- Injector problems
- bad luck and maximas! :(
- which gas is better?
- transporting maxima seats in a maxima
- HP gains
- Weird Noise when turning left
- Failed Emissions Testing - High NOx
- trick to passenger axle seal?
- Drivers Side Axle Seal Replacement
- My radiator is leaking coolant
- What the heck is this sound? How do i fix it? (Video Inside)
- bluebatmobile amber foglight overlays
- Mellings Eliminators....?
- gas leak/smell problem
- brake light and battery light on at same time.
- Black tails/turn signals on white paint?
- Belt Tensioner Question...anybody
- Attemping to Clear out my tail lights, any precautions you'd like to give me?
- Projector Lights
- Revised 4th Gen Chain Tensioners From Nissan
- Glass Pack mufflers?
- CAI = stalling
- Service Engine bulb replacement
- HELP: Sunroof Repair
- Maf sensor? replacement
- Shift Knob Re-Thread
- 1998 SE purchase. Anything to watch for?
- Hardwiring using the cig lighter.
- key transponder, where to drill for key ring
- 0603...Misfire
- poor fuel economy
- 2009 Maxima Calendar Almost Done!
- Finally some pics of my failed strut mount
- CV popped out during strut install
- Failed Water Pump Diagnosis Assistance Please...
- Water Pump... How's This One Look?
- Which Chain Tensioner Gets Replaced With Water Pump?
- exhaust manifold
- Tail light fuse blowing, brakes cause interior lights to illuminate.
- what version Maxima do I have?
- 95 max back fires
- Ahh help?? Intake gone crazy?
- which coil?
- Fog Lamps on my GXE
- where can i buy coils
- Looking for pics of fuse boxes, all years.
- VLSD swap
- maximas at halloween
- Idle issue
- OBX headers
- Can a bad/clogged EGR cause stalling?
- How do I tell what struts/springs I have?
- Interior Whine when Accelerating
- HELP!! No Heat Only cold Air
- ok.. remember me asking you guys about my intake?
- foglights no work...stuck...
- simply brakes question
- Rear suspension bushings
- replacing head/taillights?
- Shot clutch master cyl?
- $$ offered for help with tokico kit hpk245 suspension
- Trans Noise... Input SHaft bearing?>? Sell CAR??/
- sensor problems for 95 max
- need help with awful squeal when turning
- Turbo vs Supercharger
- Question about O2 Simulator.
- New Transmission? Or fix bearing?
- new exhaust??
- Windshield washer nozzels
- Shaking Problem
- Replacing hood
- DYNOMAT the rear
- Timing Chain Tensioner Gasket
- Location of stop screw on throttle body?
- Best(soft) spring for Maximus on 20" rims
- HELP ASAP
- Maxima in HIN commercial
- Please Help. Car feels studders when driving.
- Just installed a Y-Pipe
- homelink visor in 96
- Bad Day in the 4th...
- SHOULD I
- bolt/nut sizes for exhaust
- yellow fog light question??
- Semi-urgent: o2 sensor bung thread size?
- Stitches from trunk lid?
- WHat is reasonable for these repairs?
- Budget or Warpspeed which is better?
- Stock Intake ducting loose/not sealed, common? Any good fixes?
- Help with manual trans fluid change...
- Matching fender
- P0171...nothing seems to fix it for me.
- '99 with '03 SE Rims - Pics.
- Headlight output...
- Evap Code P1447
- Tinting taillights on 97 kwestion
- Problem while changing spark plugs
- MAF Sensor
- what do you think of my orange corners??
- Maxima might be F/S
- I Thought OBD II Readers Turn Off Air Bag Light
- Rear right window rolls up, but only slides down
- Bose Cassette Player
- Ever wondered how to make your own LED side mirror turn signal?
- Grinding Noise from Rear Brakes
- Back.. but with a question about dash
- Intake Question
- 95 ECU in a 96 questions?
- Does running your A/C really use that much more gas?
- Carbon Fiber hood?
- 4th Gen Maxima reliability - better info
- Where is the Drop resistor?
- Battery Help
- Passenger side tie rod?
- knock sensor related question and tip
- car shakes a bit...
- JUST LOCKED MYSELF OUT OF MY CAR!!
- Bad Rear O2 effect on gas millage
- Getting Power to New Leather Seats
- RPM fluxuation at startup
- belt squeaks when wet
- swap ecu?
- 03 hid kit in 97
- OK to put jackstands under front hooks?
- ECU Question
- interior lighting - big pics
- Opinions on home depot lip.
- car struggling to start..
- Won't Start
- Possible clutch fluid leak?
- Cattman Newsletter/Sticker Sign-up (G4)
- Slave/Master Cylinder Issue
- Rear Timing Chain Cover Leaking
- Mix/Match Struts?
- how do i clean passenger air bag cover?
- MOOG Front Strut Mount
- Wheel bearing or maybe Axle?
- could someone post pics of carbon efx hood fitment and what the edges look like
- Ice scrapers & snow brooms
- 1998 Condenser with manufacture date 2/2008
- Power Steering Pump Leaking
- airbag installation in north jersey?
- inner tie rod symptoms?
- Front turn signals don't work
- power steeng pulley tensioner..problem...
- Exhaust Questions
- Wheel bearing replacement
- My 4th gen hesitates to rip it. why? (automatic)
- Hard Shifting gears???
- Why is my friends engine so much louder and deeper than mine? We have the same intake
- Trunk wont open!! help!!
- For those who have replaced steering wheel!!
- autopartswarehouse...
- How to press in the ball joints on the LCA and the tie rod ends..
- Hood Hunting, Need some help
- help: Coolant leak (pic's inside), cant pinpoint..
- Tensioner part #
- Spark plugs and O2 sensor Questions?
- Y-pipe crush gaskets
- Weird A/C problem
- Looking to change my Spark Plugs
- 80MPH at 3400 RPMs?
- manual cc pinout
- has any one had this problem?!
- short throw shifter suggestions
- Remember that Sterling mist 1999 SE-L 62k miles i was talking about...?
- Factory Bose System + CD Changer?
- "Tune-Up in-a-can"
- VQpower.com - NWP VQ30DE Spacer Kit Review
- Opinions of stuff i want to buy
- Convertible Maxima??
- relay ?
- maxima key fob?
- License Plate LED Lights
- window regulator or motor?
- agua pump help
- Rear hub nut not very tight
- New axles
- vht nite shades issue
- car starting problem
- Loud noise from 96' engine
- p0443
- Filling Manual Tranny
- Replacement Key from Dealer
- Wheel bearing issues
- Intermittent Alternator problem -- Need HELP
- Driver side axle WTF!
- RPM low? Iddle air?
- Standard LED's Auto AC/Heater control
- What should I do!
- Weird feel in the steering rack
- Need help on an something
- ever lift the car to fix axle problems??
- New car...Problems. Solutions??
- 10 or 11 tooth starter for '99 Maxima?
- Clutch interlock override?
- Thoughts on catback..
- ECU Question
- Something's rubbing
- 95 cali evap purge control system
- Climate Control makes my head hurt
- Swaping Trannies
- drivabilty problem
- Cam upgrades for a VQ30DE
- p0400 & p0325 came back to haunt me! help!
- What twin color paintjob would look the best black +
- Brakes Question
- Cylinder 5 injector replaced
- failed to negotiate a turn *PICS*
- Weird sound..
- break question
- Wanted to share my plates
- If someone wants to cut you off, let them...
- D2 RS Series Coilovers - Groupbuy deal - Free Shipping
- Another Retro :D
- 1998 Maxima Horrible Pickup Low speed
- Hazard Lights Problem.
- factory alarm?
- Towing Question
- Forgive the newb posting but....
- p1105 headache, did a search already need help
- Mobil 1 Deal....Advance Auto thru Oct 08
- No such thing as a BCM on a maxima??
- Engine cranks but won't start until the 4th or 5th try
- Suspension setup for mild drop
- Chirping tires in 2nd gear
- Room Light/Interior Lighting Issues
- Wires from under the hood to inside the car
- Good alternator car dies
- Exhaust Too Loud (silencers???)
- 230 miles to a FULL TANK? normal?
- Power steering bypass
- Bore Out The USIM?
- heated seats question
- Picture of Harlan RPM switch circuit
- Help with PAINTING rims, please?!
- Hard starts after car is warm
- ELM 327 compatible with free OBD tools?
- high pitch whistle/whine from engine
- is there a way to quiet down my car???
- ebay y pipe/head
- Hid Q
- Brakes question price/quality/performance
- Clutch Fluid Reservoir Dry!
- simple belt question......
- anyone seen these "Pulstar" plugs?
- Car sputtering at idel in Drive..not in neutral though???
- Steering Wheel Lock/Key Broken in Ignition
- Fire! in a crowded... alternator?
- 2nd Time Getting Stuck
