- Need help !!!
- Car stalls while moving
- Disc Brake Piston Tool
- is it possible that no ECU ?
- Question for those who drives a manual Maxima
- Engine Oil Codes Explained
- Camshaft sprocket photos, thickness?
- Odometer and Tachometer Stopped Working
- Been wanting these headlights for the longest time..
- Started on rear valve cover today...
- 96 Maxima has serious trouble cold starting
- anyone do a re-learn on their 4th gen?
- Bose didn't lose presets after battery disconnect
- heater works for 1 minute and stop
- Battery is being drained, radio is the cause
- My 1999 Max: In Progress
- trans problems
- Things to do while timing case is open
- Quality Auto Parts ???
- Saggy Rear Passenger Doors
- Alternator harness wire help
- Snowmobile Report - VLSD Test
- No start after dead Battery and sitting for 6 months
- Blower Motor Recommendations?
- Rough / stumbling idle when warm - P1400,P0500,P0600 codes
- Metal burs on cam lobes
- Help Removing Clips to access 14mm Starter Bolt
- Front crank pulley and crank seal replacement troubles
- 1995 nissan max, 132k miles need help
- A32 Nissan Maxima – small screen monitor stop working
- Copper Exhaust Flange Nuts Question
- iOS app no longer workee
- Things to take off junked maxima
- Should I buy plenum gasket and exhaust manifold gasket when changing valve cover gask
- DC Power Engineering 270xp alternator
- Only get HOT HOT air out the vents
- 99 passenger seat belt sensor, mention in motor trend 2016
- Time to replace front brake pads
- Water Cooling the Intake Manifold
- Cracked fuel gauge sending unit
- TPS (old and new) causing high idle
- 1999 maxima antenna replacement
- SRS Bin File for 95 Nissan Maxima
- Ideas for your next car or truck...?
- Lower & Upper IM, EGR remove & replace help
- Anyone have an O2 sensor ON the center/rear cat?
- Rough idle. So i done a service in my 98 2.0 v6 maxima.
- Can anyone help me identify this hose in the rear?
- Fuel Injector rebuild kits
- Possibly immobilised, no stereo, no clock.
- Y-Pipe Question
- tire pressure check in winter
- Size of injector screws
- This is a bunch of bull****: 2 seized/cross threaded lug nuts, I broke 1 off.
- My horn started to honk while driving...help please
- Trying to see if my sold maxima made in back to the maxima.org
- What Ate the Odds P0335 and P1335 Simultaniously Lit
- Alternator harness question
- Wheel Spacers
- WS-Y Pipe, MF High-flow Cat, P0420, Weapon-R question.
- Quick Question - Front Airbag Replacement
- Ac compressor is getting noisy. Replace clutch?
- Dashboard Lights Out
- steering rack ?
- 99 maxima Wont Start
- Rear Passenger Door Spacing After Front End Collison
- 98 Maxima trouble code 0311??
- wth is this, a russian maxima??
- cv boot replacement options
- Electronic Cold Air Intake?
- 1995 Nissan Maxima starting issue
- AirBag Light After AirBag Deployment
- Broken Driver Side Seat Pan
- Bushes
- ECS questions
- possible diff bearing failure-not certain
- belt squeaks
- anyone have the front corner of their left fender rust out?
- Orange/pink corrosion on top of radiator
- Car cranks faster with 34R battery.
- Warpspeed y pipe, high flow cat, and 5.5 gen muffler..is this a bad setup?
- Poor radio reception with aftermarket HU
- Hood Strut Replacement - Reuse Studs or ?
- P0138 / P0139 - basics tried, what now?
- Starting issues on my '96... Can use some assistance diagnosing.
- 4th gen transmission resistor is A MUST DO
- Midlife Refresh - Phase II - Suspension and Wheels
- AIR Bag reset procedure for 99 Maximas
- Stuck thermostat, or temp sensor? (also hard shifting)
- need a new rad, steel or standard?
- How can I fix this oil leak?
- NWP Engine Torque Link Installed - 98 GLE Automatic
- Brake lights not illuminating when braking (not the bulb)
- code p1320, coil or ignition condenser??
- Moving on with the interior swap, looking for ideas
- Missing Oxygen Sensor?
- drivers side heel hole repair?
- Is this TDC?
- Decision time to keep or dump?
- Body parts , swap to Infiniti?
- Part Number for PS Cooler Hoses
- Trying a new brand of CV axles
- Strange humming noise coming from radio when the car is off
- Start of a coolant leak
- Maxima in the UK
- Thanksgiving
- From 98 to 95 motor swap
- P0325 Knock / P0400 EGR Flow / P0443 Evap Purge Valve
- Smooth Running VQ30DE
- Can I block off this fuel filler breather tube?
- Help identifying this part
- belt squeel at startup?
- 1996 maxima alarm problems
- Axle seal leaking 1998 Maxima
- Fuel Filter Maintenance Reason
- Steering Wheel issues
- Nissan Maxima 02 sensor Replacement
- Muffler delete
- Can I swap an auto lsd into a 5sp transmission?
- Parts
- 4th gen factory wheel faq
- Just got 99 maxima and Nats sys not letting it start
- 1996 Nissan Maxima SE
- Transmission shifts hard
- 1999 Max UD Pulley came apart, replaced it, now won't start
- Baked VQ30DE Parts - The VHT Curing Process
- 2 questions. High Idle and p0171
- 98 Maxima GLE starter relay melting
- Transmission Swap
- please help before my motor blows up
- Mating stock exhaust to Megan racing headers?
- 98 Headlights on a 95?
- Wife ripped side marker lamp off with her bumper
- Cylinder 1 misfire no check engine lights
- Oil
- 5 speed conversion
- ok, steam from under hood, rad had fluid on top edges and...
- Battery & Brake Dash Lights Flash... But
- Found forged pistons for vq30de with cr of 8.5:1!!
- Bose 4th gen Speaker Upgrade
- Trying out sensen quick struts
- a32 project
- Valve Cover Gasket Write-Up?
- orderinfinitiparts.com
- PO0401 code
- 97 auto cutting out uphill and engine stalling at idle
- 1998 maxima
- New $11 Injectors Arrived Today
- Purchasing a ’96 Maxima 5 speed
- Speedometer
- Noise at 60 mph
- Cranks, backfires thru intake, no start
- OBD2 Scan Port Malfunction Mystery Solved
- Radiator Support Prep
- Plastic Fuel Injector clips - LIM R&R
- Changed valve cover gasket..Now car idle is dying
- Gurgle noise?
- New Hood Bumpers
- very lean idle after replacing rear valve cover
- Replaced climate controls... again
- Bad key transponder or bad fuel pump
- EGR Hardware Cleaning
- What do YOU think my car is worth?
- Simple fix turned into nightmare
- High idle after long drive (idle is fine otherwise)
- Evap Code Problem Solved
- This car has drained me emotionally and financially. Seeking out you guys as my last
- Cat Converter Direction?
- Replacement Door Handle
- 99 Max P0505 - IACV good but Low Connector Volts - Wiring Harness or Battery Cable?
- Save Your Power Antenna - Maintenance Tips
- Intermittent starting problem solved second edition
- I drove car at flat tire for 5 miles
- Strange humming noise and smelling hot.
- 1996 Camber kit
- Replace cam chains?
- Trying Low Cost Camshaft Position Sensor
- I overfilled my transmission by 3 quarts, this is what happened:
- 1999 gen4 tries but no start
- 97 no start, what am I missing?
- what a fuking $hitty day!!!!
- How can i match headlights (possibly leds)
- Cattman fstb rare?
- trunk torsion bar removal?
- LSD or no LSD
- TOW HOOK Points for 4th gen??
- motor and tranni out of 01 into my 96, easy swap?
- hello new to this but i keep finding the wrong people to fix my car....
- I got in a wreck
- Gas pouring out of tailpipe
- A/C pulley question
- No Start, No Crank - Problem Solved
- Proper length of Alt, AC drive belt
- 98 manual transmission leak, any ideas?
- Neo Engine Cover.
- Manuals trans leak, Suggestions?
- How do you remove passanger side airbag?
- Does anyone make adapters anymore???!!!!!
- leak by rear main seal
- 99 EGR delete, no more p0400, no check engine light
- What size thread for TPS screws?
- problem with right front turn signal and corner marker
- Stillen AP BBK rotor question
- Oem keyless entry swap has me stumped
- Bend heads
- One Stop 4th Gen Motor Mount(s) Thread
- Gen 4 Fog Light Install - Help
- Bolts that hold AC lines into compressor
- How not to boom a block under boost
- My 4th gen maxima-straight piped and no muffler
- power steering high pressure hose routing
- bad brakes out of no where?
- Burning smell in engine and into A/C vents. I see nothing
- Tranny doesnt want to shift
- metra 44-PW22 antenna?
- Options for best cv axles? Mine are poppinnnn' boi
- Easiest, Best, Rear Sway Bar Kit
- P1320 with misfire that goes away
- Strut Assembly Parts Opinions?
- Low rumble above 35 mph, Motor mounts?
- 4th Gen Maxima Passenger Dim Headlight
- Help Please 96 Maxima
- Improving Steering Feel
- water pump suggestion
- axel, cv joints, inqury
- no check engine light
- Sway bars, yes or no?
- Chassis ??? and Tie Rod ???: 99 SE.
- HID light problems
- New Compressor, drier, condensor 97GLE
- Tach problem but not the gauge
- Ac Clutch Pulley Bearing
- 97' max a/t "need help"
- Tach Issue
- Voltage/current problems, dimming dash : bad alternator?
- Noise at idle
- should i R.I.P the maxima
- 98 maxima fuel issue
- Scanning code
- 99 Maxima Auto No Start/Nats Problem
- Rear motor mount and tranny fluid
- No heat
- [98] No crank
- weird dash light issue.....
- Feel guilty to say this but... worth an upgrade?
- A/C heater control panel wiring
- Rear glass, when rains, leaking lots of water into trunk
- On a 1998 Maxima, how well will a full size tire and wheel fit in the spare tire well
- Remote, visor lights, clock, key in ignition reminder, red alarm light not working
- Acceleration and then pulls hard right????
