- Small "DIY" on clutch line install
- Will it rub?
- Powerwashing around valvecovers
- Clutch pedal engagment
- Phantom Grip LSD Conversion
- o2 Sensor on Cat!
- help
- Flashing SES light on a 97 se 5sp
- maybe clutch problem
- Frozen hand braek, how do you guys deal with it?
- quick tranny/clutch question?
- HOW TO CLEAN IACV?
- heat guestion
- What is your gas Mileage?
- Front Calipers
- Replacement B Pillars
- Change water pump w/o changing timing chain tensioner?
- taillight mod maybe???
- i screwed up - tapped into a coil pack
- can you use?
- camshaft position sensor leak
- Knocking sound when slightly turning the steering wheel from side to side...
- exhaust opinions
- Finally she is dead.
- My key broke
- sticking calipers when cold
- There is some whird metal noise..
- Strut Bar Again- IS it suppose to be Straight
- Leaking after oil change. Please help.
- To Seafoam or Not to Seafoam that is the question.
- converts to HID + retro projectors . . . i got some questions
- easiest way to syphon gas (im not stealing)
- Retrofit In Socal?????
- Airbag Light Flash Codes?
- flowmaster 40 clip
- Cruise and radio related?
- Windshield Washer Question
- MAF Question???
- GLE vs GXE floormat color?
- Think 96 would look good with 97 se rims?
- Installing New Suspension....
- Attack of the Type-R maxima...
- intake manifold does any one have an after market one
- Problem rear is saggy and how can I...
- Combination switch going crazy..
- Any ideas? - Car doesn't start when idle for few hours...
- Clear bumper signal lights
- platnum laser plugs
- Should i take my lip kit off for the winter?
- Which coil pack?? Please advise!
- What size belt do I need for this setup?
- growling noise from engine
- overdrive not working
- Four Starters At 285k Miles
- I just fell in love with these rims
- Cold Start issues
- How much can i get for my car??
- Is the 94 strut bar the same as the 95
- custom shift boot
- Wrecked my Max
- new parts
- can someone search for me?
- 1,2,3???
- Troubleshooting misfire in cylinder #2
- stilllen lip kit installation Problem *PICS*
- Hard pulling after 2000RPM
- Series of bad events....check out the demise of my Max
- Replace Clarion OE AM/FM stero Cd player
- 1 Piece Headlight Question...
- CAI - will i have to cut?
- Got a new problem
- What The Hell Is Going On!? Help!!!
- car got fuqing stolen...
- Custom milled wheel spacers...anyone?
- Brakes Squeaking noise
- Problem with the fog lights...
- which is better cattman or warpspeed
- jwt cam
- Fog lights questions....
- 20" Wheels
- Projector dimensions- what do you think?
- budget is now on ebay
- Transmission Rebuild Kit??
- hose on the tranny?
- things to look for when buying 4th gen
- white clock mod question
- WTB: 01 maxima AE 5spd tranny
- pnp hid kit on 1 pc headlights
- ebay camber kit
- Anyone with Carfax able to check on a vehicle?
- Heated seats?
- Front Hub replacement
- Help with 4 codes 0302, 0304, 0702, 0111
- KS not reading any resistance at all?
- Is there a HOW TO on cleaning the EGR without removing it?
- Wondering about 300zx caliper fitment issues
- '94-'01 $15 ss braded clutch line helllzz yeah
- question about 9007 socket!!
- 4th gen Vlsd axle question.
- Three Wheel Motion
- Where is park/neutral switch?
- help
- JWT ECU Upgrades
- SAFC/VAFC users step in + more
- P!c$ 0f My 99 M@X
- Crystal or frosted clear tails.
- Clutch reservoir slowly leaking - Clutch slave cylinder hose? *pics*
- Help with codes..
- How much for a decent interior for my car?
- quick question?
- Alternator and power steering belt.
- How do I know timing chain is bad or not?
- New front shocks...
- AE'd Headlights/corner lights
- Issue with 300zx calipers
- Headlight Housings will not clear!!!
- 4th gen owners with 5th gen Stock 17s
- What the best stuff to use when cleaning out the VQ30?
- Spoilers
- can the GC'Z still do it??
- Smell gas in 95 Maxima
- WTB: Used VQ30DE Motor, or bare block..
- Wrapped Y-Pipe
- thunk in reverse..?
- big decision are being made here
- Plenum removal help!!!
- supercharger ?
- help my hand brake light on!!
- The "Rodney Dangerfield" of auto parts
- Brake squeal when reversing
- Coolant Loss/Thermostat
- Hesitation while accelerating
- Jazzin up the max
- New lighting?
- So i cant drive my max at night now
- Courtesy Nissan Fog Lights
- Considering selling a 99 SE 5 speed - replace clutch or let buyer choose?
- What color is my car
- Coilover installation question
- Question? can a 3.0 4gen chirp 3rd
- Lightened underdrive crank pulleys?
- Have you shaved your antenna?
- Taking off Dashboard problems
- Does anyone know how much a Budget B-Pipe goes for?
- FLYWHEEL Question
- Ginding From Front End
- New CAI From Ebay
- sounds kinky, but gets annoying after a while
- please help me out???
- How do you fix the hazard switch
- A new way she won't start...
- 95 maxima horn, please help!!!!
- Clutch problem
- excessive play in steering wheel***
- 6spd writeup for 4th gen??
- What intake can i get for my 98 max auto
- UNGO alaram
- What is wrong here
- Wiper pivot mount
- For real 2.5K for a repair? Need opinions
- im an ebay noob...
- 2008 Hesitates
- Tranny bolt size
- Car-Sound High Flow Cat, or Motostorm UDP
- Tan interior with black dash??
- 95-96 fog light clip?
- 6th gen bench seat in 4th gen?
- help with heater
- Emanage Blue Questions
- Anyone else notice excess heat from inside cabin when accelerating?
- Failed emission
- Strange Oil Leak
- transmission rebuild write-up??
- How do you tell if the HID bulbs are authentic?
- 0302 (EGR) ; Light's ON only when i'm pushing it ...
- Airbag Control Unit (ACU)
- ~viberation~ please help
- To HID with white or yellow bulbs in yellow IS300 projectors?
- I30 Dash
- fuel injector cleaner
- Taller tires on stock 99 SE rims?
- ebay suspension question
- Alternator caught on fire
- Got my new Modas Baby. Check it.
- fuel rail adapters
- Do not overfill brake resevoir!!!
- Air intake recommandation.
- Destroyed 3rd gear and Diff Bearings?
- closed loop module
- My radio, clock, cig lighter, and washer fluid system died today
- Replacement Air filter
- No shifter resistance (manual tranny)
- leaking engine coolant
- Sqeeking noise after UDP install...
- 0210 CODE.
- anyone know anyone with a 45 offset set of rims?
- Anti-rattle spring clip
- passenger side axle
- o2 simulator - where can i get one for my 99
- Anyone had a cracked radiator?
- What the heck is this connector for ?
- Giw to install my HID conversion kit on my 4t gen.
- tranny problems :(
- Crazy Idle when engine cold
- Leaking rack and opinon steering is......
- front hub assembly
- Who here likes the stock gle honeycomb rims?
- Selling price for a 96 SE
- ebay red clears
- cruise control problem
- Add to crazy97's post : "Starting problem"
- This sucks... broken shifter.
- CAR NOT STARTING CLEANLY!
- any1 know anyone with a 45 offset set of rims?
- Homelink/garage door opner
- I want this keyless entry pad so bad - but apparently it's only for "newer" Nissans?
- Mystery Electrical Problem
- Knock Sensor
- Does anyone have a Cosmo Underdrive Crank Pulley?
- Will these tires fit on my 99 maxima? 245/40/r18
- Door lock issues?
- what is happening
- what sealent to use for fogs?
- question bumpers.....
- need help with a few questions
- So, my alt. caught fire today...
- problem with starting? help plz!!
- Ignition Switch How to
- Burning up RF brake pads only
- Holy bent caliper batman!
- Need help quickly! New seat + no side airbags= Oh no
- Block Heater Location???
- Maxima vs. Deer--Son of a......
- smoked tail lights
- Glare Sheilds for headlights
- Yep, I think my alt went out today
- Nissan “diversity” antenna adapter
- clutch problem/question
- D2 drop hieght
- did one of the four b pillar plastic removals today
- Squeaking when letting out clutch, chatter?
- '97-'99 LED Tail Light Protoypes!
- r33 gauge cluster!!! check it out!!
- SS clutch line???
- Final drive in 5-speed 4th Gen. bought the farm...
- Cant adjust Belt correctly, loud squeaking
- Infinity FX Projector Shrouds
- Front strut replacement
- Story with cel questions at the end
- Need help with strange noise
