- how long does Maaco last?
- what can I do with a tan interior?
- Where is my speed sensor?
- HAs anyone ever bought a front bumper cover from ebay?
- Where to find....
- Need Help removing headliner 4 Sunroof repair
- EGR Valve code
- Spoiler clip repair?
- Engine Code 08 07 on a 96
- Dash Kit
- is this a good cold air intake??
- Need to Know "How-To" for FR 300ZX Brake Upgrade
- question about exhaust and y pipe.
- High stall TC Questions
- cali to fed conversion
- Ecu 0304 And 0407 After Quick Start-stop
- Cali Or Fed??
- Maybe changing bore size on engine build??
- how is ur gas mileage? mine SUCKS! dont kno why
- ok, here is a project which i always wanted....
- leaking coolant..please help
- ANY ONE HAVE RACE VIDEOS? for MAXIMA
- Update on Brother vs. Brother on the Max
- Ideas on remote start
- Need opinion..
- Are AE Headlights clearer than OEM Headlights?
- Question about getting leather seats / hooking them up
- Question about 2 ECU Codes that came and went..
- help me with my brakes
- MOD: ecu/ fuel / stand alone
- http://members.cardomain.com/ledmaxi
- Tokico Illumina shock/spring combo
- OPINION: Stillen aero Paint job
- cheapest fog lights
- If you want LED Mirrors step inside!!!!
- steering rack+ pinion adjustment procedures...
- LED's in Hazard and rear defroster
- Starting Issues (not starter related)
- video of maxima with cams?????
- How to take off Rear Door Panels????
- starter staying engaged
- waddup ya'll
- Cattman Headers/Y-pipe
- anyone ever bought their totaled car?
- Brakes-ARGH!
- Question on Interior Lights
- Security light?
- Mevi??
- What springs/strut combo is everyone running??
- Foglights Rewire In Process
- D2S or D2R which are aftermarket replacements
- Best Intake?
- 2kVI
- Nedd Help With Exhaust!!!
- my steering is scary!
- Not my day
- MEVI Install/JWT ECU
- Thinking of buying a 1998 GXE...Salvage title
- Woohoo! Got reamed by the stealership!
- Anyone know how GC coilovers will ride with AGX or GR2 struts
- Infiniti I30 rear view mirror
- Where could I buy an OEM E-brake boot
- Tranny Flush
- Fule cut of on car w/ switch
- Automatic Climate control
- 1996 Maxima--Check engine light and other problems
- SANTA'S comming!! what should i get ypipe or H+R'S?
- Torque Steer - What can cause it?
- My Turn For Pics [56k Warning]
- Anti-Theft gone haywire on '95 Max
- Extra remotes - Options?
- timing chain rattle
- Speakers not working after battery test
- '95-'96 axle-back exhaust bend measurements?...
- Engine Idle Speed Will Sometimes Fluctuate
- Ignition key Bulb?
- Newbie question - 1st mod
- Use for blank tab next to the dimmer controls **PICS**
- Where to find Brake Pad Return spring? Please HELP!!
- Just painted my brake calipers **PICS**
- Help! Tranny problem
- fstb?'s
- #@$cking over torqued bolt.. ARGGH
- Carbon Fiber hoods
- MEVI or JWT ECU
- Just ordered full exhaust
- greddy sp2 for 95-96 on 97
- how do you like your budget b?
- need help red/clears install
- Photoshop experts
- Take a look -these any good?
- Auto Lock Works
- **VIDEO** Strange whinning noise from Alternator **VIDEO**
- Front end sound
- automatic shift knobs with over drive button...
- Speed Limiter
- Good price for b-pipe?
- Whats up with this?
- Check out my maxima, rate it!
- Can you steal 1998 Maxima?
- steering wheel compatability question???
- Engine Hesitation / Surge Problem
- Part behind rotor, scraping rotor
- Anyone else have this small problem?
- Cabin Air Filter
- Buying my first Max.
- Fuses keep blowing
- More noises ....
- Auto Start on 99 maxima se?
- Aftermarket spring and struts combo
- door panel replacement question
- anyone using denso iridium spark plugs?
- How Do I Remove '99 Ecu????
- auto sux...is there hope?
- Vibrating grumbling nosie below 5mph when braking
- installing rear springs? painting cars?
- enblems?
- Need a softer ride
- Exploded view of console parts
- How to change antenna?
- Finally updated my cardomain site.....need suggestion and comments
- Which cliper color
- LED Dome
- throttle body question for 96 max
- clicking sound from the brake
- tranny fluid
- Engine Vibration
- annoying exhaust
- exhaust questions: greddy sp2 and obx
- Thank goodness for extendes warranties (long story)
- Damn Mofos!! Thank god for Viper Alarms
- code 02 15 undefined??????
- 1st Time Pics (56k grow up and get broadband)
- CV Axle fix...
- ac blower
- Do I need a throttle body spacer?
- raybestos qs pads
- Does anyone have one of these spoilers on their max?
- Ceramic Pads
- Car is sick still
- car wont start..please look..
- white smoke on cold start for about 10 seconds...
- [B]Weird IACV & CEL behaviour - experts needed![/B]
- Do you guys think i could fit 350 18 with tires with tein stech springs with out rubb
- Engine knocking when cold?!!?!
- 97 max 96 ecu
- Tranny Slipping!
- Finally done with valve cover polish![pics]
- Oil Leaks x 3
- starting problems....not starter
- Help!!
- MEVI burnout
- Can I use transmission fluid for power steering fluid?
- Airbag light keeps flashing
- 1998 GXE Headlight Adjustment
- Wired Noise From Driver Side.
- vehicle speed sensor?
- Projectors for 9004?
- Motor Mounts... NEED HELP!!
- CF spoiler?
- Flying plywood damage update (Pic)
- Performance
- @-@ for a wireless remote module!
- Hello
- Lowest Suspension...
- Change the thermostat ??
- sticky transmision????????
- I need a project for winter, any interest in gated shifters?
- Car won't go need help now
- Problem On 97 Gle
- Gasoline Post
- Power Steering Leak
- springtech review?
- "Beating" on it in the cold weather?
- How to Remove Hood Security Switch
- OD button, and OverDrive itself is bugging out:
- p0402 code
- need advice on lowering
- My floor heat don't work........
- Emblem?
- CF Stillen Lip
- encounter with a maxima
- Programing new key(99)
- Newbie saying HI and needs help
- auto tranny issues! any experts?
- Rear window switch LEDs
- EGR valve
- can anyone tell me where the tek is to reset the ECU?
- ECU ?'s
- Help!!!!!
- Suspension recommendations
- Where to get Yellow H3 fogs
- Assist with BOSE speakers
- Anyone have the dimension of the OEM muffler?
- Warpspeed y pipe
- Wow, mechanics are dumb.
- Whiteish blue smoke in the am when starting
- Lower arm
- auto tranny problem ****s high and some knocking jsut started occuring please helppp
- IN PROGRESS, changing my gauges, where do I hook up the power wire too???
- Ghost Codes?
- help with tire size
- Progress of the valve cover polishing [pic]
- y pipes legal?
- how to kill speed addiction?
- Full alarm wiring diagram!!!!
- differential bearings
- Battery tie bar (pics)
- Wont Start!!!!
- need help(timing)
- Quick Question of offset on wheels
- exalta headlights possible fit 4th gen ?
- brakes won't pass inspection...
- 95 Maxima GLE
- illuminas with stock springs?
- cost of a 2k + tranny conversion
- cd changer for bose
- +20 HP mod on EBAY
- Erratic tachometer
- code**
- My Brake Booster?
- Guys with HIDs and eyelids....
- *PIX* updated web page with nos kit and headlights, take a look!!!
- noobie here
- hi, new here and have a problem with my car
- Does anyone know the volumetric efficiency
- Auto to Manual Conversion... $$$??? post your experience...
- new knock sensor no diff?
- Any1 w/ Pics of yellow fogs?
- Who has the Multi-Lock *Post Pics If you Got Them*
- I shaved my buttox.
- Question
- Where can I get the real aluminum dash kit?
- Check out my wheel gap!
- exhausting
- Bose Radio Cutting Off?
- what kind of lip is this?
- optima yellow top... Which one to buy ?
- just since i had time
- Can anyone help with an irratic idle?
- Gauges, Mileage, and Whistling w/ throttle
- Totalled Max
- Anyone ever feel their Max is a gas guzzler?
- Suspension Lowering Questions
- How can you tell if the clutch is gone on a maxima..
- custom enterprise bulbs
- Warp Speed y-pipe vibration... Help PLS
- Clutch is squeaky
- Buttons on Bose Head Unit
