- Help...damn car again
- swap compatability transmission
- Another 95/96 grill option
- NEED help by 2morrow Shock
- P1706 - After five speed swap.
- 2000 instrument cluster in 99
- anybody got a part number for longer wheel studs?
- Iacv
- 5th gen clutch in 4th gen
- loud noise when turning
- anti rattle tape
- Electrical Issues
- would I need a LSD driver side axle for
- Which lowering springs?
- Replacing valve cover gasket and grommets
- Clear Lights
- Coolant in Oil?
- rear sway bar...
- Odometer Stopped Working
- no electrical power
- Thanks and Farewell
- so the 18" rims will look bad with stock suspension.. :(
- Car Died On the Freeway!! Wont Start! Help Needed!
- AMB button?
- Some mod questions...again :)
- Potential Sunroof Problem
- Replacing Hood Struts
- Did I blow my DEK?
- iac valve
- HID Problems
- Spark plug tube grommets
- Replacing the LCA's
- o2 sensor test
- sittin sideways?
- keep or remove AC?
- baking headlights
- need some major tranny help
- just bought 3.5..........
- Car shakes on R
- will these fit ok on my 98 max w/ stock suspension?
- Front and Rear strut bars....
- Changed clutch, now pedal engages differently
- Fuse out after installing HID
- broken tach
- slotted rotors
- cai question
- Haked vs. Stock Intake 0-60 times
- Help I Broke My Car
- Y-pipe = lower MPG
- replacing synchronizers, how?
- Oil leaks from ball joint pic available help please
- UDP slightly damaged, should I install?
- Pros/Cons of a Stage 3 clutch?
- where to get a rear wheel bearing
- chrome gauge rings...
- Painting Rotors
- Short Shifter Install
- loud BELT
- JWT ECU vs. TS ECU
- Timing Chain Tensioner...
- separating the red from the black
- Public Service Anouncement: Shifting An Automatic
- Bose Head Unit Swap?
- EBAY HEADERS and Y-PIPES
- lowering springs
- Strange Engine noise
- which overwattage bulb should i get??
- Transmission Temperature gauge reading.
- Suspension Making Noise (pics inside)
- uh-oh what does this thing goto. I found it on the ground
- Climate control lights
- length(in time) to take out all necessary parts for 00VI swap
- Ceramic= Best Brake Pad material
- urathane engine mount users - please step in
- 300k max??
- HELP!: I locked up my engine
- How much is one quarter for the fuel tank guage?
- What is your prefered tint on a maxima?
- Anyone purchase Lower Control Arms from Ebay?!
- My 96 SE manual clutch pedal is dead and can’t shift…HELP!
- Quick ECU question..
- engine mounts
- Amd Meet.....@ Varsity
- Weapon R intake...
- HID foglights
- remote ques?
- offically a 5 spd - got a ques for the "converted"
- Question: Steering Wheel Swap
- downstream o2 voltage fault
- Help Please!!!
- Removing snorkel, stuck at removing connectors
- quick question: 97 black se paint code= KH3 CORRECT?!
- will my 06 rims fit on my 95???
- UDP questions
- strut tower bar question
- emergency trunk release in the trunk
- Rattling in secondary radiator fan
- i need a broken ecu !
- Warp. or Bud.
- How to disable daytime running lights?
- Has anyone had this happen to them?
- ??How to fix EGR code??
- What brand oil to use?
- error code 0605-misfire in cyl 4
- whats this rattle
- weird noise
- Breaking loose crank pulley bolt=impossible
- still cant idle right
- 5th gen clutch help.....please?
- Gauge Cluster light question
- Starting and Braking problems
- has anyone gotten this maixma manual from here
- 5spd transmission ?
- Warning from police for clear bumber lights
- LCA's
- Cv Shaft Help!!!
- A/C Tech Question - Refrigerant charge amount??
- Step In
- suspension
- help with egr parts cost
- What should fuel pressure be at idle
- Help Needed...Vehicle Speed Sensor location
- New Wheel Bearings Front How long to I have to replace
- A/C and Auto Climate experts step in
- AUTOMATIC Tranny service and Radiator flush
- Those OF Your With Ps2's or Dvd's Players Step In
- Those that have filled their motor mounts with Poly step in.
- Very hard shift, Somethings it takes a 2nd time to shift
- How to...
- Adjust headlights
- So I have the B&M short shifter........
- vaccum leak
- Stillen sloted rotors w/ mtl matrix pads?
- Manual Tranny fix
- Overheated! Engine Hesistates
- Crazy Lights, Help!!!!!
- y pipe and exhaust
- fixed hesitation and slow acceleration
- Few Engine questions
- Question to all HID guys
- Front Door Weatherstrip
- Fidanza Short Shifter
- Front Suspension Bushing Replacement/Upgrade
- Having 2 problems, I NEED HELP!
- Locked Out of Your Maxima?
- Anyone From the west coast?
- y-pipe gasket question
- Do I keep it???
- How can you tell if you need just the window regulator without the motor?
- greddy evo 2
- Lights on the music system dont work :(
- Ball Joint Boot Replacement
- Keyless Entry install
- HEADLIGHT Problem!!!
- Question if anyone can help..............
- Need a quick answer! What is the tire size for the 16" SE rims?
- *cd Changer Question*
- ECCS Relay
- windows dropping in a 95 max
- 5spd Diff. Bearing Going Out
- Where to buy spark plugs?
- HIN @ Flushing NY
- Lowest spring, CMS or Sprint
- Crankshaft Position Sensor (POS)
- foglights are so dim. make them brighter ?
- Quick Question 03 Auto Dim Rear View Mirror
- New Clutch, help me decide, can't search
- How low can you go, anyway?
- Need some opinions here please......
- 5th gen muffler
- tune up?
- Seatbelt Light not working
- Check Engine Light: On!!!
- Is it really that hard to tint windows?
- Rear Deck Rattle Fix
- Whats the name of that part game..
- inatake or y pipe?
- Unorthodox Flywheel Opinions?
- Trans starting to go?
- Paint on Fiberglass (FRP lip owners help!)
- rear brakes grinding noise
- stock y-pipe replacement
- Finally sold the 271,000 mi 95 Max
- UNGODLY gas mileage!
- 95 nissan maxima se spark plugs?
- 99 cali-spec, front precat replacement. ?
- Need to replace my ECTS on my 95 Maxima... wondering what type/brand or model ECTS
- Question for anyone with an AEM FPR
- Help newbie to choose a torque wrench
- How to make HID kit fit
- Why is my strut almost touching my tire?
- Great!!! Engine Knocking!!!
- Tighter Trunk?
- keyless question
- After market bumper cover in Houston?
- 5-spd transmission compatibility question.
- Max Vibrates/Shakes when braking...
- Struts & lowering Springs... worth it?
- is the rear wheel bearing the same part# as front wheel bearings?
- Will this cluster work in a 96 GLE?
- Chrome Grill
- HELP-- I am getting a code --4th gear ratio incorrect
- Dashboard how to?
- Repalceing tail light outer casing help
- exhaust setup
- 1997 SE maxima for sale need opinions on price
- WhOs Unhappy with their car????
- Is the Idler Pulley supposed to turn?
- window trouble
- Maxima is dead :( HELP!!!
- Wow mpg went DOWN DOWN DOWN.
- A few simple questions
- brake noise,need help please.
- what do u think about this body kit?
- problem using the DIY AC recharge kits
- NJ Maxima Mechanic needed badly
- Misfire question
- Need help finding a carpet kit
- help! clear coat peeling off my wheel
- Another Noise From My Front End
- plz HELP!! pressure plate bolts
- o2 sensor repair
- 1999 Clutch problems - Please Help
- Will new HU blow my speakers?
- Bright foglight bulbs ??
- Ebay confuses me a lot (air intakes/short ram/exhausts.
- Maimxa abs brake question
- 2 inches to much?
- Quick Question about KS Ebay
- rusted radiator support...
- 9004 to H4 conversion?
- Must I do an alignment?
- The other harness on the 5spd
- Spark plug tube seal replacement
- Damages on driver's seat
- 1999 Maxima recal FYI EXTERIOR LIGHTING
- A/C compressor bypass belt
- Engine rebuid kits
- replacing stock speakers...
- Broken wires in engine harness
- Steering Problem
- HeLP ON Parts
- fuel filter clamp
- The streets killing my suspension...
- starter problem??
- Need inspection sticker
- ne1 in jersey have TIMING GEAR
- uhh WTF just happened? pulley flew off *pics*
- when does the computer listen to the rear o2 sensor?
- need fast help
