- light weight batteries
- Strut bracket help
- idle control valve??
- 5th gen muffler
- question of remote control... for keyless
- coil pack help!
- what else is needed to install hawk pads?
- Cattman Headers???
- gauge problems....
- What do you guys think......mod question
- door lock question......
- Upgraded wiring harnesses
- Replaced engine revs when put in gear
- 95 max rear wheel (driver side) problem
- which Warpspeed y pipe?
- !!!HELP !!! Changed Spark Plugs and now...
- Quick Easy Question for those who change their own oil
- does your gas needle go above F?
- hard starting
- coil pack problem / testing please help
- Fuel Cut Off at 7.000RPM in 1st gear??
- 6 Speed Tranny??
- Knock sensor question
- Jim Wolf Technology pop intake (95-99) for sale cheap!!
- Tranny Questions??!?!?!
- 18x8 rims and ABS question
- Steering Wheel uestion
- Updated Max-Feel Free to browse
- Hub and Wheel Bearing DARN HUB!
- 99 maxima se reverse indiglo gauges who has them!!!!!
- help with bulbs please.
- Is this possible for a 95 GXE conversion to 97 SE?
- Plated Rotors: How do they hold up in Snow? Salt?
- Cool Article !!
- Anyone outh there know if they Make???
- For white max owners.....
- where to buy obx catback?
- A laugh before bed ...
- Suspension Help
- Help Identifying a Couple Noises
- Need big help with Water Pump
- i am one lucky SOB
- 0400 code scanned
- How many screws is it to take off the head lights
- what are some good high perfomance Z rated all season tires?
- 98 max 140,000
- Nissan Specialist wont work on my car.? big problems now.
- Intake confusion
- Remove Wheel??
- need Help Lacating the Manifold Absolute pressure sensor-->>
- Clutch and Flywheel Installation
- Hard starting, help please...
- wild guess--what do you think causes shimmy?
- 124,985 Miles???
- JDM euro tail lights
- 92 hh2a prelude cant be this quick.....
- high pitched whine? please help...
- Exhaust
- OBX Type-H catback exhaust
- anyone with cattman motor mounts.
- switching 2 exedy stage 1 should i? where 2 buy one
- European Maxima QX 3.0 SE (1995) tail question
- lights
- Help please!!!!output shaft leaking!!!!!!!!!!
- Gauge Cluster wiring diagram needed...
- EGR Valve
- Headers...
- Quick question - re: engine mounts
- Strange engine/transmission problem!
- help engine leaking oil
- Courtesy MEVI question
- My 4th gen stock pics
- Need help with Y pipe
- tails
- weird sound and lighter no working
- Need suspension suggestions
- Midpipe quality?
- Changing fuel filter
- Need new struts...HELP!!
- PVC Valve location ?
- My Budget Y-pipe experience
- Noises...need help
- Any other cool ideas? (Like G35 LED lights)
- Will stillens 97-99 rear left and right spoiler valences fit on the 96 maximas
- If you have H&R/KYB-GR'2 setup,, need feedback.
- sometimes Maxima won't crank...
- New tires!!! new homepage with pics....
- *check Out Pics Of My Maxima!!!*
- Can this be an axle problem?
- Replacing Bumper
- what's the most accurate method to figure out car's gas mileage?
- couple questions...ive already searched
- Qustion about steering wheel???
- Just Got Exhaust done this morning
- 1 or 2 wires go to KS??? HELP!!!
- Hard Warm Starts& black smoke / '96 Max
- ripped cv boot
- ? about LSD
- WTK Aftermarket 97-99 Headlights
- Dash Clock Problem
- Just Curious
- 97 nissan maxima idle rate?
- **service engine soon light just popped up!!*
- HKS or Earth ground wires?
- Frankencar intake pictures
- '98 SE + ski rack
- Got Mod Plans for My Max - Need Some Input
- OK!! Who's burnt out 4th Gen is this??
- Blew my Tranny!!! Hahahaha
- RE: Fair price for 95 se?
- Can I USE a 94 Maxima Intake adaptor , look inside..
- The cheap looking strut tower bars on ebay are a joke right?
- Heater Core
- Getting an emissions test 2morrow...need a new muffler b4 hand..
- need a trans does every trans bolt up??? dam ACT!!!
- Change all ignition coils or not?
- Stupid question about trannys?
- Chip upgrade for 99 se?
- Can I hook up an amp to stock Bose
- anyone have 19's with H&R or eibach?
- which transmission should i get? LSD/non
- why did my 9004 upgrade harness melt again?!?!?
- Dealer rip-off or legit? (wheel alignment)
- I give up. (MEVI)
- Catalytic Converter
- NE1 have WarpSpeedPerformance Stage III SFC?
- Does CEL appear when tey turned?
- failed 5spd tranny... advise needed.
- bad oil leak....timing cover??
- One pint enough paint?
- Where can I buy a 96 ECU from?
- Generation IV Tail Light Swap
- KNOCK Sensor Changed~!
- gas pressure buildup?
- I need Pictures of and Location of Hazard light relay and bcm
- would a repair shop do this???
- Racing seat INSTALLS
- Power Antana not working
- Need Advice About Buying
- is this guy from maxima.org?
- MEVI sticky
- Problem of transmission or injector? or sth else?
- Haltech EMS
- really a big difference between iridium and platinum?
- cheapest price on a nissan oem clutch...and fidanza flywheel?
- Gauging Interest? Gas Cover?
- Blue Key Ring Write Up
- got GAS?
- head work?? is it worth it? 3 angle valve job
- Maxima neo here!
- Anyone wnow where to buy rubber trim for a sunroof deflector?
- The definitive spring/strut thread
- Dead starter motor?
- M bumper
- fogs not aimed properly
- Will the integration of a HAI & a Catback cause engine problems?
- Bi-Xenon Projectors Done.[pics]
- braking????
- skyline body kit
- 2nd gear problem
- Help w/Fogs on Sarona body kit!
- Progress RSB installed on 97SE Maxima
- Idle Problem?
- Surging problem...could it be the fuel filter?
- Thinkin of swapin engines for a 95 w/ 80,000 miles.
- What kind of paint should i use to paint the inside of my head lights
- couple questions regarding tune up
- Intake Help!
- ...how hard can it be?
- New exedy ceramic clutch
- long term tokiko blues
- Renewing the undercoating
- Window off track - Can I do this myself?
- Im ****ing Sick And Tired Of This Bs
- engine codes 0304 0807
- airbag deployment
- Y-Pipe sound clip
- Clutch hydraulics question
- Franken hybrid to PR CAI - pics/feedback
- Front Corner lights
- MEVI with no ECU upgrade
- Shift Lock and difficult starting
- reverse indiglo for 99
- Anybody have pics of stillen kit and 2k1 17' on 97-99 max?
- Accord Lights on a Max?
- What is VLSD and why is it so much better? (by the way, I did a search...)
- load hissing when car starts...
- Apexi World Sport...muffler only?
- need help, annoying "hissing" sound coming from my intake between 2,000rpm-2,600rpm.
- 95-96 red/red tails
- homelink visor?
- anyone know what this is?
- oh no not my tranny...
- Exhaust sound before & after Y pipe....
- How Much For Tranny??new
- Act Clutches?!?!?!
- polyurathane engine mounts
- bosch fuel injector
- Rare to find a 95 GXE with bose and sunroof?
- would this fpr work?
- 300zx brake conversion
- redline clear tails?
- i30 tail light on maxima
- Pic of obx on the car and video
- Where's that site that showed how to install the indiglo guages?
- EGR Valve operation
- turbine like whirrrrrrr most likely caused by EGRC-BPT valve
- tail lights
- 2" Drop Springs w/ KYB GR2's
- Good Buy??
- Suspension noise. Please help
- HID pics...
- Advice for these Diag. Codes
- Rusty Muffler replacements???
- 5-speed tranny differences from 95 to 96-99
- ALL Mechanics Please HELP, Intake Back fires, Vacume leaking, Other Problems
- sites to find new/used OEM parts...please post
- Put oem fog lights on my Gle Max?
- Clutch question
- bulbs from diamond-cut clears from custommaxima.com
- Adjustment of tension pulley
- Where to buy a switch for the seat heater?
- Cold Weather Package/Block Heater
- not good info about nissan from locksmith
- Im Almost Done...
- I Need Help ASAP!!! i can not get my rotor off!!
- What gains should I see?
- Replaced Knock Sensor..WOW!!
- What should I do with this 97 SE?
- Smoke/Ashes from Cali fire BAD for my K&N??
- power loss
- Magnaflow resonator vs. cheap exhaust shop one
- sound of a failing tranny?
- 0304 & 0403
- BCM Pic's, anyone???
- cattman real aluminum dash kit
- Breaking Engine on purpose?
- positive camber?
- Leak in the exhaust?
- Brighter Tail Light Bulbs?
- Driver's door panel...it leaves me with no room...GRRR (rant)
- HID parts? bulbs?
- removing and replacing gauge needles on 99
- hallowed stock ypipe
- New here need some help
- New Pics of my car
- Pics of my hurt but getting repair max.
- Crashed the max! :(
- Drivers Side Axle Removal (auto) HELP!
