- Will OEM Ignition Coils From A 1997 Maxima Work In A 1999 Max?
- Need to find part number on power steering pump
- clogged cat, will be putting a test pipe on next week
- Oil leaking from transmission.
- is there a quick way to paint the wheels?
- where can i get a straight pipe with 02 hole for my 95
- Door light won’t go out
- New MAF new Crank Sensor, but CEL comes back on after being cleared
- Maxima Crapped Itself
- alternator replaced - still issues
- Auto door locks have a mind of their own? Replace your actuators!
- "Ignition switch"
- as the alternator turns
- Is It Really Bad Starters Or Something Else?
- Door Switch Covers/Boots Still Available ...
- Bad trans, bad trans mount, or ???
- Who's Had Good Luck With Replacement Starters?
- Seats!!
- tune a 4th Gen ECU?
- 1998 maxima won't start after cold snap
- Brake pedal goes all the way down?
- Where did you mount your aftermarket amplifier
- Radio has lots of whine with fan at times. Found this...
- Which part of the seat does this motor control?
- lookeee what i found.......
- Something you rarely see on maximas
- I30 cluster 99 maxima
- How to install spoiler?
- Cornering lights
- Rear brake calipers/e-brake freeze/seize when cold out
- clean engine needs evap hose
- Tons of Smoke out of the exhaust and losing lots of fuel
- If my EGR tube is clogged, is that similar to an egr delete?
- Spec of filter box-air filter hold down bolt
- "Squeeze" type hose clamps
- 99 Cali Emissions guys, parts help needed
- Camshaft position sensor change.
- Aftermarket Radio - Bose Speaker Replacement
- Help me ID this Rotational Noise - PS? Harmonic Bal?
- 97 Max GXE cruise control lights up but doesnt engage
- LED output
- body damage questions
- cleaning headliner
- Aftermarket Headlamp Assembly Options
- '96 Maxima GLE climate control stuck on heat
- New LED’s 4th gen maxima
- Front motor mount sensor?
- '99 A/T Flywheel Inspection Plate?
- Engine Noise
- Hood Strut Safety
- Cleaning Engine Bay While Engine is Out
- Any LED recommendations? 4th gen
- computer swap - what needs to match and is repregramming needed?
- Worth it?
- Power steering pump help.
- What causes code P0100?
- Occasional stall when turning and acceleration issue
- backseat leather and foam dented from childseat
- How does the repair shop do it??????
- 1999 Production Numbers?
- Car's been sitting over 70+ days no start
- Burning / grinding metal smell when driving
- Coils and drivers/igniters?
- Ebay wheel bearing press
- DS auto non-VLSD CV axle HELP Please
- 95 Maxima starts then dies
- Connecting + and - battery terminals together?
- What are the best coilpacks for a 1998 Nissan Maxima GLE
- Trunk Leak!
- Water leak into back seat foot area- many examples!
- Suspension noise with sharp bumps
- Overdrive not working
- Is there anyone who deleted their antenna on your A32
- The Creaking Noise is now GONE
- Mechanic thoughts needed ASAP!! Please
- Tires
- Stillen FTSB Installation Directions
- Battery dying on 95
- Today's Project - New Warpspeed Y- Pipe and Walker Cat
- Aftermarket parts
- Coolant Temperature Sensor question
- Bought a POS $200 Maxima. Please spoonfeed me how to fix it
- To clear the code or not clear the code, that is the question
- Spark Plug Sank
- Cleaned the interior
- Antenna Replacement / Gaskets
- need help getting code P1447
- Blower motor speed problems
- Starters With 11 Tooth Drive?
- Which sensors would cause no spark or no fuel if bad?
- Replaced Manual Transmission. Won't start.
- Accelerator cable replacement
- Oil Leak From Motor Mount?
- Could a cracked/split MAF sensor-to-intake boot cause code p0100?
- Closing Tha Sunroof It's Cold This Time Of Year...
- Wiring help
- Transmission Fluid 98 max
- 1998 I30 two cylinders not firing.
- will 2016 knuckles swap on a 4th gen?
- Bose radio stopped working
- Ignition key and door key the same?
- Regreasing starter link
- can i get a break here?? smh........
- Mode Door Motor Replacement......W/PICS.
- Canister Purge Volume Control Valve CEL - 96 Maxima
- Slow transmission leak
- Sunroof problem 4th gen maxima
- 4th gen looking clean
- Need help deciding...
- starter motor rebuild
- so, compression test should yield what numbers?
- So raise the red line with out emu or jwt
- Anti theft tripped and no door key
- 1995 Maxima Transmission
- Auto start bypass module for 99 with immobilizer, Programming spare transponder key
- So what do you think this car is worth?
- When is the low fuel light supposed to come on?
- Cannot for the life of me get the rear brake caliper compressed enough
- Mode selector doesn't work on my climate control.
- Gas smell through vents
- starter motor teeth
- Idle Air Control Valve?
- 98 i30 drivers door exterior handle/lock bezel
- spectra coils, any good?
- Trouble with interior lights
- Best “OEM” Manual Transmission Clutch Kit?
- 98 maxima heater core replacement
- Intermittent starting
- replaced egr spacer tube, cleaned throttle body....
- P0174 Code Help
- Does leaving the hood open drain the battery?
- Oil Leaking
- TC-W3 and smog test
- "Grindy Noise" in Manual Gears 1-4; 5th OK
- On my 3rd starter in just one year
- 99 maxima with custom LED emblem grille
- Digital clock connection loose?
- guess what this is.......
- Need help with Wiring, also Cranks and wont start
- Engine Overheating
- any idea what this noise is?
- Car wont start, shifter locked in Park
- Easiest way to replace a trans pan?
- FTS struts
- Dash and right tail light fuse keeps blowing
- Cruise not working
- Black Grille ?
- Work around on EGR valve
- Size and thread pitch of stock license plate bolts
- Can anybody tell me what this is?
- Intake Plenum Gaskets? All the same or which is better?
- Looking at another Nissan Maxima...
- Engine louder at 2500 rpm
- Radio lights
- High idle only in Park
- Where are my SUNGLASSES?
- 5spd swap on 96 I30, CC no work
- On the way home from work today...
- 1998 5spd Maxima build
- Is this the cat?
- help!!😞
- P0300 Random misfire
- Update on the max
- Fuel Pump Strainer Recommendations
- RIP VQ30 Car, What Now?
- High mileage >200k maximas
- Replacing Rear Struts
- AC wont turn on 1996 Maxima
- Installed new bbk calipers in front, but cant get any pressure, pedal stays spongy
- auto tranny shifter won't go all the way back
- how to stop engine from turning....help!
- Valve cover/ UIM
- Light on
- Where do you guys buy your aftermarket/oem replacement parts
- Looking for Grounding Kit
- 99 Maxima - Acceleration/Deceleration - Not sure what to call it
- Speakers
- Reason why aftermarket coils throw codes. Enjoy
- Subwoofer / Amplifier Install 1996 with Bose
- Moog Problem Solver lower control arm/ ball joint replacement
- Infamous p1220 dtc... Fpcm...97 maxima
- 7.5amp Fuse #4 Under Steering Column
- Replaced ignition lock with new key
- Can anyone tell me what part this is?
- 95 maxima in "Limp Mode" will not shift out of 2nd gear
- Vacuum & Coolant Hoses Options
- 97 Max, New clutch master, lines, slave, clutch won't disengage
- Gauge Cluster Issues
- 4th Gen A/C Leak Detection
- Hit 400K miles!
- Something's up with my electrical
- Fuel Pressure Regulator
- constant power wire..(radio harness)
- Help with Vacuum Lines Please
- tons of white smoke coming from exhaust.....
- Cam adapters for VQ35de swap in 4th gen
- Are the cheap aftermarket crankshaft pulleys/harmonic balancers any good?
- Belt noise
- Flashing Check Engine light. Misfire Issue
- place to get crankshaft position sensor? best brand?
- Rough cold starting.
- Upper Oil Pan Seals
- does anyone know what this box with hydraulic connections is?
- Ultimate Headlight Quad Retrofit Build (HIDs, LEDs, oh my)
- Low compression - Rebuild it?
- brakes suddenly very sensitive and pedal bottoms out
- Local 96 for sale
- Where is the location Of The Keyless Entry Control Module?
- so, so much for happy ending thread.......
- Need an ECU!!
- Power steering reservoir BOILING!
- abusive relationship with my car
- clutch fluid turned black, hydraulic failure in new system
- These Are OE Wheels, Right?
- Leaking fuel.
- South Africa Maxima 2L V6
- Climate Control Mystery
- OEM Nissan Textar Track Brake pads
- Chugging like a choo choo
- The old "crank no start"
- where to find hanshin/ mitsbishi coils?
- 99 Maxima alternator help
- Service Engine Soon Light -Ughhh
- Driver side rack pinion OEM boot wont fit?
- a happy ending thread.......: )
- Sources for "A/C Kit" w/ condenser
- AC works only on one setting
- Hood release not working
- Hesitating acceleration when cold
- Feels like my 97' has oval rear tires?
- Grinding between 2nd and 3rd
- Exhaust System -- 1999 SE -
- JDM a32 (cefiro) wiring diagram - heater a/c control panel
- would you re-surface these rotors?
- how much is ac compressor for a 1999 nissan maxima
- need some help again
- Half way to 400
- Water temp resistance
- HVAC Intake Door Motor
- Starter occasionally drops RPMs then it recovers
- Ignition lock cylinder extraction
- Difference between 2.9 4 and 3.5 6
- Bad power steering fluid leak....
- STRUT/SHOCK Alternative
- Rough Cold Starts Now No Start or Stall
- P1335 question
- engine 'kicks' at idle - rpms drop suddently and recover
- WTH?? Ambient/ In-Car temp sensors!
