- ECU is fuxored....
- White Smoke on Start-Up
- RPM signal in coil pack.. which color wire is it??
- Axle Seals WTF!!!!!! rant/questions
- Help car won't start!!
- NEW trunk bracket doesnt fit
- Questions on Greddy SP2 Install
- weird noise when parking
- are headers worth it for our car?
- Engine Removal Advice Needed
- Who know how to program the factory remote?
- Yay, car accident -_-
- ****Really Need Some Input....!!!! ASAP!!!
- Axle problems..
- Maxima owners with Auto Tranny who have replaced their CV axles please step in
- need to replace a/c compressor
- "new" style cefiro
- Can anyone identify this max?
- coolant leak and car almost overheats
- Rear spring seat fitment (pictures)
- 95 Maf+AC+Alternator? Problems.
- 5th Gen Muffler vs. Dynomax Super Turbo Muffler
- What is it with warm weather and our cars?
- A new exhaust questoin...
- D/S noiseeeee
- Injector flush, does it work?
- Help! 97 Max won't start!
- A few new pictures of some mods
- Fair trade??
- Help Speedo Doesnt Work!
- y pipe differences
- URGENT: brake piston won't turn
- Strange Whining Noise From Left Front Wheel Area At Low Speed
- What is average radiator life?
- Clutch Line Talk
- Shifting gear lever problem
- Need Help Asap....
- Y-Pipe rattle?
- Headlight bulbs
- Removing a dash kit
- best aftermarket oxygen sensors?
- Warpspeed Complete 2-1/2" system?? Q' muffler??
- ebay ignition key???
- Decision time. Nex SS coilovers or Progress/AGX
- gauge install
- Suspension overhaul!
- where can i get...
- how far to push piston when replacing brake pads
- Stock Alarm Remote Battery Died
- Brake problems
- later guys!
- The Max is having a hard time starting
- Bearings for the rear
- Magnetic drain plug for 5spd?
- Driver side window rolls faster now
- air vent removal
- eibach pro-kit drop lower back then front!?
- Shift Light Help!
- Auto O/D Switch Is Shorting
- alternator amperage?
- HELP: What's best route for CD changer cable???
- Optima Yellow Top Battery Simple Question
- Spark plug problem
- i did it!!...after hundred put into car (pics)
- I think I broke my ecm screw
- somthing is wrong here
- Lamp Guards???
- Anyone who has sold their 4th gen
- Caliper question
- Undefined ECU Code
- hacked airbox
- Spark plugs: are Champion copper OK
- Window motor seems weak, whats wrong, and where to buy replacement?
- Wiring problem?
- Help: Need to know which wire
- Attention anyone with a starter replacd in the past 3-5 years
- part out
- How you know if you catalytic converter is bad?
- HELP: I need part# for a 1995 nissan CD changer
- Mevi Kit
- Sluggish Pickup.
- Belts Question on tenstion Bolt 1999
- p1320 help!
- Brake Issue Help
- Intermittent, even random Battery+Brake lights. I'm stumped! Help!
- Help question on changing belts Tension bolt
- talking smack while getting a wheel alignment
- Nissan Maxima Chrome 1pc Headlights
- How much R134a ??
- A/C wate in the car
- A/C Problem....Different Grades of Freon ??
- Misfire problem
- Programming Multiple remotes, can't find it in the stickies
- Removing And Cleaning The Iacv Help!!
- Need Suggestions for Sealent
- Crankshaft Pulley Squeaking/Oscillating
- upgrading my fog bulbs,what are my options?
- My car eats starters like I like ramen
- Cps and ignition problem
- Sunroof rust (4th gen)
- need new clutch..
- Best projectors
- Cefiro headlight rubber cap problem
- Illuminas or AGXs (for Progress springs)?
- 60K schedule maintenance.Fuel Filter changing..
- Shipping a Hood
- removing tint help
- Battery and brake light on.
- 4th gen with nismo a34 19" wheels ?
- WOT the hell does this switch do and whats that for?
- I just want to DRIVE it again....
- dealership confused me
- Quick Q
- Horn issue.. please help
- Starter Question
- changing blinkers/clear corners
- Rear Strut Blown...
- cattman full exhaust system?
- Rims size for a non lowered max
- Programming Remote Entry
- Do you have an erratic tachometer?
- Car bra on a max
- leaking oil?
- Auto Climate Control Question!!! Will a 98-99 fit a 95-97
- EMERGENCY: serpentine belt
- 02 sensor quick question
- Speedo stops working or stays at random numbers
- Changing belts 1999 Maxima TENSION
- 5th gen front seats in a 4th gen?
- p0400 : Do I must remove EGR tube from bottom?
- Trunk lid doesnt fit anymore!
- Broken oil pressure switch
- Safc-ii Knock Sensor Readings...help
- help got the C.E.L after putting in a cone filter
- Doors relock when opened with keyless entry...anyone else have this issue
- Exhaust is getting loud (rusting through)...what to do?
- for those with s techs...
- Help with codes
- Who tracks their Max?
- A couple of things that need to get done...
- Replaced knock sensor (code: P0325), vehicle still stalls
- How long fuel line stays pressurized?
- Post your grille!
- Suspension questions.
- Burning Smell From Rear Wheels
- Help: Car Wont Start (dek Swap)
- Anyone have MAF problems?
- which hi flow cat should i get?
- Front license plate frame bolt size?
- DIY: 4th Gen Vehicle Speed Sensor
- pics of flywheel?
- Really quick question
- Need info on RAXELS
- Anyone have Carfax ??
- What do you think about Arelli Assanatins?
- ok i searched and searched, and flied through the stickies...
- Auto Tranny Story
- pile o parts........
- Acceleration issue
- whats the problem?? hard to explain..
- Help, Fan works off and on.
- tokiko illumina question
- problems removing old front brake rotors
- carbon fiber hood recomendations?
- Oil leak?...?
- Master/Slave Clutch Clyinder
- why won't they turn offff????
- Sputtering cold start
- did I lock it wrong?
- sarona grill ?
- Service engine soon light now on
- Help!!!! Electrical Problem Maybe?
- Springs/Struts Vs. Cattman Suspension Package
- Fuel question
- What is with those little thumb screw cap things
- Lose the sunroof wind deflector?
- 1997 Maxima in Nissan Sport Mag...
- 0302 how to fix?
- Warpspeed Y pipe?
- New problem from changing axles
- Is it time to rebuild already, 95k
- need to know asap difference between ecu
- city lights in headlights
- Is it possible to swap the front seats?
- need help with code 1336
- 3rd starter in 3 months, please help!!
- Rusting Frame! Noooo!
- Groan when AC starts
- Master Cylinder?
- Late gear shifting problem - 95 GLE
- Help with bolt size
- For those with Tein S-Techs and Tokico Illuminas
- ECU Will Not Fully Reset...I want my timing back!!!
- Another idle issue...
- Tokico blues?
- y pipe installation
- 97 se hard to start
- How to remove center console (wood trim)
- Need Help With Clutch
- 5spd Q....
- Ugh - I think my A/C died yesterday.
- quick question...tan tripple gauge pod? or paint for it?
- how do u know if u need new control arms??
- For those who have done the TC tensioner
- whoosh whoosh is it still my cv shaft??
- What happens when upgrading tires & rims?
- Air suspension on a 4th gen
- New Bluebatmobile overlays for 4th gens *pics*
- wierd burning smell
- What drives you to keep your car?
- Climate Fan Problem
- steering problem
- REMOVING JET Chip
- Rear suspension sag more with system?
- Performance upgrade help!
- Gas Gauge problem
- Sell my car or get this done?
- Ses 1008
- hood wont close
- 0905 Crankshaft position sensor(position)
- Tokico Suspension Replacement
- Check engine light Emission
- Remanufactured Injector. Garbage.
- Passenger Side View Mirror Smashed...Help?
- Headlight Removal Q
- Wiring experts step in: Wiring harness Differences between A/T vs. M/T ?
- Tranny leaking....
- :sad sad panda: saw my ol' 99 today...
- what kind of suspension 4th gens have?
- I got a complete black leather interior for $300- good deal?
- Car cuts out while driving HELP!
- TSX Retrofit finished
- 15 inch SE rim
- No Clutch Pressure??? HELP
- interior LED lifespans
- F d exhaust
- Gas saving mods.
- Budget Y-Pipe
- greddy sp2 knock offs........
- factory alarm
- Starting My Car Problem!!!! Help!!!
- Desperatly need fast 5spd tranny HELP!!!
- Which fuel system cleaner is good for our Max?
- All 4th gens with 20's step in...plz!
- 5-speed hydraulic pump problems...
- voltage issues? alternator possibly??
- speedometer not kicking in.
- 0606 diagnostic code
- Bose speaker sizes?
- slipping clutch
