- Tail lights
- Hi Flow Cat Question
- PCV Valve?
- help, in garage now, where is my pcv valve located
- got a 97 interior free
- 4th gen headlights?
- jerking/hesitation @ idle
- Took Spoiler Off
- Brake replacement writeup
- Inner Tie Rod Tool
- A little vid from the track
- GReddy SP muffler - anyone with experience with it here?
- weird sound after parking 90 days
- Scored Some Leather Seats For 75 Bux
- car died on red light
- 258k+ Miles And Still Going Strong
- Spark plug cover...
- what is this?
- wow got a 2hr lecture on lowering
- Help, NEED STUDS?
- just for the hell of it.. who can do a photoshop??
- Tool Set
- I finally did something with that dud panel to the right of the steering wheel...
- Tranny? Clutch? Not sure...
- Anyone have a 97-99 SE rim to spare?
- Should I get a ypipe? how loud is it
- When starting car after i reset my ecu, it sputters & starts as if the batt was dead!
- No ECU codes what could be the problem?
- brake upgrade
- 0 - 170km/hr - Gauge video
- stolen rims
- im cleaning my car right NOW, and i have some questions
- Another headlight issue Help
- Suspension changes...
- Ok, so wtf is with my car
- Got alignment, now theres a hum when I turn left
- 99 Motor W/44,ooo Mi On E-bay For $100
- Window fell of track (or something) and won't roll up, help appreciated.
- Problems with front brakes after changing rotors and pads...Please Help!
- Those with AP racing BBK....
- oil pressure sensor
- Air filter Help...(aftermarket)
- I changed my park plugs (Pictures)
- HID rig
- Guys with Illuminas adjustables...
- Driver side axle problem *HELP/Pictures*
- Best way to remove Spark Plug Tube Seals??!?
- 150k!
- Help...My speedometer and temp gauge are going crazy
- Need help with compressor that I'm about to buy
- Window Tinting Help????
- Auto Trans Solenoid Replacement Success
- 74 light bulb color change in 99 max
- Got 0403, 0304 and 0201 need opinions....
- Looking for 2 small parts -- any help appreciated
- Quaife ATB
- how to replace antenna mast?
- Couple of questions on 5spd trans removal
- 0705 - Where to start looking
- pics of maxes on Tein H-Techs
- 95 headlights will fit in a 99?
- Oem foglights
- Intermittent 0302 code (EGR System Hi/Low Flow)
- black box in rear
- help with 5spd tranny not going in gear
- Rear Brake Caliper Problem, quick answers appreciated.
- need help with coilovers which one is good
- Quick question about O/D and other stuff
- my baby is gone
- MAF Screen
- 97-99 bumper on a 1995
- 120k Service
- FCA bushings..
- cleaning O2 sensor?
- CEL, o2 and more..
- wire gauge?
- Slipping clutch?
- new motor
- What you think
- Philadelphia DynoDay
- Clear corner question...
- do all 4th gen maxima have power seats ?
- omg check this out!...awesome thread...
- cefiro,smoked clears installed
- Reducing exhaust vibration....
- 6 gen seats
- Maxima OWNERS IN STAMFORD OR GREENWHICH CT
- Skyline Maxima (pic)
- Question about 16" SE rims
- Illuminas sold. Tein H-Techs still for sale, though
- wires from engine bay to dash board
- Cattman Catback Installed
- Tranny Sliping!!
- 5 speed out of gear
- has anyone tried any of these ebay axles??
- Max involved in hit 'n run at parking lot
- Can UDP and sound system work together?
- Good spring to use with stock struts
- shaved my emblems. what now
- selling amp and sub..
- alarm is f'd up
- Found white deposits on all my spark plugs... plus, Q about heat ranges
- I think Sprints saved my life today
- Bypassed KS with a resister...how effective
- Wet spark plug....should I worry???
- Any idea what these fuses are for?
- My Max '97 overheats, and I am going crazy
- Tokiko HP's with S-Techs ?
- Maxima just died
- Do I need Spacers for 17" rims ?
- Where to find: cheap ks
- Transmission problems again, but different than before
- Power Steering Belt ?
- :( how to fix a low hangin b pipe
- Last dumb question of the night.
- Installing rear speakers and I'm stuck!! PLS. HELP!!
- Water Pump is In !!
- ES bushings and brackets for adco RSB
- what kind of rotors should i get?
- difference(s) in 95-6 and 97-99 rear bumper
- will a 96 ecm work in a 95 ?
- fuel problems
- Steering wheel swap. 95 & 97
- What do we think?
- Egr
- Place to buy Hole Saw for CAI?
- have little questions
- Turning OD off to downshift?
- Please Help
- Another NooB 5spd question
- Painted eBay bumper?
- 4th gen I30 LSD axles and 5th gen AE LSD axles are the same
- 5speed transmission, in the boot
- Where to buy headlights with cheap shipping
- Air filter and MAF adapter
- Can a leaky rear main seal ruin a brand new clutch?
- Need your opinion on wheels THANKS!
- AutoMagic Hurt
- Cost of 5 speed swap
- This Is Probably The Worse Week For My Max
- using 87 octane...
- dissapearing SES light
- dead springs?
- dreaded code 0400 on a 99, egr flow problem
- Car shakes?
- Horn Not working
- G35 17x7 spacer question...
- maxima car cover
- YEEEAAAH...Starting Problem Fixed
- Totaled My Maxima Today
- My alarm is tripping
- Strut boots
- r/m quiet stop = raybestos quiet stop?
- side mirror LED's (opinion thread)
- Some tell me the difference between knock sensor and coil packs..
- Center console armrest - Help me!!!
- It took me 4 hours to do my brakes. (pics)
- QUICK: driver side CV axle won't come out
- www.ceasarschariot.net - the website is back !
- How to adjust konis (rear)
- Poopty Poop Poop ... POOP
- What's your car's name?
- an embaressment to the maxima community
- Axis Hagens 19 x 8 a good deal and a good fit?
- nooB 5spd question
- What led you to buy a max???
- I need help fast
- lowering
- engine tick
- what the hell is wrong with my trunk!!!
- How difficult would it be to swap engines? (4th gen into 4th gen)
- bad shift solenoid need help
- fans keep running
- Cefiro's Installed
- Alternator just took a dump on me, Where can I get an HO?
- please look over my suspension shopping list
- Problems
- Tail Light Replacement
- How much!?
- Monza Cat Back
- Factory Cat Hanger rubber mount bolts
- Knock Sensor CEL and performance
- transmision gasket leak
- What Size Tip !?!?
- 96 Max audio question
- Mod Time again...I'd like some opinions on Coilovers.
- Vi Mpg
- Tail Removal Issues
- White Corner lights
- All Auto Maxes step inside. (vid of accelleration)
- 97-99 Exhaust (Cat-back)
- CV Half Shafts: 5th Gen 5-sp/locking/abs tranny on 4th Gen (non abs)
- how to fix dents?
- Shaved doors
- brake pedal question
- How do I remove the front cup holder for 1997
- KS bolt a bi_tch to loosen
- Cefiro grille
- 97 conversion question
- Rear speakers
- AC/Heater Fan
- Need Help, Car Runs Terrible
- Keep on going and going and going...
- Trunk Release
- clearing out corner lights
- gas/fuel guage acting up in the car
- two things that i have notice
- Bad suspension (big pic)
- Mevi Question
- Car Starting Isssue...Probably, my last complaint onit
- knock sensor dead but no ghost code or obdii problems
- VLSD tranny and 5th gen clutch installed.
- Please recommend me some cross-drilled rotors
- p1493 code .. i read FAQ... have FSM... need adivce now
- So now that the car is found....
- phase 3 fenders
- Links for building up auto tranny
- 97 with 0903
- Recomended Clutch?
- Something doesn't sound right...(transmission maybe?)
- Blinking air bag light
- Coil Blues???
- Maxima Transmission
- how to you check your fuel psi
- City Mileage
- Spark plugs on ebay???
- Coil pack test.
- For Those with 300ZX BBK
- o2 sensor not working at first, but now working?
- cefiros with hids
- question of maxima "life expectancy"
- Fuel Filter Fitment
- code 1441, what is a vacuum cut bypass valve??
- Motor & Transmission Swap
- A/C refill or...?
- Type X spoiler question
- Infiniti J30 Seats
- Code 0503...Ignition coils?
- Finally i can post a Thread i love you MAx.org
- Higher milage 99 SE and mods
- Line Pressure Solenoid Valve (Automatic Transmission)
- ECU reset
- Clutch Question
- $700 for AC compressor pump?
- Camshaft position dying max wont start
- Release Gas Pressure before Changing Fuel Filter??!!
- Testing a torque converter
- not driving my car for 9 months...what do i do?
- Ebay Chip?
- Oil marker blinks on the gauge???!!!
