- Car stalls for 3-5 seconds when I punch the gas
- My A/C only works on high speed (4)- HELP!!
- Are 95/96 center consoles the exact same size as 97-99?
- Recalls
- Has anybody used this? (ebay item)
- Paint scratched and keyed
- stand alone ecu??
- Ok wiper stalks been replaced, int wipers still don't work!
- changing lights on auto climate control
- While driving my car shuts off??
- Pics requsts: Black on black on black...
- Problem Under Wide Open Throttle
- VERY uneven wearing brake pads
- Annoying Noise
- ok BIG problem need help pleez!!!!!!!
- changed o2 sensor but now cel appears....
- any problem using different brand struts for a while??
- How to replace washer pump?
- Oil pressure light blinked on for a sec.
- 99 GLE good and bad?
- One headlight brighter than other
- Thanx to the Gurus
- Best Inexpensive
- no starting when warm
- just checked CODES....BAD KNOCK SENSOR!!
- good deal for 4th generation fans
- how hard/long to change out KNOCK SENSOR?
- My car wiggles around constantly
- Any maxima clubs in central/west florida?
- Question about price of leather...
- Hmmm.. Interesting..
- fog light ?
- HELP, big Bounce problem.. HELP
- Airbag light
- A/C compressor clutch help
- Remote start trouble
- tranny problem ..locking into 3rd gear
- how do I know if the fidanza will fit my 95'???
- Time to convert..
- pathfinder tb
- good/bad gas mileage?
- I did not get cut up while changing the knock sensor
- 96 MaximaSE needs new clutch!...Which clutch should I get?
- brighter bulbs/LEDs for gauge cluster?
- Tranny Experts
- Sticky Throttle
- Antennax.com antenna legit??
- Ghost code?
- Projector Lights for Older Maximas
- Question on Generation 2 Altezzas
- 9004 Xenones REAL NOT BS LIGHT BULBS
- axle replacement
- D2 coilovers - dampening
- is replacing ignition coils considered maintenence???
- Noisy engine
- Map console light bulb, where to get?
- Gauging interest in Vinyl Stickers ETC.
- Phantom Grip LSD review
- Pathfinder TB
- Engine knocks but everythings is okay
- A/C help... kinda long
- Sounds from front end at higher speeds - please help!
- cattman cat back exhaust
- Temperature control plastic cover replacement
- 99 ecu no screw!!!!
- Windows On My Max..
- 98 california emmissions car modifications
- changing thermostat any advice??
- Greddy/Warpspeed
- 1995 Maxima... which color?
- Levoc shift knob question
- paradox systems now have a forum!
- shouldnt my auto be able to spin?
- tachometer broke
- New style cleared tails on ebay? 97-99
- Unfortunate news...
- ? unhooking the wire to the coil packs?
- WEIRD please read??
- Do you have glow guages, i need help
- is my y-pipe bad?
- MANUAL tranny drain bolt!!!!!!!!
- stalls when cold
- quiet aftermarket exhaust?
- im confused about my trim level
- 35% tint with a 20% tint backwindow??
- Corrosion in #3 spark plug hole, whats up?
- oem knock sensor -vs- bosch knock sensor
- best online site to buy OEM bolts and screws for maximas?
- O2 Sensor Failure, Again...
- How much to expect for a used stillen lip?
- Now what?
- where to buy engine
- jerky shifting & squealy belt
- Ticking sound in my `98
- polishing Intake Manifold?
- differential carrier bearing
- Road Noise
- warpspeed vs cattman?
- A4 headlight Bmw headlight
- Maxima Cold Start Problems... ECM? ECU? Replacement!!!
- Downstream O2 Sensor
- Oil Light Is On!!!!!!!!!
- How do you tell when springs are worn out?
- Bi-xenon retrofitters step in....
- My blinkers don't work anymore when use the lock button on my remote. Why????
- 300zx TT injectors???
- Finally pics of the MAX on the org Let me know what you think
- Heater dosent work!
- Adding power seats
- New Intake Air Temperature Sensor - any pointers?
- Low Power Under 3000 RPM
- Need Help and I need it quick PLEASE!!!
- ***custom made body kits***
- Need pics of Cefiero Headlights (STEALTH)
- part two
- she is sitting low and happy again - PICS...
- small "Knocking" sound during idle
- warpspeed lined flex section replacement?
- Rear bumper removal
- Axle Replacement
- Bumper Lenses Bulbs
- 95 stock grille removal
- 0504 code 2 weeks after tranny cooler install
- Read FAQS, but...
- new diamond cut corners for 4th gen?
- Pulled Ecu Codes Got Q's
- Bees In aA Can Noise
- Does VB mod have any potential neg. effects?
- Fitting Head Unit
- 1997 GLE Question
- what shuold the spark plug gap be?
- Ding King Works?
- Y Pipe Install....HELP!
- Attention: TEIN S-Tech @ Eibach Spring
- 60K Service
- Spoiler lights are out!
- Knock sensor and O2 sensor
- Should have a 4th gen in my driveway tomorrow
- CustomMaxima Headers, CatBack, CatConverter ?'s
- Has anyone designed a better cupholder?
- 95-99 maximas...which year should someone get?
- Low Idle RPM
- warpspeed discount?
- Upgraded Brakes W/ Minimum Modifications
- EGR/Wiring Problem
- Should I Get New Mounts?!
- EGR Valve
- motivational mounts?
- alternator
- Opinions on 97 Maxima front wheel noise?
- Budget Y-Pipe
- Steering wheel wrap
- B and Y pipe
- 5 Speed Conversion: Complete!
- ...too Fast???
- Replacement pistons for rear calipers?
- foglight bulbs
- Check Engine Light
- Please help me with my window problem. PICS.
- kyb gr-2's ALL STRUTS?
- Alternator Recall not what you think.
- good brake pads for the max?
- front license plate. do the pigs really care?
- Chrome Gauge rings FAQ?
- Rear brakes dragging & sticking to much 98 Max
- iRotors brake rotors, anyone have them? good?
- spring rates
- custom maxima vs B&M>????
- Shift knob won't come off?
- Problems with A/C on 96
- Speedometer Accuracy
- CEL 0705 &0903
- CEL code "rear heated O2 sensor"?
- D2 Racing 36 Way Adjustable Full Coilovers
- Hi there guys, after some months look my HID retros
- Door handle swap/ ECU Codes
- would a breather filter on my engine mess up the pcv valve?
- Question about replacing Engine
- TTW-Trade Manual for Automatic?!?!?!
- did a repaint....
- need help! angel/demon eye installation
- My max reborn (pics included) sorry 56K
- 99 ECU Codes? (different than 95-98?)
- Think I done a wrong'un...
- lighting question 1156 <----> 1157 ??
- altenator story
- Slow to gain speed. What to do?
- 0302 code
- Need pictures of SE-L black leather seats/door panels
- going on 96,000mi...
- Waxed the max (PICS)
- Front suspension Vibrations
- Leak From axle seal
- These headlights are great..
- how can I measure the offset of my wheels?
- Can anyone link me to that comparison of the Nissan VI and VTEC
- Y-Pipe+2.5"+Apex-I=Help
- Tail Light Clear Out
- wheel bearings
- timing chaine sliped
- "Hyper Ground System" is there a diagram to follow or no?
- Can I fix this for $1500?
- Guys with Koni rear struts, step inside
- keyless wont work after stereo install plz help
- Wheel Offsets
- Slick 50 etc.
- tail light fuse keep blowin... WTF!!!
- Q' about leather seats
- McCulloch HID install question ....
- Key with chip
- ? about MPG & Octane Ratings
- Mevi Not Sold Anymore?
- Wheel weight
- rpms dropping...
- help! what else should i check??
- Fuel Injection Service
- regular engine swap need help
- How much are used stock springs worth?
- how to take off gc coilovers
- rev limiter?
- Lugs and Studs
- selling a grill.....
- Where is my engine coolent temp sensor?
- Car Weight?
- Maxima CD Service Manual -- Thoughts?
- Ignition problems, please help
- Help !!! really bad MPG
- hey guys need some quick help
- MEVI install and lost some screws/bolts
- clutch and suspension replacement
- Found these on ebay??
- Can a old or clogged pcv valve cause hesitation??
- can someone take a pic of how the belt gos
- O2 sensor code will not go away
- E-brake light
- '95 vs '98 Max
- 5spd tranny question
- cel 0409
- NEW Cardomain site...
- taking wheels off
- I finally have a cardomain site...take a look
- Idler pully squealing
- Urethane Skyline kit on lowered car
- Maxima axel seals and crappy shop.
- diy clears : success.. except for one thing
- finally some pics of my max (56k suicide)
- My car whines, why?
- Installed Y Pipe now my CEL is on
- Back Seats
- previous owner replaced bumper with one with out fogs
