- factory seats
- filter and pan gasket
- Just a quick question for those shift w/AUTO's
- Spring tech suspension
- Maxima not starting consistently... Please help??:(
- Anyone have the stage 2 VB upgrade???
- need a main wiring harness
- What mod should I do next.. I need some help deciding...
- My car slept 35miles away from me last night
- does nissan dealer 55 points car checkup include O2 and KS checkup
- 18" rims and what lowering springs? how low with 235/40-18" tires...
- VIN ??? SOHC in my 95 GLE????!!!!
- just got my new engine!!!
- Remember the first drive?
- z3 fenders
- is the front emblem bigger on 97-99 than 95-96?
- give me prices on motor and tranny
- Pebble Beige AE headlight mod questions
- How to remove pilot bearing?
- Thinking about getting a 97 SE...
- cv axle broken!
- Looks like JWT gave me a 6800rpm limiter
- Progress Spring and GR-2 review, also do they settle?
- Custommaxima new body kit????
- at least they are using KY for this!
- Help!! My 12cu. ft sub box broke my trunk latch!!!
- Pathfinder throttle body installed
- Ok to drive 1200 Miles in 1 weekend?
- Uneven Tire Wear and Suspension Upgrade
- Feedback from Frankencar intake owners
- Crappy Clear coat. PROBLEMS. HELP!!!!$$$
- Fogs Install....
- My first Mod maybe a y-pipe?
- Whats the word on: Cattman Headers & JWT Cams
- Which is the Best Test-Pipe for 4th Gen maxima's?
- Problem! My car doesnt like the cold
- Which Rear Sway Bar?
- 5 spd swap question
- Headliner and Carpet Replacement
- warpspeed subframe connectors?
- what resistance for KS
- exterior door moulding
- Dual 5th Gen. mufflers?
- Seatbelt Won't Retract
- Failed smog test, need help!
- Cams??
- change new battery alarm wont turn off!
- need some more help
- Tranny is slipping badly... should i do the drop resister mod?
- I think I hav Leak in Y-pipe
- please help need help.....
- tranny filter
- Exhaust piping diameter affect tone?
- Walker or Bosch o2?
- transmission or something else ???
- people with EXEDY....broke trannys????
- Water temp question // Just had water pump changed.
- red/clear ?
- pics of hacked airbox any1?
- Will a 5 Gen. 5 speed shift knob fit a 4th Gen?
- knock sensor question
- K&N intake ??? concerning resetting ECU
- Back seat replacement
- Car shuts off?
- which obx cat-back?
- 98SE bad brakes
- what do you think?
- Crank position sensor to a bad main harness?? I'm getting ripped off!!!!
- What is a CORE SUPPORT?
- 1997 Maxima Rear Rotors Help
- Anyone replace Knock Sensor without getting code
- Pics of painted plug cover
- water pump....tensioner?
- Whcih transmission cooler to get?
- Miles per Gallon
- 40-45 MPH in 1st gear!
- windows going down...
- taking out the airbag???
- whats going on with my MAX :(
- For those who have to use low octane (cheap) gas.....
- Picture of IAC?
- Sylvania Silverstars and what else?
- led turn signal mirrors-choice
- What to do??
- 4th Gens With Apex Filter. I got problems..
- Engine Problem?
- torque converter?
- Addition to Horrible Horrible Story
- Heating and AC won't work at the lowest position.
- What is IAC Valve?
- Horrible Horrible Story
- Nismo
- 99 maxgle weird tranny behaviour
- Is my alt dying? Detailed description....
- Show me pic of it please
- Does Anyone Know About Air Ride?
- Manual tranny question?
- 4th gen review in AMI Auto World mag
- Which wire in fisebox for 12V on 1995 GLE?
- HELP keep my GF's @ss warm
- Recommendations to convert my low beams to HID?
- i need shocks will this setup work
- Dashboard air temp lights
- Do I Need an Engine Flush? Questions after A/T rebuild as well
- trim
- lost to a seville sls
- haha, accidently stumbled across this thread while searching for something on yahoo.
- Hearing Squeaking...Spring or Shock?
- 350z exhaust tip on a stock max
- installing FSTB
- Do your pistons knock when you get on it?
- Apex WS, not as loud as i thought
- St. Thomas Results - who says MEVI w/ no JWT ECU is slow??
- Need help fast!!
- Sachs Vs Exedy
- Some random pics of my car.....
- Cloth interior replacement
- CRAZY day...my MAX blew up...
- TPS ghost code and knock sensor test
- What Do U think of this setup
- H E L P!!! ***Leaking Oil Bad news***
- need help with suspension
- antenna won't go down
- who drives the max of the month
- Sunroof wind deflector - which to get?
- need your help to tell me how f***ed i am
- 98 SE - any suggestions?
- How to hardwire Valentine radar detector? Any ideas?
- New Mods = New Pics
- Question About Studs??
- Passenger Heated Seat not working
- aftermarket ignition coil
- Not my cup of tea.
- hawk hps or hps+
- 95 Maxima SE won't start
- changing the CKP sensor
- Error code 1336 Crank/Cam Sensor Range/Performance.. what does it mean?
- Test N Tune: Frankencar, Injen, Technosquare
- Need some help - need to locate parts
- For those who need a new knock sensor
- part numbers for axxis/hawk ??
- Ricer Civic and I
- question about Y-pipe
- Your thoughts on a dual CAI?
- How different would my exhaust note be with a smaller tip???
- The long awaited pics of the OBX Type-H!
- Getting better gas mileage?
- total 60,000 service necessary...
- Rear seat cover
- Airbag light flashing, modulator out?
- 95-96 NISSAN MAXIMA REAR BUMPER REINFORCemement
- Replacement of transaxle control rod seal
- Car wont stay running, runs out of juice, and dies.
- Car question!
- 98 Maxima hesitating at 3600RPM
- Brakes...
- OBX type H.... i searched
- idle speed
- Which exhaust to get
- new spoiler
- Please don't hurt me!
- changing spark plugs
- cleaning throttle body?
- Knock sensor code and wierd idling.
- Starter Removal
- Can anyone tell me how to remove a bumper?
- Which Catalytic Converter is the best?
- Mounting the ECU....PITA, Help.
- Has anyone changed their 5spd trani. or know a good amount about them?
- windows auto roll down?
- problem with my '98 Maxima
- Clearing the computer not just the SES light
- "What is this oil deposit close to my oil pan"
- Rough Ride In Nyc On Maxspeed's
- Thoughts on Test-Pipe.....
- QQ: testing ignition coils
- automatic lights
- I just wanted to know.....
- coilovers
- Buzzing noise from the engine....help!!!
- help, need speedometer
- Sunroof Only Closes With a Pull
- I Just got a Maxima...FOR FREE!!! :)
- Bodyshop and I can't figure out how to install Stillen Side Skirts
- New Max
- Body Shop Newbie....Quick question for everyone....
- Whose Maxima is this
- Should i buy starter from Autozone?
- Problem with HID Please help
- b pipe
- I want to be lowered
- put on the Stillen kit and rims[Pics]
- buying car! need help fast.
- Cone air filter
- Could the ALMIGHTY FAQ be wrong???
- suspension
- MSD question?
- Can 2.5" cat bolt to 2.25" bpip?
- Clutch pilot bushing 95 SE
- Confused
- what is injen?
- how much HP for this setup.
- part # for taillight bulb
- how to get drivers side door panel off?
- Installed Illuminas and Progress Springs!
- 95-96/97-99 conversion-help, please asap :(
- acc. belt install help please
- How much to change interior to black?
- Maxima chip?
- which coil pack do I want?
- Fog lights keep burning out!!!
- Is my alternator shot??
- Chrome Apexi filter
- Snapped Valve cover bolt...
- tokico lowering springs...hmm........??
- Noobie radio back on the air
- purple fogs
- pcv is a B**ch
- ebay V1 module +20hp?
- darn rickety maxima (rant)
- Causes to strange tracking behaviour?
- Weathertech Weatherflectors
- 4 Questions
- trip to JWT
- Seat question
- Need Leather Installation FEEDBACK
- MAX still won't START!
- door panel bumpstop
- Exhaust Questions....
- exedy clutch
- What Cools the MAxima Transmission
- What r my options? (suspension)
- after throttle body cleaning
- should I buy this maxima?
- Schizo starter...
- Warpspeed Subframe Connectors - Stage 2 installed
- Cefiro Chrome Gauge ring
- pis of my max
- hks catback, deal or not?
- Shaved my rear
- 97 SE Pumping
- 1998 gle, 85k, $7,900?
- 1 tool knock sensor FIXED!!!!!!
- Please help
- Finally updated my Cardomain page...
- Intake mods revisited
- New alternator
- Axle Leak...Im Lost !!
- Fast and Furious Maxima
- 96' fog lights
