- Is the altenator supposed to shake?
- How to remove engine temp sensor?
- Going to a single-DIN radio..where to get the little holder?
- oe fog install problem
- 99 i30 Ignition coils, will thet wit a 99 maxima?
- VQ30DE
- Power Steering Hose leak
- I know you guys are probably not lawyers but I need advice.
- auto tranny "Short Shifter" Mod gone Wrong
- Squeks A-L-L The Time !
- Has anyone else ever heard of this
- best projectors for retrofit
- ticking sound- driver side
- ABS Sensor diff's btw 94/95 and 97-99?????
- gas tank cracked?
- Code 1008 EVAP canister purge volume control valve
- g35 tires rubbing, suspension change solve the problem?
- Spark plug tube seal leak again!
- Idle jumps when going into gear.
- Busted windshield Grrrrr...
- What should I be paying for front brakes and rotors?
- wound up with spare parts...
- Smashed rear corner window
- Rims & Tires?
- Frozen belt tensioner pulley?
- Alittle Help with a '99 max :-(
- Timing chain broken, new engine, I'm screwed? (video included)
- So hard to say goodbye lol
- NEED HELP BAD
- Where is the ECM Wiring harness?
- Can the hood release be adjusted?
- Post alternator R&R checklist...
- My newest add on..... :)
- Thank You Maxima.Org
- Painted Engine Cover
- 2001 Special Edition Maxima
- MONTHLY MAXIMA MEET!!!
- egr CODE 0302
- Hood Alignment Issue
- Stillen rear spoiler
- Help Identifying these exhaust parts..
- Will 2000 maxima front seats fit 4th gen??
- spark plug replacement
- So... thats odd. Oil change related.
- Shaving antenna hole
- new motor?
- what to get for my max for $100 or less?
- HELP! - Lumpy idle after valve/UIM gasket fix
- side airbag hook up
- Well Finallly Got A New Car
- 5th gen side skirts on 4th gen max??
- how much can i get for my dek 4th gen?
- Electrical Issues!!!
- Difference between 95-97 and 98+ park brake cables?
- Automatic taken apart? lost thread
- ignition switch quick q&a....
- oe foglight install
- some advice on steering gear boots replacement
- EVAP EGR VSS KS - HELP!!
- turn signal wiring question
- Another SES issue!
- fog light rewire on my 97 max..
- to paint or not to paint grille opinions?
- windshield wiper clunk
- What is this next to the coolant temp sensor???
- New EBay Red/Clears - Funny Fitment
- Removing accelerator cables
- Exhaust options
- Question about a shifter bracket part number
- 99 and eibach springs
- My radiator is having a spiting fit. Help me find a shop in the East Bay.
- HELP with 97 Stillen Front Lip
- Custom Maxima Cat Back Exhaust
- was grey leather ever offered on the 4th gen?
- Trans Leaks! Yikes!
- Water Pump Difficulty !
- question about cold start idle speed
- Thanks 4 all - time to sell!
- my foggie adjusting screw doesnt work
- What brake pads are you using?
- Oil Leak...need help indentifying
- Intake Q
- SO IT WASN'T A HEADGASKET!!!
- Finding an Appropriate Axle
- Is it worth it to fix my 96 Maxima?
- How to Remove Glass from Front Doors?
- My tranny has some wired play help.
- HUGE CAR PROBLEM!!! FAST ANSWER PLZ!
- cleaned tb and now rough idle
- So it wasn't my coil packs..
- Need some advice on taking my Max for a big trip in 2 weeks
- '99 A/C Compressor Bearing Failure
- 100k update
- my retrofit light output
- Water pump replacement
- Clutch Issues
- Fuek Gauge issue
- Window Visor Help
- 4th Drive axle
- Signal Plate Torque
- To bypass or not to bypass stock transmission cooler.
- non projector hid retro idea
- Changed caliper/rotor/brake pads...where did I go wrong?
- A/c
- Beltronics Police Radar Direct Hard Wire, HELP!!!!
- from 6th to 4th gen!
- 95 nissan maxima...
- Found: Potential 95 Project, at least I think so...
- J30 Front Brake Maintenance Questions
- gotta love ebay!!
- Cam Shaft Position Sensor O ring
- Wrecked 4th gen
- OEM park brake cables, 2 different P/N?
- Dynomax muffler
- What version OBX headers are these?
- just want to know wat you guys think
- dash cluster trunk light
- Looking for a new motor or tranny (could be DEK)
- trouble identifying a part
- ds rear caliper ****ed up
- R&R Cylinder Head
- Dressing my engine!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Murano Washer Nozzles
- Maxima.org should be an iphone app
- Car sitting for only a week and a dead battery?!
- POWER ANTENNAE MAST
- another decent retrofit. thanks nalc!
- Valuing my 95
- New type of intake idea
- Doing the 2001 AE edition cluster swap in a 4th gen
- Wrong Diff bearins from GT transmissions
- backend is really twitchy after HUB install...help
- MutlipleS
- lots of air noise
- Could the P0125 Code make me stall?
- high idle promblem
- LOW IDLE
- Lower rad support: replacement PART question.
- exhaust question
- Drivers Side Corner Not Working??
- $600 Maxima revving sound! (videos included)
- hole in flex pipe?
- Replacing refridgerant in a 4th gen Maxima
- Dealership = Stealership? Think again !
- blue turn signals and sidemarkers illegal??
- Cold Start Problem
- Parking brake issues, 800f rear disc, help!
- 3rd gear went out on my 5spd...any input appreciated
- Lowering a maxima...what about road debris?
- touble shifting from cold start.
- 4 generation
- 5th gen muffler ?
- Crazy MPG !!!
- Nasty, metallic clanking from rear - goes away when brakes applied.
- y-pipe added to much noise
- the CEL light got me today
- Camber Bolts and Firestone
- 02 Color Code (Universal)
- ***Product Review and Installation: 4th gen Subframe Collars***
- Intake manifold
- Head Replacement
- HELP! Just ran over a curb, popped 2 tires, leaking tranny fluid
- LED H3 8 SMD fog lights
- Where to find OEM look 96 clear tail light? -pic-
- Brake pedal will not go down, ABS light on
- proud owner of my 3rd 4th gen...
- Exhaust Cunking
- Won't shift?
- My WS ypipe install
- Upgrade Engine
- overheating question?
- speedometer is going wild?
- Y-Pipe help. Cali?? Fed emissions??
- Repair or Part out?
- Can high idling be responsible for terrible gas mileage?
- test pipe gains??
- somethings not right..please help
- weird suspension noise on left turn
- power lag... please help
- courtesynissanparts has MEVI's instock
- my 96 maxima i dead
- Water pump + tensioner cost
- transmission slipping
- Tell us your experience
- Gotta SMOG again, 3rd year in a row!
- Help Please Black grease all in my wheel well and inside my wheel??
- Leak from sunroof controls
- Residual oil leak from rear valve cover leak??
- NEW STRUTS, Excel G did i get something out of the ordinary?
- Realistic Highway fuel economy
- Gauge light issues
- Obscure Part (Auto Climate)
- Headlight harness help please....
- can't get my cornering lamp out
- Injector, coil, knock sensor/ Problems??
- HELP - Valvecover Bolt Torque Spec
- P0300 CEL Code Assistance Required
- fuel pressure / warm start
- another federal/cali thread
- Problems after new front axle
- Power Steering Fuse Location (important)
- To sell or not to sell
- No start condition after a clutch job
- radio has a mind of its own sometimes
- Front Wheel Bearings.
- A-1 Cardone Remanufactured MAF's?
- CEL for codes P0440 and P0446 - EVAP
- Tranny question aside from the rest..
- Clutch Issue
- Replaced cyl 3 fuel injector now car dies after starting (no idle)
- no o2 sensors causing vibration?
- Need some input on bearing wear.
- Trunk keeps popping open
- best place to tap into the ignition line
- Question about A/T behaviour
- burning smell with o/d off on highway...
- Battery was dying and now the car died while driving....
- car is squealling at start
- rpm's going up and down?
- custom maxima short shifter
- Call me an closet-idiot...
- warpspeed y-pipe VS cat-back....
- rack and pinion from ebay question?
- Headers + YPipe for under 200 dollars?
- Stalling Saga (Continued): Still Need Help!
- HELP! can't pass emissions because of "not ready" exhaust components?
- Fair price for stock 1996 Rims and Tires?
- installed weapon r intake and....
- Replace Rear Wheel Bearings 99 i30 (maxima)
- Fog Light Question
- Check Engine Light Problems
- starter?
- 96 maxima wont start!!!
- P0705 with a MT?
- Another TPS Test Problem
- greddy E-U users
- Installed aftermarket steering wheel!
- Window switch's not lighting up?
- Reply ONLY if you are 100% sure why my engine dies exactly 2 min. after starting
- Minor Accident -- Suspension Correction Questions
- Transmision S.O.S.
- thanks for everything maxima.org
- overdrive on/off
- Scan Guage II(2)
- Parasitic Power Drain
- First post: 1999 Nissan Maxima se
- Where can I find replacement gold lettering?
- Clutch Slippage
- Wiring issues...
- Cam Sensor?
