- rewire corner lights
- Going to Manual
- Help!, ECU threw code 05 10, have emissions test tomorrow - what does it mean
- red and white taillights
- Water Leak in Passenger Cabin
- JWT ecu ?'s
- Frankencar intake noise....
- Polyurethane Bushings?
- NEW PICS OF MY 20s........
- A god what is it NOW!
- alternator augh!!!!
- Targa Top
- Questions on doing a 5 speed conversion?
- How Much Should a Fuel Pump Cost?
- What the hell?
- suspension sounds?
- whats this thing called
- Which coil does not belong? Help needed ASAP
- cruise control won't work above 90?
- Brake Vibration
- Custom hood??
- ordered my jwt ecu
- Post pics of gauges mounted inside car...
- Newbie question...
- 140,000 Mile Report
- Speed Sensor wire on ECU
- CAI owners -- ambient air temp sensor?
- custom adaptors
- a piece of the exhaust Pipe tray thing-a-ma-bob came off. Problem?
- Starter
- Sprint springs...cut rear coil???
- El Cheapo cone intake
- Knock Sensors $135.00 Shipped US
- Fog Light Looks Funny
- Occasional problem when starting the car
- What type of paint do you use to paint calipers?
- Intake Air Temp Sensor?????
- Autocross class for Maxima
- Dupli-Color
- Stupid auto tranny always in 3rd gear!!!!
- hood problems
- 5spd Conversion Done!!!!
- Switching stock A/C to R134
- Help! Need some legal advice...(insurance)
- Chatter in 2nd gear
- Glove Box Lamp has no current
- Need some electrical help
- Few Questions For Those With Custom Cat-Back or 5th Gen Muffler
- De-carbing and 80k mile service
- Cupholder Retaining Clip
- Rear Main Seal leak
- 60,000 Mile (120,000) Question
- Diameter of Stillen Exhaust
- Can I convert to 97-99 max
- tires
- Security Light Help!!!!!!
- Yellow fog breakthrough?
- How to clean the Idle Air Control Valve
- My Miror Wont Work. WHy
- 02 senor Questions
- Throttle Body Cleaning
- KYB AGX settings... more conclusions
- Mass air flow sensor
- How to Clean IAC Valve ??????????????
- Changing from Sprint Spring to Eibach .....I am so happy
- CLUTCH again :(
- Car care and maintenance Qs
- can i buy a universal muffler??
- foglight rewire
- replacing suspension
- Anybody have pics of a 2k muffler on 4gen??
- Hi-flow cat
- Does driving on a bend rin hurt your car?
- Bodydropped??
- did i get ripped off
- K&N or JWT
- Door panels!!!
- Hello!!!!!! & Help!!!!!!!
- Can someone help me find KYBs?
- Aftermarket spoiler installation
- which lights for brighter lights
- Just Installed AGX's, MaxSpeed, Poly Bushings, etc...
- I got hit on Memorial Day
- Timing advance at Dealer
- routine major service.. fact/fiction
- for those with '97-99 red/clears...
- removing spoiler LED to replace bulb
- Car Bra - Will '97 fit '96?
- Dash kit removal
- reverse lights....
- get E-brake cover OFF!
- Which front and rear bumper style do you perfer, 95-96 or 97-99?
- Pics
- am i crazy, thinking of sellin my max
- Right now, I do NOT like the remote window roll down feature
- which 4th gen?
- hybrid or cai?
- Better highway gas mileage?
- Stock struts w/b&g springs?
- how much money is my maxima worth?
- People with obx-cat back i need your opinion..
- Need advice on relocating battery to trunk.
- Get the KYB AGX shocks/struts!
- rough ride when braking and turing left on highway. why?
- 95 Water leaking onto drivers seat
- Replacing Window Switches
- 4th gen & 5th gen stock performance times/specs?
- Injen Intake illegal?????
- Please Help
- need help
- FrankenCar Midpipe
- Question to clean IAC Valve !!!!!!!!!!!!!!!
- Removing and ReFabricating Side Panels???
- Intake Opinions REALLY NEEDED
- Foglight/Lamp Assembly
- arew there any wider fenders available?
- ECU swap question
- so I need new motor mounts...couple of Qs
- Need touch up paint for a '97
- Intakes
- Towing capacity
- Replacing light on seat heater switch?
- Poly-urathane bushings
- Clicking sound in tire?
- Help Identify these wires
- Interior coloring
- Removing old caliper paint?
- Can somebody post a pic of the OEM tweeter?
- Kncok sensor diagnosis
- Code 1446 -- EVAP Valve Not Closing
- anyone with pacesetter shifter. griding???
- Reset Engine Light ?? -- I need the procedure
- heavilly modded 4thgen on ebay
- Help! My blinkers dont work!
- "Breaking In" the Knock Sensor
- Service Engine Soon Light (O2 Sensor)
- Need Expert help on Wheels...
- where to get a e-brake hand/boot?
- Help with CEL ECU issues
- how to install short shifter?
- Euro Tail Fog Idea...Write-up included
- Adding a ground to MAF = no funky idle problems
- dunlop sport a2
- Fact? Bright Corners method for '97-98
- intake air temp sensor location?
- Rims are on - What do you think!?!
- nology wires????
- Part # for gates belts
- Rotor maintenence question
- Looking for Brake Pads
- Stillen Body Kit?
- OBX Coil Overs
- 5th Gen Tein Springs on a 4th Gen?
- Question for you NA guys with EGT gauges
- Rear Brake Pad Deals?
- Southwest Autoworks now carries 4th gen CF hoods!
- rpms will not go down
- Engine Mods
- Anyone have a pic of a sterling mist with EVO 5's?
- Question about keeping it NA
- Oil Pan Drain Plug
- Why can't I just get a K&N and slap it on?
- skyline headlights 95-99 maxima
- How much HP loss with bad spark plugs?
- Check it out.. New toys!
- anyone have a full catback from warpspeed?
- Q? about doing tranny flush, switching from regular to a syntectic
- fuel pressure relief
- Budget y pipe vs. warpspeed y
- 4th gen on 5th gen se rims...
- ECU Code.. Dont know what it means
- Help! My engine is acting up...
- Raybestos QS Pads
- Auto-Dimming Mirror with Compass installed(pics)
- Question about GLE's
- Tan cloth interior variations between SE, GXE, & GLE?
- Which aluminum dash kit is this?
- DIY Tranny Flush --What's Needed?
- How do you remove stock tip of exhaust
- TPS Question
- how much difference does fixing a bad Knock sensor make? This much.
- Maxima Interior carpet
- PLZZZZZZZZZ do me this favor!
- Trying to fit FTSB!!!!!!!!HELP!!!!!!!!!!!!!!!!!!!
- Help with cooling fans
- ****ed off!
- looking to buy 4th gen
- What Mod for installing Yellow top?
- need to know what size lugs
- Whats up with the Redline transmission fluid
- VENOM Fuel Injector. Sould I get them?
- Noisy Timing chain during start up
- How do I turn 'AIR BAG' flashing light off?
- How do I know if my ECU is shot?
- Looking 4 Transmission Shop
- VI Issues: GM Solenoid Owners
- where to buy YELLOW silicone intake couplers??
- Some pictures of my car
- Budget Y Installed Help!!
- help! differences between Sprints and GC
- Honda 240 hp WHAT???
- how to get door panel off??!
- Misfire Problem (Again)
- blue smoke
- Stock fuel filter vs. 300ZX
- AFC install
- Emergency Brake
- Paint it or not?
- Finally, Pics of my ride...
- Swirl value
- Has anyone put FOGS on a 95GXE?? (cut the molding, etc.)
- base idle @ 420!
- Fog Lights
- they tried steeling my max last night--What options do i have to remove my trunk lock
- ECU location and Wire's diagram
- Lost to GS-R ???
- 98 SE Wheel Polish
- Shift boot & knob
- New Car ...New Pics
- VB mode?
- trendz vallance install
- Coil packs and manufacturers??
- Automatic Transmission Control Unit Signal to ECU
- Finally put up my pics!
- LSD on a Maxima auto?
- OBX Coil Overs
- Transmission question
- Midpipe Reducer
- engine light
- pcv valve
- exhaust help
- How Do I Get Behind The Guages??
- Help, does anyone know where i can find these gas caps...
- HID question
- driver's mirror
- creaking noise from rear strut towers....
- Chances of ebay STS snapping off?
- help, my engine is knocking
- R32 Projector Conversion
- light bulbs..whitest??
- New Warpspeed Cat?
- Rough Riding Suspension, Need Help
- LED BRake lights on Rear SpOiLer
- How much did your gas mileage go up 02
- hyperactive tape deck
- Anyone have these rims? Hyper Chrome?
- decided to take her out for a spin (vid)
- starter?
- whistling noise by intake
