- Hack the BOX!
- Courtesy Mevi Variable intake runner kit from
- Weird noise when steering wheel is turned all the way left
- Thanks, In Advance
- Fair Price for 97 SE 5spd
- Trunk.
- Window wont ROLL
- 50/50 Swap
- 1999 SE Manual 5 speed for sale 6500$
- Ugly Tan Interior Now Partly Black
- Rough Idle and Stalling - 99 Max
- Which one looks worse?
- Learning the proper way to drive a 5spd
- Any difference between OEM fuel filter and aftermarket?
- BBS Moda Wheels
- Coil packs that fail under 50000 miles
- What's under warranty with 89K miles?
- My first pics of the Max
- holy Maxima exhaust!
- Back-up Camera
- Where to go to fix a trunk lock?
- Worth it?
- LSD & ABS - How do I tell if I have them?
- headlamps look ****-eyed
- opinions/pics on ebay illumina/spring combo
- What type of ATF does everyone use?
- few tranny questions
- Stock intake parts
- Where Is The Starter?
- o2 sensors install....easy!!!
- junk yard search?
- Ok, what FRIGGEN size is the flare nut on the side of the EGR?
- Battery drain and horn won't stop
- Question on 300z BBK
- Slipping All Over.?????
- New Maxima owner!
- Door lock problems
- Wheel Ballance Problems?
- sudden loss of power
- My Gas Mileage Went Up.. Read Me!
- Im dumb when it comes to installation.....
- Rpm's Dip When Fogs Are On?
- New Pics of Max now lowered with Tein S-Techs/Illuminas
- Egr Flow Malfunction!
- Indiglow gauges for 97 max
- O2 sensor keeps going out
- Need some pics
- 5th gen alternator
- SP2 Vid Pt 2
- need some more kick!
- Pace Setter Cat Back
- Snapping crankshaft pulley bolt off...
- Megan or OBX Cat-back?
- Need Help 97 Max Stalling
- What is the spark plug of choice?
- Idle RPM speed screw question
- 1999 Max: Recurring 0409 (P0133) Error Code
- Free to good home....
- Bottom line about Maxima mods
- Knock sensor for Cali Maxima
- Knock Sensor Risks
- Buying Advice on Auto maximas
- Nissan family.
- Camshaft Position Sensor
- Replaced knock sensor, something not right
- MONZA Pacesetter exhaust
- where to run power wire through firewall on 97? PLEASE HELP QUICK!
- Headlamp Assy
- Hi there, new to forum, got some questions :s
- Got a problem with my knock sensor....HELP!!!!
- SuperFlo Y-pipe exhaust clip.....
- PDF format parts list
- Sick Power Antenna
- udp
- Anyone do their timing chain tensioner themselves?
- Muffler recommendation
- Found oil in intake midpipe
- rotor question
- visor mirror covers...
- Drop Resistor Ohm rating...12 ohms or 12 mega-ohms
- UR pulley owners
- Trailer Wiring
- coolant thermostat / temp of lower rad hose
- Is it Possible to Tint Stock Orange Bumber Lights
- What does everyone think?
- First Vid of SP2
- Parts dealer of choice?
- Fog light re-wire write up
- 0201 Coil Packs ???
- Wear your seat belt
- Visor light out!
- Timing chain life
- autozone mufflers
- 95's With aftermarket flywheel, please chime in
- Code scanner
- what about our top end?
- brand new wheels and shoes...cardomain updated...what do u guys think?
- Staging Lane Tragety.....
- 1205
- Dead Digital Clock Display
- Coil Question
- Strut overhaul
- 2000-and up maxima vs. 95-99 max
- EGRC solenoid valve problem...help?
- Passenger side mirror replacement
- wheel spacers?
- WHAT TO DO TO IMPROVE LAG on ACCELERATION
- EGR Valve Code ?
- I have a mod idea...
- Nokya Arctic White?
- 4gen tranny leak (diff bearings)
- Replace stock seats?
- HELP please, I feel like an idiot...
- and the modding continues
- help with walker o2
- Reverse Light Mod
- Well...look at what I got this weekend***PICS***
- Lucas ATF additive
- Octane question
- Knock Sensor ????
- Question About TPS ??
- New Headlights?? and Y-pipe
- What am I missing? Altezza owners.
- Now a 4th gen owner
- what is the P0745 code?
- AE Headlights
- Steering Wheel Shake above 60mph.
- Clear corners?
- Bose LED Read-Out.....Blacked Out!
- what other tire size can i use on sawblade 15" rims
- Electrical problem..car won't start..alaram stays on
- Strut/spring assembly question..
- 95 Maxima fault code 1205 Line Pressure Solenoid Valve
- help!cheapest price on KYB dust boots?
- Auto Trans Valve body Removal?
- Gas tank will only take 17 gals. why?
- Estimated Cost?
- Bose Repair from Stickies
- Just washed the max, first pics of my car with the tint (56K hell)
- location of 2nd o2 sensor harness?
- JET reprogram vs other ECU
- venom 400
- New to the forum and new owner of a 99 Maxima SE Limited... What's up everyone!
- changing plugs right now.. BUT
- Tranny cooler
- Greddy Exhausr ???
- New Paint Job, where and how much?
- Where to buy Starter?
- A'PEXi pricing for 95-96 MAX
- Just got my Remote from eBay!!!
- Greddy Sp2 Install problem... quick
- max pics
- just got back from the stealership...
- Thinking of installing MEVI is it Worth it???
- Quick Install for chrome gauge rings and matching bezel??
- cheap mods for loudness
- Weird low-pitched noise and more
- 2 new pix
- More New Pics Check It Out
- Guys need help to install HIDS
- Oil Pressure sensor
- Loose connector in engine bay?
- Rear Brakes Question
- LEAK!!?? Near Sunroof switches
- How To: R&R right axle
- Weird Stalls, HELP
- window switch pins
- Tire size and wheels
- Tints
- coilover install?
- Squeak Noise in Wheel area HELP!!!!
- need input on hid
- Blown airbags, airbag cover ideas?
- Mevi
- Tokico struts/springs - Front Installed
- does it have ABS?
- Another coil pack question
- Need Pics of Rear Springs...
- Urethane Motor Mounts
- Questions and pictures....
- Anyone want to try to EXPLAIN!
- Am i looking at the Wrong Forum?
- Question about NGK's...
- Horrible gas mileage!
- Looking for stock rotor size and weight again (info on the brakeman)
- Drivin Around W/ Cat Off
- Hey anyone knows about some stallings problems
- Temperature Gauge is going crazy
- I 'test' drove a 10psiSC Maxi yesterday
- ignition coils
- Fuc-ers
- universal 02 question
- help with part number
- How many Knock sensors have you gone through?
- Rolling Start?
- Sound Clips??
- Want To Change Seat Belts
- Exhaust Help??
- What is Wrong W/my Car?
- ebay: y-pipe + headers ... too cheap!?
- No More Red/Clears?
- does this clutch look good?
- MAF Sensor
- is this a clutch, flywheel or trans problem...
- clutches clutches clutches
- 500k resistor for knock sensor??
- Trying to add RCA inputs to stock Clarion Headunit - A few questions
- dropped my Tein Basics all the way...
- Help! Heater working funny
- exhaust advice
- Car Won't Start - Crank POS Sensor Fault - HELP I'M STUCK
- 7-11 degrees of timing advance at idle is this correct?
- Change Tranny Oil with Redline Mt-90 but..
- Does this come with a Y-pipe order?? (Pics inside)
- Shift Knob
- I Need Help With My Mount Or The Transmission. Please Heeeeelp!
- which leds to buy for door mod??
- dr mod
- Those w/ B+G springs
- RPM Guage Skips
- CF Hood anmd Latch.
- cattman vs greddy???
- climate control buttons
- If you've replaced your ignition coils recently, read in here!
- Cheap short shifter!!! As good as after market
- Got a ? about led's...for my instrument cluster
- How should I waste my tax return??
- POTS MOD from zx2's?
- 2k
- bulb help
- how does a y-pipe sound on a max?
- Whats the difference between headers and exhaust manifolds
- Anyone buy a these, from this seller on Ebay?
- Calling all, recently purchased, budgey y-pipe owners!
- Auto Tranny Whine of DEATH
- Programming key fob remote
- vq 35 cams in 4th gen?
- weird noise on startup
- Help
- Add 20hp Intake Sensor Chip For All Nissan Maxima
- LED Window Switch MOD????
- Just finshed installing WSP SuperFlo Y Pipe and GREDDY SP2
- installed JWT ECU today...
- Knock Sensor
- Stupid interior step light dosent work..
- Wanna get back into it...
- AE headlights question
- mobile 1 15k oil
- o2 sensor autozone?
- TSB's - Ignition coils for 1999 Max
