- Engine Coolant Temperature Sensor HELP
- Power steering leak?
- Any 4th gens in Dubai?
- intake and exhaust setup
- Overrun clutch solenoid pack
- Y2K's on 98
- To those who've had aftermarket Y pipes for a while now...
- filament bulb to LED
- Fog Lights
- how to replace ks on 99 cali spec???
- Tire sqeel after hitting a curb... Need alignment?
- 95 test pipe
- temp gague showing hot but car seems fine
- 5 spd ecu and harness?
- Timing belt or chain? 1995 Maxima
- 300zx mafs on a 96 max??
- Greddy SP
- who sells steering wheel rings on the web?
- lookin for pics of two-tone black/tan leather seats....maxima or non-maxima
- PIAA Xtreme Whites?
- Wanted: Pics with these wheels!! Please Look
- car pics
- Need Suspension Help
- Moving to Cali... Worried about emissions...
- Oil Pump??????
- Regreasing starter could use some help
- 17 inch wheels or 18 inch?
- anyone here ever repair a cracked stillen yefront lip?
- chillen max!!!!!
- Downstream o2 question
- Break In procedure for new tranny
- tint
- she told me to take her, do her fast, and she is better then my last one
- Could it be the FUEL PUMP?
- B&M STS Installation / Changing Brakes
- Noise from front left side?
- Blue Climate Control(pics)
- Port & polish and polished intake manifold...
- Mass air and O2 sensor problems.
- Which K&N Filter To Use For CAI
- **Guys With Fidanza**READ**
- what to use to clean ALUMINUM PAINTED DASH??
- ac regulator
- Front panel - ac & audio control lights are out!
- Any write up for an oil pressure sender unit installation?
- got my first speeding ticket, need help
- Nissan TSB Online Subscription Question
- 2 things...
- Exhaust pipes visible from side of car?
- ebay CAI instructions
- Projector kits??
- wheel help
- PLEASE Help with 0901 Code
- TEMP AND COMPASS ON THE REARVIEW MIRROR [please look]
- cat convertor and resonator
- Rough idle??? help
- need part # of inner and outer tie rods
- nismo ground kit
- The dreaded check engine light :(
- Changing the color of climate control
- Leather Interior Swap
- Diff grille with the skyline kit.
- Power seat problem
- Wiper Arms make weird noise? How to fix?
- 99 spare key options
- Muffler Recommendations
- Wood trim removal/Brushed aluminum install
- Idle is "thumping" at a stop
- I just picked up a 95 Maxima SE 5-Speed, VQ30DE Swap Question
- Ordered Y pipe! Should i wrap it?
- Starter replacement problem.
- Cfs Radiator
- Need Advise
- timing chain noise fix
- Noob question... Heat Shields
- Who sells NGK's
- Short Shifter: Who's got one?
- O2 sensor question
- Radio trim removal
- ss brake lines
- Knocking noise, possibly chain tensioner, pls help??
- Flashing O/D Light
- Is this a Cefiro or am I just stupid?
- Time for a new shift knob
- Just have a few ?s
- maxima from fast and the furious
- Is There Only One Wire To Your Knock Sensor???
- jus got my car
- Mass Air Flow Sensor
- How to get rid of window squeak?
- Re: Fender
- Trying to decided on paint
- Want to see pics of White Maxima w/ Gen 2 Altezzas (gunmetal)
- Horse power gain from undrive pulley?
- tachometer doesn't work sometimes
- Lug patterns for 4th gens
- Having rims chromed
- Brake rebuild
- All Those Having Egr Trouble Come Inside!!!!!!!!!
- Left Rear shock noise / Leaning car
- Unorthodox pulley
- Guys, I'm bored with my OEM shift knob !!!
- Sprint Springs with Sprint shocks
- Disassembling 97-99 Foglight Lenses & Housings
- Which CAI should I buy?
- weight of auto tranny?
- Help! Can't find my ECU Diagnostic Test Mode Selector
- Knock Sensor Screw
- Will a JWT upgraded auto ECU work in a 5 speed Max?
- Ypipe Question
- 17" 350z rims on my maxima "pimp"
- red/clears
- sr20det maxima
- New to Maxima's can someone help me?
- Seems Floaty when i get on my Max
- infiniti leather seats
- Inside/Outside Temp Gauge Mod
- 97-99 Maximas- What series Greddy exhaust.??
- When hitting large puddles the PS goes out??
- 0302 EGR Check Engine Light
- body parts- CAPA vs. OEM, and a Dallas body/paint shop?
- i need help! some technical questions........
- Who's Maxima & What Kit is this?
- TSW Revo wheels on the 4th gen...
- Who has a Street Sweeper? I do....
- Head Light Problem!!!!
- Questions on One-piece Cefiro Headlights
- My interior's shiny, but still not CLEAN!! Grr...
- Which springs are better?? H Tien, Sprint, or maxspeed??
- A/C performance problem
- speed bleeders
- Spot-free rinse at car self-serve car wash
- Extended Warranty
- Aftermarket shifter for an automatic
- Installing cefrio headlights on a 95 99 maxima
- overheating again need new tips
- affordable no-squeal brakes
- Difficulty of replacing clutch?? / Remote start for 5-speed
- Passenger Courtesy Light Not Working Anymore...
- Need HELP! My 99 Maxima is hesitating
- side skirts
- MAJOR car problem!! Please Help
- Changed knock and o2 sensor & still hesitation
- New Idea for Rear Passenger Courtesy Lights
- please post pics of painted tail lights
- Brake and Battery Lights
- Source for taillight lenses
- Part Number for Bulbs inside Electronic Climate Control?
- A/C leak at pressure switch fittiing, how to fix?
- Will a RSB help?
- anoying noise coming from front wheels at low speeds... PLEASE HELP!
- Thinking about selling my 98 SE 5-speed
- removing warnings from visors, how?
- CHECK ENGINE code
- '97 SE rims for sale
- Does auto and 5spd use different starters.....
- rotors - Brembo, EBC, or Powerslot?
- now for exhaust
- Interior Chrome Part
- window trim moldings?
- Blinkers wont work, PLEASE READ
- Intake SUCKS, Y-pipe SUCKS ! i miss my low end !!!!
- Altezza Tails
- Stock Exhaust Question
- Exedy vs ACT
- Ah...after alternator replacement belts loose
- OMG stupid console...you guys had this ?
- Illumina part numbers
- Greddy SP impression
- 95-96 red clear tailights
- 2 questions asked everyday
- ram air scoop
- Opinions on Tein H springs
- Budget Y-pipe - stainless steel or not?
- CV joints bad again?
- polyurethane engine mounts
- midst of doing clear tails
- is it bad??
- 95-96 AE Headlights (pics)
- what kind of double sided tape for body kit?
- help. security restart problem
- obx headers?
- claim ur CF hoods!!
- Pictures of my HIDs *56K Die in a fire*
- Not that anyone cares but...
- front wheel bearing
- Brakes are messed up... Need help....
- Spark Plugs- Which are the best?
- knock sensor re-location
- Greddy SP installation question
- New '98 GXE!!!!
- HELP, stalled car, HELP, Check Engine Light, but how???????
- quick question about the "oven method"
- Short ram
- rear suspension noises...
- 600 hp max
- Anyone Hav pics of 95-96 w/ Stillen lip
- Air bag light blinking! What to check?
- going to change my front pads soon, looking for tips
- HELP tapping o2 sensor threads???
- Where to tap into power for indiglo gauges?
- how to change bumper lights
- maxima with 35% tint
- engine revving "funny" ... thoughts?
- Budget B-Pipe Owners.. Question
- How hard is it to change a fog and a corner/parking lamp?
- AC motor speed - varies on its own.
- Hood Scoop
- new custom grill
- vs 92 Legend
- Ignition coils
- Suspension Help/Ideas Needed
- what is the thread pattern for the lugnuts?
- Maxima Bra suggestions
- Missing and hesitates
- How to mount projectors - w/ pics |PROJECTOR PEEPS HERE NOW
- Error code 0301 - replace ECM. Is this critical?
- ECU or Mechanical??
- Throttle Body Spacer
- 3 lens cracked 1 to go
- alternator belt tensioner HELP...
- Car bucks like a bronco on the highway
- Does anybody know where we can find billet aluminum machine mounts?
- blower motor resistor
- y-pipe
- Denso Iridium Power Spark Plugs
- brake questions
- changing out downstream o2 sensor
- Conversion Questions
- i hate my y-pipe
- AE shift knob will fit right ??
- has anyone had expeirence with h3 yellow ion piaa foglight bulbs
- 1998 Ecu?
- What Makes the needles in the gauge light up??
- CEL code 0509?
- anyone here use urathane to attach stillen kit?
- pulley install and wierd problems.. need help asap
- how hard is it to remove exhaust system from headers back?
- Has anyone tried the 5th gen variable intake on a 4th Gen??
- Trunk Rattles when Bass Is up
- Diff Bearing Replacement
- How many of you have the Sagemist Green maxima? please post!
- I Need a Bad Ignition Coil
- Different types of suspension
- Squeeling Brakes (Please Help! I'm not sure what else I can do)
- Cost to repair this fender bender:
- drive 1 and 2
- Cleaning BOSE Headunit???
- Ecu Code, Multiple Cylinder Misfire!
- JET ECU MOD and Knock Sensor
