? starter?
- Cattman Exhaust?
- Are SE springs firmer than GXE or GLE?
- numbers on camshaft brackets
- Iacv noise killing battery
- Car wash turned my rims black?
- NEED HELP ASAP!! Coil pack screw broke off in Valve Cover
- 1997 Maxima What is that bar under tie rod?
- sorry but i had to show yall
- PLEASE HELP! Sun roof stuck open!
- Which plugs to buy
- blown coilover keeps messing up wheel bearing??
- Interior swap
- found some bad rubber
- middle seat belt in '97?
- Universal Boot
- Different Tire Size
- 98 max exhaust prob
- Vq35de Swap Cel Help
- Car jerking, hesitating, suggestions?
- Tie Rod End
- Weird Shifts in 2nd 4th and reverse
- A New and Different Blower Motor Resistor Question
- 99 Maxima,Bad knock sensor,Oxygen sensor.
- Fuel Door Switch
- heat panel only works on 4
- Coilover kit
- headlights/fog lights won't turn on?
- Stuck on strut knukle
- quick help needed... strut noise...
- Taillights intermittently working
- (somewhat poor) college student needs tire recommendations!
- Lugnuts
- short ram or cold air
- airbag light and seatbelt light stay on... reset?
- Could really use some help with interior
- Vibration during idle and hard acceleration
- A find?
- no power to rear drivers door
- Fix for pump leak?
- Replacement Key with Transponder - cheap place
- The deal of a lifetime
- Cheapest/best place to buy suspension parts
- another car shutting off thread :sighs:
- 95 se panels
- Clicking noise from the HVAC blower motor?
- Changed Break Pad; should I have greased the cylinder of the caliper?
- lagging downshift. auto trans help
- ABS warning light
- Bose deck removal
- wheel bearing
- vibration at highway speed...
- what tells Coil packs to fire?
- Two Coils not Firing and wires with copper showing.
- squealing belt sound on ignition.
- Timing case is off, what a pain
- Maxima stalling in D at stop, choking when accelerated, ALL 3 O2 CODES
